View Full Version : Forced Induction
- Damn Garrett Turbos.
- Sunday's Dyno Pulls
- Tial Wastegate Spring Change
- Hondata 4 Bar
- i need help with idle problem. BAD TPS ??
- question for "the shodan"
- Piecing kit together P28 ECU on F22B1??
- need this question answereddddd
- Vortech S/C For B16 Fit b18c5?
- top mount peak boost kit and regular
- which arp rod bolts do have? 3/8? d series.
- want to buy a good turbo for my b series
- please anwser a few questions for me..
- d16 intercooler size, going from 7" to 12" ... will i notice a huge difference?
- b16 head on a gsr
- iat sensor mounting
- HT turbo kit??
- Quick AN fitting question.
- BOV Not opening properly
- Installing victor x and 74mm TB?
- IC piping too small?
- does anybody have the ECG SMC plus intructions???
- Where to get a wasteagte elbow????
- analyze my spark plug please
- need help with weird idle problem??
- oil catch on turbo f series
- Anyone's OMNI Power 4Bar MAP sensor take a poop yet?
- egt sensor question
- Someone With Experience B20 Vtec Turbo
- Turbo kit for d16z6?
- Zex Dry Kit
- Autometer Oil Pressure gauges = junk?
- Building boost at launch??
- Anyone have expierience with zex/comp Cams
- Best header for b16 s/c
- p30 tuning help
- Need a quick answer. Going from reciruclated dumptube to open. Do I need a retune?
- need help with turbo setup d16.
- return line facing foward? where to get barbed fitting?
- Searched, JRSC question.
- Engine Management
- Need help with turbo Da
- Oil Leak After Turbo Install/Dyno Pulls (Auto Tranny)
- Jdm sohc vtec D15b made 206whp at 9lbs. Buddy made 226whp at 8lbs.
- Edelbrock sandwich adapter almost blew my motor
- anyone thought of this way of modifying after market torque mounts?
- b16 turbo questions
- Turbo Feed Line
- using eclipse mani to turbo f22b2
- Help with my Turbo K swap
- Precision turbo TRASH
- Smoke screen on decel.
- F23 Tuned with Dyno #'s!
- do i need a scavenging pump?
- Your opinion on ... T3 .46 A/R, .48 hot Side on a 2.2L motor
- HKS ssqv not opening TRIED EVERYTHING ! looking like its a POS
- anybody got a hondata map for a b20 vtec turbo?
- B16 build
- t3 super 60 too small for b16?
- Change intercooler piping slightly to add fogs - retune/drawbacks
- going from 16 psi to 18 psi?
- 1/8 mile, turbo sol, first time on slicks
- Bullseye Power S366XL in a Supra
- help me id this turbo
- MBC Adjustment help!!!
- my new z6/a6 sohc setup
- IMPO performance tuning
- Turbo/Manifold HELP..
- measuring exhaust back pressure withe defi boost gauge?
- B20 V-Tec Turbo overheating problem????
- hks ssqv not holding boost
- Turbo F23
- Turbo with A/C?
- HELP! 2000 civic si em1, on 7psi MISS FIREING!
- Boost and high compression GSR?
- JRSC in 96 GSR, is the sc pulley normaly really close to master cylinder?
- TurboCharging with Factory Parts??
- what do i need for my turbo
- Extended Manifold studs?
- GOLDEN EAGLE customer service
- fuel filters
- Picture request: NOS Microswitch hookup GSR throttle pully
- Is my GSR safe to boost?
- HELP! Turbo troubles
- tbk performance out of miami fl
- 9.1 CR built b16 cam and ignition adjustments needed
- HELP! Deciding between HDMM or HDSS ACT clutch for my 94 Integra w/ JRSC
- need a base map
- Need a good tuner in MN that is very good with the AEM EMS
- turbo LS/VTEC overheating
- help me identify this turbo
- how to build?????any info
- Those that have a turbo 5 gen lude
- Boost drop :/
- What quiet muffler to use? Twin loop, magnaflow? must be 3" inlet/outlet
- Brown valve?
- maxspeeding rods, any good?
- b20b stock with greddy 18g turbo kit
- Running No IACV. Can you do it?
- gsr turbo problem
- T-25 or T3 for ls?
- Nitrous timer, anybody using? Setup ideas for mine?
- how much nitrous
- Blowing oil. Bad turbo or engine?
- Cast Ebay mani?
- Weird Situation, Your Opinion Is Wanted
- H22 Lower Compression 2 headgaskets? Search Words: 2HG, H22-T H22 Turbo
- Lsvtec power with semi built block question
- what can a b16 handle
- Please help asap!!!
- gettin ready for turbo
- Hi-Way Cel, can't pull it. Searched
- Please Help!!! Greddy Emanage Blue Software Needed
- Turbo B18C5 safe?
- check this turbo
- Where to get 2004 Civic SI EM2 D series Custom Piping kit?
- Stock GSR Turbo Setup
- matching the gauges....
- !!!!!!!!!help!!!!!!!!!!
- ***HELP*** HOW TO RUN COOLANT LINES FOR GT SERIES TURBOS
- 6-7 psi....stock internals
- BEST INTAKE MANIFOLD FOR TURBO???
- expected gains?
- IAT sensor (intake air temp)
- whats not efficent enough?
- ok for boost?
- POSSIBLE BAD COIL
- 2000 civic gsr, When going from a roll about 55-60 rpm then WOT car backfires then goes
- golden eagle main studs
- thinking about boosting the gsr
- Revhard log mani, any grinding required?
- Boosting a D16
- Interesting Over heating Issue
- Integra GSR cams. into B16A2?
- supercharger belt
- flywheel resurface: how many times can it be done
- HELP im getting NO BOOST!!!!!
- Help! Morning Car Smoke?
- Stoping heat soak?
- Problem with CP 81.5mm rings. Need help ASAP (searched)
- Lots of oil coming out exhaust, is a oil restrictor needed?
- Acceptable amount of shaftplay in a rebuilt turbo?
- Trying to get the hang of the basics
- ideal size of intake tubing n/a vs f/i
- what ecu to run????
- Fuel pressure low after putting turbo kit on.
- turbo vs supercharger
- Need D-series manifold suggestion FAST!
- blew turbo up??? help this really sucks
- Is this wierd on a turbo honda?
- B16 block / GSR head / FI setup
- E85 tuning
- Removing Thermostat?
- Surge line question (b18c1) considering a GT2871R 52 trim .60 a/r
- high impedance RC550 with resistor box?
- Wierd issue with rpm(stumped)
- B16a JRSC kit on a B18b
- Turbo d16A6 overheating, cant figure out why... water temp too high...
- D16 low compresion parts
- Boost cut
- Retainer to guide seal contact while degree'ing
- Stroker kit, 92mm Or 95mm?
- Eagle rods-safe to buy used?
- gsr turbo setup
- Need a new turbo precision pt67 failed Which BW turbo would best suit my setup
- Can i swap out TD04 turbo exhaust housing?
- b16b 300-400 whp
- B16 jdm 2nd gen... Nitrous...Cam help :)
- suggestions appreciated for this turbo gsr build...
- LS motor Turbo running SAFC
- Magnaflow 3" Cat Comparison 94109 vs 14109
- hoosier DOT drag radial
- map sensors
- What TB cab for GSR JG manifold ?
- Update to vafc hack
- Wastegate on divided housing turbine - how?
- B16A2 PVC evap woes....
- Mishimoto Intercooler??
- brand new bad piston rings
- Where to buy pigtail
- camshafts picking
- dsm injector with a resistor box help
- help with 16g turbo
- Turbo EG GSR project!
- Good cast manifold for turbonetics 60-1, GSR?
- Need help with my GSR Turbo idling!!!!!
- help. map sensor. cel 5 p1128. greddy emanage, missing link
- Bosch LSU 4.2 O2 Sensor
- Wideband permanently installed...how long do you O2 sensors last?
- Vafc hack?
- Would like some opinions on an article I came across
- t3/t67 ho ball bearing
- found a turbo.. think it'll work? i have picures! :)
- Ebay Turbo kit Hybrid?
- turbo touching manifold
- Hondata Introduces a plug & play 4 bar map sensor for the Kseries!
- Opinion on 9.8:1 compression pistons for boost?
- need assistance with evap removal!!!!
- O2 Sensor & Turbo
- 98 b18b integra ls
- Two Cylinders Running Lean
- i THINK what i'm hearing is valve chatter. still ok to turbo that sob?
- boosting a b16
- New to boost, need some advice, help, and guidance.
- 92-95 civic ex/si greddy turbo kit
- Downpipe elbow keeps coming loose. Loctite? Which type?
- opinions: victor x or ported skunk2 IM
- Keeping Cool on long road Trip?!
- looking for a new clutch
- knocking? what to do
- Turbo crx problem
- Turbo for b18c?
- Damn Turbo Bolts!!!! Keep backing out!!
- need help with map sensor
- Turbo d info needed
- Going to track today.....need input
- Supercharger and nitrous questions
- doing an lsv-turbo build...
- Need help finding APR bolts
- What size bolts? ( turbo manifold into head )
- h22 exhaust manifold turbo
- DSG or Boston Dyno?
- Alternator belt shreded
- dumb question......
- t3/t67h.o. + 38mm waste gate????
- boost gauge problem is it the right gauge
- Secondary fuel rail.
- Bad Water Pump?
- Questions about the AEM EMS
- stock 2000 honda civic hatch cx turbo help
- o-ring question
- Question on Helping Keep Cool under Boost!
- EcTune vs Crome/d16z6/Greddy kit+fmic
- Intake Air Temperatures....... what are yours?
- loud wastegates..
- Good turbo for a stock B16 build 250 whp goal
- IC piping dimensions
- my boosted ef
- Help with precision injectors?
- LS Pistons in 2g B16a block....
- ANy info about the Manley/K1 rods?
- How much HP are you making with your Peakboost turbo kit?
- oil in IC piping HELP
- car runs bad when weather is hot
- help car started smoking after turbo
- So, I smoke tested my car today. Synapse - Please Read
- FMU
- walbro fuel pump
- My b16 project...
- Turbo seals going, what should I do?
