View Full Version : Forced Induction
- Which ARP studs for a d15b (jdm vtec)
- Zeitronix does good work!!
- FMU Mounting?
- where to buy cheap uberdata 27/29c chips
- Mounting Intercooler, JDM front.
- Fuel Flow for Thought
- Is this turbo kit worth it??
- CEL 20 & 22
- 94-97 Intercooler mounting/ed pics?
- Support bracket for T3 super 60
- Help: Motor Shuts Off When Hot
- need help with turbo
- what causes sleeves to crap out? (serious discussion)
- Im getting worried with my setup--Suggestions FI GuRus :)
- what do you guys think????????
- Hondata question
- Integra GSR Turbo Question.....
- Gone but not forgotten
- Intercooler piping question.
- greddy turbo kit for my ls= safe?
- how to tell the Ohm of RC injectors?
- Supplier of manifold parts
- yay my computer's here, w00t
- Whats the biggest compressor wheel you can fit in the E housing?
- JRSC sohc hatch is on the road!
- My dream car!!!!
- need help with injectors ????
- Delta wastegate info needed.
- boosting , but car is slower than all motor
- can running rich rob a car of power?
- stage 3 skunk cams w/boost
- Radiator clearence w/SFP mani..?
- turbonetics t62-1 or garrett t3/t4 on b16
- R5671A-8 ngk's sounds right for turbo gsr?
- turbo plug??
- High Comp, Big Shot, Daily D, Ultimate All Around Thread!!!!
- wastegate with 8psi spring opens at 13
- stock sleeves w. forged pistons
- hondata question
- How to tell if an Intercooler is good or not
- JRSC B-Series Questions
- Can someone check my list?
- Minnesota: Free B18B1 motor and other stuff
- DSM Injectors, clips, resistor boxes.. clear it up for me!
- built the block and now car wont run ,
- if i wire my reistor box wrong will my car still start up ?
- greddy E- manage
- 200HP SOHC
- **South florida Performance mani...
- some pics of my turbo crx
- who has a Clutchmasters FX500???
- g-tech pro ss
- b18b or b16 turbo. daily driver, stock internals.
- Turbo ls teg wont start again!
- FMU questions?
- Noob Question: turbo s2000
- does anyone have evidence that compression affects spool time??
- t3/t04e or gt32e(gt3255e)
- In YOUR opinion, what's the best A/C Compatible manifold
- ARP head studs torque setting
- tranny question
- Unpluged O2 sensor but no check light WHY!!
- onefab mani w/ stock radi
- When you tune your freshly built turbo motor......
- Quick questions need answers fast!!!!
- Anyone making over 700whp on just turbo here???
- What kind of bolts come with Crower Rods?
- How many times have you sohc guys blown your headgasket?
- prelude skunk2 valves
- Full race turbo kit in gsr
- GReddy type-s bov.... soft/hard bolt came out, help plz
- Recommend a clutch please!
- boosted sohc timing question
- What would be the best turbo setup for me??
- uberdata D15Z1.. i think im cursed! 14.7-20+ A/F... WTF?
- T3/T4 Turbo Rebuild torque specs needed
- Turbosmart E-Boost.... any info (did search no info) Good or Bad ?
- What could be the problem?
- Is 200-230whp Possible w/ H23 + 14B?
- Greddy or Edelbrock Turbo kit
- D-series HP limits
- high boost helllp
- b16 turbo: want to use je pistons, but which one?
- t25 value
- Hallmna Pro RX Kit Boostcontroller... What do you think???
- how to use profec B spec II?????
- Accord F22B Turbo Kit.... Whats Best?
- clutchmasters stage 4 clutch?
- can we see some engine bay pics with jrsc.
- showing boost, but car is slower
- Action clutch help!!
- Can the e-manage datalog a/f?
- CEL after car warms up... anyone have some advice?
- TURBO F22B1
- Whos D series is making the most power on here now?
- Quick CAT question>
- what do i look for? broken fmu
- performance auto tranny for 00' integra ?? who makes one? richmond? TCI? etc...
- I need help on choosing some CAMS
- Ground Control Springs
- 400whp safe to tune on stock suspension?
- Apexi Safc, Profec B specII inital setup?
- Homemade turbo gaskets???
- Ran the B20 tonight, 12 Second Club!
- JR FMIC 5'' fitment on 6th gen????
- AFC not working. searched!
- Radiator Cap Lb Rating?
- My friend's ecu randomly died...
- sputtering and cuttin out around 3500rpm
- homemade mbc:creeps when not warm?
- Does JG/Edelbrock make an Intake Mani. for the PR4(b18a/b) head?
- FMU guys check in please !
- JE Forgies and Total seal Gapless 2nd Rings
- GT35R vs. t3/t67...
- help me explain how big a T66 is...
- tial bov spring rate
- Greddy install WHITE Cable B/C IN (TO MAP)
- internal & external wastegate
- Cybernation turbo on an RSX type-s
- low on oil after 1,000 on turbo
- My bov wont work
- Dyno (blox manifold)
- direct port VS fogger
- Timecerts or helicoil
- Passing SMOG on a built block
- OK to soak a turbocharger in solvent?
- full-race crew is off the hizzle for shizzle
- Availability of pulley for D16Z6 JRSC
- home depot couplers safe for low boost level?
- Wastegate vacuum source.. questions/theory
- Links to HM greddy boost switch?
- JR supercharger, alternator pulley for 14psi - which size?
- zc1.6 with greddy turbo kit. which fuel pump walbro 190 or 255 ?/other greddy ?'s
- A quick simple question.
- what do ya think about my gaskets
- FAO: speedie (or anyone who has his email address)
- msd digital 6 compared to the traditional msd 6al?
- Mase Tuning Bash Northern & Southern CA / Dyno Day 12-29-04 @ Modacar
- drag turbo kit
- Pix from SEMA of FF Geoff's Full-Race booth
- about to buy this boosted accord, need advice on a specific...
- will NOS jets fit a ZEX kit?
- question
- Tial 46mm Wastegate dimentions
- Turbomanifold flange hole too big for wastegate hole and gasket hole??? HELP
- where did you guys mount your boost controlers post pics!!!
- Dyno comparision gt3071 vs gt28rs
- whats the new hot s@#t???
- help me please!!! Start-up problems
- 9.8:1 vs 9:1
- s-afc-how good of a tune with wideband
- End of day one on my turbo install
- please post up under hood shots of your I/C piping in your SOHC ninjas.
- stupid downpipe question
- T3 Turbine wheel size
- Precision sc34, inline pro mani, tial wg, downpipe, oil line, egt gauge and probe, c/f bezel for civ
- Finally installed my intercooler!
- what clutch would be best?
- Differences in b18b1 and b18c1 JRSC kits
- How much hp before ditching the stock radiator?
- ****CEL CODES PLEASE HELP!
- greddy turbo kit for 96-99 fit on a jdm 95 engine?
- AEBS sleeve question
- Vacuum Line Pics
- Built bottom end, prices with b series
- 400whp on stock d sleeves?
- Help diagnose smoking and ticking issue...
- Turbo sizing and hp goal questions... Help if possible...
- Will FMIC fit with factory fogs?
- turbo question
- High impediance injectors in a low imp car???
- trouble boosting!!!
- Drag 3 Turbo specs?
- Best ECU for turbo setup?
- fully built gsr
- Build up my 94 jdm integra GSR for more boost capabilities
- Stock d series sleeves + overbore
- 5 bolt vs 4 bolt housing
- where to find turbonetics t3 5-bolt flane???
- UBERDATA GURU's..a ? about datalogging cable..would this work?
- is it my valves ?
- tuning Greddy eManage in socal
- Emergency...installing BLOX IM in GSR-97 and get engine check etc
- who has bought from SSAUTOCHROME before??? and r they good or bad??
- GT 30R Project: My Trip to the Darkside (An Update)
- piston rings mite be blown plz help...
- is this almost turbo setup any good???
- searched: h22 NITROUS question
- Boosted or non, how do you get ride of CEL 9
- vafc 2 with 1994 H23VTEC Prelude Turbo settings with 550's? (I searched)
- Oil breather canister/catch can question
- New Forced Induction Moderator
- exhaust recogmendations
- Wastegate dumptube bolt size?
- timing issues and tuning my teg
- Any Uberdata tuners in Canada?
- Problem with injectors...thoughts?
- valve adjustment for turbo ls/vtec
- is there a certain kind of exhaust for turbo cars?
- From N/A to forced induction
- install question
- Zex dry Kit: 101
- d-serise greddy manifold
- I call bull-shit... 600hp @30psi (on 91 octane DSM)
- turbo kits
- Uberdata datalogging cable? (nokia style) Need a part number and place to get it.
- HELP AGAIN...Take a look at my cylinder wall!
- Does anyone make B Series log manifolds anymore?
- 200 whp b18b
- Hard starting with DSM 450cc - To much resistance? This fixed it for me.
- making your own oil lines
- Painting an Intercooler
- Irran Jolly and Eric Del Rosario(goldmember) Exospeed sponsored Race Engines
- del sol
- 15psi safc no CEL
- what do i need to run 1000cc injectors/ max amount of psi for tial bov?
- GREDDY "bolton"TURBO kit on a crx d16 ZCmotor
- Head gasket for a b16a JRSC 91 CRX Si?
- prelude 2.3 turbo engine build question looking for suggestions
- boost and vtec hesitation HELP!!!
- golden eagle block guard without hone?
- UPRD - UPSD?????
- OBX 321 Stainless B-Series manny (close-up pics inside)
- Best B-series manifold for $800???
- how much h.p. you think a td05 is making on stock ls at 15 psi?
- proper thread type for oil line
- does the "Supercharge your car for 69.99" add piss anyone else off as much as me?
- where can i get a gt37 for a good price
- bent valve?
- LS Supercharger
- shes blows
- h22 fuel pump in a civic?
- spraying B20
- Anyone running Full-Race Stage3 kit on their B18b1's?
- powder coating an intercooler
- Revhard turbo specs ????? ---------- what trim, a/r
- Best block sleeving companies/brands/shortblocks...
- conflict with manifolds
- ls rods in D why not gsr rods in D
- carb cleaner white boosted?
- greddy e-manage vs. vafc
- t3/t04e on b18
- Stronger mounts for 7th gen civic?
- LS turbo project completed(56K warning)
- What piping to buy from JCWhitney?
- Head gasket and head stud reuse???
- wideband o2 reading
- Cybernation Block Guard K20
- Need your opinions
