Lsvtec turbo running rich
I bought my car with a ls b18a1 bone stock engine with a turbo, and I blew the engine out redlining so I deciding upon building it I should just upgrade to a vtec b16 which I did.
Upgrades are
Em1 b16 head
Weisco pistons 10:1:0
330cc RC injectors
Brian crower rods
Arp studs
Vtec kit
Cometic MLS gasket
Edlebrock intake manifold
Edlebrock 64mm throttle body
Itr camshaft
Skunk2 cam gears
P30ecu
Turbo is pushing 8lbs
Ngk iridium spark plugs
So upon my build I was able to get it started and when it was turned on it ran pretty rich, I took of one of my spark plugs after running it 20-30 mins and it was black. It would also turn on without my map sensor being connected prior to my computer being chipped. A lot of black smoke came out of my car without the map sensor being connected another thing I notice was when I connect the map sensor it idles rough and sometimes turns off unless hitting the gas, but the smoke goes away I don't know if it is bad or not? Double check that the TPS And MAP were not connected wrong. I'm having trouble diagnosing the problem
Might I just need a tune or bigger injectors? Any input would help a lot.
Upgrades are
Em1 b16 head
330cc RC injectors
Brian crower rods
Arp studs
Vtec kit
Cometic MLS gasket
Itr camshaft
Skunk2 cam gears
P30ecu
Re: Lsvtec turbo running rich
You posted this in the wrong section. This if for build threads not tech advice.
You need to get your car tuned properly. If you have a stock ecu and injectors install them then start it and deal with any cel you get. You can also drive it to a tuner like that as long as you stay completely out of boost. You are gonna need bigger then 330cc injectors if you want much more the 220whp witch I assume you do based on your engine having forged internals.
Yeah I am planning on seeing above those numbers. Thanks for the advice, I'm new to this website so Inwas a bit lost but know I'm getting guided correctly and knowing more about this site. Sorry once again and thanks for the feedback.
Exactly what I was thinking, if your running a stock ECU with aftermarket (bigger) injectors just plugged in you will surely have AFR issues. Get it tuned, and don't kill another engine. Seems like there were more issues with your old engine too, as "redlining" shouldn't kill a proper running engine.
Man U FTW
It was running on a generic basemap, and i tried to explain the benefits of a custom tune, but he kept going back to what his wideband says and that he blows black smoke when he shifts, so he knows the tune is fine. Would not accept that rich doesn't = good or efficient lol. Some people are just funny.
Rich is good though, just not THAT rich, I think 12:1 under WOT is good if you want to run more on the richer side, 13 if not. I'm running about 12.4 WOT right now and I shoot black smoke.
Man U FTW
Rich is SAFE, but good is a matter of opinion. Lean makes more power, but as we all know, too lean and you melt things. There's definitely a balance
Indeed. Plus a basemap is not going to have timing and fueling parameters optimized for YoUR setup, it's just generic. And mid-low 12s @ WOT isn't bad for a street car AFR, that's about what I shoot for. My turbo B runs around 12.3 up top as well. The turbo LS hatch I was speaking of that came in for the clutch was around 10.3 @ WOT.
But from personal experience, I never usually tune above 12.0 for extra safety net. 11.5-11.8 has always produced the best results.
93c1sol
09-08-2005 11:06 AM
