View Full Version : Forced Induction
- How much hp is the B18c1 greddy turbo capable of producing?
- TB size?
- why is everyone selling their HONDATA?
- Oil Return line on greddy kit
- My Dyno @ 9psi
- boost on stock b16
- compression ratios
- quick question about the EMS
- DragIII Installation confusion. eff those fans
- larger injectors with blue box
- DSM turbo manifold???????
- Name that cause...........
- DSM injectors, i know, but please read
- boost problem maybe fuel problem
- Pics of built b18c5 block and race car
- how to...
- a question about hose (not hoes)
- who running on 370cc injectors?
- ARP Head Studs
- wideband air/fuel ratio gauge. help please
- this noob finally going turbo! please help
- backfiring
- For those having master cylinder clearance problems with JG/Edelbrock Intake. My solution for G2 Int
- Link to Aeromotive FPR stuff
- NE1 ever used the Skunk2/RSR 76.2mm turbo muffler?
- Where do I start? D16Z6 long block, completely disassembled...
- Setup (almost done!)
- need some opinions
- Better turbo, i have a t3/t4 and I get full boost at like 4-4500, I want faster spool up??
- Taking Turbo Apart?
- 3mm cracks in pistons
- Which turbo/trim specs are still good @9-9.5K RPM
- loosing boost??tried everything-kinda long
- all drag owners out there, did you have to cut the fans?
- 2.2 liter b-series...here is an idea.
- what rpm are you d-series guys @ full boost
- Other parts to replace with an engine rebuild?
- How much hp on stock sleeves
- OT- selling my Turbo Setup for those that may be interested in parts
- F/S: 12:1 FMU, Missing Link
- B20 bottom end on LS head with turbo
- Synthetic Oil w/ Turbo Chargers
- This may be a stupid question but...............
- for those who have pieced together thier own kits...
- How do I even read my gauges?
- sx or aeromotive fpr
- detonation w/ afc hack on 12psi
- 5th and 6th gen oil pans interchangeable?
- Broken axle at the track, upgrade to stage 2?
- Greddy Rebic IV for water injection controll?
- Group Buy on Quaifes..Prelude/Accord units here
- Anyone need a new thermal 3inch exhaust for 3dr integra all models
- having problems finding a downpipe?
- whos going to e-town today?
- GSR Rods -- no oil holes?
- 310 injectors,S-AFC,Inline fuel pump,8:1 disk FMU, can i boost 10psi?
- 440cc or 550cc
- What's this bolt?
- are AEM cam sprockets a good mod?
- greddy kit user, plz help
- Whose Running Haltech??
- ever have a prob with oil pressure and turbos.
- limits of Walboro 255lph pump?
- Just put a 3 bar map sensor on my car today...........kinda long.
- Fuel Injector services.
- gaskets?
- Whats Haltech webpage!!
- stock or upgraded fuel pump?
- Anyone built their own exhaust?
- boost not boosting?????
- limits of stock injectors...
- Testing Waters.. Fully Built Turbo Integra and other stuff too!!!!
- civic turbo
- Anyone take their head to DPR?
- Phantom Grip LSD?
- Compressor Maps
- ATN: All homemade turbo Gods.
- maybe dumb question, where do I start with learning a standalone?
- People who are getting the pwr groupbuy intercooler
- Attn: Max-Rev
- Best Valves for Turbo......
- 98+ tegs w/ fmics...
- hondata 2b question
- do the draggers here do FULL throttle shifting?
- RC Injector Problem...
- Turbo b16w/Type R trans! Car gets full boost all gears yet I can't pull till 3rd.
- Blitz BOV...."?"
- Turbo hitting oil stick
- WTF. Subaru + Honda Making a TT VTEC 465 HP MONSTER WRX2200
- FS: Hondata 4B $1050
- IC Pipe with DownPipe
- Help with Hondata
- RX7 Turbo Resistor Pack
- 3" downpipe with A/C?
- 1/4 times kinda dissapointed
- I need someone to work on my car....
- bolt up????
- Help with Compression manipulation with Head Gaskets and other advice with mods.
- JRSC people, map controller question
- Where to plug in the mic for a J & S?
- VS racing now services turbochargers..... Most models
- B16A2 block build questions? Sleeves etc
- Recommended boost controller?
- Relaibility of DRAG 3 fuel pump??
- Rev Hard turbo specs?
- homemade boost controller
- Finally done
- Painted Intercoolers and piping!!
- Do you guys dyno with slicks on?
- 2.5" or 3" exhaust for turbo???
- Exhaust Cutout?
- Siemens injectors?
- Inline pro manifold: PICS!
- b2o vtec help
- shit, i shift from 4th to 3rd at 7000rpm
- Whats the biggest shot of NOS i can use on my setup and have no worries??
- HKS GT vs. Power Enterprise turbos?
- All you turbo/JRSC cars with high boost, what C/R do you run?
- Greddy GSR setup
- HELP: Vibration/Noise under deceleration and reverse?
- ENGINE CODE 17??? what does it mean
- oil feed size?
- Power FC vs. Hondata 2b
- Arias Pistons - Piston slap questions...
- Ball bearing upgrade worth it?
- Where can i buy the "missing link"
- Inline Fuel Pump ???'s...
- Bad Blow off valve
- Is a 255HO intank fuel pump too much for stock injectors?
- Help!!! Does anyone have any pictures of drag gen 3 install?
- Any Hondata tuners near Phila, Pa
- H22a Turbo in 91 Accord
- Welders!!! HELP! Please read, anyone... need help quick
- Does it hurt to drive a new clutch at high RPM'S???? What's the proper way to break it in?
- Fuel pump primes but doesn't flow while car is running
- helms
- To Piece or not to Piece (together a turbo kit)
- rebuilding after the theft!
- help with ARP Head Studs
- clutch help ASAP!!!
- How many people run open loop wastegate setup?
- Cheapo BOV for recirc setup..suggestions?
- making B16A as reliable as my B18C6
- Need radiator hose w/ more clearance
- Crower Turbo Cams
- FS: Hondata 4b
- Wastegate Help???
- Zdyne 3 bar map sensor?
- air/fuel ratio????
- B16 Turbo 9lbs only made 198hp and 140ftlbs of torque something wrong here????
- bore sizing
- LS turbo owners .. passing emissions?
- Turbo Size help??
- 02 Bung?
- Perfect Power PRS standalone only $600?
- greddy type-s problems
- How much for a new t3/t4 turbo?
- VAFC hack, 3 bar MAP and DSM injectors
- Alcohol injection kits
- OT:Ripped off, Twice?!! HELP!
- FP with DSM 450s?
- Resistor box question?
- bad fmu
- What to use on side port of Compressor?
- OT:anyone know the spring rates for the Eibach and Neuspeed drag springs?
- Any chance of anyone setting up a gb for eagle rods??
- $930 for used 4b with all the extras?
- turbo manifold
- WTB RC 370 cc injectors....
- how did you get your gauge's wires through the firewall
- what disc for vortech sfmu should i use.
- fuel problems
- Machune shop pricing?
- i have a 93 civic vx D15
- dsm injectors in teg
- who still hasn't recieved their turbos from the GB?
- Piston Rings Fudge UP!
- update on my engine teardown
- Upgrading a hondata3b to add dataloging? HOW?
- Fuel pressure??? Modded B16 W/ DSM Injectors?
- Thermal 3in turbo on GSR
- vacume hose off/on fuel pressure the same?
- OT: Need Max Rev's new address
- does anyone have a pic of a type 31 i/c on a 92-95 civic?
- any updates on the garrett group buy from way back?
- for those who have a big intercooler
- FMU Placement in Fuel System
- my car is idling really really low and dying at idle
- my car is runnin'...
- Can everyone tell me what stand alone you're using?
- Fluidyne or C&R radiator?
- fuel turbo ZC
- just talked to rc
- arghh! what do I do now!
- Are catch cans REALLY needed?
- Got my new manifold...:) $350 does a mani good.
- Took a ride in a JRSC GSR
- for a drag kit....
- What weight oil to use for a Turbo Application?
- n/a modded gs-r nitrous safe?
- OT: please help..oil in intake pipe.
- aem cai for charge pipe?
- 3mm headgasket
- Injector Sizing for turbo application......
- Anyone run a CF hood with their turbo? Any problems?
- Where do you have your manifold drilled for your EGT gauge?
- Would a jrsc at 6lbs of boost shorten the lifespan of my motor??
- Rx 7 Resistor Pack
- Civic VX D15 turbo'ing....whatcha think???
- ignition question. suggestions anyone?
- Mitsu or Garrrett
- OT: True race turbo manifold?
- ***F-MAX turbo kit on turbo LS crx***
- Which turbo for b20
- Is there a break in period for a Qauife?
- Powdercoating Intercooler piping? (Mild Steel) yah or Nay?
- i need some quick OBD I o2 sensor help, anyone OBD I can help here...
- Hondata... Laptop dependant?
- Resleeve Project
- Out with the old tranny and in with a new one... kinda..
- Are you happy with your Max Rev kit?
- 4 WD Prelude turbo
- crane/msd ignition question w/ vafc hack.
- Standalone/Piggybacks/Engine Management Questions???
- oil squirters??
- 1st time at the track boosted.
- Vapourtrail or anyone else who knows BB turbos
- Question about cfm of honda motors
- valve job...parts needed?
- Looking for Built D series people: What's the most HP you've been able to reach?
- fuel cell placement....? EARL, didn't you use to tech for NHRA?
- wastegate?
- What determines maximum boost?
- does this install look right to you guys?
- MPG died wtf?
- Supercharger almost done!
- can you guys tell me if i got the wrong spark plugs?
- Orifice size for return fuel on AEM regulator w/ 255lph holley pump?
- Stock ITR exhaust too restrictive for turbo?
- inline fuel pump? vafc hack? help please
- whats better intank or inline fuel pump with stock injectors......on a turbo ls
- turbo maps
- Spearco Intercooler Groupbuy, MAN THIS IS SUCH A JOKE !!
- Hondata 2b with extras for sale...
- My GT30 have arrived!!
- Whats the worst that could happen?
- Has anyone ever tried propane injection
- location of EGT gauge
- Is it the turbo/heat or clutch is out?
- Updated pics of my LS turbosetup completed
