View Full Version : Forced Induction
- question about dart's B20 block
- is there any differences between these plugs?
- Rebuilding my engine , need some help ..
- Spark Plugs for 450 hp LS
- what's the HIGHEST daily PSI are you guys running on your greddy turbo?
- WTB: Turbo parts
- How much money have you dumped into your cars?
- OT:final drive in ls tranny?
- Question????????
- Good reputable, performance shops in Central Florida?
- advantages over electronic boost gauge & mechanical
- D16 Turbo
- I have an idea to reduce car theft.....this involves nationwide participation.....
- best turbo
- Tooooo Much PRESSURE??
- Turbo'd Hybrid
- Has anyone built a turbo LS/VTEC that kicks ass?
- DOOOHHHH!!....another engine build hurdle...oversized bearings????
- Car is misfiring. . .
- how do you COMPLETE the rev hard kit????????????
- Zex nitrous
- Recommended Nitrous System?
- Does anybody have an extra T4 compressor housing I could borrow?
- downpipe and exhaust questions
- first time posting here
- 2" charge pipes
- OT: help me find raditor hose
- clutch for boosted itr
- Kaboom?
- Deltagate vs Tial Wastegate
- FMAX and DRAG turbo kit questions
- Serious problem or faulty equipment problem????
- good complete kits?
- Idle Control error !! CODE 14
- OT: I need some advice on taking legal actions......
- can you change the color of hks turbo timer LCD
- help is wanted. need help by tonight to get it running!
- Extremely Important Please Read...
- slight ping..
- Has anyone ever heard of this type of manifold. PLease help!!
- JB Weld on a compressor housing?
- Lookin for a little BOOST!!!
- Remove turbo to drain coolant???!!!???
- pressure drop...
- Damn Charge pipes blowing off my Compressor again & again & again....
- Integra / Greddy turbo timer question
- Blowout on greddy guages and greddy products..
- Fuel injector supply voltage question
- /pressure drop
- sneaky pete?
- New line of turbos
- Just got a code 90, hhhhmmmmmmmmmm...
- fucking bastards!!
- Redyno with Tial install?
- JDM HKS bov info????
- What tranny to use with turbo?
- Found a GREAT article for the Turbo Newb (me ;) )
- Could someone educate me? CLosed Vs Open deck
- Which Clutch For A Turbo Accord?
- need some help and recommendations please 60-1 settup
- Manifold adapters?
- precision pt60 turbo cfm?
- Golden Eagle Groupbuy????
- primary 02 Bad?
- a couple new options on the Full Race turbo kits
- Oil Pump issues...VTEC on a Non-VTEC Block
- fs: HKS GT2530 Turbo
- Spark Knock.....
- What modifications needed to make a 00-01 B18C1 Teg kit fit into a 99 Civic EX.
- DRAG 3 GSR piping for sale
- Disturbing pictures of my copper head gasket
- Exedy clutch resonances.....????
- Garrett GT series turob maps
- witch throttle body do I need??
- Car bogging/lagging..Help please...
- removing JRSC need help.
- 9:1 JE Pistons $480 shipped
- help my poor LS
- boost guage problems
- choices....
- T3/60-1's In Stock!
- Stuttering problem solved - MAP
- Detecting Pre-Ignition/Detonation...I know this has been asked a million times
- Can anyone give their thoughts on this TURBO B16A
- tuned, can i use?
- Need Help locating oil sending unit... Installing SOHC Greddy turbo kit
- why are used turbo kits still expensive?
- Who here actually runs water/alky injection?
- What spark plug wires for turbo GSR?
- Radiator Caps - fluidyne guys...
- Will this turbo work?
- Nordskrog gauges?
- does this sound mean anything...please help
- U need high octane gas? Here u go
- removing the head
- jrsc+aem pullies
- B18B Turbo Kit Qyestions...I need to know where to begin
- Cooling Problem......Please help me :)
- sell Apexi AVC-R for Hondata???
- jrsc fmu
- Would this be worth it?
- Endless bogging monster help!
- Turbo Pics
- 96+ SOHC Greddy Turbo oil feed Solved
- Quick Question About Silicon IC Pipe connectors.....
- there is something missing here check it out
- map sensor problems (hondata)
- 0-60 and quarter mile
- ITR guys.....Supercharger questions.....
- Final Drive Ratios: 4.4:1 vs. 4.78:1 vs 4.929:1
- ITR guys.....Turbo questions....
- what size injectors.............
- pic of pistons going in my new short block
- good or bad turbo mani???
- JE 84 mm Pistons, Eagle Rods?????
- Bridgestone Turanza ER30?
- Golden Eagle or Darton sleeves and a good machine shop?
- How much hp with a bulit b16a turbo???????
- Turbo H23 kinda studders at higher RPM under boost.
- Post picture of you sleeved BLOCKS...
- Steel or Aluminum Flange?
- Problem with my TURBO LS
- Turbo Rebuilt in NJ/NY?
- no downpipe..
- greddy e-manage
- Cometic head gasket
- OT: MSD Dig6 for sale plus extras!!! 330 shipped
- engine misfiring...help...pllleeeaaasssee
- So my road to engine building begins.....
- SMC on H/F series???
- Limitation if mitsu td05 18g turbo?
- Wastegate dump noise
- Broken turbo...what to do.
- sema, to me
- serious problem here, head clearance!!!!!
- Gsr or LS crank?
- Greddy turbo on EG GSR
- T3/60-1 Which A/R ? Steetable?
- Block Guard Install
- My CFM Flow Rate of my Turbo ?
- Trim is good, but what about the other stuff.....
- Hondata Problem...could use some suggestions...
- Quick Question: Where can I find the formula to match compressor size to an engine?
- F/S: Autometer Phantom faced Oil Pressure gauge...Thought the boosted people might need it more.
- car wont start.. still cranks though!
- *Greddy typeR BOV*
- Gauges - help me spend some $$$/finish my POS
- It's in. Only took 24 hours....
- what turbo manifold for turbo GSR?
- Is this supposed to happen?
- you guys got to see this
- Just ran my turbo teg! Any suggestions?
- My friends car is over boosting...why?
- Supercharging a B17A1 in a Second gen GS-R??
- max rev,drag3,or rev hard?
- she's gone .....
- What kind of gains from upgrading drag intercooler?
- no VAFC...
- Damn internal wastegate doesnt hold boost!
- Question about Jump from 7psi to 14+, Can someone describe or attempt to describe what that feels li
- oh shit.... boosting at 6 psi all the sudden engine light comes on runs like shit...
- What trim of garrett turbo?
- i want a final answer on "JRSC=Hot Air"
- IM FINALLY BOOOSTING!!!! but have some questions
- What brand Turbo Manifold is this?
- METHANOL & wieght penalties.............
- What is the best TURBO KIT for a gsr??
- Bergenholtz Mazda pix WILD
- all who are using d-series turbo kits on b16 motors
- Rumorville...
- aem cold air as ic piping>?
- Hondata installation???
- Weird ignition/ECU/safeguard problem. Need help quick!
- Dyno day pics, big pics not 56k friendly
- any one selling a turbo for a 92 h23 prelude
- Car rev'd up by itself in cruise control...
- Removing fuel filter on g3 integra....
- JRSC + NOS, need some questions answered
- Civic Radiatior in Prelude ?
- OK I'm pissed
- More Sema Pix...
- ??...Can anyone identify my turbo...??
- H22 intake manifolds... i can't find any
- Vortech FMU clarification....
- T3/T04E 60 Trim Dynos ?
- JDM B16a Dyno Numbers
- Oil Coolers?
- fmax install
- 550cc injectors with SMC?
- Losing Compression in ALL 4....turbo Si
- blitz dual turbo timer...as a boost controller?
- Turbo owners, step in....
- What turbo for 2.0 gsr?
- Greddy turbo problem
- Inline Pro Headgasket work w/ GE Sleeves ?
- BSPT <--> NPT brass fittings found
- SLEEVED BLOCK OWNERS........please read...
- AEM fuel rail and a fuel pressure guage???
- Anyone running an MSD DIS?
- Went to the track with my new setup...
- electronic distributor ?
- Testing Water
- OT: DSM 450cc injectors with resistors f/s!
- walbro or holly intank fuel pump?
- SEMA: Please post some pics here....
- OK, guess who else has a rwd Civic?
- Prelude intake manifold I guarantee you have never seen before
- Where to buy wastegate elbow??
- FIRST PIX..Stef's RWD Civic
- there are 2 nipples on my compressor housing, which one should i use for the wastegate?
- fuel pressure gauge to replace crappy B & M?
- When do you need bigger injectors/
- How do you determine trim size?
- Apex'i SAFC w/ Vortec FMU
- Reviews for Maxrev Kit!!!
- Did comp./ leakdown test. . .help me out.
- smc not here yet,,,,
- Engine Questions
- wisco pistons
- Pic request: b18C + InlinePro + t3/t04 turbo + large radiator
- MaxRev dump tube.....
- The differences between Preignition, and Detonation
- It's back from the shop
- Is this a good price?
- Testing waters. Possibly for sale: Maxrev polished log manifold and 2.5" A/C compatible downpipe
- Wiring a nitrous button
- Hack on chipped ECU?????
- anyone with an LS 4dr or coupe that's using the greddy turbo kit?
- Can you use the SMC and an AVC-R together? and one other Q.
- Civics with resistor boxes
- 2001 Civic Turbo, Finally Completed
- How to spend thousands of dollars-lots of pics
- whats the highest i can boost safely with this setup?
- confused about wastegate??
- deck plate block finally came can anyone host some pics, my usual host is down
- painting block questions
- greddy turbo on a B18b
- Some advice please?
- 94 Prelude turbo HELP!!!
- Brand New Apexi Temperature Gauge
- Would this make sence
- What oil coolers are people running
- What spark plugs to run
- will radiator hose hold up to deltagate temps??
- what turbo, manifold, AND WHERE CAN I FIND ONE?
- chhow much oil pressure?
- Sohc turbo... 14B or larger ?
- Troble shooters.. help me out here..
- clearance problems!
- What size??
