View Full Version : Forced Induction
- Intake Air Temps
- Hondata, lowers prices
- H23a Headgasket
- Which turbo for my B20?
- Kiwi Turbo Manifold
- EGR Block?
- To Vortech FMU users
- what should my timing be set at to run 10psi?
- DPR Racing Headwork
- converting internal wastegate t3 to accept external wastegate
- Oversized Valves........
- WANTED: AFTERMARKET SPRINGS & RETAINERS 4 B18A HEAD
- pilar mount gauges.
- FS: New hondata 4b and programmer for $1200 shipped
- Help, only getting like 15mpg with Turbo on 98 gsr
- FYI: Great place for Earl's fittings!
- injector size in a boosted applications
- LS guys where........
- Inline fuel pump for turbo
- Boosted Automatic Drivers
- FS: garrett 5 bolt discharge flange
- Search Not working! Quick ?
- JRSC and compression ratio
- Kiwi manifolds? Are they good compared to others?
- Maximum Boost!
- looking to trade my 12:1 fmu disc
- Not so nice sounding sounds when boosting
- Boost question *help*
- tial wgs hey guys check the top post
- WTB: 92-99 civic cx tranny
- some pics of my sh!t
- roots-type or centrifugal supercharger??
- rod bearing sizing question
- Anyone running a .42I/.48E T3 on a Dseries/ZC?
- where can i get a mister sprayer or my intercooler online?
- Oil Pan Help!
- What do you think of used JRSC & Nitrous instead of turbo?
- Hondata 4b
- spraying in fifth gear
- Fuel pump question and best price on an fmu?
- Cheap/good place to buy Thermal R&D 3" for Integra? (Already searched)
- Who said dsm 450s fit in 88-89 DOHC teg seals?
- Thinking of going Greddy...help me out guys!
- Pic for the Black intercooler people
- fmu rise rate (disk)
- greddy turbo on ls ?
- Hondata OBD0 Question
- Got Greddy papers? How about the CARB sticker!!!
- HEY! selling a missing link?
- 10.64 seconds at 127 mph set in Bakersfield CA.
- How to select A/R?
- FS: RC 370cc injectors, Brand New
- pics (and how to run) of my SFP manifold on my h22a
- does anyone know how to setup the scramble feature for the APEX AVC-R?
- Nitrous and JRSC
- NEWBIE to nitrous..i know you hate n00bs but help me out please!
- need help on setup, suggestions welcomed..
- How to: Save your turbo at the drags for under $5
- turbo timers, options?
- How much to "gap' the NGK range 7 plugs??? Please help!
- Overheating Problem
- msd6 btm or jrsc btc? help me.
- ARP head studs for GSR.....work in b16? <help>
- clutchnet stage 4 and clutchnet flywheel
- What spark plugs do you use on FI cars?
- Help on the DRAG kit
- Fuel cells
- is something wrong with the search on this board....?
- greddy turbo peeps
- Anyone with a Greddy 52mm boost gauge
- 440cc injector limits
- Where to tea for boost gauge
- Christmas all over again !
- Can someone answer this please
- Revhard trim sizes
- Boost dependent Fuel Regulator.
- OT: Tech Support Issues
- turbo rebuild advice
- garrett group buy 4 bolt flange
- To lean?
- Pauter rods
- (Tried a search) JRSC or Turbo in ITR?
- Should I get a JS Safeguard
- Parts I will still be able to keep when I go turbo ?
- how big around is the drag3 downpipe?
- how big is the greddy evo piping?
- hesitation between 6k-8k rpm?
- Airtex pump that comes with drag gen III kit what is hp rating?
- Cat removal (searched already)
- Can someone help me with a partslist for the oil send line?
- Wastegate dump pipe
- 440 saturated or 500+ p&h ?
- What do you guys think of my oil feed setup?
- Post your PURGING pics.....
- tilton clutches last chance to order below retail prices
- Turbo Installation
- Hondata Question
- Wastegate Gasket
- Spring Sport Compact Nationals- Moroso Park 4/6&7
- search down...what clutch
- People using Power FCs?
- how do I find out how low to make my comp./how high boost psi for max. preformance on pump gas
- Anyone using poly motor mounts? Like them?
- Custom Turbos
- Whats the best bone stock motor for turbo?
- oil line to turbo.....
- Oil return line
- a/f meter is f#"/! up car bug like hell
- anyone selling a maxrev downpipe compatible with a.c?
- Difference between b18b turbo vs b20 turbo?
- JRSC on b18c???
- Drag gen III kit come with a -3AN now??? Mine did...see pix inside.
- b18c stock sleeve whp max???
- need help deciding which intercooler
- who sells ross pistons?
- How much tq can my stock clutch hold?
- the b18c5
- What oil pump gear would you guys buy? (If you had to)
- OT: Identify this fuel rail.
- Is my power goal attainable?
- TURBO ON AUTO-TRANNY
- previously boosted engine???
- Has anyone done this before? Homemade flex pipe made out of exhaust repair kit. Pics
- Tech question: Setting TPS sensor
- Open downpipe....can you still hear the bov?
- OT: I think I got ripped off...who knows Mark Bremer(performance R&D) from Utah?
- Tell me more about these two turbo's. Graphic intensive!!
- Flowmasters or Magnaflow???
- 3" downpipe
- Where can i buy a test pipe to fit with my downpipe and thermal exhaust.
- Will I break something? (no flex pipe)
- turbo timer, radiator fan
- Drag Boost dependent FMU fuel regulator
- Grand National? does it have 3 bar map?
- installing a manual boost controler
- oil leaks suck!
- anyone with a ls engine pumping out 400+ hp?
- where should i tune my hondata in s. cali?
- race-eng blockguard install/ its loose!
- What happens if the polarity is reversed on an intank pump?
- more tranny questions
- Any good 3" exhuast besides Thermal?
- SFP Mainfodl ?????s
- POST SFP turbo PICS!!!
- your 1/4 mile goals
- Greddy and Hondata Dyno
- Misc pics of my turbo
- help with turbo buildup, b18c or b18a?
- OT: I love Importparts.com
- help on the missing link for map by-pass
- Fuzzy Logic on their Boost Controller?
- greddy turbo timer for a 94 civic
- what fuel pressure readingsdo u guys get at idle with your stock pump+inline?
- Ceramic Coatings
- Kakimoto 3" exhaust
- Cheapest prices for 52mm Greddy gauges?
- 1/4 mile times
- need some pics to show how to mount Apexi front mount on 5th gen
- boost controller??
- wtb: fuel stuff and ic + misc.
- Picts of Greddy FMIC??
- Homemade remote switch for Profec B
- boosting b18c1 w/ a PO6 ecu???
- jdm b20b soon to be turbo. anyone got dyno sheets
- Wide Band Fuel Mixture Display Oz DIY-WB HELP
- Greddy Profec B cheeeeep
- Where to find a harness for MSD 3-bar map?
- I'm bored! Here are some big pics!
- i f_ed up somthing help me out please
- 2.25" piping, why?
- T3 60 trim
- Greddy turbo install help!! cant bolt down the fuel rail...help!!
- max hp on stock rod
- exhaust and intake piping
- VAFC HELP! (did search)
- Anyone running a DRAG III on an SOHC Vtec????
- Can exhaust configuration affect the idle revs?
- Should I buy a used jrsc with 15k miles on it?
- Pics of New Setup
- Installed the Hondata 2B w/RC440 today
- Can anyone get a deal on SFP??
- who has a mechanical oil pressure gauge with a turbo setup, what readings do u get?
- replace dist?
- 2nd gen GS-R w/ turbo??
- Kakimoto or Thermal
- Anybody have experiences with a 75 shot in an Integra LS?
- what do my plugs look like to you?
- Anyone interested in a inlinepro turbo manifold groupbuy?
- Pics of a Drag kit on a b16a?
- meziere water pump
- Turbo installed, transmission hates me
- Exedy clutch Question
- OK...need to find the original post on AFC hack.. search yeilds nothing
- Got a setup of upgraded rear control arms for 96-00 civic SRR TOP FUEL JAPAN MODEL
- maximum boost!
- Got some Goodies
- Hondata, JRSC and No Dyno
- a quick question
- another colder spark plug question
- this is what i have for my set up so far.......what else do i need???
- JG Engine blocks
- AEM Plug & Play
- Help blown engine or turbo?
- 550cc inj w/o a resistor box
- JG Pro Series vs. Redline Series?
- Chip for Nitrous?
- Question about increasing piping diameter and boost spike/rise...
- Blitz SBC-Id and power meter question/
- Civic going turbo, need to know what motor is better B16A or B18A
- 94 auto accord sohc vtec........turbo options
- where to buy plugs on line cheap?
- Just curious.....what is your favorite sounding bov?
- Max psi that can run
- replacing stock distributor
- Blow off valve
- Which head 2 use on built drag car??
- Clutch Break-in Period
- analyze this for me...
- Horsepower for DRAG GSR at 7 lbs???
- D16 SFP Manifold Pics! Give opinions please! (56K beware!)
- turbo question
- ***vortech Si dyno vid**
- where can i get an internal wastegate that is set 1t like 4-6 psi?
- egt reading???
- JRSC+Injectors?
- anyone know...
- safest turbo kit
- Need help with Greddy Turbo + Intercooler install
- Few more turbo install questions
- final drive on JRSC engine?
- Is the oil return line kit gonna happen?
- question
- It's true.. bigger piping is better!
- what type of injectors
- How to find A/R size on used turbo ?
- Do you have to use water cooled or can you skip it and just do Oil?
- defying physics
- Best place to order gauges? (did search)
- AFC hack work with an MAF sensor?
- 99EX Turbo Kit
- does ur car goes .....
- Aeromotive FPR 1:1?
- civic 2002
- Which tranny for street driven high horse gsr engine???
- wooooooooooooh!
- Are gsr cams better than b16a2 cams in a drag3 b16a2 setup?
- WHHAT 3" EXHAUST DO YOU INTEGRA GUYS RUN? 1994+ CAT-BACK
- well, it is almost done....... :)
- vortech aftercooler with turbo?
- Quick compression/piston question.
