View Full Version : Forced Induction
- my car won't rev over 4 grand!
- 2" Charge pipes for stock d15b & 14b turbo?
- Upgrade valve springs/retainer w/ a turbo cam?? D16
- Technical BOV question
- Info on ATI and Fluidamper crank pulley
- 1.70 Uberdata Lean with basemap in boost range
- Does oil in the exhaust affect A/F readings?
- nice setup or nooo
- strange electrical problem
- B16 Turbo Setup this winter-Got a couple Questions
- BIG Intercooler, BIG Piping, BAD Idea?
- DSM 450's what do i have to do to use them?
- Awesome Turbo Manifold
- any one with info on charging a b16a in a crx- cant make a desicion.
- What size downpipe and exhaust?
- Need Help rebuilding a T3/T04B need gasket diagrams!
- fuel return line
- NEW RUMORS ABOUT 60-1...Tried to post in General Discussion but wouldnt let me
- Turbo compression HELP
- South dakota turbo cars
- Supercharger vs. Turbo
- Help me find a Kit for a b18b
- Low Oil Pressure
- turbo size (too big?) and intercooler size question on my dc2...
- My sohc Apexi turbo'd Del Sol
- Running open downpipe?
- timing problem, need help fast please!!!!!
- JE or Golden
- APEXI BOOST GAUGE QUESTION
- Getting valves adjusted for my 94 gsr JRSC
- obd0 engine management?
- missing bolt in greddy type s bov
- my setup
- dsm injector boring seals
- RC 440 injector installation, quick question
- Hondahvns blue turbo hatch
- Quick question? Gasket(s) related.
- Help with broken JRSC bypass valve
- Greddy type S, Turbo Xs Rfl , or Hks SS ???????????
- ECU GURUS -- GET IN HERE! something fishy is afoot..
- Anyone have a base map for a B16 w/ Turboedit?
- ECU problem with Uberdata / Hondata
- Hondata in Toronto
- Smells like oil?
- 2000 Honda Si...Turbo?
- Blitz Turbo Timer W/ Built-in Boost Gauge?
- Advice on setup
- FPR and fuel rail?
- does this save $$$
- b20vtec setup
- car smokes on deceleration........??? what can it be?
- just checking...
- 400whp, can it be reliable with out driving like a p*ssy
- CUMMINS-HONDA Joint venture
- New Turbo Problem HELP PLEASE!!!!
- Any differences between GSR header vs ITR header??
- quick SOHC base tune help TURBOEDIT
- C16 ignition timing
- what valves to use?
- BOV question
- new map sensor?
- maxworz?
- T3 Super 60 Coolant Lines
- digital accurate A/F gauge?
- do i need new injector clips? dsm 450s...
- E-Boost Controller: Any special fitting for the top wastegate port?
- ACT Extreme Clutch Owners
- rebuilt turbos???
- D16Z6 Misfiring from 4k up
- Has Anyone Tested a Venom Intake manifold Vs. a JG Edelbrock Manifold?
- t3/t04??!?!?
- yo...apexi powerfc
- Catch Can
- Free Dyno Day This Sat. 11th. in Waco.
- NOS Nitrous Direct Port kit for sale...90-01 B18 Integra, works on any Honda
- D16y8 stock valves safely rev to?
- bore size for turbo app.
- CEL light for Vtec pressure switch comes on under boost
- car cranks but won't start!
- FS: Autometer a/f guage---MSD 8.5mm Plug Wires---USDM DC Header 4-1
- turbo 90% installed, few questions..
- open dp/o2 question
- Where can I get a flange/DP for this??
- JRSC FMU problem? bogging? CEL?
- EGT Sensor Stuck
- Need help with turbo selection?? Please!!
- Apexi or Greddy? Which turbo kit would you recommend?
- Crome or Uberdata tuners in Michigan?
- Help Help Turbo Install
- Help just turbo my obd2 ls
- Pressure Loss with AEM FPR??
- thread tape
- turbo/downpipe fitment on an accord with h22a
- Best motor for turbo?
- VAFC2 afc turbo hack?
- Good Dyno Tuners in San Diego??
- Who's exhaust smells like rotten eggs?
- fuel pump loud as hell all of a sudden
- spend my money!
- dry 75 shot nitrous question
- Who has used Apexi turbo timer?
- 2 transmission questions about lsd for cable tranny. Searched
- Problems with MJM Auto Turbos. What are the truths about turbo oil requirements?
- Anyone with 500-600hp on competition clutch?
- JG/Edelbrock manifold question/throttle cable
- 625 whp @ 26psi!!
- Any shops in Maryland???
- A nice manifold... for joo to poop on!!!
- Valve lash specs
- nitrous question
- Blockguard? should or shouldn't i use?
- b20vtec build up
- ?? Boost controlling & should I switch from MBC to electronic?
- Alternative
- One more round for Earl Laskey And Dan Benson on the house
- JRSC at 11-12PSI.. Do I need a Boost timing controller?
- non-intercooled turbo
- Semi-n00bish question...
- Where to find Large TDO5 Greddy Downpipe
- Anyone cut there front bumper support?
- Running a VTEC Engine with TurboEdit. An OBD0 guide to 1-Wire VTEC.
- Compressor map - Garrett t3 60-1
- quick question....bout to get the xs turbo kit
- who here has experienced sinking sleeves?
- beneficial to trade my skunk2 manifold for a different one?
- Hondata questions for mild-Boosted D15b
- WILL KIT FIT?
- switching dp and mani
- Looking for b16 individual throttlebody setup.
- Wired speedlab "ricky" bad service
- full race + autometer need suggestions
- Strange Idle, Oil out of #2, No cels? Help!
- turbo parts
- Burning LOTS of OIL on BOOSTED B18C1, need help to diagnose
- resistor.. which is better???? searched..
- Where to find Holset Hx35???
- D16 + 100shot = Q?
- internal wastegate q's
- is this the correct mcmaster p/n for oil feed line?
- exhaust size and turbo?
- Any one running the GM Boost solenoid?
- what oil and grade are you using?
- 92-95 Greddy turbo kit and 96-00 Greddy kit
- JRSC D16Z6 Install help - Fuel System?
- is this motor salvagable????
- clutch
- 220-250whp b16 what precision?
- can you clock an 18g turbo?
- build turbo b18a
- twin boosted JDM B18C??? Thoughts...comments...recommendations
- noob o2 location question
- turbo in the rear....
- my sohc setup : review before i put it back together >>
- 2 q's - h2o injection and power gains from tuning... (leaning it out)
- Can you use nitrous pistons for turbo applications?
- Wiseco pistons for 9.0CR good for 500hp on b16a
- as promised here is video of dyno
- clutch?
- so whats the bomb ass turbo system you kids are running these days?
- Why do some guys swear by copper spray?
- question about intake valves in turbo
- BLOX don't fit at all...
- Test Pipe or Cat!!!!!!!!!!!!
- NEW TO BOOST.... any pointers?
- Any one got DOHC ZC turbo setup???
- BEST Fuel pressure regulator. Turbo integra in pursuit of 450-500 whp
- boost control help!!!!!!!!!!
- Those with compressor on the drivers side
- safe boost for the d16 engine?
- Garrett t3/60-1 .82ar too big for b16?
- oil coming out where turbo mounts to manifold? could it be blown motor
- mini-me love fab with precision TO4S fitment....
- outer edge of sleeve chipped... do i need new sleeves?
- what i need for a reliable 250whp out of my b18c1
- Newest Setup:
- will it be safe and reliable to run ARI sleeves and the ARI blockguard
- Turbo Cam? SOHC
- Integra with a b18b
- Uberdata on big numbers
- Will this manifold fit an h22 with sc61
- lightweight flywheel...car dies when comming to a stop.
- What's going on here????
- why wont my car idle !
- hks manifold question?
- Damaged Motor, what to do?
- Oil Line Map
- car dies after sharp turns....???????
- Info IHI turbo from a 90 rx7
- Bare minumum for turbo install???
- Help...Tial blow off valve stuck open during idle
- Question about valve springs for FI
- Just installed AEM EMS, have a couple ?'s
- turbo size for a 2.0l non vtec
- what's the going rate for a used set of eagle rods/JE forged 9:1 pistons?
- turbo b16 hatch
- Just wondering if anyone has done Cam comparison dyno runs...
- Hondata K100
- Is 300$ for Eagle Rods a good deal?
- GT28RS on a D16Z6... which A/R choose ?
- Want to know what the main difference between the SSAC wastegate and a Tial is? Look here...
- check engine after running open downpipe please help.
- Automatic Tubro.BOX Question
- Injector Size ?
- Couple Questions....
- why does my car misfire at high rmps
- MBC question?? Already searched!!! I need help!!
- hks turbo kit with fmu?
- running stock w/ uberdata problems, soldering problem??
- How many here are running stock motors + turbo (~12psi)??? Broken ringlands?
- Please Read Very weird misfire problem.
- is it a t3 super 60 or a 60 trim?
- head is not getting any oil...any suggestions?
- What Kind of Injectors to buy
- turbo manifold: inline pro SS vs. equal length
- *** 2.5" or 3" DP ??? ***
- 410 HP B16 tuned w/ Uberdata
- B18b turbo prep
- which oil grade??
- wich turbo should i get?
- GSR oil pump, where to purchase?
- Lovefab in crx, room?
- Spooled Motorsports question
- Hows this Car/Turbo Setup?
- fire ring problems
- anyone have experience with the VCN-1000?
- VICTOR X mani question!!!!!
- question: FMU?
- wtb girdle for b20
- turbo question
- Some cool Video from this weekend...
- ITR81 is alive again.
- Stock honda valve HP rating
- Is this the correct way to hook up a mbc?
- major over boost
- Maximum Boost heh...
- Anyone using a GT42R on a gas HR car?
- hp/torque limit on stock 4-lug cx hubs?
- AEM Wideband Setup
- Jackson supercharger D16a6 Question
- ok to use non-divided manifold w/ divided turbo?
- Yellow deposits on valves
- hks BOV vacuum nipple broke.....
- any one have axle on life time warranty in autozone?
- Where to buy cosmetic head gaskets?
- possible turbo kit
- Oil Pan for turbo oil return
- Question About Slim Fan Sizes...
- 95 GSR transmission
- B16A2 What turbo kit??
- Something I noticed with JG Victor X Manifolds
