Intake Manifold upgrade
Old Oct 8, 2015 | 07:16 PM
josediazz94's Avatar
Default Intake Manifold upgrade
So I have a 92 hatch fully built and boosted. I was wanting to get a bigger intake manifold. I'm currently running a skunk2 pro series intake manifold. I was looking at either a skunk2 Ultra Series IM or Golden Eagle IM. If I upgrade, will I have to tune the car again?
Pro series
Old Oct 8, 2015 | 07:32 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Intake Manifold upgrade
There's no point in upgrading if you aren't going to retune to take advantage of it.
Old Oct 8, 2015 | 08:15 PM
boosted94gsr's Avatar
Yes a retune is absolutely necessary.
Old Oct 8, 2015 | 08:52 PM
TheShodan's Avatar
Moderator
And the only reason to upgrade is if the entire setup is changing from turbocharger to purpose of car. Otherwise, your wasting your time.
Old Oct 8, 2015 | 10:30 PM
Alright, I think I'll hold off on it for now. I appreciate the help!
Old Oct 9, 2015 | 02:48 AM
LightningTeg's Avatar
Community Builder
Curious what the goal is? You'll sacrifice whatever low end that D series has for more peak numbers.
Old Oct 9, 2015 | 04:02 AM
wantboost's Avatar
Who is Mr Robot?
Yea unless you're trying for SFWD power or something a manifold with a larger plenum and shorter runners is going to kill whatever midrange that D currently has.
The Skunk2 pro series is more than enough for 99% of the builds you see. Most people buy overkill **** because it's popular or looks cool to get show points and talking rights with little care or concern for actual performance. Just like the guys you see running 6262 or larger turbochargers that don't even make 500hp. Bigger turbos just look cooler.
The smallest 3.5l plenum is for applications up to 600hp but on lower power applications it murders midrange. Not to mention that it isn't designed to run small diameter throttle bodies and the B series guys running a 90mm TB on the Ultra have run into drivability issues regardless of power output.
95_red_dc
Oct 11, 2008 10:07 PM
existanzcivicb20
Mar 23, 2006 11:28 AM
boostd ls
Feb 6, 2006 02:36 PM
zattypleat
Apr 21, 2005 03:51 PM
