View Full Version : Forced Induction
- PRECISION PT70
- Management Questions........need help!!
- where can i get a T4 for my H22 ?????
- M45 or M62 Jackson Racing Super Charger question
- i have jdm b16a obd1 want a list of things i should use to safely boost 10 pounds
- Fleible tubing for wastegate dump...
- Compression Ratio! which one is right?
- OEM Turbo List
- Differences between Piston's concerning heat transfer?
- WTB: fully built D16 motor with turbo or without
- Winter build up for my drag car
- turbo surge i think?
- what i've been up to lately (turbo ls/vtec) pics inside
- Do i need my oil sensor when iam installing my turbo....
- I need a turbo that doesn't require oil restriction.
- What turbo company do you like/prefer and why?!?
- Question.? Been hearing aome bad stuff about Turbonetics turbos, whats the news.
- my boosted teggy video ( project boostedweasel)
- My turbo sounds like a skateboard, what's up?
- westgate {deltagate 2}
- bc spec III cams with turbo??
- Rebuilding a 98 LS engine for Forced Induction. Need suggestions on parts?
- well... cars werent enough... ssac has to go and build turbo manifolds for bikes....
- cant find manifold
- Phoenix t3ptrim/gt42 turbo will fit a full race prostreet manifold?
- GT3567 v t3/t04R v t3/t67 H.O. or nothing?
- check this out
- ebay forged d16 pistons
- GT42R turkey shredders?
- b20b supercharger question
- Compression ??...but different than the rest....LS VTEC
- Boost gauge only reads vac... Hooked up directly to manifold!!
- Boost on a H22
- I need a 3 bar bin for my D16, someone help?
- t3, external wastegate, adapter
- Exhaust for b16 turbo?
- Oil pressure and oil lines questions
- Input NEEDED, on correct turbo
- oil in compressor houseing?
- Increasing Octane... what's the all-around best way to do so?
- Warner Ishi IHI RHB5 turbo, worth the time?
- Questions about valve adjustment affecting A/F ratio and overlap on dohc vtec motor?
- making a b16 a 2.0L ??
- want to boost my h22
- which intake manifold is best
- Ignition: What are you running?
- What do you guys use as a replacement gasket for the tial 38mm wastegates?
- Important question about turboing d16y8
- AAM Hiring - Website / Marketing
- Budget turbo for F22?
- 4inch exahsut systems?
- GT2871r
- Which 4" muffler is best?
- turbo and A/C?
- turbo cams test? {yes I searched}
- What could i make w/ this turbo??
- gsr injectors
- Jun intake manifold
- Charge pipe blowing off..
- Buying turbo manifold.....how important is the wastegate location.....????
- FMIC any one recognize these?
- 2.5" or 3" DP
- odb0 pr4 turboedit chip
- Pic request: Cutting bumper support for intercooler
- Boosting my LS with a T3 setup
- garret t3to4e what kind of thread is the oil intake? a.s.a.p.
- a good cheap place to rebuild a Turbo (SOCAL)
- ........................who has built their engine for the first time?...............
- Earl Laskey´s bearing thickness chart - where can I find it?
- just got my car tuned, what do you all think?
- My BOV is like my old lady...
- motor mounts?
- Oil Cooler on turbo?
- Greddy kit internal gate will not hold 16psi help.
- 35 mm turbonetics deltagate w/ tial spring?
- Aebs Intake manifold for boost??
- piston pros need help
- JG engine dynamics rocks.
- What's the MAX BOOST YOU can get on GREDDY PROFEC B - BOOST CONTROLLER??
- Laptop ECU tuning requirements?
- serious efi advice needed*****HELP****
- Stock axles on Boosted LS
- limitations of a 38mm wastegate
- Where to buy JRSC?
- the ever presesnt "help me pick a turbo"
- garret .48/.42 turbo on stock LS?
- Fouled O2 sensor from running 3 bar map sensor and stock ecu...Can it be cleaned?
- *Video* 12sec Pass Turbo D-Series Stock Block/Head
- Top-Mounts & Cooling
- TO4 Type Turbines P , Q , GT-Q .
- Turbo reccomendation...400whp pump gas b16
- any1 running oil cooler on there turbo cars?
- new to forced induction, please shed some light on my Accord question
- gm-8 on stock b16?
- DH racing
- What's a good turbo for Revving a B16a to 10.5k?
- recirculating bov and closed wastegate
- Need spiro locks for srp pistons!
- How does your stock cooling system hold up against boost?
- How does your stck cooling system hold up against boost?
- TDO4h 15g
- H22A turbo, 290whp at 7psi...what LSD to help?
- PIC REQUEST: Equal length(pref neukin) manifold, with tial 38mm wastegate, top of engine bay shot
- how much boost for stock rods on s/c??
- HKS ssqv question
- Vaccum pump on a turbo motor??
- What intercooler do you guys suggest (need an Upgrade)
- traction bar question
- B18b, do I need to retune??? help please
- water-air-ic water reservoir size?
- Turbosmart Pro-Gate or Tial 44mm?
- how many quarts of oil used for stock gsr oil pan
- need help with uberdata and i dont know where to post it sorry
- Happy Thanksgiving HT Boost Crew!!!
- t3/t4 garrett turbo + b series parts
- Help with Garrett Turbo
- head gasket
- Turbo with internal wastgate
- do u use a gasket between the turbo and downpipe?
- xs power turbos
- H22, JRSC, EK
- turbo or nitrous
- boring question please help i have only 1 question
- Piston Ring gap - Wiseco - what size?
- conversion: oil+water to just Oil cooled?
- missing link?
- tubular manifold Q.?
- gunk between intake mani and head
- Anyone have a 3 bar D16Z6 Uberdata 1.7 MAP for me to work with?
- Results of the Royal Purple Dyno!!
- which pistons and rods for b20 block turbo?
- Prelude h23 downpipe
- Supercharger intercooler?
- 1 bend 3inch exhaust???
- B vs K for boost
- s100 tuning and SO.CAL tuner needed...
- ACL Bearings: Which ones? Details inside.
- Waste Gate Dump Tube placement *Good info*
- wide band vs afc
- 476whp stock sleeves 18psi :)
- Engine bay pics for mounting, Turbo AND A/C
- is anyone running a holset hx35w???
- should i turbo my stock dx or find a swap
- boost leak hunting
- Autronic pnp honda board user, i need your help !
- question baout my turbo LS
- B18B1 stock bottom end with p30's and 125 shot ???
- Those of you using HKS mani on a B engine..........
- need help rewiring my buddys obd 2 vtec well its obd 2 converted to obd 1
- anyone ever use ZEX/COMP CAMS valvetrain?
- GT35R surge problems on a b16?
- Need help with building b16 block to handle lots of boost(search is down)
- log manifold with sc61
- Anyone do a ZC oil catch can/PVC setup?
- wtf is wrong with my car now
- Vacuum hose wrap?
- blox /skunk2 manifold good on a turbo setup?
- Turbo newbie: a couple questions
- New Set Up: Shooting for 350-400ish whp.
- why are 2 38mm wastegates so uncommon????
- Nitrious Questions!?
- post pic of oil feed line
- Downpipe Temperature Q
- greddy turbo kit
- 96-present......obd2 converted to obd1
- 02 4 wire Sensor wire identification?
- Turbo filter
- I will be making a how to vid(oil tap) and posting it but first..Does anyone know what all fittings
- Where to get TD04H-19T parts?
- has anyone boosted hondata/3bar over 28lb
- Where to get oil feed line locally?
- Paintball tank nitrous?
- My Wallet Says No, No...But My Engine Says Yes, Yes...
- Would you reuse these?
- Retarding Timing For 75 Shot: Got a question...
- vacuum source for boost gauge?
- Dry sump setup and firced induction... a few problems... i think
- need injectors
- anyone here using a gt30r w/garrett 3in turbine outlet with any a/c fullrace style manifold and down
- Some information about GM 3bar and connnector install for Hondata
- sfp street manifold
- greddy 18g turbo power
- need a good turbo manifold with a/c compatible??
- five angle valve job......
- water temp .. were to install ...
- minimum
- MSD Ignition setup
- I anyone is interested in a JRSC
- zero compression with rebuilt head
- Where can I find a cast wastegate flange??
- full race
- lowering compression on d16z6
- 225whp 162tq turbo gsr 6psi graph inside...
- broken tranny pics
- What size injectors do I need?
- Finished 500whp Daily Driver Turbo Project (Non-Honda)
- LS/Vtec turbo problems
- WHAT DO YOU THINK OF NLR AMS-1000 MULTI CHANNEL BOOST CONTROLLER
- Runs like shit when when changing to open loop??
- Greddy Profec B Spec 2 owners look here!
- Headlifting problems for D series> Fix now or can I wait 1-2 weeks?
- relable greddy turbo kit, Why?
- Question about check vavles
- VR6 w\GT30R vs. civic w\SC61 spool time
- Post your turbo gsr setups
- Are the new T3/GT40's Ball bearing?
- Maintenance on a turbo honda?
- sleeves
- DAMN thermal exhaust
- Emissions prob. w/JRSC
- billet turbo backplate ?
- has anyone ever tuned e-manage...
- hey question about oil
- direct port dry nitrous?
- turbo setup with vtec problems
- Where to get Boost Guage Fittings (not T), That screw onto the back of the boost guage
- code 21 pops up when i hit vtec in boost? any ideas cause its leaning me out bad!
- What oil to use with quife lsd in GSR
- HELP Major fitment probs with turbo need some advice
- Waistgate dump tube question
- SOHC ninjas - who's running a .040" (or 76mm) overbore on stock sleeves?
- How did you get your Boost controller vacuum line to the source (engine)
- Put a wideband on the greddy kit today...
- 99 SI, B18c5, custom top-mount mani, Hondata S300, Precision SC34, KAIZENSPEED
- Help with Kpro RSX turbo
- Lost HKS SSQV adjustment screw - Will any bolt work >>
- Oil in Compressor Housing
- Guess that intercooler!
- enough oil supply to turbo?
- Video: Stock internal B18B track and dyno fun.
- 1/8"th good enough to get oil to turbo?
- gsr turbo gone wrong
- how much power can a d15b put out
- question about turbo
- INTERCOOLER ?
- AVCR map sensor problem (possibly)
- h22 turbo question
- OBD2 02 sensors and Boost
- 84mm head gasket w/ gasket set ?????????? B series
- FITV, screw keeps backing out
- Electrical deamons in boosted gsr
- water/methanol injection.....
- what do u think about the new manifold
- SOHC DYNO UH OH....
- Quick turboXS MBC question... need this for tomorrow
- S300 not need boost controller?
- noob question..boost controller
- just put my head together what u think?
- fuel system requirements
- ANOTHER BOOST ?
