View Full Version : Forced Induction
- How to rebuild TD-05H Link.
- Thoughts, Opinions on my JDM B18C setup
- Need better solution for bolting down wastegate
- Which turbo should I get???
- b18c or b18b
- Do I need to downgrade cams???
- Turbo advice for built F22B1.
- Can someone explain this 'video'
- Fully built b18b1
- compressor wheel and housing
- Water 2 air intercooler on H22
- Help on Turbo Build
- Boost Reference Before or After I/C?
- engine smoking, very weird, how to tell what it could be
- simple answer on oil line and restrictor please
- Oil inlet restrictor for oil line on turbo
- why does my piston ring look like this?
- Ignition Advise
- headache.. oil feed questions
- Block guard, yes or no??
- B16A3 valvetrain / head gasket
- Apexi AVCR help install
- need help completing nitrous kit
- Mystery compressor surge, experts chime in!
- Boost by gear question
- So does anyone run there oil feed like this??
- 00 civic si turbo build. HELP!!!!
- Where is the factory knock sensor on the D series motors?
- dual fuel pumps
- D15B Turbo Bogging // hesitation // stalling
- Locking vtec in all the time d16?
- turbo oil feed and return line?
- Oil pump gears
- Downpipe Fitment Help
- Compression 30psi lower in #2 cylinder..safe to boost?
- Uneven bore (circle) on ported blox intake manifold, will any problems occur?
- Aeromotive a1000 pump controller??
- MBC Routing
- This is what happens when you buy crane cams.
- please help with vacuum/boost lines for hondata boost controller
- Max 7lb problem
- Just installed turbo now i have oil leak maybe breather box
- 600+ whp catch can kit question
- Turbo info
- High compression b20vtec?
- b20b block with b18 head
- turbo b18c5
- anyone know if there's a bumper protector made for civics out there?
- Where to find Injector Clips??
- GM MAP Sensor Identify HELP!!!
- I need a tuner.
- ITB Turbo?
- Going BOOST !!!
- Turbo build done, engine bay video, need feedback
- Roller Rockers & Roller Cams question?
- Bad Precision Intercooler, take a look
- Finally dyno'd my 4dr GSR
- injector help
- fuel problem helpppppppp!
- Oil feed, oil pressure sensor T leaking
- 70mm B series plenium throtle spacer??
- building a h22 block for boost
- Possible 350 Hp with this set up?
- who uses anti-lag?
- Smoke at low rpm down shift
- AC/PS compatible turbo kit for 2001 gsr?
- upgrade springs without valves?
- B18b/B20 JRSC on a B18C?
- sc34 three oil seals and still leak
- PROOF that bypassing coolant gives more HP!!
- E85 tune toggle?
- A noob fuel system question(but I did search)
- Turbo Build for 09 SI?
- im confused
- I need help guys please
- How reliable is K20/K24?
- AEBS good deal for Drag Racing?
- I cant figure out why my car is smoking w/vid
- Need a good dyno tuner around Rochester NY
- swap questions..
- JRSC experts please chime in 99 si
- help with 4 bolt downpipe
- missing fire ring= no boost??
- aem water/meth kit install help
- turbo d16z6 opinions?
- Type R B18c Block B16 head...what pistons
- Voltage drop after walbro 400 install?
- clutch slipping help
- b18b1 turbo oil return, oil catch can questions
- blox manifold cracks : will it cause problems ?
- Just want some validation on my plan.
- prices on machine work?
- what is the maximum Sleeves overtaking?
- What Full Race Kit is this?????
- b18b1 turbo stock motor, thinking about installing block guard?
- m24 ar.70 turbo...need specs
- boostflow topmount
- JRSC or Greddy Turbo kit
- Help choosing turbo
- Milling b16 head to rais comp.
- B series ramhorn.. Wanna see you turbo inlet setup
- First fire on turbo build, it ran! Now issues
- greddy TD04H turbo rebuild kit
- '98 Dx d16y7 possibly turbo questions?
- requesting pics or info on intercoolers
- Glasspack vs resonator vs turbo muffler
- Precision turbo 6262 V-Band and clamp help
- polished ls meshies
- spitter spatter at high rpms/ head gasket leak
- Want to turbo a stock B18C
- turbo help please
- turbo manifold keeps cracking
- What cooling fan are you using?
- Early budget turbo advice
- Anyone Using A GO-AUTOWORKS SPEC Turbo?
- turbo open (exhaust wheel nut)
- car wont stay running plus smokes some
- First turbo build fire up tomorrow
- Need help with turbo setup!!!!
- Knowledgeable opinions on new bottom end. Oem vtec Vs B18b/20
- piston pics - is my piston to wall too tight?
- B18b1 dsm 450 injectors, hard plastic o ring?
- Eve piston rings?
- 94 civic, b18b1 turbo, walbro pump, rewire?
- 11.1-12.1 compression on boost?
- whats the smallest ball bearing twinscroll either T3 or T4 turbo?
- Precision Turbo
- b18c1 trans problem, need help
- Has anybody here of Focuz cam gears
- Is Crome Pro sufficient for 500whp+ e85 setup or hondata s300 be needed?
- CP pistons...
- Max HP on this turbo?
- Walbro 255 fuel pump and 1200cc precision injectors enough for 550whp on e85?
- PVC question
- B18C Rebuild Advice Welcome!!!
- d16z6 aftermarke valvesprings with oem retainers?
- WHAT TURBO DO I HAVE?(MEASUREMENTS AND PICS)
- header that makes turbo lagg...question?
- ARP .625 rod bolts vs. ARP 2000's?
- The Truth about Daily Driven Turbo Hondas...
- Drag manifold, does it look good.
- i
- whats the most hp you getting out of bc stage2 turbo cams
- turbo crx 1.6 lean.
- Itb and boost?
- Precision 5 bolt DP flange Question! PICS***
- Leak down results...
- 1in or 2in exhaust wrap
- d16z6 turbo?
- Boosted d series
- Building bottom end
- k20/24 hybrid turbo cams?
- Post numbers on a 35r
- Free oil feed line adapter
- Head lift with stock y7 head bolts
- B16A Integra Turbo Questions
- 99 civic ex sedan turbo
- Power Pros SFWD build (f.A.M.E Hatch)
- GSR turbo problem
- 2.0 liter GSR Civic E85, GT3582R With AC 709.8hp Mase'd Tune
- ls turbo code 35? need help please
- eg civic, b18, turbo downpipe touching half sized radiator
- Good size ic?
- Help deciding what clutch to go with
- Preparing to Boost. Need Help.
- Rate my oil return drain kink - *pics*
- La001268 quest to 9sec pass for 2012
- turbo cause dizzy to fail?
- Turbonetics 60-1
- Need Help setting up EBC
- Need some help with H22 main bearings and clearances
- b20b build. 94 eg civic
- Bisimoto 2.4 turbo Cam OVER Skunk2 Stage 2??
- d16 turbo charging..
- causes of oil ring failure
- Vtec Problem Recently Tuned
- Has anyone had a CUSTOM turbo manifold made for an EF???
- 6262 vs garrett stage V turbine
- GSC Turbo Cams Vs 01 ITR Cams... Better spool and 30whp+ Gain...
- Vortech
- ls motor build for turbo
- stock b16 rod failing point boosted
- TURBO build question
- Need some advise: Ferrea valve springs/turbo application
- Middle of turbo build, questions
- Anyone running DeatschWerks injectors??
- difference between turbos
- Help !! Sleeved block water leak problem
- Fuel System Questions??
- Safe cam gear adjustment for B18B FI?
- WBO2 sensor and dump tube placement
- 3 inch 4 bolt dp question
- crank pulley fell off, can it cause my oil pump to go bad?
- Turbo to manifold bolts coming loose? how to fix.
- 90 degree fitting directly off the turbo
- Turbonetics or Precision
- correct oil restrictor for journal bearing turbo?
- 60 trim B18B WHP!?!?
- Question reguarding turbo build. -ARP head/main studs
- Single BB Turbo
- Cams?
- Need turbo advice
- Anyone seen more info on the new Precision 6466 billet CEA
- Is there a easy way 2 get more turbo boost
- M&W Pro 10 problem
- Built H22 doesnt idle on cold starts
- d15 with 3" thermal r&d exhaust (video)
- Anyone tuning with a Vampire for safety?
- Wierd Idle Issue after Tune on dyno
- My Built LS/Vtec setup
- Help me out with wastegate springs!
- Which is better?
- Drag manifold replacement
- what size should i make the manifold?
- advice on widebands
- d16z6Tcrx 700whp stock sleeve daily driven street car!!!! CMR tuned
- Spark plug bk7re and bk7res-11
- converting over to e85
- question about LS/Vtec/T, :)
- d16z6 t3t4 turbo ?
- D16Y8 Tial 50mm Q BOV Question...ASAP
- Fuel pressure drop during Dyno Tuning
- noob question oem or aftermarket valve guides?...
- My intercooler size for 400whp
- Cast mani port out
- what manifold to use
- User feedback on AEM Tru-boost system wanted!
- need some help
- Turbo build advice for B18C
- Which turbo??? again
- Ramhorn vs topmount for my setup
- Which Blox Cams
- Attachment of nylon line and plastic t fitting
- Poor mans R street/race turbo build~what do you think?
- Calling all 57 trim owners!
- Let's talk D series and headlift.
- Low duty cycle, yet high boost?
- 1/2" ARP head bolts/studs
- I need advice
- boosting d16y7, need advice/build thread here
- Installing turbo with IACV check engine light??
- BOV Spring rates
- do i need and oil restrictor
- rx7 injectors
- exhaust port #4 wet in oil
- Do it make a difference
- Stock Everything D16 w/ Turbo... Q's?
- Question on turbo coolant return line
- Precision turbo 6262 turbo gone bad. Whats caused this?
- Civic Sir (Vti) from Brazil !
