View Full Version : Forced Induction
- Are there any tried and true turbo setups that make good HP and high reliability?
- 83mm and Head gaskets
- Anybody ever get tuned at Altered Atmosphere ?
- What injectors are 450cc??? from what cars?
- what exactly does a missing link or check valve do?
- v-afc precautions?
- my dsm injectors do not fit!!!!!!
- Pic of my setup
- Idle problems
- I didnt want to rob Bluehadow's post...but...
- No Hondata Blue Box or Chip????
- Is my engine blown???? PLEASE HELP!!!!
- lsvtec burning coolant?
- Triple turbo setup. not on a honda but still interesting
- Turbo kit, question!?
- New personal Best
- Is the Edelbrock fuel rail available for sale yet?
- 255lph in-tank 88-91 ef civic/crx guys, did you have to...
- 75 shot nitrous=75 flywheel hp?
- I need help setting the new greddy TT
- problem after install of tial wg..
- DSM 450 injector users...
- Almost ready pics (a lot) of setup...question about Walbro install! ...
- ... b16a oil pan with b18c1... will it work?...
- anyone know "speeds"...i think i may have got ripped!
- Greddy Profec E?!?!
- Resleeving
- EGT Sensor Service Life
- wastegate question
- tig welders in the bay area
- For those running Methanol. Fuel Line questions
- i need a "missing link" (new one)
- Special holes in your head for turbo?
- g sensor module - hondata
- are the hondasaver FI cams out yet?
- Dumb ass manifold question
- Drag Gen 3 manifold with a T3 60-1????
- 96lb injectors
- Name that axle...
- what else do i need with a fmu set up?
- sleeve
- help with greddy sohc turbo kit
- best turbo for 2000 civic DX?
- Any HT Member a RevHard Dealer
- fittings: NPT, BSP BSPT, 4AN etc etc etc....what do they all mean?!?!?!
- HKS Turbo Timer us spec type 1
- hey guys i talked to somebody in here who made custom exhaust......
- B&M Command Flo FPR with drilled stock FPR
- Clutch Problem: Bad Installation or Bad Clutch???
- Pay your respects for it is gone....
- Big thanks to Ben and Importparts
- Running Compressor on Driver's Side
- ... speed pro
- Help my setup... please.
- will a 90 crx sohc exhaust mani fit my 97 civic ex?
- damn NITTO.......
- fuel problem on turbo b20/vtec
- Tuning B16 Ignition Tables
- My SMC review
- turbo camry!
- question for you ppl w/ 440cc saturated injectors w/ VAFC hack
- what turbo manifold for LS in a crx...
- Fuel System requirements for 550hp??
- DPR Longblock!!
- LINK engine management question
- what's the normal vacuum reading?
- VAFC hack vs AEM EMS at 7 PSI...
- Stainless steal oil feed line how close can it run the manifold.
- please post pics of turbo manifolds
- Hondata Help
- Christmas wish list ?RevHard Mfg Blowout Sale....!! LOOK
- is the egt good for anything?
- Competition Engineering fuel sump...where to get?
- Eagle rods vs. Crower rods
- Fuel Pressure Regulator leak?
- AEM EMS...give me all the info you have...i am thinking about buying one
- DSM turbo/honda oil reutrn set ups ..
- Who's running AEM engine management?
- oil leaking out of turbo exhaust outlet
- Damn it...got some 70's cel's now
- Can a p28 be "chipped" with a stock DOHC program?
- Nitrous Question. Are there 80 shot direct port jets
- What intercooler size is best for EG6 hatch?
- Where can i get an HF mani to t25 adapter plate?
- these the right NGK spark plugs?
- Autometer EGT guage - which one? Pyrometer or Exhaust???
- tunning problems, need help.........
- Greddy Dyno Results???
- Max-Rev Shipping times
- difference using headgasket to lower compression instead of lower compression pistons ?
- integra VS civic coupe
- Walbro 255 high pressure hair dryer
- Where to find a DART block for b18c?
- flat top or domed pistons to make high comp raito
- Anyone know the torque specs for the ARP head studs for an H22?
- JRSC and throttle bodies
- Motec m4 FS
- T25 and 14B users OIL DRAIN INFO
- will it be safe? and fast?
- anyone ever used a sump pump to pump oil?
- max boost with 11:1 compression
- Who was it that was selling the mandrel bent 3 inch exhausts?
- emission issues with hondata??
- Good FMIC for the price?
- Turbo Advice
- Check my fitting... Just makin sure.
- Are DSM 440's overkill for 7lbs boost?
- Too rich, Now too lean, why??
- TONY1 in Turbo MAG.............
- Hondata Tuning in OREGON
- Payn 8-Rib Vortech Drive
- motec standalone
- Common problems with AEM PEMS?
- what is the stock bore of a b16?
- ok, dont flame. Oil pan fitting for oil return line.
- Car running like crap
- im still lost on what copper spray does...some help?
- Basic Knowledge for some....how do I....
- a new project,maybe????
- revhard
- Zex vs. NX
- JRSC GSR needs 2.5" catback. Suggestions?
- differential bearings-lsd
- afc hack problem
- The integra is finally moving along..
- What in the hell is goin on here! manifold bolt backin out...
- LSD...
- Something is wrong with my car...please help!!!
- Anyone need some tial wg we have few left before next year orders
- EGT probe on a sfp manifold
- ... stage 3 vs stage 5 turbin wheels
- OT: Away until jan 2nd..
- Tech Edge Wideband O2 Meter
- Fuel Help?
- how's this setup?
- Hello
- egt probe...noob question
- Raid for Ricers
- Most psi on stock sleeves??
- What is the correct breakin procedure for a rebuilt engine?
- High fuel pressure is not your friend...
- what compression for 10psi
- Weird noise coming from walbro pump or fuel system when getting near low?
- 9psi what timing to run
- hondata s200 q???
- Pics of projects!! small thumbnails
- OT: wiring harness
- milling for compression- looking to gain 1 full point.
- type-r tranny for boost
- OT: Formula 1 engines can sing now
- itr cams gsr head valve clearance question(did search)
- question about HID's
- Question about drag 3 on 98 integ ls??
- is it true?
- please help me out
- Ah no, why! Go turbo?
- Letter from my mechanic to me about Golden Eagle
- T04B S-3 for Type R.
- should I keep my motor?
- Whats the procedure for a dyno run?
- Question of Fluidyne and CF hood.........
- what could be wrong with my car....???
- 3" t-304 mufflers on ebay 4 cheap, opinions?
- upgrade my jrsc pulley???? yeah or neah??
- Both trubo and nitrous
- What turbo for 400 plus whp??????? B16a
- what typr of ignition?
- link to my turbo hatch for sale
- Supra SMIC Size???
- If i get a T3/t4 to my d16y8 , when will spike
- ZFR6F-11 --> ZFR7G-11 (Nitrous & H22 Related)
- Turbo kits for H series motors
- ARP Head stud intall questions?
- Piston and rod upgrades
- NOS Injector adaptor??? Any feedback?!?!?!
- T4 tubo on a singlecam
- what are you d-series guys bored at?
- DC JDM 4-1 vs Kamikaze
- This looks home made (ebay BOV)
- Do you run your coolant lines on your turbo???
- Hondata Question
- Wastegate info. Anyone seen this?
- MotorMatrix Civic w/ H22A@26psi Dyno Sheet !!!
- D16Y5 Turbo? Need help...
- Need To take out the turbo for emissions
- Does anyone have experience with the Mugen program on a turbo honda?
- Manifold and Downpipe?
- Final Drive and Gear ratio
- Need internals for a f22-b1 HELP!
- 83mm v/s 81mm pistons?
- Head recommendations.
- need some help, i need to know if this will work!!!!!!
- oil feed leak
- Holy Crap.....Check this out.....
- Any feedback on the NEW NOS injector adaptor yet???
- recommended sealant
- Zdyne guys- What OS?
- Check this!!!
- what type of nitrous setup should i use on my turbo lude?
- studs question for manifold..
- How long does it take to take a NOS wet kit off a car
- need to sell ASAP.....considering all offers!!!!
- Buy this*
- pinging vs. valves in need of adjustment?
- Please help.......Fuel pressure question
- MarkC
- Apexi SOHC kit on B18B1--> Dyno graph
- Intercooler oil film
- Does turbo limit your rev??
- Greddy PE2
- what size injectors do i need ???
- drag downpipe size???
- Bearings
- Turbo holiday song...MUST READ
- GReddy Internal Wastegate porting OR Welding
- Not leaving the honda world just yet.
- map sensor screws
- Your opinion: best sleeves for 400 hp
- How hard is it to build a block?
- Stock crank
- 83mm vs 84mm
- map sensor problem
- Does anyone know of a nissan site that does not do this?
- ANYBODY interested in a speed based PROFEC B EBC
- turbo is going back on tomorrow
- What is the most WHP ever verified with Hondata??
- Sohc ZC VS Dohc ZC on boost
- Wastgates... Internal or External?
- Question about the large NPR intercooler?
- 70mm Throttle Body's
- Anodizing Intercooler?
- need o-rings?
- ZDYNE, 450's, inline and a tough start-up...
- OT: I need some camber plates for an EG
- Which Would You Choose in this Boost Build-Up?
- hondata?
- What turbo should i go with?
- GOing crazy.. some easy questions.
- which turbo for this honda?
- Cold Air Setup with Turbo
- CRXs with large intercoolers... help me out
- you guys have to see this LOL!!!
- Pix of our ACT 12lb steel flywheel
- what Volvo's came with T3 Turbo's?
- Turbo STuff/Moving OUT SALEE!!! Please help me out!
- What fuel managment system is better overall?
- Lenso VPD 13x7.5 available again. GB on again. by request. Slicks added too.
- Turbo question
- OT:hondata 4b with ECU....
- zex nitrous bottle warmer
