View Full Version : Forced Induction
- Question about turbo ID (pics) different flange
- Greddy setup on OBD1?
- Integra Injector Wiring Colors....and What is Their Order??
- map sensor + frost + cold = wtf
- fully built low comp pass smog?
- 2 1/2 exhaust good for 300whp
- What size i/c piping???
- B16 built sc44
- hey what happened to 14point7????
- d16z6head poerted by RLZ 3 middle rod caps wore
- Mahle Rod length?
- Nitrous Camshaft/Nitrous with single layer HG
- Horsepower on a stock ITR head? T3/T67 H.O. power
- WATER METHANOL INJECTION kit question
- When to run an oil restrictor?
- What is BB turbo?
- dh-racing?
- Tial BOV question
- Purple pain 600+
- How to tell if i have a fake Walbro pump
- Question about resister box...
- fuel pressure gauge?
- AP1 throttle body on a B series?
- help me decide on a turbo, 400hp h2b
- Engine management?
- what size injectors, t3/t4, b16
- Block blown!! is head still ok?
- quick question b16head vs b18head
- 65 shot b16 sirII in 91 crx
- thread size for oil return flange?
- Vacuum line questions
- D16Z6 build
- which turbo??
- Built H22 DBB 67mm garrett vs S366 - discuss
- non vtec sohc TURBO camshaft?
- so ive decided i wanna boost my gsr
- VTEC problem in boost
- mini-ram oil return line.. does this look ok?
- Intercooler Question ? ?
- Throttle body question..... 300hp DD
- NX Piranha dp kit?
- best cam for power
- cleaning up my engine bay
- block ok to use?
- Boost Creep or Solenoid Issue?
- Dyno's in nor cal
- gt28 vs gt30 compressor cover
- Intercooler for 700+whp
- where to buy fuel bonjo and lines?
- Clevite mahle caoted bearings
- Turbo b16 dying when its warm
- 2 Emails I recieved about Oversea EBAY Turbo's? Tial and Garrett Knockoffs???
- 2 poll questions
- Rebuilding turbo with rebuild kit. Any advice?
- ''First turbo build,How much HP?''
- What head gasket goes with a super charger?
- RC injectors dont fit?
- Inj., rail, mani question
- Time delay relay to control nitrous solenoid
- GReddy 15g downpipe bolts
- Replace ARP Headstuds? need opinions
- Ideas for water in cylinder on cooldown
- Midwest Autoworks New Project S2000.400HP.12's.Under 10 grand total
- H-to-B help!!!
- Valves for d16y8 Turbo???
- turboing a da what radiator
- Need help asap
- b18b Almost 200k Boost?
- Small coolant leak from my turbo?!
- simple valve spring question (d16)
- itr cams
- B18B Vs. B18C (GSR)
- injector size and myth
- Need Help with turbo.
- my b18b
- Why turbo?
- Horsepower limits of standard .42/.48 T3 turbo?
- Direct Port Nitrous
- Catch can filling up with oil to quick!
- Bullshit detector required about bearings? Can u help?
- piston to valve clearance.
- Neukin/Alex=Possible Crook
- Turbo but non Honda thread!!
- b16 turbo retune questions c16
- itr pistons..can i go turbo????
- Greddy Turbo Kit?
- Can I Turbo An All Motor Built Poor Man's R?
- Question about sleeved block
- tubro questions (hot side exchange)
- 85mm bore? GT35R boost, safe?
- Ls Turbo need help Transmission or tune
- Choice of Gauges?
- Obx topmount turbo manifold for honda/acura b series
- What blow off valve is this..??
- quality affordable manifolds?
- What muffler are you guys running?
- question for specialist engine builder..
- golden eagle sandwich plate cover!?!?!
- pooRmans type r turbo vs gsr turbo
- Filterless Cold Side
- SOHC Turbo
- post up your nitrous pics.
- General Info!?
- Big turbine and small compressor?
- Forced Induction Database, any interest?
- oil pump question
- JRSC B-series blower pulley boost and belt specs
- Car is breaking up going into boost . . .
- motorolla 2.5bar map ((Junk))
- turbo Help Asap
- blox 4" velocity stack gains
- GT4088r Exhaust question
- can u have itbs on a boosted car?
- Any good for turbo?? (cam quetion)
- Drilling turbine housing for larger (1/2") Studs ??
- B&M FPR on golden eagle fuel rail w/ Edlebrock manifold??
- Anyone Using Precsion Injectors? Need Input
- B18B1 Rebuild/Buildup Question.
- Nervous about my new set up, HELP!!
- SRP pistons? Shit??
- how much power will my trans and axles hold before breaking
- will evo 8 or 9 injectors fit 92 integra
- what is the difference between saturated and peak and hold fuel injectors
- top mount manifold revhard or ebay cast manifold?
- ? what fuel injectors should i use ?
- GSR head work.
- when to upgrade FPR?
- Is rebuilding a t3/t4 with a t04e compressor set worth the hassle?
- oem gsr pistons and eagle rods
- Second HG gone. . .
- Hondata 4 bar Map sensor?
- Bad Turbo Cuasing Low oil pressure
- How much do you think this short block is worth?
- 1" head studs....torque to what?
- nitrous ?
- Rage Big Tube or New RMF Narrow Copy w/ bigger boost JRSC?
- torque arps to what on d-series
- Turbo Kit Q's!
- s300 questions
- avcr: steps to troubleshoot?
- Opinions and Reviews: Spec Stage 3+ clutch
- exhaust hangers
- This Turbonetics T3/T4 any good for me?
- block clearencing
- oil pan problem??
- lsvtec turbo guys, stealthmode line
- Ebay Turbo Kit
- *Which oil to use on Built Turbo'd motor?? Opinions please
- FJDistributors.com gasket kit, super kits
- 83mm LS/VTEC (benson) GT35R Turbo - No Power
- Calling all MSD pro-billet owners.
- Turbo Manifold Choice
- An oldie but goody.
- what fly wheel are you higher HP H22 guys using?
- E85, any input is appreciated.
- Help A Noob Out (B Series)
- New to FI.. Abunch of questions
- Question about strange leakdown results..
- Equal Length vs. Ramhorn
- New Turbo: Intake housing outlet faces block, can i rotate it?
- DOHC ZC nitrous users?
- Need help picking out turbo
- b16a .020 over stock sleeve w/ block guard w/75 shot
- boost flow turbo kit?
- Coolant overflow keeps getting full?
- Skunk2 pro 1s vs. itr cams
- Which is the best ac ramhorn manifold to get?????
- Does any body make a Twin Scrool turbo manifold with A/C application?
- Stock LS
- Cams for Turbo Set-up
- need help on gt35r build
- boost questions
- Intercooler setup help needed for custom mani
- Well I blew my motor. Reseaching a new setup.
- Canton fuel filters..
- buying turbo tomorrow
- Anyone running an F20B turbo motor
- How many horses is too much???
- Is this turbo bundle a good deal?
- Can i have Some help with my first build?
- 35mmtial wastegate
- my turbo build
- (HELP) ITR cams in my GSR ??
- TURBO GURU'S; Is this turbo setup worth it.............
- intercooler size for greddy 18g?
- benefits of using E85 and thoughts about egt gauge
- Mustang dyno, or Dynojet dyno...
- turbo outlet/downpipe question
- TEO4H turbo ???????????
- T3 super 60 or T3/T04E 50 trim???
- OEM fuel pump and boost.
- HELP BoOsTeD D16 ????????????
- Built D16Z6 turbo options
- Turbo not spinning freely
- Cheap turbor D16y7?
- do ITR cams need ITR LMA's
- check out my timing map
- Should i switch turbos and intake manifold?
- 10sec honda with stock block
- fuel pump???
- did i buy the wrong RC injectors?
- surge or tuning problem
- What oil filter do you use?
- Boosted GSR problems........
- d15b7 Eagle rods
- can anyone identify this rod
- Turbo?
- question about my turbo set up
- K24 9:1 4088 20psi 547hp vid!!
- double valve spring
- Milky oil In my catch can
- boost reccomendation
- cant fix my compressor surge..
- performance levels of a log vs. equal length manifolds
- IHI VF34 Question?
- T3 .42a/r oil restrictor needed? no shaft play
- what does it take to get a f22b1 to 300whp
- D16z2 short block in a ej8?
- t3 t04E 50 trim
- tuning problem, or setup?
- what turbo do i need???
- turbo for d15b?
- which t3/t04e turbo for b16?
- Toda B's on a boosted B16?
- APG EK Civic K20 turbo
- Built D16 Leakdown / Compression Numbers: Results
- bought a turbo worried its too big
- ek9 h2B turbo build
- just boosted now extra coolant in overflow
- Sick of NA, neeed boost and Help asap.
- Built K-series Frank Help/Suggestions
- What is Needed to Run E85 in my Car?
- hy35 or sc61?
- What rev spring to use with gsr cams
- Turbo seals
- JE or Wiseco piston?
- Catch can questions...
- EG vs EK Question
- What are the advantages and disadvantages of an internal wastegate?
- best blockguard to get?
- oill feed line and water lines t3 on em1
- Storing a turbo?
- greddy 18g on SOHC
- B18C GSR JDM
- block guard question??????
- thicker headgasket?
- remove muffler
- B18b CP pistons on GSR rods?
- Better for my Setup?
- H22 Holset Turbo
