View Full Version : Forced Induction
- if its not one thing, its another
- Question about water intercoolers
- safety tips and help on b20 boost
- Post tuning question
- deltagate sux?
- Are b16 and B18c headgaskets the same????????
- Using aftermarket bearings (Napa)
- wierd problem...5-10 second hesitation/stutter about a minute after every startup
- what would you recommend M300 or the LM1 wideband
- Master Power
- NEED HELP AND IDEAS. RADIATOR PROBLEMS.....
- What's your method for PCV?
- Cometic headgaskets , who stocks them?
- Dyno today (56k ok)
- Bosch LSU 02 sensor
- Not sure if right place..... Wiring
- Info for inline fuel pump wiring
- Turbo Spark plug for Teg???
- Replace greddy downpipe with a 2.5 inch???
- Do full turbo kits require tuning?
- Water cool turbo HOW???
- New problem with turbo, need help diagnosing
- Anyone using a pt-61?
- i need someone to look at my block
- Missing Link + Emanage, can it be done
- Run open header at the track....yes i searched
- where to put my turbo timer?
- turbo spits oil?
- what is the ideal management system for a DOHC ZC with 8psi?
- turbo gs-r ...sputtering at certain rpm
- Where to get an upgraded oil pump gear for h22?
- What spark plugs should I be running?
- Which gaskets are a must?
- how many miles are on your motor? feel comfortable boosting?
- Anyone every bought from these guys before?
- what setup for 330-400hp 00 si?
- Crower Turbo cams
- 1/4NPT Oil Restrictor Fittings
- which rom editer for obd0 ghettodyne or turboedit
- B18C5 JRSC Running on 3 cylinders?
- Got a new digital camera....
- Downpipe A/C clearance
- type R cams + boost
- Can anyone help me identify this turbo?
- T3/T4 help..
- in car vid, 350whp on the street :)
- stone racing?
- Oil pressure
- considering boosting an h22, thoughts?
- EF B series swap..... that turbo will clear full-size radiator ?
- Your thoughts on the PWR radiator and fitment issues.
- Is my oil feed hose end too close the manifold?
- 99-00 Civic Si Vortech SC on 93hb with b16 (will it fit)
- To keep spraying, or to boost,,, The ever so often asked question...
- Garret t3 super 60 (hot .48) on my d16y8!?!?!?
- intercoolers
- Help with d16 fuel management w/T25...
- who's running STR cam gears on their turbo'ed motor??
- So I'm done with my Honda.....
- quick spark plug question... jdm h22a....
- Main stud question
- Is there any difference between Type R and GSR oil pumps?? SEARCHED
- SOHC Ninjas: Do we ALL have overheating/head-lifting issues?
- Best place to buy turbo parts on HT.
- b20 JE Piston going in B18a
- what whp are RC 440s for???
- need some info on crank case breather kit
- vafc with emanage
- started my fully built d16z6 swap/turbo/ntercooler nitrous kit goin in at same time lots of pics 56k
- Hondata with B18b ?????
- Dp Fix (pictures)
- Internals F22b1
- driving w/ no downpipe?
- simple injector question
- Bent Compressor Fin
- HOW TO: Mount a JRC FMIC on a Civic
- Akari Motorsports Coated Pistons Meltdown Test.
- Anyway precautionary steps to prevent a blown head gasket
- I need large 5 bolt flange for this turbo.......Please Help
- compression test results. ok for boost?
- Broken skunk 2 cam gear, has this happened to anyone else??
- msd6a + coil
- high compression fouling plugs?
- new emanage with new kits any diff than the blue box?
- Swift-Performance.com IC piping kit - What a RIP OFF
- Which engine, oh which engine
- Just Turboed, No Boost! Please Help Me.
- stripped headstud threads
- oil drip from muffler and turbo
- which BOV..RFL or blitz SS??
- MSD injector question
- can u re-use hondata intake gasket?
- I installed a new intercooler and moved my IAT sensor .. now my car is loopy?
- Question for turbo engine builders?
- injector ?
- Which Honda?
- Went to the dyno ... Can't figure this one out
- Mocked turbo mount..
- Anyone have that DIY Turbo Timer website saved?
- Has anyone used a StreetImports intercooler?
- modifying injector seats,
- Installed SX 1:1 fpr, started car, and 71psi of fuel pressure!!
- Car is back together but NO oil pressure... HELP
- 2.5" to 1.75" to 2.5
- chipped ecu for b20 turbo?
- Should i go sc61 on my ls?
- turbo troubles
- what are cold bent pipes? same/different from mandrel bent?
- ATTN Drag 3 owners.
- ZEX dry kit on d16z6 (some fuel questions)
- Can I run ARP headstuds for a b16 in my Gsr
- T3 50 trim .48 A/R hot side .42 A/R cold side practical enough for $250whp?
- -10 AN Oil return steel fitting?
- where do you got your front license plate ?????
- t70 on a b-series?
- Why are eagle rods so cheap?
- Any Honda Dynos with GT30-R or GT35-R?
- building the bottom end???????
- greddy intercooler smog question
- Garrett intercoolers.
- TELL ME IF THIS IS GOOD....
- using 4 bolts on a 5 bolt dp flange.
- Spark Plug issue....
- Anyone with a Crp turbo setup?
- Painted Intercooler Performance?
- JRSC w/ uberdata tuned using PLX M-500 WB (lot of pics)
- 60mm NS111 turbine vs GT30
- bad exhaust smell inside car...
- What does a guy need to do to install DSM 450cc injectors on a OBD1 Honda???
- Ordering a BOV...searched but need your opinions.
- NGK BCPR7ES-11?
- who has bought an intercooler from this site?
- FAST 4 door Tegs .. Any out there in the 11-12's?
- drag gen 4 oil drain?
- which junkyard turbo is best for gsr?
- eagle lightweight forged crank
- anyone on here using 24 or 24.5 inch slicks on thier civic
- Advantages to externally dumped wastegate?
- turbo not spinning
- wideband
- banjo bolt?
- E-RAM ELECTRIC SUPERCHARGER!!!
- two questions regarding turbo and build
- Advice on a downpipe (look at my first try)
- how do these plugs look?
- HKS Mani
- Using internal WG hole for EGT gauge probe?
- turbo manifold
- wiring turboxs dsbc
- Can turbo spooling still be heard with resonator, cat, and exhaust?
- New Dyno Numbers
- Help, Yellow specs on Plugs?
- Turbo not spinning while idle ?!
- JRSC is better on B18C1 rather than B18C5??
- I need an UBERDATA TUNER IN DFW, TX!!!
- Greddy kit with car throwing no codes
- Jrsc questions...
- 83mm sleeved closed deck block can it be daily driven?
- what exaust should i get
- searched...need help with bottom end
- What is the best traction bar for 97 integra
- How do you take the rotor off a *Distributor King* Distributor
- Charts on certain turbo specs... can u point me in the right direction?
- Almost Boosted D16Y8
- check this site's kit out! Too good to be true?!
- T25 turbo for D16a9 engine? headgasket problems?
- engine management question
- wideband o2 sensor OR EGT probe?
- D16Y7 Turbo Project
- ARC Billet Rods
- ? on Tilton (pic request actually)
- Nitrous help with turbo
- NO BOOST!!! NEED HELP!!! STRESSED OUT!!
- I think my turbo is dead...yes..no?
- Finally got it to idle decent...but, more issues...
- Plasure PLate help ????
- what all do i need
- Swapped to uberdata, 4500 rpms idle?!
- a little worried about my timing (pic inside)
- k26 turbo on d16y8
- Apex super intake filter
- will my 450cc injectors work with the bottom cracked? pic
- Air Filters for Turbo use
- radiator clearance issues with revhard kit
- what kind of cat converter will make my exhaust louder
- what does it mean when turbo says available in either stage 3 or stage 5 wheel?
- Nitrous with Skunk 2 Ecu
- missing link install
- 86mm bore...high boost?
- Question for anyone with a H22 with Hondata
- what is it like for all you turbo hondas?
- homemade mbc
- Greddy Civic Si Performance Question
- help a bruber out??
- B18c with hytech manifold
- Are T3 compressor housings swap-able?
- Garrett T3/T4 .63 A/R stage 3 turbine/TO4E-50 compressors specs?
- Whoa please read what Precision Told me
- greddy TT install
- Where to get rubber connections for charge piping?
- Compression test engine out of car?
- inline pro manifold bolt
- Methanol injection on turbo motor
- #Quick question: Will a Hondata for P28 work for P75?#
- Oil Drain Question......NEED HELP!!!
- Is there any difference between OEM fuel filters?
- HELP!! Turbo install finished. UBERDATA BIN HELP!
- turbo newbie : need advice
- 4 puck or 6 puck clutch? Help me decide on a beefy clutch.
- Bov Flange
- Exhaust flange thickness?
- Any Info on MP Racing exhaust manifolds? (did search)
- turboxs rfl problem fix
- Need helping finding an Exhaust leak
- Were turbo sounds related problem..
- Anyone using a DIY-WB from www.diy-wb.com?
- is porting my ls head worth it?
- supercharged ls??
- My D Series set up in my 2000 Acura 1.6ELT Pics included
- 04 civic lx on boost?
- dyno chart post here now..
- Vacuum nipple for compressor hole
- Question about FMUs
- manifold ?
- WHICH 750 Injectors for prelude?
- going to japan for parts, where should I go?
- NOISE from MSD 6AL
- Question for Full-Race guys
- charge pipe size
- Need some help idenifying this precision turbo
- Quick question on turbo matching
- Is it important to evenly torque the manifold to the head?
- Anybody in FI forum from Puerto Rico?
- would detonation cause hesitation??
- anyone know how to read spark plugs?
- i am newb please help(i have searched)
- 2000 Si on the Dyno
- Average air intake temps.
- can i turn around the top on my Aeromotive FPR?
- greddy a/f gauge
- Clutch decision
- will d16z6 greddy turbo kit work with wrx intercooler
- Nitrous and fuel pump??
- To those that have put your ecu into limp mode with too much boost for the map...
- New dyno numbers for the D series ELSPOOL and JDMCRX
- www.cheapturbolines.com
- Anybody using Uberdata for SOHC turbo?
- TIAL BOV Question!!!! Please help....
- Pics of my custom piping and turbo setup. 56k no
- Wow this has to be the coolest H22 2Gen integra ever look!!!
