View Full Version : Forced Induction
- Turbo Integra
- t3to4b vs t3to4e....upgrading turbo? What can I do to meet my goal of 400ish whp? Currently at 300wh
- 81.5 mm bore? 81 mm gasket ?
- What kind is this turbo?
- Over heating boosted gsr..
- slipping clutch = bad smell?
- Garret water cooled TURBO ?
- calling all FI gurus!!! crazy cooling question.......need help
- aftermarket intakes with stock runners???
- What setup should I get?
- Quick Q...Catch Can
- head lift symptoms?
- turbo exhaust manifold
- JAckson Supercharged GSR Trying to Switch to chrome... HELP!!!!
- this or that
- what else do i need..tired of waiting..
- Electronic boost controller...Recomendations. What are you guys using?
- got parts today!!!
- Oil pump: LS, GSR, ITR all the same? High boost application...
- FPR NEEDED ON MY SETUP?
- OIL COOLERS: Where is everyone putting them? Show pics!!
- Skunk2 manifold
- Need street tuner in SoCal
- WTF is a td06-25g?
- My buddy DC2 making 344whp on a mustang dyno
- b16 turbo (injecors turbo map n ecu) Questionsss
- Tranny Help!
- can head lift when running hard?
- what does it mean when the upper radiator hose is squeezed in when the engine is cold?
- 200whp+ possible with d16z6 and 8.5psi?
- 550cc injector fitment prob
- B18a motor and trannsmission$$$$$
- can i turn the turbo and housing around
- boost spike
- Any shop in SoCal who can rebuild my turbo?
- Wideband probelms HELP!!
- JUST GOT THIS OFF EBAY
- Joe P MBC or Hallman MBC?
- possible to mix match turbo to a "setup"
- Boosted B16 re-birth.
- lsdmotorsports.com? have any experiance with them?
- Vitara Pistons
- wastegate spring question?????
- BOV question... kinda weird..
- clogged muffer?
- UBERDATA and PLX-M300
- My Honda Prelude H22 Dyno Sheet
- Mazworx V1 cams or CTR/ITR cams?
- where can i find a 5-bolt fange gasket for my downpipe?
- Just moved. Have a vacuum related question.
- New 1/4 mile times for my turbo D16
- Exedy 3 puck, good for 400 whp/280-300 tq? Searched, no results
- 2nd try B18c1 on boost (what went wrong the first time?)
- Is t3/T4 turbo the same as T3/T04? and what about T3/T04e? Please enlighten me
- Can someone make me a list of what i need to turbo my b18c
- Misfire or cut out at 7,000 rpms?
- B-Series Turbo Manifold...HELP!
- precision T70gtq
- Nitrous Nitrous Nitrous
- Turbo Pistons
- thinking about a valvetrain. lsvtec on about 15psi?? not sure of what to get
- what else can i do to fix an oil pan leak
- Boost creep?!
- Re-torquing arp's
- 97 Accord Fuel Pump?
- Vortech b18c1 with CRV pulley
- boost + nitrous
- Boost gauge question...
- Turbo Coolant Lines HELP SETUP
- 85x77mm B16A Any good experiences and how good are they for boost?
- AEM Tru Boost Boost controller
- turbo type r down under
- Is it safe to run 3 oil sandwhich adaptors?? oil cooler question?
- Head gasket question
- quick question about a turbo fitting
- Whos running a GT35R??
- ignition not strong enought?
- Odd coolant leak.
- 82mm GSR is that a 1.9l?
- can a bov change sounds without really touching it??
- CBR 600 COP coil on plug there are different lengths
- Joined the 400hp SOHC club today!!
- Evans-Tuning Forum Hacked!?!?
- head work good for 10psi
- LS IC piping on a gsr?
- Exhaust gasket for a turbo integra?
- Garrett turbos, O-ring'd compressor housing?
- anyone ever use "Torco Mach Series Fuel Accelerator"?
- Getting car tuned in Upstate New York
- oily exhaust?
- Calling for GT3076R users....what numbers are you laying down at XX psi?
- turbo downpipe exhaust suggestion
- spool time with GT30R
- which cam to use?
- Broke 12s
- Weldon fuel pump
- BB t28 good for a d16z6?
- I need 550 Injectors, 3" Downpipe from Turbo to exhaust and Boost Controller.
- HOW MUCH BOOST?????
- WTF is wrong with my walbro pump?
- pic request: high horsepower street car wheel and tire combo
- Blue smoke at idle...sometimes...
- "funner" street set up....
- Thinking of downgrading turbo
- ANY HP/TIMES FOR A BOOSTED SOHC VTEC
- Where can i find reducer couplers locally?
- Upgrading the turbo setup..
- car doesnt go when pass 5psi!!
- Is the throttlebody plate supposed to be totally sealed when closed?
- Velocity stacks for turbo integra?
- egt temp at idle?
- Turbo Build help...just a little question
- Moroso oil pan, bent rail seat... able to bend back?
- plugging egt hole with aluminum plug? will it melt?
- just fucking great, ITR motor siezed, not I need your help w/ a rebuild...
- 4g63 turbo on my B16
- Turbos Interchangable Without Changing Piping? TURBO BLOWN
- Hondata s300 Boost Control
- Whats the difference between 18G greddy turbo and 18G DSM turbo?
- How to install BLOX Gauges?
- AEM tru boost boost contoller?? Anyone here use it yet?
- compression for turbo?
- car dies, troubleshooting before the dyno
- Question about TIAL WG
- WTF w/ KAMIKAZE
- High Temp Hose to withstand exhaust temps for crankcase evac?
- Turbo Tuning question
- Precision GT3767 on a B16
- vacuum line quality
- HELP CODE 14 CAR CUTS OUT LIKE A DSM
- how much boost on a stock head
- where can i buy turbonatics turbo rebuild kits?
- A couple of pics for your pleasure (HUGE turbo)
- it is hot and i need a/c w/ my turbo
- NEED SOME SUGGESTIONS PLEASE!!
- Boosted single cam hb or GSR hb...?
- Is my oil return OK?
- Howto: Refinishing Intercooler Piping
- GSR Jackson SuperCharger EM Help
- Searched: Quick Answer. Oil Pressure #s
- Running a hard oil feed?
- What are the disadvantages of NOT running a dump tube?
- Differences in brand of pistons
- RC 1000cc injectors
- Where can i find 4bolt downpipe..
- Starting build, have questions
- manifold help
- built b16 turbo new numbers compare what do ya think??
- I need help getting my boosted sohc running again heres the story...
- boost spikes
- performer x/victor x
- Pic Request: Turbo DA's (90-93 Integras)
- 8x24x3 Spearco I/C HP rating?
- High Torque Low Horsepower...ideas what is wrong
- Boosting A 2000 Civic EX Automatic
- I think my Hondata S300 Is Fried!!!!! HELP
- WorldWide Business, please, need HELP.
- Sohc turbo runs like poop list of attemts but no sucsess i need ur help...
- Garrett T3 Super 60
- .7bar spring hitting 12psi...is that normal?
- Wheres the cheapest place to buy arp headstuds?
- Turbo integra power cutout? HELP
- Car smokes a lot, turbo may be sit too low.
- Looking for clips of fast civics...
- Are these really presicion injectors?
- B&M Fuel Pressure Gauge as Turbo Oil Pressure Gauge?
- What is this hole in turbo for?
- Moving to the dark side, any suggestions for my B18C1?
- which headgasket for boosted b18c5? opinions
- Injectors
- Duty Cycle Question
- a/c blew....read please
- Worth going single cam Turbo?
- hesitation
- New! Cast Turbo pistons? Tell me what you think of these new pistons!
- Slowmotion Turbo Teg hit the dyno..pic/vids
- nooBie... GO EASY... J30a4+GT35r?
- Are there any Honda tuning programs for Apple?
- T25 internal wastegate do i need a boost controller to up boost?
- help me figure out how to make my downpipe!
- Check out my new topmount manifold! SOHC FTW!
- <<f22 turbo odyssey broke trans... h22 swap auto turbo>>
- Is this going to be a problem? NEED HELP.
- Question about top mount and heat
- over heating while in stop n go traffic
- Any Benefits To Building My Head?
- F*^& I p'wned myself, can this be fixed, imma gonna kill myself
- turbo waste-gate question?????
- intercooler?
- oil feed source
- knockoff greddy type s
- civic turbo with aem ems anyone know where to get an electronic boost control solenoid????
- GT28RS on stock b16?
- Installing turbo myself, how does it look? (pics inside)
- Oil in charge pipes, not at the turbo though, only after intercooler?? Pics inside.
- Alternator/Stepper Pulley JRSC
- boost gauge related
- How much power is the Greddy Type 31 intercooler capable of handling??
- Burnt Valve or bent valve Make a loud ticking noise
- boost gauge
- acl race/standard size bearings
- Garret T3/4 turbos, when do you hit boost on a GSR/ITR?
- Ignition Maps Are Crazy. Need Help Adjusting - TurboEDIT
- Turbo gurus help me out, oil problem
- noob question
- FINALLY RUNNING RIGHT! B17t dyno+vids ... 300/250
- Oil pump Question B18c1
- axles to use for turbo set up?
- Hondata S300 Anti Lag Settings
- Adjustable Wastegate Question...
- full-race downpipe
- How many MPG whould i obtain on a crx with 300whp or less
- new to forced induction
- big horses??
- Log Or Ramhorn?
- disadvantages of the DRAG manifold and wastegate
- spark plug hot
- anyone know who can TUNE a turbo si w/ems in iowa? minn? ill? neb? misso? help??
- A few pis of my turbo install....
- ebay manifolds?
- Wrist pin HELP
- LS/VTEC VS. B20/VTEC for FI...
- JDM GSR stock boost question
- Wastegate springs... where to buy
- Post up your Huge Intercoolers with USDM Front Integras.
- OEM 98+ Bumper with Precision FMIC?
- where do download freelog
- need some answers with my problem. please help
- Maxrev log and A/C
- Using stock sleeves what size turbo
- Where can I order online a small, inconspicous but high quality boost gauge for my JRSC vehicle
- WTF is this thing on my buddy's ECU 94 dx hatch
- B18A1 + USDM 81.25 ITR Pistons = 11.39 Comp. Ratio........ turbo ?
- Clutchmasters twin disk HELP HELP HELP
- can't boost over 10 psi for some reason (please help)
- Stupid Question...Need A Quick Yes Or No
- Greddy Remote HI/LO Boost switch? Any special instructions? Help on hook up.
- Injector Clip Question
- anyone run an aem ems? how do u adjust boost throught the wastegate???
- Profec Spec II - Spooling Faster - Do you need to retune >>
- quick Q... new turbo setup = new tune?
- just installed turbo in my b16, how should i prime the turbo before i start it?????????
- Leaky oil on turbo cars
- 1" Score on top of Cylinder 2, catches fingernail
- JRSC owners please read!
- Apexi WS Universal 80mm Exhaust
- Thicker head gaskets to lower comp. for boost on stock pistons and rods ?
- Garrett turbos: t3t4 -vs- t3/61 -vs- t3/67
- Tbone coating services second to none!
- GSR block damaged in shipping. Pics inside- THoughts?
