View Full Version : Forced Induction
- This is what happens when stupid people drive........
- Rant: Sick of baker precision
- i need opinions on injectors
- anyone has turbo JDM sir B16a
- Lets try this again.
- which fittings to use for oil pressure on back of block
- I need a pic of this please
- GReddy O2 sensor....how long will it last?
- Turbo R watcha think of this setup?
- Anyone here have a XS Engineering turbo?
- drag g3 turbo
- Is it a good idea to port out the turbine outlet hole to WG on a Turbonetics style T3/T4?
- Vtec and Turbo......go together well.......
- What cams in turbo B18C1??
- The future of Torocharged
- Why Doesnt Greddy Make a Turbo Kit for 2001 GSR?
- The motor stop in downhill when braking.
- Boosting safely--98 civic sohc??
- Quiet blow off valve?
- centerforce clutch?
- What do i need to complete a Turbo Setup?
- InlinePRO turbo manifold $539+shipping for honda tech members!!!!!!!!
- Integra GSR Vortech Dyno results
- Where can I find a JRSC 9psi Hondata map???
- greddy turbo kit with lightened flywheel
- Can I oil my turbo from an oil filter sandwich adapter??
- Greddy Turbo on 95 civic ex
- Turbonetics Stainless Turbo Covers...
- fs turbo manifold for d motor
- ok, another hondata question..
- Valve springs upside down - re & Re????
- What's needed internally to up redline?
- How much boost with Greddy Kit w/out Intercooler?
- Advanced FI question
- Basic FMU
- Chrome compressor housing...
- Can an AT handle SC/Turbo/NOS
- just hooked up an oil presssure gauage and got unusual results...
- Is the Blitz BOV Interchangeable with the Greddy Type S?
- je 81 mm
- newbie question
- check valves
- Pigtail to tee on firewall- enough pressure???
- what is needed to run hondata 4b with jrsc
- Who here has a JRSC on a B16a hybrid
- Greddy 18g upgrade<did a search>
- I'm looking for ....
- Lots/New/Better Pics of my Portflow worked head
- HKS SSQV
- USED Crower rods or NEW Eagle rods (B18C)
- good vaccumm source for wastegate on gsr
- d16a6 ( built- 0 miles)
- Intercooler Maintence
- What's the biggest bore the OEM head gasket can accept?
- line locks
- How much for clutch install?
- Ball bearing turbo?
- TO THE NJ GUYS PLEASE READ!!!
- TURBO MUSTANG, check this out!!!!!!
- 3" thermal exhaust
- Need car inspected in NJ...can anyone pass me???
- jrsc on D16Y8
- D16Z6 turbo dyno's
- Turbo Manifold???
- Anyone here ever blew their B18C by adding a turbo kit?
- I just needed to brag
- Who makes a 83+mm piston (turbo app)
- hondata +310cc=whp??
- how much nitrous can i use?
- boost+ valve cover breather=?????
- Alamo in Arlington TX?
- Generic enigine design question
- what is and o ring???????
- whats a good ecu program to run??
- downpipe question
- just some updated pics for ya guys (56k beware)
- Turbo Trim
- Need help posting Dyno sheet
- Does anybody here have a Exedy Organic clutch with their turbo?
- Q? on 92-95 greddy kit on 91 civic si
- compression ratio for turbo'd engine
- 3 inch exaust spool faster
- Z10 radius arms and intercooler piping!
- does 300whp make 3rd gear spin
- turbo or nos??????
- DSM injectors?
- Apexi turbo timer install?
- Guy in shitbrown truck + Package on doorstep =
- what NGK plug part # to run on Greddy turbo kit?
- losing boost...??
- Z10 Block Girdle?
- which one should i turbo b20 0r b18c1??
- break in period for headgasket?
- turbo b20??
- D16Z6 bottom, D16Y8 top with Mistsu TDO5H. what to expect?
- What Stops you?
- hondata?
- Can i get a wastegate actuator set for 6psi???
- Need help w/ my Blitz SS bov
- drag kit fit in my hybrid delsol?
- NOS help?
- Turbo a Ls or a B16?
- Keep DRAG kit or go custom????
- Gasket for Greddy turbo
- 310cc injectors w/o fuel control?
- the winter-story of my car
- What is your turbo LS setup
- Wasting more gas with bigger fuel injectors?
- T2/3 or T3 for B18C
- Misfiring at idle with Greddy kit....what could it be?
- FS: Front Mount Intercooler
- what can cause an oil pump to fail?
- What kinda power from a b18c1 w/ jrsc
- where do i fill the bottle?
- Braided fuel line (filter to rail). Who did it?
- Mugen wheel weight?
- FS: haltech...
- making a drag manifold streetable.
- What gasket to get for 14 PSI car? OEM or aftermarket?
- Problems running 12-15 psi and carge pipes!
- Is this a good "upgrade" for a fuel system?
- B20 water jacket
- fuel cell questions, whats the legality
- O2 sensor +racing gas= any good
- Fuel Pump "already searched"
- white smoke at idle
- Crower = blows
- Rebuild...more disappointements
- Did Maxrev make a D series turbo manifold yet??
- Turbo planning
- Anyone have results of the first race in IDRC LACR event
- Please give me your opinion of this...
- Upset, frustrated, and disappointed with my Hondata 2B - PART II - RESOLUTION
- HELP me make the right boosted b20/vtec decisions...needs some reassurance here
- Max Rev Manifold question
- Anyone selling their Max Rev Manifold?
- How bad to run wastegate w/o the gasket?
- Which Turbo manifold will clear the A/C?
- anyone using an oil cooler
- Pic of Inline Pro Turbo manifold
- Wide band tuning
- one more time only, i promise:between these 2 manifolds...
- TO4B to big for a LS?
- Greddy E-manage
- My set up so far... Any Reccomendations on what else???
- where can i have a hondata 4B dyno tuned in NY,NJ,CT area?
- Got pics of my ZC turbo setup...
- GOD DAMN.... anyone a master a pipes? Dustin, ART or BEN
- Deltagate wastegate question
- Turbo + Legal Problems in Cali
- Where to buy....
- oh well my stock clutch is now slipping....
- reuse head gasket
- My car's new smile
- 300zx Turbo Mini-me Completed!
- Timed Civic/1.8L For 1st time!!!
- texas shops for turbo R's
- Running 8psi
- Engine check blinKs???
- Turbo Kit List
- 92 SI: what color is the TPS Wire??!?!?!
- High vs Low compression
- OT: Does a turbo have that awful intake sound?
- Got my car back and HAPPY as F@ck!! Hondata all the way!!
- need help on oil return line on greddy turbo
- Anyone have a 6800 rpm pill sitting around? From MSD?
- Greddy AF meter users.. please look
- Opinions on AVCR.. Pros & Cons please.....
- Torque specs
- anyone running a t-28?
- Greddy Profec B??
- quetion about greddy gauges
- Greddy Blue box and VAFC
- Hondata Tuning Experience
- SDS engine management
- To those with apex turbo timer......
- does this set-up look good to you or would you add anything??
- Best Place to find a T-Rex or Bosch inline fuel pump...
- is drag 3 kit reliable ?
- BAY AREA Dyno Day meet. Need a head count.
- oil setup question (not search related)
- questions about max rev
- JR SC type R ,or JR SC GSR??for my 94 civic hatch?
- Well guys, my 60-1 nightmare has officialy started!! :(
- I guess I know how those N/A guys feel when picking cams out...
- Can you list all parts needed and prices for Best Peiced together turbo kit.
- Slicks
- FMU Chronicles.....loosing faith in the turbo
- Crower's site... "JE Pistons" what are they?
- Popping sound when i shift...???
- Best motor mounts?
- is this ok??
- what kind of ignition control and coil should i get?
- Has anyone ever jet-hot coated their turbo?
- How well does the Blitz Dual Turbo Timer Boost Gauge work?
- Where to buy BPST fitting for oil feed?
- wrx stock turbo gauge thingy
- Which wastegate would u rather have,HKS or Tial
- Drag Gen II vs Drag Gen III
- my new engine!
- the 11th September of my car
- When i press the throttle...it makes a tick sound
- Help with fuel system
- What is the fitting on the inlet of the Airtex fuel pump?
- For those that rebuilt their b18c5 block with eagle rods...
- ready to increase boost..needs help
- Calling Arturbo
- Field Vtec Controller for Fuel Enrichment
- anyone here used a chrysler turbo?
- victor x intake manifold
- did i f*ck my engine ?? hiks
- Any benefits??
- WHAT SIZE FITTING FOR OIL SUPPLY LINE??
- is ball bearing upgrade for drag gen3 worth it?
- BBK 70MM Throttle body
- How much does your Civic/Integra coupe weigh?
- Please post first driving impression after installing turbo!
- Do you guys have your fuel tanks tapped for an inline ?
- bad turbo seals
- I am opening a shop and needed some suggestions for distributors...Thanks Guys!!
- Anyone have pics of Thermal 3' exhaust on a Teg???
- who installed a nitrous system themselves? help
- Ok, RC injector fitment again
- The difference in turbos?....T3/T4 & T4 ?
- Please Help with a Bogging issue!
- rebuild turbo?
- what specs for turbo?
- greddy vs. autometer.
- **B16 OIL PAN ON TURBO LS??**
- Turbo newbie...... Joining the darkside LONG
- No Vtec?
- whose running the new BFG drag radials?
- Question about rebuild & turbo
- weird humming/hissing coming from under car.
- Bay area dyno day?
- Blown Pistons -- Ring landings breaking more on intake side?
- SoCal Dyno Day Schedule
- ngk spark plugs differences?
- Hondata B16b turbo Base Map for a pw0 JDM ECU
- What's the costs of a well built B20/Vtec Turbo good for around 350-400hp?
- What will this setup put down at 20psi?
- JUST REBUIlt..HELP!!!!
- lenso rims
- Some Pics and an update on my Turbo Integra.. 400whp or bust thanks to Polk Performance
- NPT and BSPT explained.
- AEM EMS Setup
- THE best place to oil turbo from?
- lph of the DRAG III fuel pump
- Wiring schematic for blue box on 96-up civic?
- already did a search...please help
