View Full Version : Forced Induction
- Any one have pictures of a t3-60-1, in a integra?
- NX Group buy
- Whoa.......running without coolant?????
- Taking offers on..
- HP GSR axles can take...
- sound like a good deal for this hondata?
- what fuel management to use with OBDII???
- turbo sohc, fuel problem
- ... air in the coolant system
- pics of the car
- Wastegate Vacuum Source?
- How much nitrous would you dump on this setup
- SOHC turbo guys, I have a couple questions 4 ya.
- just installed my greddy kit and i am boosting to much.. please help
- Exhaust question for my turboSIREKhatch??????
- ... help me pic a new turbo!!!
- 2.5" muffler that looks stock?
- what oil weight for winter?
- Turbo done...couple Q's
- t04e on a h22
- how to install a prodrive oil pump gear
- Drag radial size and type ???
- going rev hard on 00 Si
- Anyone know where to get a specific part off an Apexi EGT gauge?..........
- Is there any cheap/easy way...
- How much boost?
- for the DIY guys
- FS: Drag III LS / Type R / SI
- fastest stock Ls head and block street car
- Did anyone see this Del Sol?
- where to get good deal on Rev hard manifold and downpipe..
- Do you need a flex pipe??
- Overheating (another thread)
- ** PISTONS for LS/VTEC?? **
- fmu + hondata?
- Where to mount boost gauge?
- ** CONVERT from kg/cm2 to P.S.I.???? **
- Oil Pans, Is There A Difference?
- Custom B20B head gasket for turbo
- Got my new downpipe for my Greddy kit.
- ATTN: Greddy Turbo Kit owners....wanna trade?
- FS: H22A1 Iron Sleeved Block, Endyn/Wiseco Rollerwave Pistons, Cometics Headgasket
- Shimming of oil pump for boosting - is it needed?
- Anyone know the number for MVA Motorsports in NJ?
- is a ported + polished built head and a turbo too much for stock internals?????
- Building a custom turbo kit
- ... car problems... please help... !!!
- No oil from oil pressure sender outlet?????
- Turbo first or second? Advice, Opinions... Guidance Needed!
- traction bar pics
- Going hondata on JRSC...knock sensor question
- How large turbo's affect torque...
- Timing and Fuel Problems on 99 Accord w/ F-Max kit
- wtb crx si 88 or newer
- need help fast...going to install turbo in 4 days
- manifold/gasket leakage?
- good or bad???
- 0.48 or 0.63 a/r housing for b18b
- My first problem...car wont hold vacuum, joygasm
- jrsc and camgears
- 2 1/4" vs 3" for low boost
- spaying the turbo
- Where can I buy Cunningham Rods?
- OT: But I need help with my LS
- Need to complete rest of my turbo setup
- Filter for revhard kit?
- Where can i get a turbo manifold and downpipe made.
- Anybody have a turbo for a 95 Integra LS?
- quick turbo question....oil feed
- 18lbs on stock ls head and block
- Group Buy On Oil feed and Return Lines?????
- leaky seals
- what is nessisary to boost this teg?
- Overheat problem.....WON'T GO AWAY.... Help
- Welding on to Compressor Housing
- anyone ever tried one of these?
- Group Buy...EAGLE...NX...CR radiators
- who needs a manifold? i got one
- Newbie question
- Anyone havea MaxRev kit installed yet??
- Turbo timer + keyless entry
- WTB d16y7 cam
- cheapest place to get a turbo rebalanced?
- Thinking of selling my car...should I do it?
- Supra 440cc injectors direct fit in 92+ honda/acura?
- i need a cut away diagram of a t3.....
- How will this set-up do?
- what fitting goes in the oil pan for turbo?
- FS: H22 Turbo Manifold
- Need help, just did a compression test
- Another Newbie Wanting Turbo info!!
- Any body got a greddy turbokit?
- Could somebody post a pic on how their inline fuel pump set-up looks like?
- HELP Over Boosting
- ... running too rich for too long... problems
- Not Boosting after running too rich...?!
- T3 Turbine Bolt Patterns
- New rev hard downpipe for sale
- Whos got the cheapest turbo set up!
- Car is getting funny on me......
- Boosting issues.
- Check engine light on....need help!
- Does anyone have an intercooler FS
- AFC Hack not working right
- safe to boost?
- nos jet numbers?
- Still running lean!
- Help me pick out a turbo for a 2.5L
- AEM EMS Wideband O2 AutoMapping.. Does it justify purchasing a wideband???
- I need help running my oil lines for my turbo...and help with the check valves
- measuring resistance on resistor box
- turbo on v6 accord (2001)
- what rpm range creats boost?
- nitrous pressure relief valve...
- Need urgent info right now! Viren, Rocket etc..
- Did compression test, need help
- Whats YOUR weakest link
- Just got off the Dyno...
- what are symptoms of a seized motor?
- can someone tell me how to reduce 12 volts ..........
- 14b turbo setup
- Any gear sets that are preferred with turbo?
- dsm injectors on a del sol?
- Oil squirters for B18b( How, where, NEED HELP
- Custom exhaust help
- WG gasket not sealing.. Any suggestions??
- exhaust manifold
- prepping the block for turbo
- d series drag3 manifold $350 shipped to your front door!!
- Forced Induction and Auto-X.
- quick boost questions
- REV HARD DP and o2 sensor???
- Help Please
- Just gain 4 psi with rewelded intercooler.....
- N20 on leaking head gasket...
- Turbodreams vids, anyone have them?
- What the hell!!!
- Afc Hack and dp question
- New Swing Valve Assembly and Actuator - $75 Shipped
- Dual Fans to Single Fan?
- Need Instructions on Drag Turbo Kit!!!
- filetofit DIY maplimiter
- sohc vtec turbo vs. b16????
- FS: APEXi AVCR electronic boost controller..Cheap!
- greddy turbo problem
- Anyone put Jackson Racing SC on a ZC?
- t3 60/63 on a b16
- 314 WHP Turbo RSX?
- Compression on boosted engine
- OT: help forum or FAQ?
- 300ZX Motor?
- anyone know where to get 2 arp headstuds?
- bogging out with drag turbo kit
- Sohc turbo spark plugs
- fpr and gauge
- Is this the correct 60-1?
- Zip you are the man!!!!
- Detonation or misfire?
- car won't freaking start
- weird quesion about how an IC can be used
- Help! Car runs great cold.
- WG spring..which one do i have?
- JG/Edlebrock or Venom Manifold?
- good timing system
- aeromotive fuel filter question what to do with fittings
- My Dad is in the hospital...I'll get back to all you guys later this weekend or Monday.
- anyone using a moroso oil pan?
- Anyone noticed my new name >>>>>>>>>>>>>>>>>>&
- Need your opinions boys-n-girls
- How Vortech just screwed me over for one of my customers..
- Got screwed bigtime by JG!
- B20B turbo - please give me some precautions!
- Hondata releases S100
- Greddy Turbo kit for 2001 GSR?
- Starion IC modification
- Reliability is overrated
- Is it worth Turboing a D15b7 in a 92 Dx i have laying around?
- Quiet exhaust compatible with turbo...
- AEM EMS + techedge DIY wideband = Autotune!
- Vortech Boost ????
- *** just did a comp........ BLOWN HEADGASKET???? ***
- prob w/purge kit
- Greddy Profec B $250 Shipped
- BOV routed back into intake pipe... pros and cons
- Air Fuel Ratio of 310 injectors and FMU 8:1
- Turbo Timer
- NX Incognito system HELP
- turbo cams in NA setup
- want to run 10psi what to watch for
- Will the fuel pressure be too high if...
- WTF!?!?!?!? I was thinking about upgrading my 4B to the new s200 but...................
- Apexi AVCR!!!!!Come on....
- what does oil in the coolant reservoir mean?
- Is Kaaz tranny fluid bad for my tranny?
- thinking about selling my full set of slicks on bogarts, how do are they worth?
- TB Sealent
- Tried the serch , but NADA , pics and specs to turbo type R's appreciated.
- ... limitations on increasing boost
- Have an SMC question!!
- Anybody got pics of their civic turbo kit?
- How loud is Your BOV??
- Greddy type 24 intercooler and the Type 31..which is bigger
- RevHard Stage 2c
- compression on built motors...
- *little* step on the gas will bring it stalled?
- A question on SMC
- Who's running a GSR turbo?
- Storytime: I drove my first turboed hybrid tonight :)
- Those with tech edge wideband diy or prebuilt.
- Heres my setup and fastest track time.....
- Bergenholtz breaking in his rings
- custom turbo kit please help
- custom turbo kit, please help
- Is a Walbro fuel pump needed?
- Hybrid Tranny...somebody school me real quick
- Does anyone actually RACE with a ZDyne?
- B18B tunning questions....with a Zdyne.
- Anyone planning a dyno day in the Tri-state area??
- BottoM END, boost!!!
- Connecting O2 sensor signal wire to AFC
- vortec fmu, what ratio?
- B18C stock + EMS + 550 injectors: Base map needed!
- How can you tell if the fmu is sticking?
- FASTEST Honda/Acura streetcar listing (current)...
- quick question on banjo fitting
- Honda Fuel pumps universal?
- swapping stock intake manifolds
- laptop for hondata...
- Its time for Rev hard groupbuy some one do it....
- Cheap BOV?
- HP limits of walbro 255lph?
- DSM injector install horror story
- OVERHEATING, I am totally stumped. any ideas?
- N20 and Street cams
- REVHARD Manifold owners.. please help.
- R cams or Crower Vtec/turbo cams???
- pics of 3 Bar map sensors!?!?!?!
- Should I rebuild 110K mile GSR motor before boosting?
- is T3 to big for sohc
- Serious technical thoughts on the effects of altitude......
- T4 and T60-1
- Car is running!
- any good?
- 7 or 8 psi sohc greddy turbo
- open exhaust on turbo?
- I need info on SOHC turbo!
- ... stock block & head w/ vafc hack (550s) & cometic headgasket
- Call partsbin now. they o2 wideband sensors and going fast
- JIC 3" Exhaust?
- Anyone have an opinion on Turbo Cams?
