View Full Version : Forced Induction
- 1992 cx hatch gsr boost
- Port and Polish GSR Head
- b18b plan to 600 hp ,, need help
- Turbo manifolds- Mini ram
- Turbo question..need help
- Msd plugs wires?
- tial turbine housings?
- use vacuum block as oil block?
- Identify this log mani
- Need some advise from some friends on if i should go back to NA.
- catch can no drain block high power setup
- how to do the cheapest turbo build
- Has anybody used EV 14 bosch 850cc injectors
- flashing oil light and buring oil
- Motor Mounts for Boost!
- My 99 SiR build
- Cheap Ebay Map Sensor Test - Epic Failure
- Someone help me get this ugly external coil out of my engine bay! pictures inside!
- what would it take to run this turbo on a b16a?
- B18 bosoted help
- Turbo GSR Skunk2 Pro1 Cams Idle
- F23A Turbo question ?
- OEM Crank VS. Eagle?
- s2k turbo kit questions
- EK9 turbo questionaire from AUS
- B16a max power on stock sleeves. build ?'s ect..
- My LS-T Build
- Power expectations.
- Turbo JDm F20b !
- Dual W/G which springs and connections?
- For those using the AEM methanol injection kit - What nozzle did you end up using?
- What oil would you guy's run in this setup?
- Integra '91 + Bosch 044
- painting turbo compressor housing?
- Is a 2mm (.080") oil restrictor adequate for a journal bearing?
- Tial 44 wastegate
- need help with turbo d16 build
- Guess the sleeve
- WWYD, "Keep" 3" DP or get 2.5" to mate with 2.5" piping?
- D Series with Evo 8/8.5/9 Turbo and Divided Manifold. Who's done it?
- Anybody running Golden Eagle Parts?
- Can this Block be saved?
- hx35 topmount options?
- rich only at idle.....
- Safe PSI for basemap?
- .42 Ar GTR turbo on B20v?
- garrett gtx3676r or EFR 7670 for my s2000
- Duel Wastegate w/Boost By Gear Diagram-Check it out
- Toronto Turbo New member RSX Turbo advice
- Fuel injector keeps failing even after new replacement
- MrGrims B16B JRSC High BOOST BUILD
- Low boost/quick spool D16Y7 - worth it?
- 93 Accord Hoodrich Build. NO MONEY SPENT! Get ready to be entertained.
- CP Piston big problems!
- 95x89 Questions
- Godspeed gt30 anyone?
- boosted ef, z6 @ 8 psi, low numbers???
- Best paint for aluminum intercooler piping?
- Compressor maps / surge limit
- ID Injectors Voltage compensation?
- CR JRSC D16
- ek hatch h22 turbo pick?
- best oil line feed kits out there
- rev limit assistance
- gsr or ls internals
- Recomend me a turbo for budget drag car.
- How can I tell if my flange is stinaless or mild steel
- Any TD05HR-16G turbo users?
- HELP b16a turbo afr problem
- H22 turbo target - 500whp - HELP/Opinion
- Camshaft specs: NA vs. SC vs. Turbo
- Fried piston... :(
- FYI...MAJOR SALE SPORTCOMPACT!!!
- Valve springs
- H22A turbo wide band sensor help
- Need Help Identify this turbo too!
- How to: make Cold air Intake for turbo for Ramhorn/Cast Log
- Tires for boost - STREET??
- Map sensor?
- b16 project question
- Stealthmode Performance- *Closing for good*
- Just turbo'd the K, now a few questions.
- AN fitting size
- Check me please
- stealth mode performance oil lines?????
- Go-Autoworks street vs. tuner kit
- 96 Boosted Civic in limp mode....HELP !!!!
- Decent size turbo for goals/setup?
- New turbo, sale pricing, which one help!
- VTEC and Boost
- big power ef/ed chassis fuel line questions
- Go autoworks vs Ebay
- Coolant temps when it's 20F outside
- Custom coolant setup
- How to plumb a return oil catch can correctly
- can you help reading my spark plug ?
- The thermodynamic effects of turbocharging a factory NA engine.
- Turbosmart wastegate actuators
- Looking for some experienced suggestions.
- 750+whp Setup. Suggestions & Opinions
- turbo with no intercooler or bov
- Cris Hybridworks EG6 Final Results
- Best Turbo Intake manifold?? HELP!!
- Diy catch can, filter venting or can I simply drill lots of holes on the top?
- ------------------- Need help identifying STRANGE GSR Final Drive ------------------
- Help Identifying Turbo
- Jackson Racing D16 crank pulley
- walbro inline fuel pump and 255 fuel pump 700whp on e85?
- New CX Racing turbo manifolds, allot better qualitiy what's your opinion?
- SRT4 intercooler
- Greddy type r bov - how to tell which spring it has?
- B16A2 Bad injector or something else I should look for?
- Connecting air filter to elbow/bend and turbo inlet
- Oil return question
- New i/c piping (torque mount don't fit)
- What Turbo Would You Put On This Set-Up?
- Looking to go turbo
- need some advice on new fuel pump setup.
- Best Water to Air Intercooler Kit
- Boost Creep?
- WTF did i do? Help, no boost no clue
- B16a-t with CTR cams stock rev
- RHD civic eg with blown turbo swap. need some advice
- Advice on sure things to do for a turbo ready ITR build
- BOV, what is this style called? what type is this?
- 3" downpipe and exhaust help please.
- T3 vs. T4 S362 ETT turbo K20A2
- my lame rebuild thread and a timing concern.
- wastegate sizing question on lsvtec
- B20 non vtec nitrous problem...
- DA integra, tall intercooler, what to do with crash beam
- Win Free Turbo Manifold
- Correct pulley combo for 8-8.5 psi (ITR with M62 JRSC)
- wideband advice
- meth thread
- turbo da smoking?
- Minimum CFM fan rating, rad almost entirely blocked
- Hondata BBG and Solenoid issues
- My 11 Second Turbo Integra ! Finally!
- 90 integra da's Ls/vtec turbo build
- Crack In Turbine Housing - Safe to use?!?
- Aeromotive 340 Fuel Lines
- Wastegate relocation problem or not
- garrett turbo question
- bouncy idle
- turbo gsr advice
- time to choose my new turbo
- Type r pistons in my gsr motor
- Turbo selection for xmas gift! help!
- piston question
- New fuel pump (now too rich at idle)
- ~~ how much ft of hose for fuel feed/return lines ~~
- Very quick question on turbine housing...
- OIL QUESTION
- Ls/vtec build?
- crx goals
- few issues with plx sm-afr wideband
- B16A 83mm or 85mm?
- EM USA racing turbo kit help.
- ARP head studs or bust! Wtf?
- manifold seperated from down pipe; damaging to drive?
- B20b Turbo Build Questions
- turbo in 98 integra ls, minimalist setup
- Turbo b18c vs lsv turbo
- Hondadsix's turbo DA rebuild
- Best Oil cooler / install suggestions
- Injectors
- combustion chamber damage?
- low voltage problem
- B18b turbo *need suggestions*
- He431ve Info
- FiveOmotorsport EV14 1200cc injectors
- Turbo choice help, down the road
- 2 questions! (d16y8)
- Garrett Core size and power
- PSI vs CFM
- Ebay turbo
- can someone learn me on upgrading turbo internals/housings..
- quick question on compression, turbo d16
- need help with gsr turbo
- Low power on b20b???
- Ef Si hatch or eg coupe
- running lean
- Too much fuel/ too much timing??
- no boost
- couple of questions regarding driving on a fresh build with no tune.
- Blue Ridge Turbo Manifold Info
- Plug Garret T3 wter ports if not using?
- Experience with BWR BLACK SERIES 1/2 size radiator
- DirtyDSeriesWOot
- 550+hp stock bottom k20
- B18c Boosted....Need help with gear ratios
- Intercooler dimensions for 94-01 Integra?
- Boost leak?
- 99 Ebp Em1 (Rebuild For Boost)
- new, looking to spray 100-150 shot on a semi stock b series help me out!
- catch can issues
- Thermostat?
- New b16 nippon question.
- Looking to Build my B16a
- Bone Stock GSR turbo build for 300-350 WHP
- Opinions on AMSOIL oils?
- 95 Civic B18C top mount turbo kit
- Help me pick the correct turbo for my set up and hp goals
- Guide for adding timing after dropping compression ratio
- DD turbo k build?
- time for new rings?
- churches dyna pack vs raceline dyno jet. My results 60 less hp on the dyno jet
- just ordered 8.5:1 wiseco pistons..questions.
- limits of b20z sleeves on nitrous? (no noobs!!)
- help with turbo
- head gasket choice?
- New motor smoking issue
- Simple B16A Build... What Turbo Would You Use?
- K20 turbo setup intake manifold - RSP, RRC or?
- Anyone run this turbo before?
- Borg Warner S372 @ 27 psi??
- oil weight
- J32 Crankcase ventilation question
- spark plugs for 13.0:1 compression + nitrous?
- Billet Ball Bearing Turbo Concerns HELP.
- for advance users, ls vtec turbo having MAJOR issue "look inside"
- my ls turbo build
- touch screen tuning?
- Variable Nozzle Turbine, any B series builds I can look at?
- Downpipe trouble: k20 ekk2
- right before boost...
- EK D16Y8 DSM T25 fittings and hoses need!!!
- SCORED a 1g bov dirt cheap, would cleaning it hurt it?
- Intercooler. I need one back door, one side outlet. Not common??
- Needs some info on an ITS turbo (Turbo internals)
- Jerking Issues
- turbo question
- LS/Vtec Build
- smoking problem
- Supertech Valve identification help
- OBD0 Crx, will stock injector clips fit PTE 650cc. HIGH or LOW imp?
- LS crank vs GSR crank
- Turbo civic running very rough
- Variable vane/geometry turbo setup
- Turbo build opinions?..
- Evans Coolant?
- Tial MVS wastegate problem
- end tanks.... who makes them?
- The post what cylinder head/valvetrain you have thread
- recomend a turbo upgrade for my s2000 gtx3076r or gtx3576r
- Need good quality T3 Turbo Manifold
- Blew headgasket or cracked sleeve??
- Hondata or AEM
- oil coolers
