Suggestions on sleeves for b18c
Old Oct 7, 2015 | 05:00 AM
turbohatch96y7's Avatar
Default Suggestions on sleeves for b18c
Css (not sleeves but cheapest)
La sleeves (local to me and 1100 )
Darton ( checking prices today)
Erl (1600)
Css is cheapest but just by 500 compared to la sleeves.
User machinist1 installs a lot of la sleeves in his machining thread
Darton ive seen used
Erl has the highest price tag
Suggestions and why
Can a mod make this a poll ??
Old Oct 7, 2015 | 05:47 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Suggestions on sleeves for b18c
I would go for Benson or Darton MIDs.
I had a block with MIDs back in 05/06 and it survived hell. Now I've got Muckmans old Benson GSR block that I'm resurrecting. Seeing how the rod let go I'm amazed the sleeve isn't way more damaged so they are definitely beefy sleeves. Apparently they have two layers of ductile iron or something though.
Old Oct 7, 2015 | 06:37 AM
No love for css?
Check out lasleeves.com they do a lot of work locally and been around a few years
Old Oct 7, 2015 | 07:10 AM
DC4KiD's Avatar
I've had nothing but good experiences with Golden Eagle and Benson sleeved blocks.
Old Oct 7, 2015 | 07:20 AM
Schister66's Avatar
Man U FTW
Originally Posted by turbohatch96y7
No love for css?
That depends on your power goal...and i didnt see one listed anywhere.
I've always been a GE or Darton fan, never owned a sleeved block, but had I gone this route, those are the 2 i'd check out.
Old Oct 7, 2015 | 07:48 AM
Mmm power maybe sub 600 for a while
Old Oct 7, 2015 | 07:49 AM
Im really leaning towards lasleeve because they are maybe 20 min from me and i can drop off and pick up
Old Oct 7, 2015 | 08:01 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You are comparing prices on some things without shipping included. Kinda makes sense since you don't have a build thread though, and don't know what you are talking about because of that. If you make a build thread then you instantly gain knowledge and experience - amirite?
It also depends on what block you are using for CSS if it is even an option... soo much information is missing from this thread.
It seems LA Sleeves is the obvious choice if you can drive to them. The only two real options here are Golden Eagle and Darton, but since cost is an obvious factor to you do what fits your budget or keep saving until you have the money.
Old Oct 7, 2015 | 08:08 AM
98vtec's Avatar
moderator emeritus
Darton East / ARFab / Howards Hot Rods.
Done.
Old Oct 7, 2015 | 08:25 AM
Sorry ive only seen a shitty crv posted from you so ill take your advice with a grain of salt thank you.
Old Oct 7, 2015 | 08:26 AM
Done.
Called ar fab and looking like 1650 total with bore and hone.
Old Oct 7, 2015 | 09:08 AM
wantboost's Avatar
Who is Mr Robot?
I'm probably going to have my F22A1 block sent to CSS. Mostly because 12:1 static compression on stock sleeves lol.
Old Oct 7, 2015 | 09:20 AM
I mean for my power level why not?
I havent read anything bad about them and read a ton of good stuff about them
The owner Seems very confident on the process too
Old Oct 7, 2015 | 09:28 AM
98vtec's Avatar
moderator emeritus
Does that include an align hone on the mains? He is very meticulous with his work and pays attention to even the smallest details. His cost is higher, but it's worth it in the end. I had him do my whole bottom end and his turn around time is very fast. Every single build is scheduled in a slot and from what I have seen and experienced, those slots don't vary much from day to day. When you sleeve as many blocks as he does every month, giving real life dead lines is damn near spot on.
Old Oct 7, 2015 | 09:32 AM
Dark_Teg's Avatar
There are guys putting nearly 1000whp down with CSS. I don't intend to make more than 600whp but honestly the biggest reason I went CSS is that there is nothing to go wrong. No sinking, leaking sleeves etc...
Old Oct 7, 2015 | 09:37 AM
TheShodan's Avatar
Moderator
Aww, damn!! I wish I could comment about my sleeved GE block and as to why, but since I don't have a build thread, I might not know anything about Golden Eagle. Not even their phone number.. Ah well..
#nobuildthread.com
More details on the process pls
Did they do all the work or just the css gaurd? Did you bore hone elsewhere?
Did the assemble the bottom end?
Old Oct 7, 2015 | 09:38 AM
#nobuildthread.com
Yes i know
You have the same block for 10 years.
Ive asked before how many miles are on it and you never answer the question.
Ill ask again. How many miles are on that motor?
Old Oct 7, 2015 | 09:44 AM
TheShodan's Avatar
Moderator
Ohhhh, so you finally found that out, eh, mate?....Alright for you.
To answer your question directly, about 75,000 miles for both circuit and street, give or take. That's with no change in the rotating assembly, save a clutch and a bearing or two over the years. Mileage on circuit racing for each event is the equivalent of giving the engine the abuse of 40,000 city miles in a matter of a day or two. (even more abusive than drag racing) So, even though its about 75,000 actual miles, I'm sure the engine has experienced easily double that from its high exposure to extreme cylinder pressures and varying temperatures.
CSS does all of his work, in-house. He won't state whether or not he actually makes the double-guard from his own hands, or sources them from somewhere else with his specifications for material, size, etc. According to his website, he seems to have the means to fabricate his own. He keeps things rather simple in his by way of keeping the best part about his system.. to himself. In which case, can you really blame him?
From what I recall, I believe he actually can hone the block to your specifications if you send in pistons, with an 81.5mm limitation. Specific honing, decking and other "cleanup" are considered as extra costs. In the long run, I think its better that if you decide that he is to perform services on your block, just let him do the whole thing, which may eat up the $500 savings that you initial have vs. sleeves... hard to say.
He's more of a fabrication specialist, so engine assembly is probably not going to be an option. But, you can always call.
Old Oct 7, 2015 | 09:46 AM
LightningTeg's Avatar
Community Builder
Sweet pink coolant hose.
Old Oct 7, 2015 | 10:16 AM
TheShodan's Avatar
Moderator
Too bad I sold those off last year for urban camo... I got those Samcos as a prize raffle for a racing fundraiser for breast cancer.
Old Oct 7, 2015 | 10:37 AM
Dark_Teg's Avatar
Your block is machined to accept the CSS, The CSS is press fit between stock sleeves and block and rest on a machined ridge, Getting the block and CSS decked is mandatory and an extra $75.00 through CSS.
I had my local machine shop bore/hone and assemble. 82mm is the limit with the CSS I went 81.5 so I could rebuild again later if needed.
Old Oct 7, 2015 | 11:07 AM
DO IT ON ALL FOURS
LOL! Was that supposed to upset me? If they suck soo bad then why does everyone want their B20 blocks and convert their vehicles to RT4WD? Also, I have clearly stated my CRV wasn't much to talk about multiple times before... Meh, still don't see anything nice from you either with your cast manifold and faded headlights, LOL!
It seems this thread (like most of yours) was only created to start **** with people. You obviously have your mind made up on what EMS, type of "sleeves", etc Which CSS isn't sleeves anyway BTW if you haven't figured that out yet. It's cool man, just trying to help you with all your serious questions?
