View Full Version : Forced Induction
- RC 360 injectors good for 300whp?
- precision sc50..
- garrett t3 volvo turbo
- Who Ever Knows About ZEX DRY Kit....
- Boosted Nissan
- car hesitates then stops after warmed up....o2 sensor??
- wiseco ring gapping problem?
- OBX (moroso style) OilPan
- compression question...
- Connecting Rod Bolt Upgrade. Nessecary? Facts/Opinions
- toda b's with boost???
- knowledgeable boost heads... Quick Ignition/Rich mix. Problem?!
- i need some help with a turbo
- Radiator Overflow on Boosted Teg Help 347whp...??
- Read this please!!
- Video: Full Race Hatch In Action
- Do You Have Catalytic Conveter?
- turbo sir2 problem... please help
- anyone in the new england area instal/tune motec?
- B20 Turbo Project Finished
- What else do i need?
- Finally dyno'd new GSR setup!! w00t!
- I need some help on how to spark a big bang.
- Mini-Me Turbo....is it reliable?
- DEI's Cryo2 Intake system
- ? About Greddy turbo kit for the 96-01 Integra GSR's
- well.....having a birthday has never been this good...ITS HERE
- Carbon turbine wheel upgrade available??
- type r camshafts in my turbo gsr????
- RE: stock map over 11psi...
- dyno tuning my car
- gt28r on a stock b16
- Overheating issues new t25 setup??
- what kind of turbo is this
- My Oil return line doesnt look right?????
- my low comp motor putting out too low of a comp?
- ALL BULLSHIT ASIDE:::GREDDY TURBO KIT SOHC..
- MODACAR and MASE come through like ive never seen!!!!!!!!!!
- best sleeves for turbo b20vtec?
- TD05-12a-8cm2 Need help with exhaust flanges and other things
- GT30R or GT35R on b16a2?
- GSR Block with LS rods, crank and piston on Boost application
- Where can you get a new rotor for a distributor king dizzy?
- My LS build. Want your thoughts on Goals
- GT30R benefits
- Need info about this turbo: Garrett T3/T4 (T04E) 57 trim hybrid (50/63 A/R)
- Spearco Intercooler Too Small?
- uberdata tuners? m.d. dc, virginia area?
- downpipe and cat upgrade
- Vaccum line
- motor blew; doing oem rebuild; need help checking check list for parts
- Am I correct with this catchcan setup? (really sweet MSpaint inside)
- turbo coming tomorrow.....last minute questions
- max boost on a stock d16y8?
- Intercooler piping problem. Drivers side compressor, and trac bar.
- Do I need a cam?
- Check out my new setup....!!!!
- Chipped Ecu...Need end plug for datalog connector
- DIY - WBo2, Sensor location
- Does my car use "high" or "low" impedance injectors??
- Upgrade from td04h????
- t3/t04e vs gt35
- anyone ever seen this before ???
- 2.5" to 3" flared DP at turbo....??
- Going to build a turbo setup for the 1st time. Got some questions.
- Quick and Easy Question about Walbro 255lph
- how many miles b4 a rebuild?
- Gaskets
- What everyone get for Xmas? This is what I got...
- Oil feed resevoir
- Lensos, tappered or flat face lug nuts???
- FPR's What are you guys using?
- how long will stock b18b last w/ turbo compared to built motor
- MY BRAND NEW BEAUTIFUL JOHHNY RACECAR 8 INCH INTERCOOLER!!!!
- b18c5 head vs b16a2 head(for boost)
- filter for sc61 s cover
- blow by caused by cold
- Anybody with 'Microtek' EMC experience?
- How Is This Looking?
- Ported head for FI and NA, differences?
- compression
- GT35R oil pressure...
- Colorado Buyers BEWARE
- can i run open downpipe?
- oil level on turbo
- ever heard of hks bypass vavle
- People with autometer elect. water temp gauge
- greddy blue box or e manage?( i did a search )
- New Dynojet Open, Nyc Area!!
- Best D Series Transmission for FI and Drag Racing
- whats cost of normal turbo rebuild
- Garrett .63 or Precision SC50??? Both almost the same price but which to get???
- Running nitrous on H22 Euro Accord TypeR?
- Ok, this can't be good..
- Turbo went out. Any ideas?
- JRSCed B18c1 and tuning with hondata ...88si CRX
- FMU consideration: which to get?
- New Greddy Type RS BOV sound....????
- Last minute questions
- What mani you using with your backdoor?
- Turbo xs type s bov??
- can i drive home if...
- Turbo oil line feed location
- Opinion on this turbo size (SC61)
- Good or not? What you think about this head.....
- Turbo broke in half?!!!.... (SSAutoChrome/XS Power turbo)
- Largest intercooler on a honda
- 4inch Exhaust..Is it worth it??
- how to install my new injectors
- What management?
- Ebay DIY intercooler pipes any good?
- weird sound from turbo ls?
- My new turbo setup goin on Newyears eve!!
- Piping popped off...Any damage?
- WTF is wrong my car this time >={
- HELP!!!, installing turbo NOW
- (searched) what do i need to run nos safely in a ls?
- Stand alone turbo oil system??
- open downpipe
- what does a blinking light on hondata mean?
- T25 question
- turbo clearnce issues (pics inside)
- installing turbo in about an hour, octane question
- Do I need an FPR with Hondata?
- What are you guys using to run your low-boost setups?!?!
- Problem with Blitz BOV
- where to get cheap pump for DIY water injection?
- surge line question?
- need a shop recommendation in LA county
- Rusty flange
- gt30r trim question?
- 1800 miles and counting (dyno inisde)
- Link me to Chrome (obd1 ems, not the ebay :))
- Help w/ NOS nitrous setup
- Some eye candy from our current projects(AR FAB)
- Peicing together turbo kit, need help.
- Anyone have a JR supercharger on a d series motor? ...
- My Xmas gift to myself:)
- PLX M-500 in an EM1. Anybody use theirs to datalog? Need help setting mine up.
- injectors and other fuel stuff
- Greddy TT Speedometer
- 0-5V sensors. Need actual ranges please.
- compression
- Turbo heat shield
- Ls rods in b18c5?
- how much boost can a stock b16 handle
- JG intake users
- Where to buy Parts for Buildup Online?
- Turbo Manifold and Custom Pistons for J32A2... where can I get one?
- Washington State Greddy Turbo owners
- O-ringing really worth it??
- Hondata Stage 2 w/boost Question
- Synthetic Oil on stock boosted Rings
- B21 Crank Possibility
- Serial adapters for Hondata....???
- noob who found a resister box at a junkyard
- What turbo for 84mm b18cR
- walboro fuel pump install, help
- What the fawk is a Hemi....????
- Mold construction??
- t3 turbo question(s)
- Fun thread: Who's changed their motor/turbo setup the most?
- which turbo kit for 99 SI
- D-Series Exhaust Manifold Head Flanges?
- Eagle rods made of titanium
- 89 crx b16a......Turbo worth it
- MAP BYPASS? ASAP
- Anyone use this intercooler? How does it look?
- NOW NEED HELP WITH TURBO BUT IS A SSAUTOCHROME TURBO GOOD..HERS LINK:
- greddy turbo kit for sale
- compression test results sound low
- Where to mount Inline Fuel Pump?
- before i start piecing my kit together...
- T3/t04e 82. AR too big for mild b16 street/track set up?
- Ball Bearing vs. Journal Bearung?
- how much boost can i take?
- piston to wall clearance
- Just Installed T25 Idle jumping????
- Torque Freaks - Groundzero Motorsports - C-speed Racing
- resister box or radio shack resisters?
- dyno question
- *** HELP! VTEC Is Not Working On My LS/VTEC ... Along with my Car's Biography ***
- T3/T04E with what injectors?
- How are your winter FI projects coming?!
- Sound like an exhaust leak?
- LS/VTEC TURBO help?
- OK to only run one port on the endyn catch can?
- Ignition setups?
- SC61 owners.. do you suffer tEh lag??
- Dseries big Bore Throttle Body?
- sleeved d series - any blown headgasket issues?
- Torque for rod bolts?
- Who here is running a 14b with a front mount intercooler?
- the time has come....
- Leaking OIL!!!
- Dyno Day Video from SlowMotion Motorsports
- guess the turbo game......again!
- Need suggestion for my setup
- who is running 300 whp on a d series?
- Will an 8" JRC fmic fit an ek with foglights?
- need a better turbo setup for my gsr..buying a new turbo
- Do i need a 3 bar map sensor??
- Exedy twin plate or Tilton Clucth?
- What to do for catchcan????????
- Tial 50mm Blow Off Valve spring colors
- List of all sleeving contacts
- 3" DP worth doing on 370 whp?
- my car makes more power with exhaust......WTF?
- turbo d15b ?'s
- vacuum source for wastegate....turbo or intake/vacuum manifold?
- How many of you guys use a moroso oil pan?
- Is there anyway to check a wastegate to see if it opens?
- front x member in the way!!! 88-91 civic
- Where to get Full turbo kit for arround 350whp?
- for sale
- internal/external wastegate ??
- JRSC LHT intercooler - what kind of core?
- BOV Question - Leaking?
- boost leak question
- torque drop on ls engine
- OBX's full-race style ramhorn copy turbo mani,,, wierd WG bolt pattern or i am goofy !??
- Oil lines???
- Uberdata ? and yes have searched here and the Uberdata site
- WTB::::GREDDY BLUE BOX!!!
- my setup - revision
- 300z31 T3 . . . Which Exhaust housing...
- short tubulur manifold dyno's ( minime style)
- EFI on turbo
- BOV on an auto...
- How much does this garrett turbo go for new??
- log vs equal length?
- 550 injectors and fuel pump
- Im new to building a turbo kit and i need help with the wastegate on a blox manifold!
- Finally boosted and drove it around for one day then....
- uberdata error message.
- ***BOV Audio Clips*** (for ringtone)
- Autometer EGT gauge anygood?
- need help on a set for my crx i wanna go turbo what do yall reccommend
- help with turbo upgrade
- Need help choosing clutch for turbo CRX
- y8 stock ignition?
- ClubEK B18C1 Project
- help me pick out injector size...
- What wastegate are you guys using?
- *HELP* Which motor to add a snail on question??
- a little exhaust vid...lumpy like Nana's gravy.
- Rev Hard kit oil feed line: do they come with an oil restrictor?
- ??? ssautochrome
- Quick question on Housing specs
- MERRY X-MAS! i got something cool today
