View Full Version : Forced Induction
- RC injector clips wiring into GSR
- Professional Products Crank Pulley?
- Is this block sleeved?
- RC 750's with E85 what will it max out at?
- Anyone running any of these turbos? Help me pic
- 4 Inch Mufflers, Do They Really Work??
- ECTUNE
- Opinions on Fuel Injectors
- gm 3 bar vehicle * searched*
- lsvt running to lean
- Need suggestions for turbo. Time Attack / SM car.
- best coupler other than wiggens??
- nitrous and boost?
- H23 BOOST BUILD ADVICE
- aftermarket flywheel?
- GSR going TURBO help?
- I need help with a brand new smoking turbo b18
- t3/60-1 turbo vs t3/t4 57trim
- d16z6 with HKS HI-Power exhaust/turbo???
- How does my oil drain look? Pics
- Race-Tech turbo kit
- e85 pump setup
- what cams to use on supercharged b18b
- Fixing an old stripped out oil pan
- question about turbo
- To port or not to port, Please advise!!
- turbo brand question
- do i really need a mufler on the street?
- Who makes reliable gauges? Autometer, Stewart Warner?
- Help me choose itr trans. or gsr trans mf 4.9 fd,mf 1st gear, quaife lsd??
- rear mounted intercooler?
- help on ls-v turbo
- kompressed h
- where to find hondata s100 basemaps?
- LS Turbo or LS Vtec turbo
- Looking at this turbo kit what do you guys think?
- Turbo Suggestion
- running different boost levels?
- NEW TIMES!! need some advice!
- Turbo water lines?
- Compression Help
- Got the laggy-spool blues... Help!
- Boosted GSR Build; Specs, Dyno, Pics Inside
- Porsche BOV: I've read that they work great.
- skunk 2 cams
- Turbo d16y7 first start up
- B20 turbo *torque monsta!!!* video inside
- aem intake
- What Clutch should i run?
- 525whp turbo coupe *video inside*
- Any one know?? O2 sensor wires??
- Precision Injectors 11mm top..
- ls vtec build... b16a head studs or b18b1?
- d16z6 need help with bottom block build
- E85 Winterblend - Rich or Lean?
- an line for vac/boost reference
- Very Cheap Turbo Setup
- Meth Injections
- Question for the Nitrous Guys
- TOP Mount or Ram Horn Manifold for 500+HP D16????
- Replacing Log Manifold
- B20 with GSR crank: Yes, I know it will fit, but...
- Ignition issue on my drag car, coil or ignitor?
- what to do with sensor in intake??
- exhaust manifold bolts getting loose help
- boosted b20 vtec daily reliability?
- manual boost controller problems
- Problems with turbo setup
- Eagle Forged Crank
- b16a vs. GSR for turbo
- Subaru WRX Turbo- Would it work?
- oil drain for s400sx(71mm)
- DSM turbo on a D15B setup
- FS: JRSC with extras
- Full-Race Manifold-Intercooler not fitting together as expected
- b series oil pan installation from hell
- fuel problem!
- oil feed and return question
- b-series turbo manifolds
- what are base maps?
- Turbo civic falls off dyno *new video page 2*
- B16 turbo questions
- Over revved wtf did i hurt.....
- Making a downpipe for Garrett T3-TO4E
- turbo question [need help]
- ID 725cc injector wiring
- Built motor questions?
- Stock sleeves hp rating
- LS Turbo Blowing White Smoke
- aluminum or stock flywheel
- How do you guys think my turbo set-up will run??
- Loud grinding/rubbing sound. Need diagnosis!!
- IACV, surging idle and AFR nightmare...HELP!
- 500whp Build?
- where to put the o2 sensor?????????
- Getting opinions.. Nitrous + Built b20vtec
- B16 boosted can handle how much on stock internals?
- precision GT30R visually....
- s300 boost control
- couple questions on my build
- FI Forum's Opinion on Ebay Turbo Kit
- boost cut
- Is a stock half civic radiator enough??
- Anyone used Injector dynamics 750cc??
- How Many Running Precision Turbo Journal Bearing with -3 Oil Supply Line ???
- T1 tune results
- Problem: EG GSR Turbo 3000rpm @ Warm Idle!!!
- PUTTING A JACKSON RACING SUPERCHARGER ON A 90-93 INTEGRA
- large turbo on small displacement... why?
- Misfiring? Please help.
- where is check valve on D16Y8???
- 850cc on b18bs ls motor
- Stock Map sensor good for 10psi??
- Is a mini-me swap worth it?
- Will it be enough? D series question..
- hx35 oil restrictor. What one.
- My B18A1 turbo project
- best bolt on turbo kit
- Street Turbo Driving Characteristics
- BEST 67MM TURBO OUT THERE???
- Downpipe Exit on Driver Side Or Passenger Side?
- f22b1 turbo swap not running.
- Which tuner and which EMS would you pick?
- 95 Civic Built Head, wont start!
- boost manifold suggestion?
- adjustable oil restrictor question
- What fuel rail? E85?
- H22 Turbo Manifolds ?? I NEED ONE
- Prologger?
- AFI kit pics please
- Garrett GTX-R turbochargers?
- Used Turbo pistons? Please chime in, Need GURUS**HELP
- Catch can/venting dilemma....HELP!
- Some advice from turbo ITR/B18C guys?
- Skunk2 IM or Edelbrock VictorX IM
- which bearings to use, D16
- Who makes a ramhorn or top mount that allows
- over boost baddd need help
- T25 turbo wastegate actuator arm adjustment question
- turbo question
- 508whp front mount turbo b18 divided t4 gt35r at 17psi pump gas
- overboosting with tial 44mm wastegate
- B20 VTECH
- Water-Meth injection fail,....what are your suggestions?
- Anybody use this t3/t4 cast manifold?
- Boosting H22a, FMIC/IC Piping Question!
- bang for buck FMIC (under 300whp)
- HKS Super Sequential Blow-off-HELP!!!
- How to?? 5wire bosch
- Trying to locate silicone ASAP
- B18 Ls Oil Pan Same As B20b?
- tranny/gear set?
- Anyone running Supertech Pistons?
- Stock 95 LS Turbo....help!
- NOS QUESTION CAN SOMEONE HELP PLEASE
- Boosting, which is better D16Z6 VS. D16Y8
- I'm BACK! After 2 1/2 yrs... (DYNO ADDED)
- Garret GT35R no resitrictor causes permanent damage??
- What kind of power SHOULD I be making?
- Intake Plenum Volume per Liter of Displacement?
- map sensor
- s256 anyone keep a/c with these
- Seeking advice/suggestions with this fresh build's problem.
- Holset H1E
- HX35 users.....what manifold!?!?!
- Car suddenly running lean
- gt42 turbo
- Forged pistons clearances for street engine - experienced builders welcomed!
- wondering about the stregth of this manifold?
- LS Vtec head gasket???????
- Piston swap
- no bov,no gauge
- full race traction bar, any good?
- anyone running T4 to T3 adapter? results?
- GT35r turbo
- ebay radiators, think twice people!!
- Extending hondata Ribbon Wires?
- Calling Turbo GODS!!!
- problems w/ motor. help
- What to choose?
- Fuel pressure question?
- ITR intake on boosted b18 Vs Other Intakes..
- turbo doesnt have fitting for WG??
- Cooling issues with D16
- Budget boost controller
- DSM+Civic=BadAss streetcar(video)
- stock fuel pump with walbro inline pump and aeromotive FPR
- ls turbo mani?
- Hose Separator and Engine Mount problem?!
- B16A - Borg Warner S200 - Pump Gas Dyno Tune
- what's the most power you made on a stock h22 and how long did it last
- 20psi what size injectors?
- Upgrading ingition opinions
- need some help on psi choice for my setup..
- lfh on b18b turbo kits
- OEM D16Y8 CLUTCH OKAY FOR 161TQ DD?
- another vaccum routing problem. HELP :P
- high compression + turbo ????
- Turbo choice for D16Y8 build
- when to tune?
- GReddy Turbo Help.
- s300
- Tell me why I shouldn't daily drive a turbo car.
- quaife differential in teg type-r tranny
- D16Z6 Turbo Engine No Turbo All Nitrous Questions....
- ls tranny.. good for 300whp?
- Need help on where to tune my ap1 in tri state
- will bov work without intercooler
- **Official Boosted DA/DB Thread**
- project "D-serious?" 400whp+ d16z6
- Can anyone identify this Flange?
- billet precision 67mm
- Max whp with precission 780cc injectors on E85?
- Central Florida Turbo bound from Texas<
- Resistor box wires...
- Bisimoto's 1st full Turbo build: Quest for 700whp D16Z WagoVan
- B18a with CTR N1 pulley, ignition timing question...
- BLOX turbo Manifold
- white smoke still
- What Motor to run.
- Dyno Results 1.8L B18C PTE 6262
- Yes, i've searched air filter, gt3040rls ramhorn
- HELP!
- how to tell if a turbo is good or bad
- D15B7: Turbonetics T3/T4 5 psi - Pump Gas & E85 Dyno Tune
- What should i do?
- Catch Can Advice
- 2.5 or 3 in. Exhaust
- K20z1 ITR + Evo 9 (photos and vids)
- 502whp LS, 93 Octane
- need help ls-t
- How much boost?.....sleeved stock block
- retard timing?
- help on drag slicks launching and etc.
- 90 integra turbo downpipe HELP!!!!
- skunk2 pro tb sticking helppppp please
- best site for turbo parts?
- Inline pro manifold
- H22 turbo question
- high flow fuel pump & stock fpr issues
- will 550cc injectors support 300 whp???
- Lets Get Some Ecu Help
- Pictures of a sleeved block
- lsv turbo build
- oil restrictor?
- stock b20 turbo hp
- map sensor problem
- B16 guys, do you port yor oil pumps ?
- building motor!!!
- Running FMU but What Ratio???
