View Full Version : Forced Induction
- What kind of numbers shuld I exspect?
- change injectors on stock ECU
- What pistons best and why are they the best? No bandwagoning please!
- How long did you take you to tune with uberdata?
- Funny oil problem
- Re-tune if running no cat?
- mitsu 14b turbo seal replacement??
- Dsm Fuel Cut Question
- sc61 and 2.5 dp
- SAFC II for tuning?
- spooling rpm??
- b18b turbo loses power at 4k
- another B16 hp question. can it be done ?
- broken fitting in the block. help me get it out!!
- a good shop to have my pistons coated ?
- The real truth about big time horsepower...
- dynapack or mustang dyno better for tuning for part-throttle
- Uberdata and JRSC
- EFI University
- FINALLY COMPLETED MY H22 TURBO! CHECK IT OUT!
- walbro fuel pump not delivering enough fuel?
- T04E/T3 turbo question
- Turbos
- K20 Turbo questions
- zeitronix wideband and one heard of it?
- bronze valve guides bad for your engine?
- how can you tell what a wastegate is set at ? ------------
- Nitrous bottle + hot car = what?
- What dyno is better?
- LS/Vtec valve clearence
- hey guys quick question
- Nitro in B20 non-vtec
- Spark plug Gap size for turbo setup boosting 30lbs.
- Missing Parts for a Drag Turbo Kit in a 94 integra gsr
- AEM EMS basemaps post yours here!
- Blue smoke at idle?
- Do I have to re-tune before boosting again?
- looking for mech in wa
- bottom end done - time to build the head??? valvetrain
- Running wide open exhaust, will this muffler do anything?
- HKS SSQV - rear screw sound tune???
- Cooling Fan electrical connector question (esp. DA owners)
- What color smoke for leaking coolant and running rich?
- What size filter for Garrett t3/t4??
- Goldeneagle Block girdle
- Dedicated Port on Stock IM for Vacuum Manifold
- Oil leak from oil return line...
- Cool Can - fuel cooler
- best turbo kit !
- Engine selection advice needed!
- nitrous oxide color?? someone help!!!
- Endyn catch can in Integra (post some pics of mounting in Tegs)
- what are the advantages???
- SC50 .48 Going to slow me down? On a boosted built LS
- Where to buy GReddy intercooler piping and downpipe?
- Anyone running a supercharged nitrous setup on a B16 crx...
- fuel pump wire upgrade
- opinion of flexible exhaust.....
- Smog Help
- am I getting ripped off ?!?!?
- Turbo on a stock D15 motor...
- Boost Controllers on Internal Gates vs. External Gates
- How Much PSI
- Officially back to the "light"side
- Limits of the 18G turbo?
- d16y8 build
- boost spike @ WOT but only when using MBC!?! - please help
- dsm on civic
- What is the best block guard for b18c
- Where do you guys ge Hondata basemaps?
- ~ 9" Tall FMIC on DC2 ??~
- Cusco Intercooler Sprayer Kit Feedback please
- Question about Fuel Pressure after changing my FPR
- Please HELP!! Running Stock Boost Kit JRSC. Overheating....Why!??!
- can u take out rods/pistons without taking off the crank?
- b20 intake manifold same size as b18?
- pcv valve (smoke)
- turbo installed with aqurium parts spliced on map sensor (why?)
- Cheaper alternative to AFC hack?
- Update pics of the strip/street setup, getting really close 56k beware
- idle help
- vafc2 tuners in socal?
- i need nos jetting sizes....plz help.!!
- dumptube for 40mm wastegate
- what do you think
- emanange
- rev hard turbo kit on B16a what else do i need?
- turbo a f22a1 accord
- couple of questions: ebay manual boost controllers, block.
- R Video
- B16 Turbo
- Three white, one black... what's up with my plugs?
- Good tuners in the philly area?
- Reason for 3rd grind besides synros????
- I think you FI guys will like this...
- Stoid Racing - Dallas, TX
- Need opinions on my setup.
- Can I tap into the PCV line for my wastegate vacuum?
- Does anyone know the rod bearing sizes/number for Crower Billets on an ITR crank ?
- New Turbo Magazine?
- pics request....dish and dome pistons.
- My SOHC Precision Turbo Setup (56k, bad idea)
- What intake manifold to get??
- dumb Golden Eagle lsvtec dowel pin question
- How to get to the next level after turbo kit?
- Major cooling problems!!!
- Roll call for H-T members going to the DENVER efi101 tuning seminar
- Good Bye Darkside! Back to stock in a day and a half!
- In everybody's opinion whats better for a 1/4 and top end swap??
- i need a turbo manifold
- Hows this setup sound?
- Any Good Shops In The Minnesota area??
- Will a InlinePro manifold and Tial 38mm w/g clear the hood on a 00 Civic SI?
- valve adjustment for b16 head w/ gsr cams....for the b16 or the gsr ???
- run with out windage tray?
- GSR-T pics....Phiz tuned
- ubrdata ignition/injection
- Exhaust Dilemma...opinions needed...
- EGT probe tap and information.
- My oil pressure seems really low.. Need some help
- Need help finding H23 Flange
- Build and Install done WHATS UP WITH THE IDLE
- GSR Block built by Viren, any good?
- Temporary Fuel Managment???
- tilton (or any other twin disk) clutch feedback?
- Forced Induction
- Leakdown results, need help interpreting
- Possible to run wastegate wide open?
- engine management and emmissions....!!!
- Accord turbo- Super 60 or T-25
- Where can i buy a Tial 35mm wastegate gasket?
- just installed my turbo kit
- STROKER OR BORED W/ SLEEVES?
- Do I need Fmu with this setup?
- pigtail for 3bar map sensor
- Turbonetics evolution wastegate?
- Jackson Racing.....anyone in here have a JRSC like me?
- RPI Turbo Manifold Power Increase
- Is this the correct way to approximate bhp when adding boost?
- the greddy 96-99 turbo kit on a 94
- Edelbrock Turbo
- Blocked stripped! - piston bore Q
- centerforce!!!!anybody use it
- Fueling questions with SDS EFI...
- DIY Profec B Dual stage switch...
- Has anyone used or know anyone that is using Hydra Engine Management systems?
- 5th Gen Lude Turbo, Perfect Power SMT-6 management..questions...
- the naked truth about big time horsepower...
- Garrett (NON-DSM) T25 Downpipe question....?
- what kind of power does this sound like?
- I am starting to hate my car!! HELP??
- turbo setup question
- turbo lx civic?
- Horse power Limits of 38mm Tial Wastegates?
- Turbo XS Dual Stage Boost Controller Reviews?
- how are tial blowoff valves.
- Lowering compression question
- The kit is almost together. Build bottom end or not?
- Anyone in Oceanside, CA/whatever willing to help me out?
- Hmt @ The Dyno 5/25 Video/Pics
- Engine broken. Help please
- turbo prelude smoking turbo civic with nos...
- t 3 turbo question
- Please tell me what you think of motor's compression, Got me worried
- exhaust question
- Turbo ordered...opinions?
- Bay Area: Where can I get custom piping done???
- SOHC rods that DON'T require notching
- any ideas on this? car is jacked after tuning........
- turbo vacuum diagram
- good turbo kit for B16a
- 14b on b16, what ex. manifold did you use?
- CLUTCH ADVICE plz
- ELECTRONICS ?? NEED TO KNOW WHERE ALL GROUNDS ARE? HELP
- LS Rods on D16, what pistons for FI?
- Crankshaft pulley chipped off , can I still use?? help asap
- b16a turbo help????
- dyno at inlinepro...and a few questions
- BOV not going off.....
- MAP sensor problem, need help
- does anyone run the explicit speed turbo kit?
- Vortech FMU on 89 CRX SI... where do I find fuel lines?
- turbo-ed dohc zc
- People with Auto/Turbo's
- Anybody Had problems with the tuner toys/stealthmode oil feed fitting?
- vortec supercharger on a 99 si?
- MY Greddy 18G Turbo needs help
- finished intercooler piping
- Cracked a Sleeve on a Stock B18B
- OVER SIZED VALVES OR NOT ?
- DSM Removal Wire Colors to correct location forgotten
- turbo problem
- Full Race has been busy! (Full Race/Leone Racing 2000 Civic Si, Garrett Supra, S14, S2000, K series)
- N/A guy going turbo but still has one "stupid" question HELP!!
- my timing belt broke, took apart my motor..what do i look for?
- obd1 conversion problem
- B18b buildup advice wanted
- What is the capability of a turbo Non Vtec SOHC Motor
- Missing link question
- The winner is....
- turbo sizing help?
- what is the best turbo to use on my setup b18 turbo
- One Fabrication E-Cutout Downpipe?
- brand new t4 set up
- Edelbrock PerformerX Manifold for 92-95 Civic.....Writeup.
- Is it ok to paint a Turbo Manifold with High-Heat Paint?
- built h22 what turbo setup do u suggest?
- boost on a h22?
- 3bar map sensor install pics ?
- D16Z6 potential
- SAFC II on a D16A6
- Can you identify this manifold??
- Questions About B16 Motor With 50K+ Miles
- emanage injector and ignition harness questions.
- should I change out the cams or replace them?
- anyone have instrutions for a NX wet kit?
- Goin to the DARK SIDE!!! Some Q's!!!!!
- Teaser video of the R
- anyone delt with vecco.com?
- let me see some of your e-cut dp's. 3 inch or 2.5
- DSM BOV question
- HP capabilities of a 16g?
- sohc zc turbo...
- boost but no power.
- drivin a turbo car w/ no IC???
- h22 Turbo install so far...
- Tial 40mm WG
- Downpipe from ONE Fabrication
- What welder to buy?
- QUIET 3" exhaust question
- 2000 Civic Si...Turbo or S/C??
- BAD oil leak (oil pan)..
- read my sig. with 7 psi (intercooled) with a t3/t4 turbo, how much hp will i make?
- helllllllpppppppp!!!
- 3rd gear pulls on dyno or 4th gear pulls which is better?
- STR throttle body and Intake manifold, what throttle cable bracket???
- Question on Rev Hard Turbos
- OT - What brand of air compressors do shops/people use?
- Nitrous on an auto trans?
- Not new to H-T but back from the dead
- How to fuel tune turbo on road instead of on dyno?
- went to dyno jet today to see what my numbers on there would be and i am so pissed
- Any thread on "How to rebuild your own turbo" ?
- Alternate place for oil return line? Other than tapping into oil pan.
- opinion on dhracing products?
- Excessive Heat Part 2 Please help!!!!
- what settings for cam gears on factory cams for turbo civic
- Any local chip burners for Uberdata? (Tacoma, Washington)
- setup info
- Something very wierd and unusual happened today...
