View Full Version : Forced Induction
- Best oil for turbo? 10W-30 Mobil1 Tri Synthetic?
- D-series Turbo Manny
- Hondata Launch Control & Full Throttle Shift
- Darkside is slipping away!!!!!! NOOOO!
- Boost? Turbo?
- how to swap wastegate springs
- Pink LS main bearings upper and lower.
- people running T3 super 60
- The last step on my install... need fast help with one more thing! =/
- Need flange for a blitz BOV!
- Who ever paid for the Prodrive Gears GSR/Bseries
- not Honda but FI related, JRSC guys how do u REMOVE pulley?
- brown lower LS main bearings
- If you boost spike, how can you tell if you messed up your motor?
- slimline fans
- Some Pics of my newly modified Pistons (not coated)
- Hondata VS. AEM EMS's
- Installed spark plugs, and TERRIBLE gas milage
- Boost Controller setup.. READ THIS PLEASE
- vafc or hondata?
- Turbo Compressor side a/r ratio question
- Anyone heard of Westach gauges????????
- Integra (LS) - FI Question
- Attn: Max Rev manifold and 60-1 turbo
- DRAG Gen 3 Turbo Kits Back In Stock!!!
- Do i need a boost controller?
- just thought i would show you guys the latest pic!
- hondata plus stock internals =?
- B20 hybrids..which turbo?
- is the cheapest act clutch kit good for up to 250whp?
- Just purchased Moroso Oil catch can. Need help hooking up!
- Stuck on install again, need help.
- How much shorter is a Deltagate than the shortest Tial Wastegate?
- Max boost on stock LS rods?
- some quick questions
- count on people going to MIR on the 12th
- GReddy Turbo Timer How-To on an Integra
- finally got turbo from import parts
- has anyone ever use the moton suspension setup
- futuresi = future boost junkie, What should I do
- for those that wanted the JE pistons please go to the classified section
- Greddy blue box and V-AFC together anybody tried this?
- custom turbo manifold
- Opinions on the M42 .48 a/r Garret?
- I just got my turbo....and a promotion at work! ROCK!
- drag 3 DP.....tiny
- water injection?
- Taking it to the track...how much to boost with race gas?
- Website For Building Custom Turbo Kits!!!!!!!!!!!!!!!!
- SOHC Turbo project pics...
- Ghett-ology performance and my homemade turbo
- Kinda OT: Can you 10psi guys beat a Vette?
- Hey.. help guys.. ignition problem.
- whats the truths bout boosting????
- Dyno Results - Bad, Very Bad :(
- Cheaper way to buy a turbo, Peice by Peice, or Kit?
- OT: Turbo Escort!!
- What does a TIAL wg sound like when its venting
- my new gauges setup
- turbo sohc
- how do you clean up a motor?
- just got greddy kit, what else do i need?
- If someone spun a rod bearing...should I buy the block
- Break In Times for a new turbo kit?
- autometer sucks, what about blitz gauges?
- installing a/f guage.....where's the O2 line? and how do i tap into it?
- In need of turbo knowledge
- idle problem with 310's in a zc
- Went to the track kind a dissappointed:
- Turbo kits then Custom?
- OT: anyone from PA going to the NHRA races in ATCO NJ?
- why do BOV's and wastegates invalidate smog check?
- OBX fuel rail
- hooking up an oil cooler to the turbo
- Is a wastegate necessary?
- T3/T4 and Drag manifold for sale
- Look what I am getting tomorrow!!
- brakes question
- SR20DET project pictures
- install help with pics please
- How far can I go with the walbro 255lph?
- New Product in the Works...
- Stand Alone ECU - PMS vs Hondata
- For those using the J&S dual monitor...
- Another mid-install question, please help quick!
- b&m fuel pressure regulator
- how bad is it to have a 255 pump if it's not needed?
- Any Turbo Accords?
- i need a link to that website w/ exhaust parts... flexpipes cats etc
- Where to Mount oil cooler on turbo'd car with intercooler?
- Anyone using the 92-95 Apex'i Turbo on there civic?
- What 3" CAT-BACK exhausts are available for the 3rd Gen Integra Coupe? Help ASAP!
- JE Pistons(not SRP) sale!
- AVC-R people..HELP-(Pritos)!!!!
- Which Turbo is bigger?
- Turbo, Hondata, and Full Throttle Shift Issues.
- integra turbo
- Just pulled my head - ugliness inside, need some opinions
- B16 turbo-- gsr or ls tranny?
- Double clutching/Heel and toeing with Turbo, can it be bad?
- Who is DRAG?
- Are the older B16 stock valve springs Ok for boost + high redline ?
- apex-i rs turbo muffler
- Hey you tuners..
- greddy turbo timer install question
- stock muffler?
- "Stealth Turbo Setup" ideas and tatics...??
- bouncing off rev limiter w/ forced induction
- fuel pump chassis questions...
- Air filter for turbo
- dsm 450cc work with hondata???
- OT: 300zx rebuild
- 2 stage rev limiter
- how do i get a 14b down to 7-8psi?
- 3" Turbo Exhaust
- Hey, autometer boost gauge. Can someone give me a rundown on the install?
- How to Fix Idle Prob.??
- has anyone here hit 10's with a t3/t4?
- S-AFC Hack - Is it worth it?
- Videos and Pics of VTC's dyno session 5/7/02..
- Cams and C/R ?
- motor to boost? b16a1 or b18a?
- std manifold?
- Turbo.. Extra Power Big Breaks. but what tires for 17" rims...
- A/F & EGT Guage
- rods ??
- Running out of gear with new Turbo setup
- anyone with a ls engine pumping 400+ hp...with no headwork?
- 16 Ohm injectors?
- Injector clips
- ummm... i just got a 3" 'turbo' muffler and now im slower than before.
- Oil return line
- Flex pipe
- Flywheel/clutch for my boosted GS-R
- Oh god...I think I messed something up. Am I running too rich?
- What setups do people have on there stock B16a's?
- list of question i have been saving up
- Turbo questions with stock ECU
- Quick injector install help!
- Hondata question
- ? about spool up time
- Guage installation
- Anyone ever Feel like their Honda/Acura is just a Kids "toy" car, they are playing with?
- Stick with t3/t04b or go bigger?
- Possible b18c1 head set group buy.
- garret turbo!wich one?
- MY new Turbo
- Need help quick, in the middle of an install!
- New to FI, help?
- Rattling at idle after turbo installation....grrrr
- when is an engine unrebuildable?
- SOHC manifold fit on 00' Gsr?
- race gas topic(warning been beatin to death)
- B18B and B18C o2 sensors the same?
- Ok folks, she's dyno'd and Hondata'd!
- Recalibrated Autometer A/F gauges...
- Mirror AFR meter install????
- which kit for my setup.
- Help! How do i force my internal wastegate to stay open?
- stock injectors good enough for 6lbs?
- How much boost on import builders package 4
- SR20DET or Turbo Teg? Help please!
- Turbo EG
- install tips on drag gen3
- whats better (HKS Twin power or MSD 6 digtial) Ignition for a Turbo GSR???
- ignition timing Q
- how to properly readair/fuel?
- Turbo the GSR?!
- Would this block be reliable for FI?? Used LS block.
- Max PSI on stock LS internal?
- gave up a chance on the dyno....:(
- upgrading turbo, where to buy manifold and t3/t4 plus wastegate
- Tell me what you guys think of my TURBO setup::
- EGT gauges for everyone? or just the real racers?
- Woohoo! Its finally arrived, the beast has come....pics inside...
- Help - Fuel System ?'s
- OT: Who here can deal me with an Haltech ECU?
- turbo oil feed fitting yes I SEARCHED!
- FS: B16A Turbo Kit
- xs engineering turbos
- J&S safe gaurd?
- B16A2 Ignition Timing?????
- video of my car (1mb)
- Who has the most miles on their Turbo before problems occured, if any?
- Help me out here...a few questions....
- Too hot?
- aftermarket (trust/greddy) oil cooler... worth it for FI?
- My For Sale post: come and get it...
- What pistons/rods to get for stock crx si motor?
- Junkyard turbo mania...Garrett T3 pics inside
- HELP I've fallen and I can't get up! (Blown engine, need ideas fast!)
- Help with fuel or ignition problem
- DSM 450cc injectors...
- stock clutch ok for 7lbs of boost ok?
- having turbo problems!!! plz help!!!
- WTB b16 head.
- Block gaurd install?
- 92-96 Prelude Superchargers
- JRSC locked up last night...Help
- Turbos - where to to begin
- Vortech FMU from Rev Hard Turbo kit
- "maximum boost"????
- Update on QUAIFE buy
- do a lot of you guys do this fpr thing?(link inside)
- DSM Injectors...
- I have no dyno, help from experience please.
- What needs lubricating on a used turbo?
- What's wrong with my fuel pressure?
- Internal Wastegate Problem
- JRSC VS Vortec..
- Question about a fitting on intercooler piping.
- What boost level should I build for?
- Can the o2 sensor die w/o cel?
- VAFC fuel settings
- how to read air/fuel ratios?
- Why is my turbo abnormal? Help!
- left the darkside for now..garage sale
- those with inline fuel pumps... what brand do you recomend??
- Can I use DSM injectors?
- Will PVC piping work for charge pipes?
- 14b
- Here's an even crazier idea...(kinda off the "noob question"post)...
- Turbo Preparations
- Give a shout out when you receive your groupbuy turbos!
- metal rings/washers for tial wgs???
- my civic new setup
- Can't figure out what's wrong!
- 3" exhausts causes boost creep?
- Cheapest place to buy 3" thermal?
- question on retarding timing...
- what ecu for turbo zc w/310 injectors
- TYPE R swap or Turbo charge on 98 LS
- Turbo is finally back IN.....pics....dialup beware
- Turbo my GSR oR Buy A Turbo DSM?
- Running boost on a stock / near stock fuel setup.
- Hondata or E-manage?
- Anyone try the spoon thermostat and coolant sensor?
- HELP!! FMU stuck??? wtf???
- anyone know of any worthy places to look for sponsorships?
- Moroso Oil Pan?
- How do I know which is in/out for the coolant lines?
- Using a B-series intake Manifold on a D-Series??????
- apexi exhaust
- Ok I'm a noob w/ experience, but a crazy question...flame if you must
- Which is the ignition wire for a turbo timer?
- 3psi on DPFI
- Turbo timer help
- My AFC hacked beater CRX *pics*
- re-doing a/c lines for more clearance.....
- Sparkplugs for 55 shot with zex kit....
