View Full Version : Forced Induction
- How much oil pressure is too much
- B16 with GT32e
- Built high compression engine with Boost,VSC?
- TURBO QUESTION
- New Dyno Numbers!!!
- SC61 too big for stock internals?
- Hondata problems still
- turbo necesities
- turbo exhuast manifold measuremnets
- OHIO: Good Dyno Tuners
- total seal rings...machine shop telling me to KEEP them...
- Can I trust RPM NYC to tune my car???
- neptune....
- injector leaking! Help...
- HEY HOW MUCH?
- Turbo oil catch tank (the one with filter on top)
- 1st time turbo user
- 35mm tial on blox
- V-AFC Hack and JRSC
- looking for equal lenght turbo manifold...
- good uberdata tuner in the northeast?
- turbo 90 civic HB (D16a6) ???
- Having Problems with new Motor Build: Please help!!!
- Action clutch user... do you find your clutch pedal engagement too low ?
- I dunno what happened here..weird boost problem.
- strange strange strange
- Anybody with the AEM wideband
- t3/t4 vs t3/to4
- LIL BLUE "" VALVE"" on a dry NOS kit
- Dyno Video... 500whp Street Car
- DSM 450's. Whos Maxed Em Out? 325whp no problem..? Complete setup listed *SOHC*
- HKS exhaust or Electronic Cutout
- Where to buy T04E compressor oil seal
- hks b18c1 exhaust manifold
- Need help with a BOV and water cooler lines on my turbo!!
- B16 JE Pistons
- Humble Performance and Rolo tech h22 turbo hatch dyno vid inside<<<<
- Anyone here have shaft play with they're PTE turbos?
- 93 H-23A1 Turbo?
- max boost on fmu with stock civic d16 injectors?
- Tunning question
- T3 or t3/t04
- Super Blow Sunday!
- DIY a/c downpipe materials
- blox turbo manifold
- tuning in NWFL
- Fitment question: Turbo Kit Help please.
- aem tuning (DYNO DAY) in jaxs fl
- 16g too small?
- DynoJet Wideband Commander. . .
- mini-me vs. ram horn turbo mani. any tests??
- FMU and stock fuel pump
- Post pics of your K Teller 3" setup....Preferably Civic Coupes
- blox manifold.....
- Another Build...Bigger and Better Than Ever!! (Neptune Info Inside!!!)
- RC Injector Clip Wiring
- help me with turbo feed line to this. pics inside. ihi turbo for homemade .
- 91 accord obd1 h22 turbo question????
- Where to get schedule 40 butt-weld pipe for manifolds?
- Help engine randomly doesnt make low end to well.
- Holset HX35 Exh Flange
- head gasket
- What WHP is an Aeromotive A1000 really good to?
- Need some help, im burning oil...
- Jackson keeps eating belts?
- sc61/neukin
- Running nitrous with a chipped ecu?
- ECU wiring - lambda sensor
- Took my D16Z6-T to the Dyno today
- nitrous setup: what else would i need?
- gurus...i need some advice please....need to order these parts already..dont know what to get
- A/c clearance
- Running to rich.........
- light or heavy flywheel for turbo
- Any one heard of chemlube
- B16 Block Gsr Head What Timing belt?
- turbo oil catch can
- Look at What I ran into on Ebay...RWD Civic V6 Turbo....
- T3 clearance issues(gurus please)
- WHAT MANIFOLD TO USE?
- Turbo and ITBs
- Broke blitz Bov Vacuum nipple (help!)
- formula for intercooler piping?
- LS Turbo....high dreams crushin reality...
- pistons/rods turbo setup for sohc?
- Quick question...Injector size / Hondata
- Were do I connect the blowoff vacume hose to?
- anyone heard of these guys?
- Need help deciding on a turbo
- turbo intake
- Crazy back fire then car dies...Help
- WHAT SIZE OF WASTEGATE SPRING WOULD I USE?????
- Inexpensive/Relieable engine management.
- toyota ct26 turbo, would i be able to use it?
- Earl(Bensons) vs Dart
- How much time to pull per pound of boost???
- Opinions on this turbo (k26)
- Do I need a new fuel pump for my turbo setup?
- t3/t67 on 84mm b16?
- Need help asap.
- turbo mani question
- Turbo'ng a CRV
- ARE EITHER ONE OF THESE TURBOS GOOD, AND IF SO WHICH IS BETTER
- Huge Thanks to Camp 1320! (Pics/Dyno)
- for integra half radiators and AC ?
- help! hks turbo timer type 1 usa spec
- what turbo to get for stock b18b?
- removing secondary butterflies for boost?
- Final Pics of B18B turbo project
- exhaust manifold coatings
- whats is a good turbo kit for my ls b18b1
- How To Make My Ls-t last for 2 yrs.
- Most N2O on Stock Engine?
- Tuner in Maryland to tune DTA P8Pro
- JE Pistons and Crower rods for cheap?
- nitrous setup
- single fogger, biggest HP shot??
- turbo timer install help
- transmission/flywheel/clutch install issues...
- help for camshaft for my turbo
- Looking for someone to Dyno & Tune my Turbo setup.
- Hondata Map For Vortech B16?
- Help me, Give opinions, Turbo b18a1
- Greddy Type S or type RS
- victor-X intake ?
- sc34 or sc61 for my setup?
- Plug for the head on a h22
- What size Exhaust tubing should I use for a 500whp civic?
- turbo manifold studs.......AFTER DRAG KIT!?!?!
- Who actually has experienced big(bigger then ctr/itr) cams with turbo?
- Need help with setting up map signal for datalogging...using LM-1
- INTERCOOLER QUESTION
- Turbo 1.5 VX w/ MPEG movie... 12.1 Megs
- dyno info
- Help!!! what oil lines are YOU using?
- Stock LS dyno...
- questions about hooking up NOS
- ASSEMBLING: Eagle Rods - Vitara Pistons Need help, pics n junk
- Tell us about your Homemade Turbo Kit !
- Revhard Downpipe question
- Anyone have the Blitz DSBC?
- Pics of my turblo 2nd Gen GS-R. (56K get a samich)
- Turbo Sounds Like A super Charger???
- Dyna Pak has no external RPM imput???
- i remember there is a site for engine oil comparison
- Help with Greddy Profec B Spec II setup, please help?!?
- What do you think of my setup?
- TEO4h turbo
- what will i need to run a 65 wet shot
- low compression before turbo??
- New to the FI forum!!
- what size?
- Turbo DSM
- Built engine+Smog testing
- Socal, Need a machine shop for adapter plate.
- rlz engineering head ???
- the little green watermelon that could
- Turbo gsr dyno with Drag III Kit
- final checklist please confirm
- how good are obx turbo manifolds?
- Zeitronix wideband
- How to inspect a turbo for possible rebuild?
- Car running rich on no engine managment
- hkPa conversion?
- B18B1 T3 turbo AFC limited to 12 PSI???
- Turbo RSX 25lbs Turbo Advice
- Engine Managment
- Translucent oil drain fitting?... anyone have one? worth it? or no?
- Tial 40mm Wastegate Dimensions
- greddy EBC question
- 92-95 civics have the same IC piping as 98-99 gsr's?
- recommendations for a intercooler?
- Nitrous question...retarding timing on ob2 distributor
- Good Dyno tuner in MD??
- fuel pump and ignition question
- Greddy water temp adapter is it NPT or BSPT and what size 36mm or 38m?
- Must Dos for rebuilding your engine?
- Crx B16a completly stock w/ turbo?
- High HP D series, what is your timing >>
- Hondata chip direction?
- Anyone have a honda pt71 dyno sheet?
- How do you clean yor turbo?
- Wideband (PLX) freezing
- Funny air/fuel readout!
- graphic video (powerpoint) step-by-step of how a turbo works?
- Homemade turbo questions
- Brackets for Precision IC?
- going turbo now
- what to use to clean spark plugs?
- turbonetics/fmax or rev hard
- Question about ebay
- bov problem?
- Missing link question
- insearch of lovefab manifold for d series
- insearch of a lovefab d series turbo manifold..
- intake pipe or no intake pipe for turbo?
- cast iron vs stainless steel manifold
- #1 AND #4 ROD BEARING SPUN
- sc61 overkill for 400whp LS?
- LS power/time RECORD
- installing rc injectors...need "certain" seals?
- Any good tuners/installers in New England?
- BENSON ENGINE NEED HELP????????
- Hondata vs. CFT's MicroTech LTX-8
- turbo question will this kit work with my car?
- electrical supercharger
- i need to tap my intercooing piping
- Turbo on an Automatic?
- Good cams to go with Vortech S/C?
- SFWD B18C Dyno...
- How much boost can SRP's take? How much power?
- HKS Turbo Timer
- More Questions about my Turbo'd Ls....Tuning?
- CTR/ITR cams with Boost
- Vibrant Mufflers?
- Turbo w/ Internal wastegate question...
- another name that turbo!
- specs on a turbo?
- y7/y8 oil pan question
- turbo'd crx smoking from the turbo and exhuast
- help on calculating helmholtz resonance
- name that turbo!?!
- TD04-19t
- Easiest way to hook up a catch can setup
- Turbo Vs Supercharger Dynos
- Ls turbo to ls/vtec turbo...loosing torque????
- GReddy Turbo Kit for D16Z6
- how light is too light for a flywheel on a turbo lude
- ITR FI?
- Another possible D16 blown headgasket...
- Anyone have this Hondata problem? Cant enable datalogging
- how can this happen?
- which is right????
- HF T3 and A/C ?
- In line fuel pump
- should i use this turbo?
- p28 to run a ls?
- How to "clock" my turbo
- Building b18c i japan for boost
- i need to know which oil is better for turbo
- which wastegate spring to run? if ranging in psi
- Drag turbo kit for sohc zc in a 89 crx hf???
- Boost controllers.. what's the difference in single or dual solenoid?
- Broken bolt in manifold
- turbo h22 numbers?
- Should I turbo my B17?
- a little help plz..
- O2 simulator
- Moroso Crankcase ventilation system, anyone using this instead of pcv
- Hidden FMIC on 92-95 Civic? (sorry if repost searched)
