View Full Version : Forced Induction
- Parting out my car
- Eagle Rods Torque Spec + 25psi=SAFE??
- search for the H22 Knock sensor
- H22A sleeves
- Noticeable difference between .63 A/R stage 2 vs stage 3? (for an H22)
- sandwich oil adapters.
- couple questions regaurding a turboed d16
- Question about TiAL wastegate and the vac fittings
- thread and bolt sizes
- Who has had there greddy kit the longest!
- EGT and Wideband O2
- the difference in these turbos?
- 550cc suport 400whp (hondata)
- Some questions for the turbo gurus...
- how does runner length effect turboed motors?
- LS motor w/ B16 tranny?
- need head gasket, and studs
- 90-93 integra turbo guys.. Pics of intercooler piping??
- Arias 83mm 9:1 Pistons BRAND NEW In BOX $400shipped OBO
- Expansion slots. Turbo guys.. Take a peek...
- anyone using a drag2 kit on a 97+ prelude?
- rc440cc+walbro intank fuel pump+aem ems??? will this work?
- Installation tool...
- TurboXS High Performanc BC. Quick question.
- Best turbo cams?
- Jg turbo manifold
- what is this fmic off of?
- most reliable equal length runner manifold under 500?
- all these agony...worth it??? help me join the darkside...
- Formula for air required?
- A not so good xmas nite :(
- Big Year Coming Up for Us This Year...
- which MIG welder would you get?
- Timing and cam gears 91-92 sohc
- Hondata s200 troubles...
- What bore piston in GSR block?
- Intercooler piping?? what size??
- what would you chose?? turbo honda or s13
- boost spiking question
- Need some feedback
- ?'s and answers on : spark plugs for a 97 Turbo LS, EGT gauge
- should I go with a greddy or tial wastegate?
- Advice on Turbo Manifold
- need your comment on my sparkplugs
- Turbo exhaust, where do i get the flanges?
- I Need 1 JE 9:1 Piston in FL area!!!
- Who else does sleeving other then Darton and GE...
- Fuel system setup ...SEARCH couldnt help
- Anyone gonna do a intercooler group buy anytime soon?
- ... b18c1 with 83mm bore and ls crank - 2.0
- Where do i get an 83mm head gasket?!?!
- Vortech FMU
- Trying AFC hack... TOO RICH...?? HELP!!! (it's cold outside!~)
- Anyone running a Max-Rev Manifold w/ Deltagate?
- DIY Vacuum Fitting
- Where to get hoses and t-bolt clamps...
- Looking for a drag 3 downpipe for b-series...
- TURBO Si vids
- Where is a good place to get IC piping connectors?
- Digi 6+boost+timing retard?
- Black top DSM injectors= 390cc?
- Need Help Building My Ignition System for N2o
- Need Turbo Compressor O-Ring to complete project!
- Considering spraying on a 94 GSR...
- Question about turbo smoking
- zex kit for my crx
- turbo n00b questions...
- how do I mount my turbo???
- H22 boost...JDM or USDM?
- who sells tial replacement parts??
- Had my turbo rebuilt help sounds strange..
- What fan to use with fluidyne?
- how to polish intercooler....
- Building a custom turbo kit need help?
- What size piping shoud be used from IC to intake manifold?
- dc sport turbo manifold any good?
- Turbo crx exhaust, Opinions.
- Jet pack! check this out!
- GReddy Manifold EGT pic's
- Greddy type 31 intercooler for sohc different than type 31 for dohc si
- polished my maxrev manifold+painted piping=*bling bling* pic intensive!
- ... turbo rebuild kits
- clutch
- Some Crazy Movies...
- Merry X-mas
- Fuel pressure question?
- I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!!
- Arturbo came in,err i mean turbo from arturbo :)
- Can i do the vafc hack with dsm 390 injectors
- How much HP do you guys think i will make?
- pics of my new WasteGate DownPipe (lOOk)
- obd0 Hondata question
- can Autometer boost gauge Tee'd off from BOV's vaccum??
- Gifts from santa?
- Engine swap completed, assitance needed with rpm's!!!!
- Where does the dipstick gog on Dropshop style log manis?
- Merry Christmas!
- my goal 300hp
- Any good shops in the Sacramento/Bay area to do H22 Darton sleeves and piston/rod installs?
- Wishing everyone a grand christmas and great new year.....
- May your turbo spool quick and your traction be pleniful
- Is my block still good?
- Where can i find a 18g?
- Take a look at my turbo manifold, and offer suggestions
- ... anyone use this manifold... (turbo-performance.com)
- MESSAGE FROM ROCKET - Prepare for '03
- anyone ever have buyers remorse?
- 4" or 3" dowpipe?
- New to FI is this good setup?....please leave your feedback
- Greddy Kit.....what do you guys think
- can you vouch for boostedek?
- happy holidays to all
- Tial Wastegate... (need someone to help point me in a direction)
- Turbo timer question that I've never seen addressed or answered
- Hondata
- Stress on turbo motor
- inline fuel pump install and turbo timer questioin
- What to look out for when buying turbo hondas?
- Sorry ... but i need help with (ya) the VAFC hack
- hks type 1 turbo timer install?
- Necessity of the following gauges?
- Anyone selling a T3 Turbo Manifold
- 680cc + ems + Low Boost?!!?!
- Best upgrade for a stock turbo car
- post pics of your downpipes !!
- fuel pump probs, HELP
- anyone interested in SAFC V2??
- SRP pistons?
- Turbo Matching: B16
- What size injectors and what fuel pump on a b16 running at max 18 psi?
- what are the specs on a t2 turbo
- lowering compression with gaskets=bigger n20 shot?
- shopped around for a turbo kit and the winner is...
- obd 2.5 o2sensor
- hf manifold adaptor plate
- Front Mount Intercooler + Water
- correct spark plugs for turbo gsr?
- My Winter Project
- is 320cc RC injectors too big?
- Are these turbos any good? KKK K26 and Mitsubishi TD04?
- got my new volvo turbo in today
- About how much HP is a A/R .48 T3 good for?
- Clocking turbo, no compressor bolts...
- ok, I did a search but did not find the answer to this resistor box question
- max rev manifold
- greddy turbo kit for gs
- Dart/Payn Block Pictures
- NSX is gone.. Traded for a 95 SC400 and 14,500 cash.. FS: SC400 =)
- FS: EAgle LS Rods $300 shipped.
- Glovebox Gauges
- I got my Compression Test #'s back, GOOD and BAD
- Yet another help me decide which turbo to use on my engine thread...
- Is a Honda Smarter then us?
- CHEAPTURBO.com Garrett GT30's and GT35's now available..!
- Insanity!!!
- Turbo oil feed hardlines??? anyone???
- Missing Link Unit
- hesitation with test pipe or gutted cats?
- Good tune shops in south cali.
- Rev Hard Stage 2C 2765.00 Shipped
- Rev Hard Turbo Kits
- will a hf manifold work on b-series block for turbocharging
- ZDYNE tuners in Cali
- injectors and turbo parts for sale
- tilton clutch really cheap
- hondata question with base maps. . . please help
- best place for a t3 60-1
- Need some flanges to complete turbo!! Please look and help!
- keep the cams or no?
- WTB: gsr clutch lever and spring
- Are b series and d series slave cylinders the same?
- Question about intercoolers, efficency, and pressure drop.
- t3/60-1 or t3/t043 60 trim????
- Heres yet another completed project
- Tuning issue.. what would you do?
- audi 5000 intercooler?
- my present came early
- spiking....not holding boost with avc-r....ugh....
- HELP!! Problems with my NOS system....
- How to do a Compression test?
- "theoldone.com"s fuel pressure mod...
- GReddy kit for Si CARB legal?
- installing a oil pressure gauge....little help please?
- Comments/suggestions on JRSC
- Where is the Forced induction hybrid EG forum
- Got a used turbo, want to clean it up...
- can i use t04s for daily driven
- t-25 Garrett Turbo for sale
- H22A boosting concerns
- anyone using turbopanda's d-series hybrid/piston rod combo package? reviews please.
- J&S and Hondata w/ P28 on turbo h22 will this work
- Is it possible to put a BOV on a JRSC????
- Turbo installation, need pics and directions
- DSM 450 injectors w/Greddy's RC310 injector clips
- anyone have a turbo d15??
- sputter/miss/cut-off at 2500 rpms?
- Jotech's Dyno in finally ready
- Del Sol Supercharger
- Mounted my ic today . . . kinda depressed
- turbo prep question
- Quick injector/clip question. w/ funny pic
- What comes with turbo?
- New car
- where can I buy a downpipe flange???
- Jet sizing for a 100 shot of nitrous
- LS Tranny with GSR Final Drive
- i am a moron.
- Is it a bad idea to use this line for vac?
- Hybrid901's pic's
- 2.5" --> 3" Down Pipe (pics)
- Hit the track (12.20.02)
- VAFC hack turbo problem
- DIY piping - how many pipes?
- Pics request: H22a exhuast flanges.
- Update...Project EK D-series
- how does this setup look to the experts?
- fs 42mm Turbonetics Racegate wastegate
- we have 3 sets of 95lb injectors left anyone want them
- Max rev on high boost and stock crank??
- What size injectors and fuel pump for a built b16 that could run a max of 18 psi?
- Anyone here play Midnite Challenge?
- Turbo Bugs w/ first install: Hasn't the B16 been done enough that they're all worked out?
- What turbo to use? Please reply!
- Injector CEL when it's cold outside
- D-Series Manifold for KKK K26 Turbo
- SMC+DSM 390s ?s
- charge pipes
- new turbo oils inlets???
- Looking for a dumptube
- look how some guys bash hondas.........FI....
- zc turbo setups
- Turbo Specs
- Drag Kit Application Question???
- h22/h23 turbo
- Running a/c system through liquid-to-air intercooler?
- Where to buy: T3 O-Ring
- CheapTurbo?
- MAP senser...can i throw it away?
- Why do you lower fuel pressure to run a lower direct port shot?
- Pics of Apexi AX kit on B18B1
- pr4 ecu with hondata
- Oil Return line from turbo to oil pan...questions...
- WTB: fmic
- ::more turbo help please::
- anyone have problems with stock fuel rails breaking with turbo?
- i will ask you guys too
- F-max, Drag, Revhard
- where you guys mount your honata boxes?
- Turbo is finished (kinda)
- Help!..messed up my tial!
