View Full Version : Forced Induction
- Is this turbo in useable condition??? video
- Post your Boost by Gear setup
- Where to find a restrictor...
- do different but same size turbo increase hp?
- HG? somthings up with cooling system. advise PLZ!
- Need advice! Oil restrictor on my Precision Turbo SC44?? Use one or not?? PLZ HELP!
- Eagle rods - connecting rod bearing clearance question
- Tps problem boosted s2k
- water temp to high ???help
- Turbo Development for F1 engine circa 1984
- B18B or B20 Rebuild and Swap
- Lsv turbo advise
- boosted D16, coolant reservoir overflow after spirited driving.
- boost control via rear vss
- The new T3/T4
- vitara build help
- pump gas s366 users
- filter for turbo??
- ringland or headgasket?
- Can you help me order the right exhaust flange/clamps, etc?
- 00 prelude jrsc surging when accelerating
- Turbo Filter Mesh Screen
- What psi have you run on a 9.5:1 motor on 93oct?
- H22A is my oil pressure readings ok?
- Resistor Box Question
- this piping good for a B18B integra?
- B, E, or S compressor cover?
- how much hp needed to brake tires loose in 3rd?
- tuned w/o air filter...now what?
- Turbonetics 60-1 Stock LS/V??? Too big?
- video from yesterday
- Greddy Turbo price check
- Turbo B16 all of sudden running horribly
- H22 Turbo Manifold Need Help Deciding*PICS*
- boost solenoid issues- wont make consistant boost
- Smallest radiator with turbo setup - Thermostat?
- d16z6 cant limit boost?? HEEELP!!!!
- Gsr boost?? what # to expect???
- Older GE sleeved block
- 95 Civic Ex Cp..LS-T/Full Set up..I need Input
- Failing PTE turbos?
- tial 38mm gap between manifold flange
- Ramhorn question?? turbo ef owners please chime in!!!!!!
- Need opinions on LS turbo build!
- 500hp goal turbo ls
- Honda logo on intercooler?
- New turbo Scraping housing
- Question on b20 block
- 98 dx turbo
- turbo spec help
- need some advice on valve train
- mini me vitara turbo. what works??
- Idle Issues JDM B18C
- Boosted B18C Flapping noise??
- wrap for lines / ic piping
- Help B16 turbo build
- Down Pipe to cat back issue.
- restriction
- Jeff Evans and Jason Hunt's NEW 67mm turbo
- T4 garrett 60 to 1 58 ar ehx
- Finally finishing this project after way too long!
- Sending bottom block out, need advice
- Building For Boost- Head Question
- Vortech powersteering line
- engine dying at stops! help
- need hlp IDing precision injectors
- mishimoto intercooler review
- please read!!!please!!!!
- Best intake for low end and midrange?
- Nitrous Experts! Got some questions
- Supercharged type r questions.
- A GT35R with a .70 a/r on a basically stock b16.
- Turbo stock F20B
- New/old guy returns w/ question on engine management..
- Max Power made with Log Manifold ?
- ???? K24/K20 turbo engine build ????
- what is this turbo capable of??
- methanol/nitrous jet calculator?
- TURBO F1 era....two great MUST SEE videos!
- AEM fuel rail -6 adapter question
- 1990 B18A Integra Turbo.
- T3 to T4 Adapter - use gaskets and ultra copper?
- Project b18b
- What are the turbo guy's building today?!
- Official: Stock Sleeves Most HP, B and D Series!
- Help me Understand. Turbo EMS.
- FULL SIZE RADIATOR AND TURBO ?'S....
- need help picking a clutch
- oil restrictor, oil passing
- What's quicker on a real street tire?
- Help id my used JE forged pistons
- Main bearing clearance calculation confusion??
- help me choose which turbo to use!!
- Daily/Reliable Boost on stock B16a2
- Engine cleaning fluid & Assembly Lube preference?
- I am finally assembling my GSR head but I’m missing bolts
- Correct Detailed Catch can install help
- Can I Run Dual Bosch 044's on Stock Engine
- Journal bearing turbo and cool down cycle? Turbo Timer?
- Recommend me a Fuel Pump and Injectors :)
- Multiple problems, can't find a solution
- 650+whp... BB's 62 turbo/E85 2008 S2000 build
- Garrett 4 bolt pattern...
- Turbo build ideas!? Anyone care to input
- Car slugish and poping, Just started Fuel or Spark??
- Main stud question
- b16 zex kit
- What comp. Ratio?????
- oil problem boosted 92 integra da
- Won't start!
- help with my build
- What kind of paint should i use to paint Intercooler/Piping?
- eclipse turbo on a d16z6???? How to's?
- First Oil-less Turbo???
- Do you agree that the SS weave inside flex pipes is the problem?
- Any problems with a long oil drain line
- RPM/Power limit of stock rocker arms???
- Got tuned on Monday. Need some help
- wrap IC pipe?
- rpm goes up EG h22a turbo
- B16 internals in LS block.
- Need info, not build help, ls vtec owners chime in
- It this turbo screwed?
- msd fuel pump 2225
- Reliable turbo?
- GTX3076 vs GT3076
- Cylinder 1 gets hotter ?
- What is a P-Trim ?
- GARRETT 60mm .81 A/R P-Trim ok for H22A ?
- idea for boosting the H23a dohc vtec
- effective ways to lower underhood temps
- A few simple questions...oil and valvetrain.
- untuned jrsc si is sluggish
- changing from 60 trim to 50 trim retune?
- EM1 Greddy turbo kit plans, any advice?
- JUST SOME PICS OF A D16 CRANK GRIDLE CUT TO SEVERAL PICES.
- Tuners: Hondata S2b
- What bolt pattern is this?Need a downpipe
- Can i supercharge a d12b?
- Turbo seal gone..
- t28 turbo
- Pushing the set-up
- 20g on B16..opinions & guestimations wanted!
- Do i really need catalytic converter on my turbo b20
- fuel system question.
- intake manifold
- $250 for a garret ball bearing turbo?
- Fuel Pump Question
- ITR intake manifold VS Victor X
- typical oil temps?
- Car wont stay on: T1 Cam Trigger and AEM 1020 & Twin Fire Coils
- gt35r .63a/r wanting to swap to .82 or 1.06
- Stock SOHC Boost Reliability?
- Turbonetics Turbo Rebuild
- Spoon N1 Exhaust + Turbo Thoughts?
- LS/VTEC overheating or normal
- Help with turbo kit/cams for B18c1 Daily driver/weekend track warrior??
- Misc Questions - 11:5 Comp - Boost - Meth - Vortech
- ITR valvesprings on an LS head?
- Turbo B16 hard to cold start after ignition box and external coil
- Thinking about JRSC
- dc2 with 3 row rad
- Mugen Twinloop vs Greddy SP2
- JRSC stepper pulley
- Aiming for 400whp
- bmcracing intake vacuum question
- CA:Aftermarket Blow off Valve: Legal or Illegal?
- I am maxing out my turbo. Is that BAD????
- Where are you guys getting your SS braided lines?
- methanol injection users, question about temps
- Idle pully, JRSC?
- JRSC DEL SOL B16a?
- Pressure drop when replacing 255 to 340lph pump??
- experiencing slight rod knock @ idle..help!
- 60trim turbo
- Painting Turbo Stuff ... fmic,piping,manifold,housing
- Options for 02 Acura TL
- Is this a real HKS SSQV Black Edition?
- need help with crankcase fittings removal
- Is my B16 head ready for boost? Help with identification
- break in!!!??
- what plugs are good for boost?
- O-Ringed Block......Copper Spray HG?
- I need to rebuild my JRSC
- Waste gate spring issues
- B16A2 stock sleeves with PT6765 Billet with video ?
- Vacuum Line
- Injector question ! Please leave quick response
- engine knock and oil light on startup
- Searched... I think its running lean now... please help
- At what boost pressure do Z6 intake valves leak?
- My approach to turboing my GSR.
- Anyone with a ATI Pro charger on a b series?? chime in!!
- Top Mount vs Bottom Mount manifolds
- GT Series Oil Drain
- one more time t3/t4
- 907whp SynapseTurbo.com Gtx42r S2000
- 93 gsr turbo hatch idle problems. help!!
- turbo d16build help!
- tech suport
- Is a lightweight flywheel well suited for FI?
- boost guage not showing boost?
- 9:1 or 11.1 on a 6262
- greddy turbo kit for a sohc civic
- loud pop in turbo civic
- Lst Build Questions
- whats the most boost i can run safe on a b16
- GT30r issue
- FullBlown setup into a Ef???
- Anyone using Rs machine Itr spec pistons on turbo setup
- Tial MVS fire ring question
- Boosted No VTEC!!!!
- NEED HELP. D16 s300
- What do i need to run hondata s200 in a 2000civic
- Help with tial F38 wastegate!!!
- T70 63AR good for built H22A?
- anyone know where i can get a 38mm wastegate valve seal in HAWAII??
- Boosting issues
- Do I need to re-torque ARP head studs after a while?
- D15z1 turbo how much psi for dd?
- d15b7 turbo help
- Problem with ITR/JRSC
- Precision 67/65 vs Turbonetics-HPC 64/65 Dyno
- Not your average 2.5 motorola question..please help
- quick question
- Help! Boost is gone!
- Fuel Pump: Inline or Intank?
- No Spark
- injector questions?
- boost cutting out bad turbo or......
- stage 3 all motor cams with turbo
- what size injectors to run?
- Turbo manifold help
- about that boost controller....
- B20 vtec turbo cutting out during acceleration. Help!
- Running richer than before
- Gt35r question
- possible new technology inexpensive turbo supercharger big power upgrade
- I need help with pullies on my integra crank pulley lightweight
- LS/Turbo Smokes at idle just started
- b18a1 turbo problem
- H22A Darton Replacement Sleeve... Question...
- Best Exhaust for Turbo K24?
- random head gasket question
- couple tuning questions
- Rev hard with big turbo Question.
- Turbo manifold design software ?
- EG6 - B16A2 Turbo Stock Internals
- tuned ecu?
- boost drop off
