View Full Version : Forced Induction
- Top Fuel turbo for integra..does anyone know about it or where to get it
- MF2 questions
- anyone have the list of all the parts that go with Fmax?
- Turbo Manifolds
- on a EGT gauge...
- Itīs offical, JR is commin out with an intercooler
- My new CRX
- i think i solved my h22a problems
- Turbo Life
- cel code 72 damn!!
- what pump?
- cam gear valve cover
- my dilemma, thread only for well known Hondawhores!
- Gasket making material... anyone ever .....
- NOS Plate Kit for GS-R
- any huge differences btwn drag gen 2 and gen 3 kits?
- Automotive Switches
- pistons for motor
- Block?
- Turbo manifold
- Pros and Cons on Drag Gen III, Rev Hard, and F-Max Turbo Kits
- Revhard turbo kit crap......Way OT....
- FMAX turbo Buy-in Information here!
- Turbo Type-R Dyno Round 2 - TurboR616's Daily Driven Beast
- OT: B18C5 9:1 JE pistons vs. B18C1 9:1 JE pistons.....
- is $3700 for Revhard 2 turbo and install for gsr a good deal?
- when installing new pistons/rods do they need to be balanced?
- BOOST CONTROLLERS increase HP!
- If anyone needs me for the next couple of weeks....
- Intercooler piping questions....
- is 500 bux really worth it for ball bearing upgrade on drag or revhard kits??
- Anyone here shoots fireballs?
- need a little help finding turbo parts ...
- R motor good w/ NOS?
- Tuning large (440+) injectors on a V-AFC
- Question for the GSR owners with the Drag Gen 3 turbo kit
- What size fuse for fuel pump?
- where does o2 sensor go?
- Test........
- Rebuildin' my H22
- Anyone with turbo personally experience problems...
- best gauges to use to keep up with N20?????
- Safe boost level question
- greddy turbo kit for civic 98 ex any good?
- Blitz sbc-ic or Apexi avc-r
- congrats to jbsadler
- Intake manifold for ZC
- almost have this turbo stuff down!!!!!
- tial wastegate vs. hks/greddy/apexi/$$$ ones
- boost the R?
- My fuel pump bit the dust
- just bought my turbo kit!
- Hondata??
- anyone have a 2 or 3 step msd luanch/burnout control?
- HEY! all of you with cam gears!
- Is Vortech coming out with a SC for 94+GSR?
- greddy turbo vs JRSC for GSR, I know this topic has been covered forever but..
- DRAG3 on a stock D16y7
- My new dyno with 3" downpipe
- Where do i connect breather line when i have a turbo??breather filter bad?
- Laws & Nitrous in California?
- Exhaust Size??
- Anyone need a brand new "missing link"?
- STR or Venom intake manifold??
- injectors for H23A running 7 PSI of boost
- water/air compared to air/air
- clutch recommendations for around 450 hp.
- need ideas on timing maps for turbo application
- few quickies.....
- Check out my Turbo Integra website
- Where Can I Find A Turbo Head Gasket For My ZC
- Best piston rings for B18a/b?
- Throttle Cable
- MSD ignition question
- need help very confused as to which fuel management to run/use
- what the hell kind of turbo is this?
- Relieving fuel pressure?
- supercharger with shaved head
- WHO SELLS CARTECH FMU's? should i go with a 10:1 or 12:1 for my set-up?
- Why when i launch at 5300k I aint getting no wheel spin ?
- FS: HKS boost and EGT gauges
- The 'Teg has been fun...
- Anyone in Knoxville
- fmu ??
- Head work
- which head gasket for my soon to be gsr turbo?
- Nitrous and back pressure
- Vortech air / water intercooler
- I have a VFC now want JRSC will they co-exist together??
- more overheating problems - this is getting old REALLY fast
- what damage can bad or used up pcv or fuel filter cause?
- Rich? Lean? Dumb? O2 code coming up
- does anyone sell exhaust manifold gaskets (copper) for an h22a?
- I gotta vtec prelude! Now for a turbo.
- On a 88-91 CRX, which hybrid is best for turbo?
- Speed Pro + Turbo + Stock GSR head = Boost
- Advice on codes 71-74.....
- FUEL INJECTORS
- which walboro?
- manual boost controllers... worth it?
- -AN fittings made of gold??
- spark plugs....and wires...?
- 2 questions. air/fuel and fuel pump
- vortech fmu?
- drag 3 for 94+ gsr
- Where can I get a copperhead or similar wastegate gasket...??
- fuel problem on turbocharged 92 civic
- Does the external fuel pump create higher fuel pressures?
- selling DRAG3 kit, might go back to NA!
- Is it possible that I'm Running rich even though...
- ANOTHER Type R Dyno
- ATTN: LS DRAG 3 owners!
- JDM Type R turbo pics
- Drag or F-Max turbo kit for GSR?
- missing link
- what kind of plugs to run?
- Exhaust temp gauge?
- another question on finding the right turbo w/ compressor maps
- Tuning Cam Gears on Supercharged Prelude, Anyone done any?
- Why only 365HP?
- OBD wiring problems
- how to stop melting pistions
- JR Map Converter Problem
- Here's a reason to not use aluminum cam gears
- anyone have a SKUNK 2 manifold?
- !! Need to sell. I'm broke
- Difference between lbs. of boost and bars of boost
- Bosch Fuel pump questions?
- hey guys i need some money advice
- ring gap for total seal rings?
- Question about a turbocharged prelude...
- Turbo Type-R Dyno
- what happened to honda-acura.net?
- Got EBL?
- 1300$ what to use it on...
- DELTAGATE
- 91 octane in CA
- Ballistic Turbo,,,anyone heard of them?
- greddy civic or gsr IC kit not available???
- how to tell if an engine is "healthy"
- FS: BRAND NEW! Tial wg $225 shipped,fuel pump from Drag kit $75 shipped
- Just installed DRAG III kit....HELP!!!
- OBD1 GSR TURBO HESITATE? - SOLUTION TO H22A PROBLEMS
- JR Map Converter - Installed.
- DRAG GEN3
- Any recomendations?
- revhard blockguard
- Nitrous Install
- IC piping made out of aluminum....okay ?
- upgrading IC to 2.5" hurt?
- dyno results.
- poll: which would you do ? $ 150 for starion IC or $400 for XS engineering IC
- Drag gen 4 kit?
- open wastegate = dirty engine, how do you clean it?
- has any one here installed there str intake mani.
- gsr vs. ls turbo
- difference between p72 ecu (Doug?)
- Ben - Question(or anyone)
- OT; 2001 Audi A4 1.8T
- Garrett turbo Questions
- Does Anyone Need DynoJet Software?
- traction problems... how to control power!
- Why NOT dyno your car?
- dyno session tomorrow..
- Does a lightened flywheel make power?
- Hey Dirtylude, any news on the Haltech?
- car smoking
- DUSTIN !
- Where can i buy this in North America ??
- suggestions for DRAG 3 power on LS!
- I finally got my Greddy turbo installed
- can i leave my head stock?
- damn i dunno what setup
- What would be faster?
- A poll for your Forced Induction FMU..........
- Hondata systems for DRAG turbo kits
- Does anyone have a pic of Check valves installed on their car?
- Need help quickly on IC piping fast,....pleasee......look
- Arturbo
- How good is a 'lude vtec and turbo
- tuning cam gears w/ a turbo -- which way to go?
- Turbo rebuild; who, where and how much?
- which regulator and wastegate do u recomend?
- To Evocelica
- guage install help
- Grag gen 3 kit for 93 integra ls??
- whats better closed loop or open loop?
- This is for inlinefour
- fuel setting diffs on WOT and partial throttle?
- Turbo for an Accord
- Which turbo kit is the best for LS auto? any suggestion
- NOS blow up
- bbk 70mm tb?
- We are trying to Help Drag3Gsr about his stolen car!!
- ECU question!!!
- New Turbo owner
- autometer gauges ??
- thermal wrap the drag 3 manifold and downpipe?
- When is the Greddy turbo kit going to come out for the b18b
- fuel options for turbo setup
- Cartech issues and lowered boost pressures
- Where to get one piece front end????
- 12.4@114 ... first time out
- why can hondas only run 14-15 psi on pump gas ?
- a way to get boost with no turbo or super
- How to mount 3" thermal on G2 Integra?
- AACK!! need help with greddy gsr kit/ecu issues
- finally returbo'd need CEL help
- Question on vacuum reading on my boost gauge?
- Turbo seals bad already???? white smoke
- to blockguard or not to blockguard...
- SHOULD I GET SKUNK 2 MANIFOLD W/TURBO
- so, guys... would this something of interest to you or someone you know?
- JRSC installation questions
- MF2 probs
- Scatter shield....................
- power brakes?
- o2 sensor: voltage
- HeadGasket help please:)
- Apexi dunk or Greddy evo/ PE
- turbo wheel question
- Everypone running Cartech fuel pressure regulators......
- BRAKE MASTER CYLINDER! HELP!
- How good are the Greddy GSR turbo kits?
- Reformulated gasoline.
- Attn: Purelude
- JRSC with what kind of exhuast????
- no power after, 3k.
- Hondata??
- TPS Sensor Questions Part II
- drag piping = alluminum ?
- Turbo 4 Integra GSR
- IHI compressor maps, where?
- Datalogging
- rolling chassis
- 1\4 Mile Times
- I need a turbo exhaust manifold!!!!
- Intake air temp sensor placement with turbo
- anyone see stephs new civic coupe this weekend
- Please read all 'Teg LS turbo owners
- HOW THE HELL DO I SET MY TIMING
- JUST GOT MY TURBO H22A BACK, QUESTIONS
- whast the difference between DRAG kits??
- JR/Walbro pump question..
- SOHC greddy turbo kit fit a DOHC motor???
- Lic plate
- using NOS with TURBO?
- New Supercharger?
- is the greddy PE to small for drag turbo kit?
