View Full Version : Forced Induction
- How much power?
- Think I have a vacuum leak?
- New Import Tuner model search includes a Boosted Teg owner! One of my good friends!
- is my ecu fried
- Its about TIME! many pics
- Ecu code thrown after 10 mins freeway driving????
- H22 turbo hatch.. went to dyno...263.8 whp on stock motor
- Smoke inside engine bay =(
- If turbo seals bad, how does it leak?
- when should you think about a scatter shield?
- Is Kyle @ KS Motorsports on vacation? I can't get ahold of him by phone or e-mail
- The great (or NOT SO great) TRACTION issue! FWD... what can we do?
- Car won't start. HELP!
- Common VAFC Hack Problem?
- engine build up questions
- help.. hondata with aem wideband
- Does resetting the ECU reset ignition timing back to stock? OBD II
- anybody know about kook manifolds?
- Finished Turbo project two weeks ago...
- how much hp can 96lb injectors handle
- I'm crying :( is my turbo gone due to my leaking oil
- JE pistons and honda rings??? why they dont fit?
- Possible to remove the block girdle with engine in the car?
- Whats a good turbo to run 5psi?
- GS-R b18c1 boosting on stock internals --- setup question....
- Need SMC Plus wiring instructions!
- dyno'd car, no a/f tho.. .
- How-to-install a b18c turbo??anyone?!!!
- is this the right gm 3 bar map sensor?
- Best Supercharger?
- what are signs of bad turbo seals?
- lovefab mani
- O2 Sensor in Downpipe???
- anyone using or used this turbo?
- pic request: GREDDY Type 31 IC for SOHC
- Get JRSC chromed
- gm 3bar map sensor
- Installing SOHC BEAST's Greddy SOHC turbo kit tomorrow...tips?
- Why The F*ck is my car making this sound?!?!!?
- boosted si
- which setup for daily driven low to mid 13's
- CEL code retrieving problem
- Worth fixing my B20b bottom end?
- Is This Turbo still good?
- 15psi plug gap
- Which cels wil cause v-tec to not work
- attn: E-manage users with boost
- What 3" muffler for somewhat quiet idle/low rpm driving ?
- Cel code charts for 99-00 si
- Profec-B Spec II users read->
- Copper head gaskets
- what causes your headgasket to blow?
- 1.8t head vs. b18c1 head
- HF or VX manifold for turbo?
- Turbo shaft gone...only 7 miles on it....why?
- 16.3 with 12psi on a b18a1
- Another ATTN: motormatrix mike post
- AEM Traction Control
- heard of this
- 400+ whp... post your ignition setup please.
- are iridium sparkplugs good for turbo?
- rev hard question
- turbo question
- Pivot ACS Revolution Fuel Controller
- Nitrous in vtec motors
- ZC Turbo
- timing... stock ls.. fmu
- Did I get a good set up and deal?
- Just got my turbo in today T3/60-1
- Intercooler from Boostcooler On ebay??
- Another cool downpipe =)
- How about this boosted Truck?
- open turbo
- WTF my oil press guage says 115 psi! haha.. help
- 5 wire oxygen sensor on a 87 Civic CRX?
- please help... erratic idle- rpms constantly goes from 1000 to 1500 updown up down
- help
- Slightly Off-Topic: Whos cars are these?
- help, priming engine/turbo but no oil comes out of oil return
- my ride
- 450 hp LS block reinforcment?
- Turbo kit on, car starts, now questions
- general diameter of 1G/2G DSM stock charge pipe??
- Turbo spool
- dyno pics y0
- tial 38mm fit on a 35mm flange????
- Need external wastegate help! asap!
- dump tube routing through side of bumper
- d series headgasket
- Fx%$in transmission
- yeah, wrong forum...but this is where i post, damnit
- dynoed today !!!!!! 272 WHP 223 WTQ stock block LS
- Where to get flex pipe and exhaust flanges??
- Too rich at idle!!!!
- Have a safe Labor Day weekend!!
- Del sol turbo owners with boost gauge please help
- Have any of you guys tried out a XS turbo on your car?
- Nology PDA Dyno >>>>
- ACT Clutch Break In with boost?
- JG Manifold and Throttle Cable?
- Has anyone ever tried to use a B20/21 bearing cap bridge on their b series?
- Advice from someone that is running turbo, or has run turbo.
- Neat fuel tank drain plug fact
- anyone have any probs w/hondatas200 basemap p28 550 injectors
- A little help with pistons....
- do dads for boost going in
- Greddy turbo kit install question?
- Greddy Turbo question
- Greddy turbo
- Which Intake Mani to use?
- BOV affecting MAP sensor?
- 2.5" downpipe for sohc Greddy kit
- is there anway of installing the oil line w/o tapping the oil pan?
- cheap easy to install blow off?
- Newly built H22 -- lack of oil pressure!!!
- clutch feels really soft after only one week after boost
- How cold can you go?
- 14b/t25 Oil Drain
- Low Oil Pressure after Turbo install
- New bottom end done....how to properly break in
- Rev Hard Turbo Kit
- JG vs GSR manifold
- Boosting 11:1 compression=boom or vroom???
- 2 1/4 downpipe with ecutout
- Open dp tuning
- 1 or 2 degree colder plugs... v power or no?
- where to get pipe for turbo manifold?
- need help and prayer
- JE piston help
- Block guard with stock boost?
- sorry guys..newbie question..FMU
- What years did they make JDM YS1 (gsr) transmission? HELP!!
- Boosting the swap...need guidence.....
- high boost on stock internals
- Adding datalogging to S200????
- To those who use Turbo XS MBCs
- What do you think about my set up?
- Help choosing my new GT Turbo
- where to get T3 exhaust flange???
- piece of crap intercooler piping...
- Is 85mm bore on b16 block strong enough with boost???
- Oil on #2 Plug, Compression is Fine
- DSM Injector issue, not warm starting
- fuel pressure problems
- is this normal for turbo, i tried filling oil feed manually, not able?
- How High?
- Can a Center Section be rotated??
- My Benson block and CP pistons. thanks Earl (pics)
- what is a code 19????
- torn between which turbo timer to get need help
- just turboed and having fuel problems pleas help
- stainless exhaust flange
- How do i get a lower a/f ratio
- need some advise with turbo hitting block
- Pics: AEBS / Professional Products Intake + Edelbrock 4760 Comparison
- tapped manifold for some fittings..
- *NEWS, Greddy Released a new Turbo kit!
- slight hesitation at 20% throttle and sometimes stalling/starting problem
- FMU/Intank Pump? am i ok for 2 months until hondata?
- JG Engine Dynamics Regrind Turbo Cams... need info
- Best exhaust for turbo?
- SFP Manifold ( What intake are you guys using?)
- presicion turbo owners
- RS Machine Sleeves Website? Contact info?
- produced less horsepower w/ turbo at 5 psi...
- No teflon coating on older M62 model?
- Best Piston and Rod combo for d series (bargain shop though)
- Getting started
- Best places to buy turbo kits from.
- 10 grand to spend...
- Who makes a Fuel Pressure Gauge for the AEM Fuel Rail?
- turbo oil line / chamber question, not the usual questions , something different
- exospeed sleeves are they any good
- Ready to build motor, break in CM stage 5 before dyno?
- REV HARD Stage II --- oem kit parts = blows?
- FPR
- Hytech Turbo manifold question?
- How much is my intercooler worth?
- Dyno #'s for turbo ls
- CAI as part of IC Piping.....
- How low oil has to be to light the oil light?
- 3" downpipe and exhaust
- What do YOU look like... not your car!
- intercooler faq
- Horrible 1/4 miles times after rebuild/turbo upgrade and retuning, can somebody suggest anything!!!!
- disappointing dyno numbers =(
- anyone now who makes 3in downpipes
- SMOG QUESTION n JRSC applications HELP
- manifold with 40mm wastegate flange but have 35mm wastegate
- H23 Turbo HELP
- Help on compression...
- Catch Can hook up with FI
- Well, looks like it finally happened.
- help, WTF kind of bolt is the oil sender (stock) on my 2000 civic ex????????????
- melting dipsticks, what can I do?
- Oil turning black quickly.
- What wastegate to get?
- never ending problems!!!!!!!
- Exhaust leak =(
- B&M fuel pressure gauge
- safc hack base settings ls/turbo@10-11 psi suggestions
- Turbo timer problem after jump start
- Precision Turbo question...
- Supercharger
- weird boost problem
- Got my built motor.... problems... NEED HELP!!
- driving your turbo car w/out intercooler piping...
- I have a t3 turbo .48/.42 will intercooler piping size even make a difference??
- Injector help
- Greddy Blue Box and Airtex Inline Pump
- 3 bar map sensor?? help!!
- Please help me ;/
- 3.00" Tanabe Racing Medallion or 2.5" ES oval muffler
- Endyn Catch Can Setup. Need help.
- Oil return parts
- Smog with turbo kit?
- which t3/t4 trim and AR sizes?
- My new clutch is here! should i attempt to install myself?
- ATT sellers, I need an Intercooler!
- Burning Roms: Stupid Question
- Boost Vs. Pump Gas (93 octane) when do you have to switch?
- My 91 teg for your turbo kit
- hooking up the oil sensor?
- Boost Gauges?
- Dyno result on Greddy Turbo Prelude with EMS. Need Help on fixing power curve.
- Turbo parts needed to run low psi?
- Final Engine Assembly (TONS of pics + article)
- planning for 450+hp,what head?vtec or non vtec.
- will ls manifold fit a b16 head?
- i/c piping diameter - rule of thumb?
- who runs Garett GT Series? I want to see your dyno sheet
- Am i aiming to high turbo wise?
- nitrous installation
- Dseries turbo...maing 200+ let me know your mods!!!!
- Rebuilding The HKS SS bov
- How much Timing Retard @ 8-9psi?
- Hey guys Am i missing anything for my Setup???
- SAFC And BTM installed no start PLEASE HELP!!!!!
- what boost controller ?
- 90 Integra Manifold Choice
- My turbo DA , pics
- anyone have instructions for the HKS EVC III?
- Need to Upgrade Braking System.
- oil in inlet manifold ...
- jumper for honda's
- greddy or turbo specialties?
- J&S and Hondata will it work HELP!!!
- Tuned Hondata for 91 Octane... what happens if I run 100 octane?
- what car is this turbo from?
