View Full Version : Forced Induction
- Dohc ZC
- 3 bar map sensor
- It's been a year!
- Sputtering from 6k to redline!!! Ideas?
- .7 bar(10.15) psi spring, 9 psi consistently 10 psi once, 11 psi once, weather???
- b16 or supercharger?
- turbo glowing red
- 610whp/445tq, STOCK SLEEVES, 28psi, SFWD/T4 car
- NOVA people in need of uberdata tuning
- any damage?
- Catch can and PVC routing question
- p28 ecu question
- B16 dyno 7.5 PSI
- Map Sensor ??
- GSR dyno @ 9 PSI
- LS/Vtec dyno SC50 @ 8 psi
- finally got tuned right... had some scary stuff happen on the way...
- LS\Vtec turbo motor problem
- where can I get this oil feed line fitting?
- stock head gasket or .074?
- Odd CEL codes (1 and 21)
- Manifold for TDO5H
- how to wire my dsm 450's using crome ecu?
- Let me see ur engine shots w/ Inline pro manifold
- How to tune cam gears??
- 2.75" intercooler with 2.5" piping?
- spark plug wires
- no b series manifolds for a gt28r/rs
- How long did your motor build take?
- any experienced boost fluctuation with a MBC.....my boost drops a couple psi @ WOT
- Looking for UBER tuners in MID Western WI
- Can't figure out this UEGO wideband.... HELP!!
- mitsubishi eclipse gsx
- full-race b18b dyno on low boost
- Confused for Ecu?
- vac line help PLEASE
- NOS direct port. misses when nitrous hits
- question about soldering injector resistors w/ ecu plugged in..
- Best 2.5" silicone elbow?
- Car almost complete
- Sportatic Idle + Sticky throttle = ?
- 2.5bar map sensor Question!
- HP max with inlinepro headgasket and conservative tune?
- cutting up air filter for turbo screen
- help with hesitation after 5000+ rpm
- boost leak please help!!!!!!
- Turboing my ITR
- whats the max hp a t3 turbo can do?
- boost controllers
- Cooling
- Msd 7al-2 ignition for daily driver
- how much would you pay?????
- fuel pressure with JRSC
- DSM BOV doesnt seem to blow off??
- turbo for b18c1
- Can anyone vouch for Sketch_hs
- HKS D-series kit......Making an intake??
- injectors question
- *************please help me, i have a problem***********
- need help... DSM injectors.. confused
- T3 oil feed question .....plz help
- o2 sensors
- d16 can it use integra injectors???
- condenser fan
- Dowel pins on Mini-Me
- Map sensor
- Ls turbo teg makes 373whp on pump gas
- Zerolift turbo kit: 94 GSR, 120K miles, 278whp - 190 ft/lbs, 9psi
- Overheating problem.
- Peakboost kit, Ohio-style - 303whp 214 ft/lbs / 11psi / pump gas
- Car stalls at Stops or After boost? Any ideas? (In Hot Weather Only!)
- Turboxs Manuel Boost Controller Problems with Hondata Boost Cut Off
- emanage wiring same as blue box from greddy kit?
- What spark plugs for turbo Integra LS?
- tial 35mm wastegate
- grinding the block?
- Sensors and Gauges
- ebay super charger knockoff
- MACHINE single cam homemade turbo project.
- tuned....and now difference in weather
- ZEX Nitrous Tank Valve Removal
- what is the highest rpm for a turbo car
- anyone have pics of their oil return line with a greddy 18g, (upgraded line pref)
- Turbo Efficiency
- Intercooler Efficiency
- Do i need headstuds running 6 lbs on a b18c1 ?
- Timed my engine...off by 6 degrees and running 28 degrees of timing under 8psi!
- Keep A/C with Full-Race Manifold or Neukin Manifold?
- problem starting
- major oil leak after build....help
- turbo parts and gaskets
- jonny race car intercooler?
- Where to buy v-band for tial bov?
- how much timing to pull
- dyno vid and pics. D16Y8
- intercooler piping sizes
- b16a Turbo Questions.(Will i feel the lack of torque when racing SRT-4's & EVO's?)
- drag turbo kit worth it?
- in-line oil cooler?
- Those running a Golden Eagle OEM custom head gasket....Help?
- Help! Lovefab SST Manifold doesnt sit flush with head
- blew up turboed GSR in del sol...
- ebay clutch
- stalling?
- cometic headgasket for aebs sleeved h22a!
- Has anyone ever used Siemens Deka/Mototron 630cc saturated injectors?
- Where to buy?
- oil leak & black smoke!
- is it ok to run a car without an 02 sensor?
- Question regarding crank on a GSR project
- Shimming KAAZ LSD?
- What is Flowtech Race Ready?
- injector size
- blown head gasket @15psi
- important internals to upgrade for a turbo setup?
- Questions about a block
- ls vtec turbo
- b18a valve cover on b18b setup
- question about pulley
- Not holding boost
- How do you hook up a Greddy Blue Box?
- Using a blue box on OBD0?
- vacuum at idle?!?
- quick question about a td05h
- what causes main bearing from going metal to metal
- Walbro 255LP
- Cheapest Tbolts
- 395 whp stock motor gsr
- What difference will these mods make?
- air temp sensor needed?
- hks PFC F-CON questions.
- Greddy Type S bov same for a teg as an eclipse ANy1? need help ASAP
- anyone ever make good power on a log manifold or is equal length the way to go?
- possibly in need of an engine build
- hondata for pw0 ???
- at what psi should you run race gas?
- b16 turbo pw0 Tuning with what??? HELP
- does leaded gas kill wideband o2 sensors like it does stock ones?
- wheel size on a drag to4b anyone know?
- T3/T67 H.O. with ported shroud
- Sponsorship
- Switch for Turboxs Dual BC. What kind to use...
- Liquid to Air + A/C
- 14b oil lines and size
- Swapped 91 Civic fuel question
- Lets talk about heat, the damage it does, and the best ways to mitigate it.
- not Honda related, but.........
- My setup....*lots o pics*
- anyone have anything to say about this clutch?
- BMC Racing manifolds anyone using them?
- Oil drain leaking between turbo and oil drain flange, best way to fix?
- Honda Factory Exhaust Manifold Gasket
- 0 mile shortblock vs rebuild
- Whats a better comp ratio?
- Two-Part Question (Tranny/Manifold)
- Need question answered asap...d16a6 headstuds
- NOS blow down tube
- NOS bottle heater wiring diagram ?
- T3/T04E on B18C1, 76 trim?
- turbo from 88 saab
- Deltagate Mark II Install?
- Is anyone here using a GT2871R?
- Oil Return Weld on Bung
- Crower Turbo Cams - Cam gear setting?
- help not boostin
- Leaning out @ full boost
- B16.. to stroke or not to stroke... sending block off next week, need to know asap.
- APEX AVCR boost controller help
- 255lph walboro pump and 1000cc injectors
- .::Getting white smoke::Help::.
- need a cat for emissions, catco or carsound?
- Another Vitara compression Q
- anyone have a HKS EVC I or II?
- Jumpy Tach problem
- changing the exhaust housing on a sc61 from .63a/r to .48a/r
- Will i need a new oil line kit?
- Compression Question
- Nitrous jets??
- what turbo to get to make over 700hp
- Anyone have remarks on ERL
- what size injectors to run?
- Half or Full Size Radiator?!
- Looking for input from Turbo Honda Car Owners!
- head gasket options?
- choosing a clutch
- tuneing
- Weird Problem Regarding Check Valves/VAFC II
- sohc turbo setup help...
- Seem slow for 7psi?
- Confused on my water pump
- How much can i boost?
- Would you use Toda pistons and rods for your turbo buildup?
- Boost on gsr and some other issues
- fmu fuel return
- Steps for TURBO b16
- What cams to boost my gsr?
- EK piping kit fit in DC??
- LS motor......404's + boost???
- Idle hunting
- Turbo car sucks.....HELP ME PLEASE
- New dyno results...Innovative t68, full-race
- Hondata s300???
- Walbro fuel install with pics !!!!!!
- TURBO KIT FOR SALE IN SO CAL
- saturated or unsaturated injectors?
- mini-me
- My car has beaten me
- remove the pcv valve?
- CAN YOU GUYS GIVE ME IMAGES ON HOW TO INSTALL JRSC ON MY DC2
- Injector size question for my SUPERCHARGED B18C5
- Calculating Volumetric Efficiency with a dyno graph
- Hondata S200 with out boost option??
- Turboedit OBD0 TUNING in *SOCAL*?
- need help with install turbo kit
- b16 Drag Turbo kit
- Debate:BOV location, no idiots allowed.
- 9-3 turbo on an hx
- what other dsm's has 440 or 450cc injectors?
- is this comp test ok?
- car is boostin higher and higher in every gear is this ok???
- b16a wierd idle... possible vaccum leak?
- OEM headgasket and boost
- turbo SI psi question
- can this turbo fit?
- What do you guys think of this?
- some ???'s
- boosted ls/vtec
- H22 rods?
- I want to learn how to tune
- What is a safe boost level for a JDM GSR motor?
- Timing for a turbo car
- best tranny for high boost 400hp+ ???????
- Turbo smoking under boost.... drainline help!!!
- f series turbo
- Parts list for a boosted b16 block
- Turbo Guru's come on in...
- Exhaust flex pipe for turbo???
- oil problem
- b16 turbo pistons?
- turbo given to me :O)
- Adjusting valves on boosted car
- what times are people running
- Middle Tenn. Uberdata Tuners?
- Who makes Head Studs for D16a6?
- gsr block with aftermarket pistons and stock rods- what's a safe whp range???
- how high is too high for egt's on a built motor with stock sleeves?
- problems with newly installed turbo
- Car running bad
- Can someone find and ship me this
