View Full Version : Forced Induction
- Dumb question about valve cover lines to intake
- tdo5 flange for a tdo4 turbo??
- Steel braided lines
- intercooler paint?
- realistically, how much can be safely taken off of a stock flywheel?
- turbo vacuum lines with avcr install
- Uberdata H22 turbo basemaps
- WTF?? FPR will not drop below 39 PSI?
- DSM Setup
- Another quick Z-10 catch can question?
- 300 mile plug check....how do they look?
- Just got my exhaust installed
- Who has the highest boost on stock b16 engine?!
- Benefits of MSD digital 6 over MSD SCI
- Bad Signs, please help...
- 3bar map sensor question
- How to defferenciate a hks wastegate spring
- wastegate gaskets the same?
- B16 dyno with Precision SC34 (447.8 whp at 25psi). Pictures and Video.
- SSautochrome's selling these turbos for hondas?
- Calling all boosted h22's
- tuning question
- How to tell a condition of a wastegate?
- Ongoing Wastegate boost issues. Please see inside.
- Fitting sleeves pistons and rods?
- how much can......
- diameter of ZC throttle body?
- Freeway/city engine break-in
- SS Autochrome Manifold
- stock injectors size ?
- S-AFC II, Boost Controller, MSD. Just a quickie
- Akari Motorsports Coated Lovefab Manifold and Turbo
- got a turbo question
- Waterless radiator fliud
- Just wondering...
- homemade catchcan? What dimensions?
- pay monthly for a turbo ((help))
- need help dunno whats a matter wit the car
- new car d16y8 turbo stuttered and stalled out HELP please
- Cometic head gasket q.
- Send it back??? or is it an easy fix??
- boost problem? turbo 5th gen
- FMU questions
- New pump gas dyno numbers in
- Need help - took turbo off and now car throws map code
- Twin Scroll turbo on a honda?
- I have ~$1,000 to spend on upgrading my turbo setup. HELP!
- Carrillo rods
- Weird Problem, Cant Figure it out
- Can someone convert my Hondata Rom for me?
- afc hack problems - 5, 7, 13
- Technical question about Wideband Sensors
- throwing strange codes
- precision 525 injectors
- turbocharger
- Leak down and Compression test results
- Nitrous on hatch
- Someone get the record straight.
- air intake manifold leak?
- b16a2 turbo or b18b turbo?
- Garrett GT32 turbo
- Overheating Turbo GSR!!! HELP!!!!!
- could i run a 75 shot?
- del sol kit
- Which Turbo kit?
- w00t! Turbo Type R dyno @ .4 bar: 198 whp hahaha
- Best Turbo Manufacturer
- Code 13-Barometric Pressure Sensor. On boosted 2000 civic.
- Precision Turbo
- putting together a turbo need help please.....
- Intake Temperature is TOO HOT! Here's my remedy, what's yours?
- Some Turbo Related Q's...
- nitrous wiring diagram??
- oil in charge pipes
- Awesome, I made a ton of WHP, now the car wont start anymore. EMS/distro/main relay?
- OBX Turbo Manifold on Ebay
- is there any way to check if injectors are flowing properly?
- Looking for more horsepower
- downpipe...
- Shoot me a hondata bin file for my turbo gsr
- Look what the donkey brought me...
- OneFAB h22 prelude Setup
- d16y7 back from the dyno.....Need bigger injectors
- Question about my InlinePro Manifold!
- Eclipse Turbo on a Del Sol???
- Picture Request. EF with b series turbo
- where can i get some crower rod bolts
- yet another ls turbo setup
- motor mount issues...
- RC injector calculator...Is it too conservative?
- is stock timing and a 75 shot safe?
- Takin a trip to Boosted Hybrid tomorrow..... hopefully it'll work out!
- I went to the track a few weeks ago. Turbo D16z6 (Del Slo) on ~8.5psi.
- HELP CLICKING NOISE
- how do i wire my oil pressure gauge-psi gauge and air/fuel ratio gauge..
- FULL RACE turbo kit for H series!!!
- Can someone tell me the secret to the profec spec 2?
- Autronic SMC/SM2 v Hondata
- Injector question
- No start after OBDI changeover! Please help
- my downpipe and E cutout pics
- Ok please don't hate me....
- Emmision proof JRSC LsVtec?
- 92-95 SOHC Greddy Kit into '99 EX?
- fuel cutting out at high RPMS
- Is the upgrade from hondata Stage series to the "S" series worth it?
- turbo language
- Love fab mini me manifold
- No spark???
- just curious....
- What Oil: brand/weight are you running on your FI honda?
- ps cooler ? whats did you do ?
- will d16a1 crower rods fit into a d16y7?
- cel=primary o2/ car stalls after throttle.
- need an uberdata tuner NOW!
- replacing tial wastegate spring???? How?
- hybird Turbo
- turbo's with similar flanges?!
- 5th gen auto ludes with boost
- LS SC on a K-series
- AEM Base Maps
- Misfire?! OBD-0 --> OBD-1 B16 Turbo
- Will i Hit 13's ? Info Inside, please help
- D16y8 on BOOST in EG???
- Does my oil feed line look ok?
- New: Autronic PNP board for Civic
- diy block posting by homemadeturbo
- T3 4 bolt exhaust is a 3" possible
- What are signs of a blown turbo?
- daily drivers... what turbo mani are you using??
- how exactly do you tune a turbo setup?
- Power FC for EK9
- My Jdm b18c in the works??? Need some input
- Civic DX AC Wiring Question...?
- Blue box wiring Instructions?
- turbo smart 45 & tial 44 mm v band
- which car to turbo
- what kind of power can this b16 make
- RWD H22 del Sol project, thread #2.
- Quick catch can question having a brain fart.
- question about FPR's
- what kind of exhaust for my turbo?
- i found a diy: air fuel gauge
- The built motors running strong, now its time to build the turbo setup... :)
- Boost H22 stock internals
- Expo trip + dyno shiet
- low vacuum
- Finally got my turbocharged civic running!!!
- Need some help/Advice on cooling System!!
- can i make 500hp? what else should i do?
- Need resistor box with DSM 450cc's?
- need SPRING RATE help!
- Carbon on bumper?
- o2 sensor question
- B16 W/ a JacksonRacing WHATS NEXT
- Anyone near H-burg PA have a ROM burner?
- Totally disappointment in my Dyno number...
- 275whp on B16A1 sirII..........
- anyoen with turbo B16 ? hows the torque?
- jrsc and pulleys
- im planning on boostin my B16A1 sir II......
- Dyno tuned with pics! - Greddy 18G on 94 GSR
- 96 turbo dx???
- boosting creeping up @ 7600 rpm??
- Dynomax super turbo muffler 3 inch
- Fuel Pump Questions, Need some Quick advise...THANKS!!!!
- mandrel vs. crush bends for charge piping?
- Map for D16Z6 greddy turbo kit
- ??good setup for my 96 rs integ??
- check engine light and only 5 psi?
- Hondata s200b vs. Uberdata/Chrome *searched*
- Help with Blitz SBC DC
- blue box 2000 gsr
- Question about Springs.
- Correct me if i'm wrong?
- D15B Vtec turbo?
- help with turbo kit
- first time at the track
- Limits of stock valves
- idle will not settle after boosting?
- best turbo to use with this set up?????
- B18b1 @ 9psi is studdering/hesitating @ 5k rpm. Help!
- Need Help Deciding what ECU for an LS turbo. HELP
- 108k and boost...finally done for now
- need some help
- Intercooler
- New game: "Guess my headgasket!" 4 layer??? (RePost from EG forum)
- ACT Streetlite or ITR flywheel for boosted application?
- need help with wiring b18c1... pics included
- How much should i expect to pay for a tune?
- Blown engine....cyl. #1
- 27 x 12.5 x 3 too big for H22A?
- For those who drive their boosted cars in winter...
- Compression test 240 all across ...but
- OHH NO!!! Houston we have a problem
- B16a? turbo in CA
- XS GTR Intercooler or apexi gtr intercooler.
- well, it's in...finally
- Engine Management for OBD2 Cars
- hondata vs. greddy elec. gauge boost reading
- Boost falls off at higher rpm????
- bov leak
- quick question: flex pipe and dumptube
- Need the hook ups on how to install my MSD6A/w ext coil/ 1st Gen B16
- Question regaurding intake temps and possible resolution to hot intake issues.
- turbo CRX
- Greddy BOV stripped
- t3 question
- engine management on a budget
- What size fuel pump needed for my setup...
- GSR turbo with no intercooler???? (94 civic hb)
- finally started my car- smokes alot -mostly grey and some black
- any news about aerocharger's
- Reliability of my turbo setup
- mcmaster carr vacuum manifold installation ok?
- NEED!!!!!!! ALL THE HELP I COUID GET!!!!
- TURBO VS SUPERCHARGER
- TurboXS Dual stage boost controller main connector help ( missing plug)
- 70 mm Throttle body on Edlebrock mani.
- Need help about filter or turbo.
- t72 ball bearing (reassemble)
- Almost done...
- How much boost can a Stock GSR take w/40k miles???
- Why did i only make 196whp at 8 psi?????
- 14b Crack Question
- Damn Inline Fuel Pump Issues/Problems, PLEASE read...
- Ported Shroud/Antisurge Compressor cover vs. Sound?
- Bone stock B16/DRAG kit 11's at Nopi!
- MSD ignition systems
- In the process of building a Turbo S2k, one question though...
- Stock Supra turbo size
- does someone remember...
- putting together my turbo, couple random questions...
- What kind of turbo is this?
- need soem help car an fine now rich as hell boggs through all the gears
- Finally getting ready to put it together, HAVE QUESTIONS!
- D16Y8-T won't start after airbags deployed from bottoming out (long story)
- Is the older Profec B better than the Profec B Spec 2?
- Golden Vacuum Manifold Install Lines Help????
- info need on Rev Hard kit...Ls teg
- Change from the norm
- $5000, is it possible to go B20 Turbo?
- how to gap a spark plug?
- Best ECU for boosted ls
- 96 GSR with 107k miles...need help about where to rebuild
- need help w/rev hard on rsx
- D16Z6 Greddy Kit 6psi Uberdata tuned Dyno graph
- aem ems. beginner?
- something broke...
- Please Critique my Plugs.. 84mm sleeved gsr, built of course..
