View Full Version : Forced Induction
- HKS BOV issue. Video inside..
- can you explain what happened to my turbo
- gt3037r.82
- manifold bolts keep backing out
- GsR Turbo SetUps
- gsr cams on stock motor???
- GM 3 Bar install, random engine light, no ECU codes
- Tranny question
- Need advice on DD clutch for boosted car
- Specs of the GT3076r (weight)
- turbo kit
- Is a oil cooler necessary?
- Edelbrock X turbo kit for D16Y8
- 350whp Turbo SetUp??
- First Time Starting Turbo del Sol
- oil feed help/o2 sensor help
- Drag radials...
- jason14's bore and piston size & sleeve questions for a new turbo project
- Making less power on bigger block.. Suggestions?
- heat wrapped manifold
- missing link or 3bar map sensor
- just got tuned but having missfire problem
- need block help LS Vtec Turbo
- Whats this thing in my engine bay?
- turbo manifold
- skunk2 pro 2 cams
- Cometic Fuzion HG Leaking/Blown head gasket when car is off? Smokes when turn it on...
- Homade turbo kit pics
- 3.5 liter pistons
- Anyone useing kms valvetrain parts.
- Exhaust housing question.
- went to dyno today
- injector o-ring?????
- Boosted k24 frankenstein
- newbie actuator questions...
- GOING TO TUNER!!!! WHAT DO YOU THINK
- Who does good block sleeving?
- Bard turbo setup?
- Sol Piping search
- Just had to ask. How much power w/ this setup?
- Mishimoto Intercooler?????
- how to know if spark plug are resistor or not
- d16 itb turbo.
- Ls vtec turbo setup looking to hit 12's
- Boost Problem .. please help
- 50mm tial bov what spring to use in a gsr...
- Supercharged teg
- About to buy some OEM cams for my turbo setup.... know what these are?
- T4/T70 vs. T3/T67 H.O. on stock motor
- help! CEL 3!! runing uberdata on decell!... tuned... weird issues.. motorolla 2.5!
- 14b on ls issues and questions
- New turbo manifold on our crx
- Cant boost past 6lbs any ideas
- T3-T04e trim 50 63
- how do you determine what injector size is needed?
- Went to the Dyno today! *VIDEO INSIDE*
- Hondata s300 Chip a d16z6 computer?
- odd howling noise from turbo?
- B20 turbo questions?
- future kit
- gsr turbo setup
- head question need some help from you D16 junkys.
- turbo gsr setup
- motorola map sensor mounting
- a small amount of smoke from turbo.. insufficient drain?
- GM 3 bar or stock for .6 bar?
- Stock Gsr w/ 75 shot
- What kind of turbo is this?
- WHAT INTERNAL DO I REALLY?
- * New to the BOOST world
- td05hr twin scroll
- what type of oil to use?
- Turbo d16a6 what kind of injectors to use?
- 92-93 Integra BIG FMIC Fitment!
- BW S258 or S362 for a 500+ D16
- suggestions for my progect
- My 450hp 6th gen accord
- turbo motor setup
- Oil Return Line, Need Help Please!
- Nitrous oxide vs compressor forced-induction question (chemical makeup vs power)
- quick resistor box question
- JRSC rebuild question
- My Build is finally going to be done ha
- Diy turbo setup gone smoking!!!
- SMIC???
- Help: missfire @5000rpm (H22 Turbo, AEM EMS + Twin Fire COP setup)
- HELP!! How can you ID a REAL garrett turbo by housings?
- Turbo build!! Need help with all the little misc. stuff!!!
- oil smell and possibly gas mix?
- GOOD place to get a replacement cartridge for my Edelbrock GT28r turbo?
- quck question about ic pipping and ic
- about to tune...street tune or dyno?
- ANY WRITE-UP HOW TO INSTALL HKS BOV AND TIAL WASTEGATE.
- msd
- Sandwich adaptor & oil filter size thread
- Question about v band flange size needed
- replica GT35r on ebay?
- stock LS b18b motor.. good for turbo or needs rebuilt?
- ams-1000 version 3 highlights
- Fuel Sump Using Fuel Tank Drain Plug?
- Zex Or NX... anyone running one of them or had both? ..
- T25 turbo gasket set
- obd2 turbo question
- Inline Pro T3 Manifold bolt size?
- ****Several JRSC Vacuum Questions with lots of pics! please help!!!! ****
- looking for a basemap for a b16 9:1, 450cc, 2.5 bar, t3/t04e 57 trim, CROME
- GSR will not idle
- Pic request of a 94 to 97 accord 3" exhaust.??
- Opinions needed on future build (turbo virgin lol)
- *TURBO HELP NEEDED BADLY* Video inside.
- two turbo questions in one?
- Stock 335whp H22a - AV Tuned
- how much boost?
- new motor set up and n/a dyno
- twin disc on h2b
- Question about skunk2 cams
- installing boost controller. retune?
- Questions about full-race's EK/EM1 B Series ProStreet Stage 2 GT kit
- Cam Choices for Fully Built B16 head with turbo application
- Turbo + Nitrous Question
- Side Mounted Turbo Manifold
- Im thinking TURBOoooOOoo...
- Water cooling lines for turbo too close to manifold ? (Pic Included)
- PLXM300 and S300 just aint happenin... why?
- boosting my integra question
- Oil in the exhaust side on first start up
- H22A Turbo water lines hook up ?
- HELP! fuel pump failing
- D seri-es questions
- boosted mini me
- has any one tried the ebay b16a low compression kit?
- Turbo question
- Sleeved block?
- Whats the max Boost on a stock b16?
- light pop from exhaust during pull
- Boosted B16a2 - Looking For More Power
- Opinions On My Set Up?
- NO fuel pressure... car was running then lost all pressure, Aeromotive, dual walbro, stainless lines
- k24 turbo frank... help
- i spark plug wires
- Supertech Valve Springs?
- Hi I need son feed back from Borg Warner users
- part reference
- Help...oil leaking from valve cover!!!
- Whats the pros and cons on turbo kits?
- Help! Need Basemap to get my car to dyno,Turbo B18b1 on Hondata s300
- Help in GSR HEAD build!!!
- Old School HKS BOV?
- Optimum AFR to Avoid Detonation?
- running 87 octane when your car is tuned for 93???
- Still okay to boost?
- precision turbo wheel broken
- building a h22a1 and need some help
- need advice for b16 turbo build
- finally getting going again!!!
- 450's with resistor box?
- LS Vtec turbo
- Peakboost Powered RSX
- B16 greddy turbo
- help with power curve
- going thru some pics
- Stock USDM B18C1 15psi
- where to buy premade turbo pipes for 1991 integra
- Ebay Vitara pistons. Anyone have experience with these?
- anyone using blox turbo manifold please give me some input!
- smoke AFTER I get on it...
- GT-K Turbocharger how big can i go
- b16 turbo smoking like a mofo. HELP!!!!!
- Strongest sinlge plate clutch...
- looking for block
- turbo jdm h22 accord
- engine bay hot
- Compression Results on D15B.
- LS vtec turbo built question ?
- nitrous
- Do I need a re-tune after fixing turbo manifold gasket leak?
- Question on housings
- Moroso OIl pan leak
- gsr intake cam with skunk2 stage2 exhaust cam? is it worth it?
- s300 distributorless????
- Going to build my D-Series! Need some insight/advice!
- turbo vtec disabling vtec
- coil pack and hondata??
- GT35R vs GT37R??????
- Benson Sleeves
- wastegate spring 10psi??
- b20 question...
- headed towards the right direction
- 2 weeks down, out of ideas.
- HELP ME SPOOL!!!!
- Wastegate placement... is this any good?
- 99 LS RUNNING RICH
- Nitrous tuning/NA tuning
- 15g greddy turbo kit downpipe ???
- !!!!!T1 Race Development Turbine Blanket!!!!
- Bottom End for Boost....What do you guys think?
- Turbo B16a2
- why is my boost gauge jumping!!
- B18c1 timing
- Turbo H23a Vtec integra...reliable?
- anyone know who makes a boost controlled exhaust dump tube other than ATP's VES
- Pictures of B16 vs GSR cams
- need some advice.. oil pan fitting is bigger than -10 AN line
- bw s258 dsm, any idea where to get this vband flange??
- Not a Honda.. but FI nontheless
- Please help me design a switchable fuel system
- Wierd check engine light problem on my turbo car.
- Car wont start :( after turbo kit
- Open dump tube - pros and cons ?
- Beginning of A Failure Part 1
- turbo d issues, need advice on resolving them.
- AFR changed after subwoofer removal !??!
- why does my oil look like this???
- straight LS vs. b16 on the dyno
- PCV valve and oil catch can b serioes motor
- inline pro log manifold with ssauto downpipe
- Turbo Manifold
- Car boosts, but doesn't go.
- Rad hose pressure - how much is too much?
- best oil to reduce piston slap
- Ls or Ls/Vtec Turbo?
- Turbo Kit For 2001 honda accord
- Anyone use an OBX header?
- waste gate question
- **My boosted setup/plans! help choosing between two turbos**
- fuel system questions
- where can I find these flexible couplers?
- How to replace supercharger belt
- Cutting up. Not sure if it is spark related.
- Q's for the turbo pros about my setup.
- my idle is high, what did i overlook??
- cams and pullys and flywheels
- XS intkae any good?
- Turbo Spool Question
- gt30r coolant fittings
- oil filter dissection diagnosis
- stock sleeves ????
- Turbo Air Filter setup - is this okay??
- 92 eg cx hatch ls turbo build setbacks need help
- what turbo kit to use
- Twin Disk Clutch-- TILTON Vs. SPEC
- B16A Highway rat...Methanol w/o IC
- Which turbo to use for my b18c1?
- Will 2.5 inch intercooler piping be restrictive for a 600HP Engine or upgrade to3.0 inch piping
- Protective Coatings for turbo components, Vbands, etc.
- parts list for 600whp daily driver Si anybody
- GodSpeed Project Turbo Kit????
- Question about total timing - b16
- Fuel System for Turbo cars up to 700hp
- jdm ls block has no black breather box?
