View Full Version : Forced Induction
- need help chosing turbo specs
- anyone running a stock sr20 BOV?
- 400+whp on blox turbo manifold???
- Buying a used built head, what to look for
- inercooler flow?
- Bad Misfire when accelerating hard
- 97 Prelude h22a Turbo Downpipe
- need some help boosting my D16Y8
- need help, aem fpr fitting
- GT water lines tapped of radiator..Too much pressure?
- Valve cover venting ????
- i think my clutch saw its last bit of boost today
- Pulled out old oil fitting, found threads attached to it, what should i do?
- boost gauge?
- methanol injection
- Bigger injectors and FMU?
- KAIZENSPEED Turbo RSX and K20 EK
- Can I jb weld this or will I have to use some jdm epoxy?
- My d-series build.... vitara ls rods crower bushings honda bearings
- 11.9 @ 122mph 225 bfg's 323whp 207wtq, stock gsr, 2300lb 92 cx
- some aem problems
- shaft play
- injector size....
- I'm using an AFX and have written some info on it.
- who can tune fast ems in or around the md area?
- bench testing a tial44mm??
- Best oil to run on turbo hondas
- No vacuum line to wastegate.....
- where to get greddy CARB badges????
- is this a minor or major crack?
- hp #60-1
- Full exhuast or E cut out?? Your thoughts.......
- 2.75 inch turbo inlet? what areyou all using for a filter or coupling?
- zex spark plugs
- Lost motion Assemblies
- what fuel pressure to run?
- upgrade fiel lines on honda crx for turbo
- Why NOT to buy a built used motor...
- A few questions from a n00b
- Walbro 255lph users, I have a Q??
- quietest high flowing muffler for a turbo
- H22 intake manifold on F22
- Need help, installing kit, oil feed problems
- kinda new to turbos please help
- ** HAS ANYBODY USED THIS TOP MOUNT TURBO MANIFOLD FROM TURBO ELEMENTS **
- help!!! anyone know if i can get an upgraded timing belt tensioner???
- Which exhaust to get?
- ebay setup
- Top fuel?
- OIL Drain
- Juss did oil change and no OIL in FILTER? WTF?!
- Boosted b18b1........
- turbo / tranny
- ANYBODY HAVE PICTURES OF REVHARDS TOPMOUNT TURBO MANIFOLD
- stock 97 ls motor....>which turbo&mani
- WHP VS BOOST
- arp headstuds
- Question about high HP (600+ hp) ignition set ups. M&W, MSD, AEM CDI, Coil on Plug set ups.
- central florida nitrous guys
- ARP head stud torque spec+steps
- zex cam 59500 in a d15b?
- rodbearing clearance - ist this ok?
- quick weird turbo question
- Turbo b16
- BEST CA Legal Turbo kit/setup
- turboing a b18c
- Dyno sheets...
- d16a6 with a 14b set-up
- need help with turbo id <<< LOTS OF PICS
- HELP PLEASE.
- Member appreciation thread for Crufork!
- turbo install clearance problems. PLEASE HELP!!
- Head gasket ?
- Is it worth going N/A?
- how long did it take to get you cleeved block back?
- Will this oil drain work?
- HELP! name this turbo!!!
- Distributor King Dizzy's and high whp applications.
- catch can??..wtf!!!
- Remove ball plugs (crank)
- Boost LS Vtec?
- Valve Stem Seals
- problem with turbo B18C1?? HELP!!!
- Diferent Blow off valves
- which Turbo set up do u think is the best in u guys opinon
- Willing to pay a finder fee if someone can find me the bottom most piece in this pic
- Car stalls at lights
- Car won't start after 1" of snow
- exhaust???
- Turbo plugs---NGK BKR-7E---!?!?
- is this worth it?
- Help me pick a turbo for my NEW winter project..
- Very odd question, I know
- need some help with half size PWR radiator install
- T1 FTW! John D Re-Tune. 926WHP!! PUMP GAS!?
- Adjust Fuel Pressure for nitrous?
- does anyone now if these will work together?
- diy warning lights?
- Cleaning oil pan
- cutting hole in frame for intercooler pipe?
- boosting a b18c1.
- my setup 300+whp goal how much boost?
- BOV question.
- input on clutch
- Possible to order a standard 50-60 trim T3/T4 with an internal WG?...
- (walbro 255) fuel pump VS inline pump (areomotive,paxton,etc..)
- Profec B users: one line or two, on the wastegate?
- Which Turbo?
- Did SSAC actually make an original design?
- where can i get an oil t?
- boosted h22 overheating
- Sleeving Question
- intercooler selection??
- poor mans type-r...realistic or not?
- what 3' exhaust do you recomend on 96 hatch
- Question
- just finished first turbo install
- Stolen Eclipse GSX in MD - please keep your eyes peeled...
- Smoke - What's the cause?
- Turbo B16A2 or B18A1?
- boost problems
- problems with boost
- Hi-Temp Turbo Coating *Pics*
- Coed KIlls
- Odd oil/headgasket problem?
- increasing the PSI (F22B1 T3/T04e)
- BOV Leak? Slow Spool, Little Noise... how to check?
- Oil Restrictor Question
- Vaccum assisted Engine Ventilation
- is straightlinespecialties a good company?
- Turbo GSR BLOWING WHITE SMOKE !!!
- ext. wastegate on internal gated turbo question(I searched)
- Anyone know what thread the IHI RHB5 uses on the oil inlet?
- Greddy turbo need oil restrictor??
- A/F ratio kumping from lean to stoich then to rich even at idle
- quick question.. what size Tial wastegate will i need.. 38mm?
- ??????? JDM Intake Manifold? Weird design check it out!
- wastegate is LOUD!!!!
- should the inside of my t3 look like this?
- LS/vtec which crank to choose??? HELP
- t25 off an sr20 vs. t3 .42/.48 off a volvo?
- Coming to the dark side
- AEM EMS HELP! AEM Experts please chime in.
- psi bar?
- Just wondering, if you got this manifold, would you take it back?
- Do you use oem parts or any auto parts brand when rebuilding.
- which piston and rod
- top mount kits
- Ls vtec compression
- Turbo Choices!
- Nippon turbo pistons for b-series are they any good
- Bigger fuel line is it worth it???
- allright this is for all the people in seattle/tacoma area
- Safe amount of boost on auto
- Help with ZC head gasket problem
- help!! need a new turbo kit for a daily driver!!! need some suggestions
- intercooler piping question
- THE IMMCAULATE WAY OF BUILDING A B20?
- Selecting Injector Size.
- Re-balancing a turbo?
- Help me build 350whp B18c motor
- Just quick Intercooler question
- m300 and hondata! open loop? BAH! Help!
- Converting a Zex dry kit to a wet kit....how?
- Stock LS Rods... Has anyone managed to bend/break them?
- How much tuning necessary?
- when should a 57 trim spool on a b16a2?
- WHICH SC61 TURBINE STYLE TO PICK???? HELP
- GETTING STARTED NEED HELP/POINTERS ANYTHING U ALL CAN TELL ME
- Upgrading Motor Mounts after boosting
- what do i need for this turbo to work
- is fuel pressure regulator necessary?
- T04S cover housing w/ neukin A/C manifold
- Apexi Power FC - End user fair/friendly?
- b18B Block build up Questions
- BMW's new 335xi in the hands of Shiv (Vishnu), dyno's, tuning...etc
- power steering fluid boiling
- Turbo transmission Q
- gsr tranny vs b16 tranny
- getting started need help/pointers
- safe to run 1 bar wg spring while only boosting 5-10 psi?
- 5 bolt Garett DP flange question.
- Max power on Eagle Rods.
- i cant feel vtec when boosting
- Turbo D help
- ecu tuning
- Boost controller help
- Turbo parts for sale...b series!
- Mini-ram manifold vs. ramhorn
- Pictures of your GT42r setups
- JRSC owners chime in....B16b?
- ANOTHER 2JZ 240....
- what size down pipe and exhaust?
- which intercooler?
- Down Pipe ????
- Turbo'd B20 w/ E85
- Thinking of getting this, input please
- Build up suggestions
- My million dollar dillema...Turbo B16a2 or JRSC B18C1
- AEM Two Step using a switch
- D series turbo upgrade 300-350whp pump Which turbo from experienced d series guys
- Which Piston Compression HELP
- Forged H-Beam Rods on D16.. need to modify something?
- im getting a tune but do i need a widewand first?
- Boosted ITB's throttle response and turbo spool
- The Official FASTEST LS/Vtec Thread...
- Biggest throttle body?? 75mm??
- Apexi AVC-R starts car fires?
- Special Thanks to...
- anyone ever use this turbo?
- Where is a good place to buy low compression pistons?
- Cheapest Couplers and CLamps?? Need this week/
- AutoLink Motor works Has anyone tuned with them?
- dose any one have a working greddy rs bov or intercoole piping they want to get rid of for a 2000 si
- t3 turbo on t4 manni...specficlly onefab top mount
- GT30 BB on the single Cams whos got one
- Almost No Vaccum
- 14b Turbo for b20vtec?
- d16 setup
- I'm stumped...car won't start. You won't belive what preceded this problem.
- dose any one have a working greddy rs bov or intercoole piping they want to get rid of for a 2000 ci
- best clutch for 400+ whp
- 8atman's EF civic sohc supercharger write-up
- help anyone????
- Oil light came on
- Small Front Mount Intercoolers...
- Sebera Fabrications - s-fab.com
- which ecu to get for boost
- 2.5 downpipe capable of???
- greddy e-manage and boost
- Anyone ever heard of "biagio turbo"
- Wideband/Narrowband with the innovate LC-1?
- gm map sensor hook up
- head gasket or something else???
- turbo preference
- FOr all The People Thinking about making Custom turbo kit:)
- V Band question
- buying a b16b that was once turbod @ 5psi on fmu + upgraded fuel pump =reliable?
- went to the dyno problem though please help
- diff question, though i'd get a response here
- i know, i know, but has anyone used the ssac HUGE TURBO POWER MANIFOLD?
- EGR Valve problems on turbo h22a1
- \\-The Official Boosted del sol Thread-//
- just installed turbo need help
- converting turbo to external wg?
- ALright Boosted Honda guys... now that the season is almost over...........
- wastegate problem
- Car smoking...
- Problems after head swap.......
- i need advice!
