View Full Version : Forced Induction
- Drove to Idaho, had a few problems. Check out my spark plugs. some overheating. Feedback please.
- Switching over to INdividual Coil Packs, Where to start?
- Boost creep/spike question...
- car runs like shit (compression results inside)
- turbo return placement
- Jackson oil cooler ?'s
- HELP: Turbo leaking oil
- AVCR Shutting off
- PLX m300 install HELP
- New to Honda-Tech
- pic request: dsm injector connsctor (not the clip)
- peakboost = 12's
- will 3 90* bends and a 180* bend be enough for charge pipes?
- where did you buy your silicone couplers at and how much did you pay?
- Apex'i SOHC kit owners.. Dyno results for comparision?
- will it work?
- jackson racing and pcv valve help
- Down pipe selection
- twin radiator fan on single core.
- Which should I build... Turbo B16 or Turbo LS ???
- What Radiator? (on a tight budget)
- Looking for gator axles
- CANT TURN TURBO FOR OIL DRAIN..PLZ HELP!
- running no filter
- Removing Burnt Caked on Headgasket From Block. HOW HOW HOW?
- b16a2 problems low compression
- any body using gsxr coil
- peak boost kit on LS
- GT40R vs PT71 GTQ........
- PLEASE HELP TURBO PROBLEM b16
- Finally, 1st full pass at the track with the new motor build. (vid)
- turbo manifold
- where to buy endyn catch can
- h22 supercharger in EG?
- Alcohol Injection ran safely
- Anyone have big numbers on cheap intercoolers?
- Boosting d16z6
- power?
- Help! Is my car safe to drive? Have some (prolly) simple turbo questions.
- b18c1...with FMU..safe boost level?
- b16 Vacuum pressure
- Which brand inline fuel pump to provide 50 psi to nitrous solenoid?
- Installing Action Clutch, which side does the 6 puck disl go?
- JRSC dynoed at 240whp @ 12 psi, want to tune with wideband !!
- lookin for a turbo for my del sol si d16z6?
- H22... direct port 100 shot...
- Nitrous jet for oil restrictor???? what size??
- Tiny bit of oil on compressor inlet?????.......brand new turbo
- HONDATA w/ boost option ~VS.~ GReddy E-Manage
- Cannot lean out Uberdata idle
- TurboSmart UltraGate 35 vacuum hook up???
- Engine sleeving by local machine shop?
- Turbo Coolant Lines Idea
- 3 Bar Map Sensor Question
- 310cc good for 10psi
- SOHC GReddy dyno numbers
- Bearing clearances???
- turbo problems (gauges)
- installing map sensor hoseing for turbo kit.
- want a T-kit.
- Power loss at the track, LS turbo, could it be the 116oct ??
- Exhaust blowing out oil
- well after all your help, i pulled the trigger. thanks for the info guys (PICS!!!)
- need ecu chipped in dc area asap
- solid check engine quesition
- trying to decide on a turbo kit????
- Setting up Wideband Datalogging with Uberdata
- Installing ARP head studs without ARP moly lube
- which is oil inlet and drain on IHI turbo
- need advuce on how to rebuild my B16A2.
- 400+whp, what intercooler should I go with?
- is this turbo ok for my b16?
- turbo placement problems?
- Coating turbo VS. Heat blanket
- cant boost above 4psi even with EBC....
- t3/to4e right for me
- Oil Burning
- Oil Line Question
- Neptune Download
- gt28rs turbo on t3/t4 flange?
- Fluidyne or Koyo radiator for Civic 95EX-T ??
- gt35r spool .63 vs .83 on b16?
- Pocket Programmer II with Romulator
- Alrighty, coming close to my install time, Just a few more Questions.
- GSR throwing code ????? help.......
- Evans Tuning in PA is now Apexi Power Excel authorized shop
- problems with start-up on new setup
- Need help on shop info in bham/atl area for rebuild
- HELP need info on turbo bearings
- BRAND NEW fresh engine....sleeved and turboed. Having problems!!!
- dyno'd my sohc
- re-use crank bearings??
- Himni Racing? Expereiences? phone number?
- Stock Evo 560cc injectors info
- Plastic cased bearing on bellhousing for mainshaft...
- diy dual stage boost controller with GM boost solenoid
- off topic: cheapest place for k&n filters?
- Overheating Problems... Cant Solve!
- Swapping exhausts after getting tuned?
- searched but cant find safc2 hack for my turbo gsr
- Installing ARP Head Studs. Write Up? How To? D16A6
- hooking up MBC
- everyone with "intake"
- What du guys think of this Turbo?
- rc550 saturated use box?
- daily driving with ats lsd?
- how often do you need a re-tune?
- Which Turbo setup would be better for me and why??
- LOOKING FOR A TURBO TUNER IN THE BAY AREA
- where to mount my IAT intake air temperature sensor
- Do these bearings look ok to reuse?
- Should I brace this manifold, pics.
- First time turbo user
- My D16Z6 Turbo Project
- Any turbo tuners in ny/nj?
- Replacing pistons with used ones...
- 880inj+mild built block+60-1=bogging
- Which turbo is similar to HKS 2835R?
- How far did you get and why'd you back out on your turbo kit?
- UBERDATA QUESTIONS AND MORE<<< CAUTION...NoOB INSIDE
- ls-turbo daily driver
- LS VTEC TURBO QUESTION! NEED THE HELP
- Safe to drive not in boost with no tune?
- external wastegate
- 601whp/430tq, Stock Sleeves, Stock ignition
- What's the power record on eagles?
- Jason (st00pidr)from Houston comming up on Aug. 27th for a tuning session (Ft.Worth)
- Crower torque specs for D16? Possible to use stretch gauge?
- cheap turbo?
- D16Y7 block with D16Y8 head question
- Turbo B16 wont start?
- Piggyback controllers and knock sensor?
- OT: trouble getting into 1st after lsd install...
- 06 GS
- Car not starting with 450ccs and Uberdata
- S300 vs stock edu?
- One Mean Accord
- bringing together a 500+whp ls, what does it take?
- Am I too small? (I bet it is)
- manifold?
- no fuel!
- Two 14mm allen bolts on back of B18C how to remove?
- down pipe questions
- Just a little Eye Candy..
- Anyone Use Autronic EMS?
- High output fan for supercharger
- torque specs
- t3/t4 and t3/to4
- need serious opinion plz
- high milege engine for turbo...
- Knock and pre-Ignition?
- tail wastegate install Q's.
- NAisBest but BOOST in progress. i need sum suggestions.
- what you guys think of the new setup
- 14b efficiency
- Dyno Video's, Highway Races.......Raceline Built cars
- RC 550 injector install
- The WEIRDNESS CONTINUES!!
- How to tell difference between A/R on T3/T4 in Sohc Drag Kit...
- Differences between the GE and AC sandwhich adapters?
- Is this d16 crankshaft ok to use in my NA build?
- Vortech b18b setups?
- Limit HP to my current LS nonvtec??
- Suggestions?
- Ebay turbo rebuild kits good bad and which to buy???
- TD04 14G Water or Oil cooled?
- Need help, where to buy silicone couplers (90's)?
- WHERE TO BUY ALUMINUM I/C PIPING
- question about map sensors?
- whats the different btw .63 & .82 ar?....
- Couple isues i never had to deal with before.....
- NEED HELP,now CEL code 45!!
- running great,but....
- what will happen if ill remove the oil lines from the turbo???
- What timing for 83mm B18C, LS crank, 9.4:1 c/r, Portflow head, stock GSR cams
- do all turbo motors smoke?
- normal #'s?
- T3/4 turbo lines and setup
- Garrett gurus a quick question
- Drag kit turbo information
- Why you should not over boost a K20A2 on stock rods
- Fuel question on 8psi setup
- Blown Integra Non VTEC
- map code and waste gate not oping help!!!
- Correct me if I am wrong.........
- JUST BLEW MY ENGINE!!!! AAAAACCKK!!
- Anyone use this turbo on a D-Series?
- action clutch users......please check it out.
- Building my first turbo manifold. need pics of h22 setups
- B18b turbo
- retorquing ARP's on a D16Z6 - on hot or cold engine ?
- Fuel pressure regulator needed or not needed?
- Can't identify my Turbo
- GT30R Oil Lines Water Lines
- Subaru WRX Turbo on B18C?
- can i use a 6 puck disc on my CM stg 3?
- 1boostedcivics built d16z6 in the works.
- do i need valve train upgrade when going turbo?
- datalogging on neptune
- help building my turbo setup please...
- need help asap! zex dry installed now problem
- Anyone still on a single disk clutch for 500whp street cars?
- Oil filter inline with feedline to turbo?
- Need some good turbo info...dont understand a few things....need advice...
- Opinions on this EBAY manifold
- greddy turbine housing gasket Q?
- CRX B16 new Turbo setup NO Boost problems help???
- blowing blue smoke(oil?)
- Datalogging with Uberdata
- E-manage voltage clamp?
- thermo wrap pics
- Converting to OBD-I: Do I need to put o2 bung in Carsound cat?
- newbie faq
- greddy turbo timer harness ?
- IS this CO2 Setup possible?
- what should idle boost gauge vac be at???
- Is there any risks... ( lapping session )
- Nitrous
- DYNO #'s: D15B turbo
- Max boost on a TD05?
- Cast Iron Or Stainless Steel
- Another Skunk2 manifold Question
- Lets talk H22s and N20
- Back from the dyno and i just want to know if my #'s sound about right
- 615whp/395tq, 30psi, b16a, neptune....ON STOCK IGNITION?!?!
- D-series turbo build
- Which headgasket?
- GT35R h22... .63 or .82?
- Where can I get a bearing/seal rebuild kit for a T3/T4 ????
- exedy vs tilton twin disc
- where to tap into vaccum lines on a b16a2?
- Washer Reservoir do you still have it with your turbo?
- Greddy.....replace or rebuild?
- Vouch for R & D Performance Tuning(albuquerque,NM)
- how to know how much degree with cam gears are possible?
- need help picking one of my 2 motors to build ls motor or v-tec motor? build starts monday!
- d16 kit w/ h22
- Timing to aggresive?? detenation?
- turbo gasket?
- MAJOR SPIKE PROBLEMS!! HELP! :@
- AEM 5bar vs GM 3bar discrepancy
- Possible vacuum problem after going back to stock!!!
- fitment question
- turbo spool and vtec engagement
- How do these plugs look?
- Piston ring question - large gap = less power?
- SSAutochrome 1mil+1, B16 Civic 0
- s300 and JDM Ecu
- Wastegate Question
