View Full Version : Forced Induction
- Looking for 1st hand AVCR info...
- SOHC Turbo Intake Manifolds!!!!!!
- Help, I lost 10 psi of fuel pressure over winter...
- Downpipe help
- Fuel Pump question...
- GE fuel Rail Question?
- Going turbo, buy an LS or GSR Integra?
- Anyone have exact piston skirt measurements for 81mm endyn/wiseco's?
- Question about techedge and my a/f
- Just bought a spearco race intercooler for 350
- to anybody who knows about ludes
- Air/Air Intercooler Vs Water/Air Intercooler??
- Front Bumper Mesh/Grill: ~~post all of your pictures~~
- maxrev downpipe
- losers get a life
- HELP! URGENT! 450cc injectors installed: CAR WON'T START!!!!
- ecu codes after boost on jrsc....help
- $115 for a nice oil Return line?
- need help for turbo R
- newb oil return line question
- turbo question
- Battery Relocation
- rebar removal concerns
- HydraCharger -- anyone heard of this concept?
- JRSC question for 99-00 SI please read
- ETs for Turbod SOHCs
- installing guages-need help on tapping wires
- fuel rail and fuel pressure gauge opinions
- Oil feed/return lines For T3 turbo.. where do i get them???????????????????
- what size i/c piping for greddy turbo on d16?
- Fuel needed upgrades to run 9lbs
- How do you figure out what size fuel injector to use?
- BCPR7ES-11 vs. ZFR7F-11
- Accell 500cc sat. high imp. injectors from 2g eclipse fit an LS?Help fast!
- Need answers on this MAP sensor issue
- what kind of metals are you using..
- JRSC OR TURBO please help me decide.....
- B20B/VTEC Turbo Dyno @ 7 psi...Comments?
- Larger Diameter Downpipe - Greddy SOHC Turbo Kit
- profec e-01
- Intercooler piping for a 91 Hatch w/ a b16 and front mount intercooler
- anyone have a PWR IC mounted? opinions
- How to make my GSR a SLEEPER? Any suggestion??
- What other wastegate flanges are the same? (ie-Deltagate/Tial 35mm)
- what kinda cams do you use
- Critique my Setup
- anyone use Innovative Turbo Systems MSBC-1 Multi Stage boost controller before?
- Breaking a Rod?
- Wastegate Install?
- DRAG3 Si vs DRAG3 Gsr ???
- Anyone runing the Rev Hard equal length turbo manifold...
- could this be a sign of engine running lean???
- Screw N/A im joining you guys
- JRSC people look here
- Inline Pro manifold and TIAL WG fitament in an Integra?
- please help with pics of your return lines
- ? about CODE 1 for an obd1 gsr turbo (oxygen content)
- Best turbo package for d series
- oil return line is really close to downpipe...is it gonna be a problem?
- who's tried a msd 3bar map with hondata
- smoke from turbo? HELP
- Which is safer at 7psi.....b16a stock or b18a1/2/3 stock?
- What oil pan fitting?
- is your turbo setup ever finished?
- Should we go with DRAG-III kit or Greddy?
- Charge piping/welding costs?
- What HeadGasket for a Drag III setup on a 98GSR?
- Techedge with Hondata, works for me.
- Will a Drag downpipe for a LS fit a GSR?
- retorqued your arp head studs?
- Were can I get a vaccum line distributor?
- Whats the point of a HKS SSQV BOV Return Kit?
- T-25, T3 questions
- anyone get their anthem shirts?
- Wrapping maxrev dp....no worries?
- what fuel pressure to run, and cam timing
- Hit the track yesterday= Not so happy!!
- can i weld pipe to my oil pan?
- What FPR (Fuel Pressure Regulator) are you running?
- Intercooler fitment ?'s
- Whats about your Meng manifold?! the great crack poll.
- Selling the POS pinball machine!! (56K no go!) Engine rebuild final phase...
- Greddy Intercooler
- on a civic DX?
- GSR Greddy turbo. Possible oil on the threads of the spark plug on cylinder 4
- Greddy kit! Am I missin anything to make it complete? gsr kit to fit 94LS
- My Dyno results: CarTek Tuning South FL Dyno Day
- SMC500?
- How are you guys dealing with the gas prices?
- pics of ge blocks
- How much have you spent??
- Need diagram for Turbo timer + Alarm
- what does detonation sound like?
- MY turbo Accord
- Link Extra Injector Controller
- Finally finished my first junkyard turbo...lots of pics.
- Not another 2.5-3" downpipe pic
- what type of flange do you need for a 3 inch down pipe?
- Cost of going to Hondata??
- New IM.... Funky
- Question on which Injector Size For the FMU Setup
- Where can I get a SMC?
- SMC dyno results (baseline pulls)
- Just got my car back...just blew it up. :(
- Can someone help me with turbo sizing? I have all the info, I just don't know what to do with it.
- pounds vs. size of turbo??
- can i weld a egt bung to a ....
- air to liquid intercooler questions
- Wastegate dump pipe size?
- where to buy the following parts to finish my install
- leaning out problem
- Does anyone have a pics of Je piston(9:1) B16
- Tempest Racing, Waldorf MD....for those who have gone...
- o2 sensor question
- SAE corrected numbers
- Another collector...TIG welded
- how much boost with 370's?
- Oil pan blues...
- Ripleys believe it or not
- Dyno of 2.0 GSR @ 10psi
- Tuning out overlap... questions....
- ECU Upgrade? PR3
- Check this collector I made *56k no no*
- jrsc integra ls hp#
- how much is for a maxrev kit??
- Finally Dyno results
- Ford SVO t3 .60 .63 good for b16? Thanks
- manifold ?'s
- Fellas what's your take on the SMC+?
- So I passed emissions without a problem, but...
- deltagate mark II wastegate
- Hondata
- Philly Dyno Day Aftermath
- Stock b16a2 + 35 dry shot = ???
- fmu so i didnt weak? :(
- Injectors who to use and who to stay away from...
- What would you guys do?
- Anyone ever able to get 300+ hp with the GReddy kit?
- ??? about discharge flange on Greddy kits
- 60-1
- Slight "buck" at light throttle and upon slightly letting off throttle.
- 2 quick easy turbo questions
- injector wires .... to rc clip wires ...
- Weight Watchers....for the car (suggestions)
- Why does my car stutter when hitting VTEC?
- FI Car is starting and dying....CEL Someone help!
- GOLDEN EAGLE vtec conversion for turbo app oil line size question
- ITR Injectors Vs NSX Injectors
- JRSC chatter=loss of power?
- Twin turbo s2000
- aem ems forum help
- i'm ordering my turbo today...few questions
- About to Piece Turbo Kit NEED HELP
- if running the hack?????
- about my D-series set up...
- question about dsm injectors in a 4th gen
- Leaky Headgasket... How can i check?
- Critique my setup...
- Look what FedEx brought me from GE
- SAFC II???? anyone have one of these?
- OBX manifold junk or good????/
- Need help with turbo install :)
- New cheap fuel managment option!
- question for Ls/turbo guys
- T3 or T3/T4?
- b16a or b18a turbo?
- emissions...anybody do this
- Car is Over Boosting, why??
- Blew a fuel line tonight!! Why?
- Anyone try out the "autotune" feature on hondata s200?
- haltech install on a civic del sol
- need help tuning a AVCR
- Turbo on ZC
- Can this be resleeved???
- Stock sleeves!!!? Street car..
- AFC problem, help please :o)
- Help! Wierd problem
- T3/4 mod to t3 60-1??
- Which Hondata system with Drag 3?
- Whats the most boost you can get away with on stock sleeves?
- crower stage 2 cams and emissions?
- Quick Honda Logger Q?
- T3 rebuild kit
- Where to buy ARP head bolts?
- Tell me what you think of Greddy turbo kit (92-95 civic kit)
- Almost done, need little help though.
- Investment Worth It?
- help with second b16a turbo
- looking for a boost controller
- What turbos came in the drag turbo kits?
- PICS of my new full-race manifold
- Anyone ever used a JG EdleBrock 65mm TB?
- Which Fuel Pump for FMU setup?
- making of 3inch dp..
- anyone in north nj need help............
- HP gains from hondata... how much did u gain...
- Pics of my SOHC Turbo(Finally) 56K Go Away!!
- Are Spring-Loaded T-Bolts necessary for silicone hose?
- 2 questions: Ring Wash Symptoms? and VAFC with FMU and Check valves.
- what clutches you guys using???
- OT: anyone lives near Baltimore MD ?
- I would like to thank everyone for there help.......heres some pics
- WTF are these.....?
- Enought fuel? 290's fpr 255 and 12:1
- oil leak from turbo...
- Anyone have a Civic Si running 11's?
- Where do you guys buy your injectors?
- Stainless lines
- Paxton FPR Thread pitch?
- Can you identify these pistons?
- sound clip of JRSC?
- Jackson Racing supercharger noise?
- Homade WG gaskets....what do ya think??
- Question for the Turbo guru's
- How to check CE light code for h23 w/hondata & a different ECU?
- What size pipe for manifold??
- >Has anyone here ACTUALLY USED the Phantom Grip LSD that can give me some insight???
- Where can i buy endyn pistons?
- FMU vac source can you have it off?
- Emulator & Romulator Q's
- Hondata dataloggers - what is datalog errors?
- Fuel pressure on a stock b20, walbro 255, 350 cc injectors?
- Mounting of MBC?
- Valvespring Compressor that Works on D Series Retainers?
- my new project....
- t3/to4b vs. t3/to4e...tried a search..please help
- Turbos
- 2 new goodies came in the mail today
- Detonation? or turbine hitting housing?
- Wastegate (open vs closed loop)
- 11.34@126.55
- Setup Suggestions
- PHUCK! I can't get my turbo to fit on right! Do I have to shave the block?
- intercooler pipin on ex
- will 9psi be ok on stock internals
- ARP head stud torque specs?
- BOV mounting location
- blitz dual sbc type-s, or greddy profec b??????????
- fuel pressure and pump questions
- Can machine shop tighten piston/wall clearance on stock bore?
- JRSC: does this schematic look ok?
- help in choosing the right turbo/turbo kit
- Anyone using AutoTechnic oil filter adapter on b16a2?
- Endyn PCV breather routing?
- boosted accord (already posted in accord section)
- lotsa creep with GSR/Drag 3/DeltaCreep (No spring)
- Noob BOV questions
- First pix of our CRX
- Need a little backing here kids......
- Think this might hurt performance slightly?
