View Full Version : Forced Induction
- 515 hp track ITR Turbo Dyno
- bad ass machine!!
- Tial fittings for SS Lines
- how to clean up Aeromotive Fuel Filters?
- Some gsr questions.
- all motor no more...im the noob of noobs about turbo
- H22A in EG Intercooler Piping question
- what bov is this?!
- turbo manifold heat shield? where do i get it from?
- Help. d16 T3 turbo can't start *video*
- Turbo kit for civic 2.0 EL .
- What you should know before running E85...
- My stock block GSR turbo - 345WHP@10psi
- Wich K20 head to build????
- Clutch question
- break up in high rpm ignition problems can someone help please!!!!
- Cause of scratching of all four cyliders?? help!!
- Hondata S300 and spark plugs, need some info.
- Looking for an approx wieght of a top mount manifold.
- spearco intercooler? is it big enough?
- Bore .20 or .50...
- New setup. big problems!!! HELP!!!
- Need some help choosing a headgasket for my ERL B18 GSR block.
- ** BLOX PRO 1 CAMS Vs. SKUNK2 PRO 1 CAMS **
- CHANGING MANIFOLDS AFFECTING AIR/FUEL RATIO ADVICE
- JRSC belt slipping??? Cause of power loss?
- H23 Exhaust Questions
- AVCR users....i think i just got scammed
- Pression Turbo Center cartridge bolts snapping the head off the mounting bolts
- Why is everyone ape shite over the ball bearing 50trim t3/t4???
- AVC-R problem
- "Flatness" of Moroso oil pan
- k20 ?
- Turbo Kit F/S
- gasket for exhaust?
- Motor almost rebuilt again but worried!!
- eg gsr turbo help?
- ebay turbo kit
- Please help...quick question...need answer now!!!
- TURBO $550////ADVICE AND OPINIONS
- what does it take to build an e85 fuel system that will support 600whp?
- upgrade to GT35R.....is it worth is with my goals
- Oil pan removal with 3" downpipe
- stuck between ACL race bearings and honda yellows
- b18c turbo help
- b18b stock internals w/t turbo
- 1 cylinder has very low compression, others fine???
- help me to install my jackson racing on d16z6
- QUICK GREDDY QUESTION (D16Z6)
- Here's a PeakBoost shot for ya... 1st startup video
- Quick D series question.
- REV SPEED T3/T4 COMPLETE TURBO KIT.... review
- noob z6 boost prob
- Hondata ECU and Fuel Pump problems, Main Relay
- not a honda but needing some help
- Dart Block Question
- Think this would help with boost creep at all? (ramhorn / sc61 / b16)
- Max hp limit of stock fuel lines?
- another quick ? for pistons
- I need injectors ASAP!!
- Does this seem right for power???
- Some pics of a custom setup I just completed for a buddy of mine...(whats 56K?)
- Exhaust Manifold Studs -> Sheering?
- does anyone have a peakboost turbo kit with an moroso oil pan
- wastegate dumptube flex
- royal purple oil with turbos
- heated dipstick
- Ls block
- Whats mike Laskey's name on here
- holset hx35 on a d series
- b16 tuned b4 build.. tuning question...
- A little confused on bearing for my engine....
- Question about Blox Manifold
- Fuel rail...
- Should I tune with VAFC2?
- drag 4 dp... what kind of steel?
- Valve lash (consequences)
- hondata... i searched
- is my compression good to boost?
- new job, new username
- Civic half-size radiator into my turbo Miata: what to do with hoses?
- fully built turbo h22.how much power should i make
- diy electronic boost controller
- TT rods for sohc ?
- Modifyd Performance - anyone ever get tuned by em?
- new project... =)
- Opinions on JRSC on a 2004 RSX-S
- A/C compatible manifolds....??
- gt40 on bseries 2L...any dyno?
- rc injector question
- Air/fuel too rich under boost?
- Injectors
- what compressor housing can replace a to4b ar. 100
- Apr Head studs. Same for GSR and Type R?
- VGT - Variable Geometry Turbo
- B20B vs B18B for 8-10 psi?
- boost creep w/ ramhorn mani
- hiding your turbo stuff ?
- look at this turbo kit for me is it any good
- Ramhorn AC vs Quick 4 Tubular AC
- b16 turbo problems...
- intercooler install help please
- oil pressure question
- went need help with this intake?
- Best turbo H22A Setup
- problem on the dyno, need help
- all stock d15z1 with a 55 shot?? help pleaseee
- How much power do you think is realistic with my setup?
- new to turbo
- difficult blowby/catchcan problem
- nitrous and turbo
- Dyno: SOHC, SC61, AEM
- Moates Ostrich eprom emulator...
- Ebay Catch can? Can I make use of it with my FI set up?
- tial blow off valve and wastegate fitting sizes?
- iat sensor with threads for charge pipe
- map sensor question? i searched
- Blown engine, suing builder
- How do you seal the oil pan gasket ??
- Loud ticking comming from my motor.
- Keep my turbo or time to upgrade?
- Want to do a Turbo Setup for b16a2 EG hatch.
- LS Breather/Catch Can Question
- H22 Questions??
- High flow Radiator for a Turbo CRX
- Oil restrictor on Turbonetics turbo
- Headed to the track....(turbo gsr hatch)
- Nokia cable (for dataloging) isn't recognizing on my laptop!! Anyone have any ideas why?
- What wrong with my turbo?... =(
- startup oil pressure for fresh motor
- crower 402-T cams
- TOGA Oil Pump?
- Noise from turbo anyone have any input ? video inside
- injector sizing for a high comp nitrous b18
- oil restrictor ?
- I need your input on my d16z6 build that I want to do...
- GSR cams Vs Skunk2 Pro1's
- Anyone in cali that does street tune?
- Are blowzilla's turbos ballbearing?
- 3 bar map sensor
- hondata question: replacing battery
- Question about vitaras on a mini me
- What kind of fittings and nozzles are you guys using for alcohol injection?
- boosted b18c1 with micro-tech mt-4
- what is a used SR20DET worth?
- how do I check atmospheric pressure? motorola 2.5 bar map sensor...
- painting inside of intercooler pipes?......
- kkk t3 compressor housing
- Motor cuts all power on track conditions and comes back as throttle is lifted / reapplied
- aluminum vs. braided stell fuel lines??
- Need some ideas...anyone have pics or own a DelSol with a cut front bumper for intercooler?
- help on turbo electronics
- Street Tune Good???
- are these precision injectors?
- idle problem after turbo.
- Tuning issues with AFC Hack - turbo 2001 Prelude
- which wastegate to buy?
- Basemap inspection please
- wastegate not holding spring pressure
- d15 with aftermarket rods
- how hot is to hot?
- Oil Pressure gauge???
- Front bumper for BIG intercooler.
- vtec less noticeable with more boost.
- Moroso Oil pan@!
- Port Match Big Throttle Body to Edelbrock Victor X
- Engine builders....is this normal?
- GSR with gt3076R .63 AR turbine housing (please comment on set up and goals)
- First time tuner
- fuel pressure
- 1600cc injectors = bitch
- 700whp build. is my setup worthy?
- My little Del Sol B16A3 build...a few pics for your enjoyment!
- Running a mustang throttle body- What TPS?
- help identifing a turbo
- ok guys total noob but i want about 300 to the wheels
- turbo help
- friend wants an turbo on his f22a1
- d15 turbo ??????
- fluidyne radiator?
- gt30r b16 dyno?
- Any1 in pottstown pa area that can install my lsd
- uhh, idle afr suddenly in the 10's...what else to check??
- Nitrous cams for street B16a???????
- Forged pistons without sleeving
- t3/t04b
- turbo question
- 1997 Honda Prelude Liquid/Air setup
- Question for you turbo guys!
- Honda Tuning Long Beach Love.
- FullRace IM not available anymore
- Turbo GSR question
- SLS mini log EF fitment issues?
- oil restrictor question please(i want to get tuned today)
- Upgraded, yet i'm now slower! Turbo Size in question. lil help here guys.
- Simple Digital Systems (SDS) engine management. Anyone using it on their honda?
- D15B7 with jackson?
- 482whp / 332 tq: 84mm GSR w/ T3/T04E 57 trim pump gas
- What do you think of my SetUp?
- zex wet kit help. searched!!!!
- Saab 900 Turbo
- Love Fab ramhorn manifold with GT40R?
- blown GT30R turbo after less than 1 k miles
- help, new turbo manifold wont mate with the turbo
- Finished my SOHC build....
- Total timming
- diesel turbo.... good idea or bad on a d15
- need help on what turbo is best!!!
- What gaskets are you all using?
- Honking noise coming from intake, IACV?
- internal wastegate s300 boost control
- looking to sell kit, how much is this worth?
- need help picking a turbo
- Motor blew again...Ideas???
- Which manifold? Lovefab SST or Neukin Top Mount?
- Steel Turbine Housing
- Full Race Motorsport
- Audible boost warning?
- Good choice for JRSC D16y8? F1 STAGE 3 CLUTCH & X-LITE RACING FLYWHEEL 8.5lbs
- Need Help with Golden Eagle Intake Manifold Install
- looking for some stuff
- turbo?
- ebc question
- Precision injector install ?
- tuning issues
- so whats the low down with the greddy type s bov
- autometer /aem widebands
- Hondata Intake Manifold Gasket..??
- Help With valve train selection, Gsr, Crower, Manley? Help
- Wastegate questions
- My main problem is blow by: Had 3 motor with blow-by
- H22a1 Supercharger Question?
- pistons
- STOLEN!!! ORLANDO plz help
- overheating problem HELP!
- crome tuner in portland area
- pte vs rc 1000cc injectors?
- lsvtec turbo build help
- Aem uego or Plx m300?
- Integra turbo piping fit 92 civics???
- d15b turbo setup... questions about injector size (cc's)
- Anybody using the Holset HX35 Turbos?
- hondatas300 prob?
- before tunning
- help with this turbo kit....
- how good is this turbo?
- eg b18 turbo installation help?
- Intercooler question
- First Start up, high idle and smoking
- Should i buy RC or Presision injectors
