View Full Version : Forced Induction
- dosnt pull
- Pre-steps for installing turbo next weekend
- My new oil return..
- My turbo project woes
- fuel settings
- Full-Race + AC???????
- Need a little help here ASAP!!!!!
- Some New ***Dyno Graphs *** SRT-4
- I need a bigger turbo. help me decide (did search not much help)
- f22b1 manifolds... mine wont work...
- My plans!...Need help!...
- Garret GT32
- i think i'm going to cry
- Apex-i Turbo Timer????
- Block Guards
- sc61 vs t3/60-1
- what would a 70mm T/B do for my bone stock turbo ls??
- My Custom 2.5" Greddy B Series Downpipe .. Should I add Flex Pipe (PICS, 56K ok)
- Hondata missing parts????? Proper orientation????
- Shitty Ass Profec B!!!
- 15lbs of boost
- d16z6 sleeves vs...........
- what injectors do i need?
- What NEXT????
- EGT placement
- major problem: car won't start
- joining the dark side
- Anyone know where to get 76 Cool Blue in San Diego?
- top boost on b16a with stock sleeves 9:1
- most whp (sohc)
- code 16
- BTM and power loss
- Is it safe to use a pressure washer on my short block?
- WRX break in period???????
- just sold car need opiniom
- afc hack
- "Boostcoolers" Spearco intercoolers from eBay
- Those using Goodyear Gatorback belts with your JRSC
- Do I have Enought room?
- ls/vtec turbo
- puttin ZEX kit on stock block???
- ?? on installing holley 255lph fuel pump
- is hondata prounced honda ta or hon data???
- Is everyone looking for 500whp+ these days?
- Experience with baker precision
- VAFC hack running rich
- Multi-Stage Boost Controller
- Selling out for a DSM?
- JRSC used prices?
- Attn: FJO Lambda Meter Users some questions! NEED HELP!
- Precision VS. Turbonetics
- drag and deltagate
- Turbo Oil Inlet and Outlet Flange help
- NOVA thieves!!
- where can I get check valves at?
- hks type one turbo timer wiring help
- edelbrock sohc turbo kit
- couple shots of the never ending parts collection...
- Not making any boost
- Keep the D or get B series!!!
- Project Madness has finally begun.
- Just got my rebuilt turbo-Why is the shaft so hard to spin?
- ECU tuning
- fuel pump question
- gauge installation which wire to tap?
- Maxrev BOV is garbage
- FJO Lamda Meter question
- Best block to boost?
- Intercooler Manufacturing
- how much torque for 14 psi with built engine?
- jdmhondapro custom turbo kit??
- Will pistons from a b18 fit my C5?
- Cam and turbo question?
- SOHC w/boost, what rpm you go to?
- Datalog FJO output to palm without FJO software?
- AEM Plug n Play?
- AFC Timing, Fact or Myth?
- type-s, need flange?
- STi is here!!!! :D
- components for turbo setup
- 3" DP with 5 bolt turbonetics flange...possible?
- Just bought one of these for fun!
- HUGE engine problem. Vid included please HELP
- nitrous questions
- an size fittings for fuel rail and fuel fittings??
- Intercooler Mounting....Are You Bolting It Up
- Hondata Woes?
- how important is it to port match head/block
- Turbo Timer install - 93 civic
- Having second thoughts
- Could this work?... Stock tank and fuel cell? Diagram inside.....
- 3" downpipe with A/C
- another turbo related problem
- Fuck a SMC+
- Autronic SMC
- integra ic piping
- installing greddy type s blow off valve
- why is my profec B doing this?
- Manifold
- ... intake manifold comparison... skunk2 vs jdm itr...
- EAGLE rods: who sells them?
- what sparkplugs are you running in your boosted cars?
- Redline Tranny Fluid
- jrsc'd b18b1 with jg cams....
- bov choice
- anyone know why its taking 4+ months to get my turbo kit?!?!?!
- Needed a LeakDownTester...Made My own TODAY!!
- Help: turbo Oil feed line for D series engines
- hks setttings
- Thoughts on the race core crower camshafts?
- uberteg ecu installed
- Questions on B16a2 Turbo Size and Places to buy a Turbo?
- msd knock alert anyone experience?
- Won't Boost Past 3-4 PSI In First Gear
- "Black-Magic"
- someone tried to steal my car yesterday ....
- ImportParts.com would like to formally announce...
- b18b1 at 10psi...can i use 97+ prelude injectors?
- Zeroing cam gears on milled decks
- I/C piping..How many U-Bends or J-Bends needed?
- Tapping the turbo housing for the wastegate? anyone try it?
- more injector help
- fule system
- upgrading my t3/t4, suggestions?
- crx+t3
- Whys picking a turbo so hard........
- Ball bearing ownz Joo *vid*
- about to put on turbo kit BUT!!!!!!!!!!!
- d series turbo kit on b series motor
- greddy turbo kit owners- size of union piece going to oil feed line?!!
- .42/.48 T3 Bolt Patter??
- Fmu?
- ?'s about this guys posts
- Integra People, need your help!
- Precision T3/60-1, 10:1 compression, is it streetable??
- D16Z6 Turbo?
- Another one. Still need help with some stuff here, plz take a look.
- a.c./intercooler, '94 GSR
- can i use my hx manifold ??
- turbo SOHC stock internals.. standalone worth it?
- defi guages
- are stainless steel lines necessary for the oil return?
- Any Ohio FI's?
- what manifold to get ("inline pro's)?
- Passing Va emissions with 450s?
- Greddy d16z6 boost help
- back pressure in the dump tube? your thoughts?
- ZEX question!
- ZC vs D16Y8 Head flow charts (Thanks to Earl)...
- prepping for ZEX
- oil feed line - 3AN vs 4AN?
- Junk Yard Turbo for Dummies????
- Block Sleeving
- engine knock
- Strange sound from my BOV - need some input...
- To anyone who ever posted something like, "I'll only be boosting about 6 psi....."
- What turbo from what cars for a custom turbo kit on a 95 gsr?
- should the tuner need wideband to tune the car?
- Does the flow of a dumptube matter?
- Can this be done to an intercooler?
- Is sprayin with turbo ok?
- Afc fuel pump
- Fuji - it's not just for photos, its for engines too
- Turbo doesn't pull past 5500RPMs?
- Which FPR for Turbo Setup
- Greddy B Series Kit?MSRP $1999 ?????
- single fogger wet nitrous safe?
- Alcohol and water injection....
- 160 lb bosch injectors questions
- I was wondering...
- Manifold for a prelude
- A/F gauge problem...still there...
- could i ge running too rich FPR@60psi? turbo gurus help!!!!
- I keep blowing Alternator Fuses!!!! Help!!!
- which turbo for a h23
- leaking inj. can I run 310's ?
- Should I buy used crower rods????
- Q: About using stock injectors with stand alone ECU + BOOST?
- MSD Window Switch
- pics of my turbo setup b18b1 custom turbo. 56k beware.
- Boost controller question
- ... msd ignition... recommendations?...
- valve guides or rings
- saab turbo injectors
- QUICK!! need help!! how to tell what condition a JR supercharger is in!!??
- Boosting a 90 rt4wd wagon....?? about FMU
- Got my new intercooler!
- can i hit 200?
- installing fmu
- Running Nitrous w/ a JRSC
- diverter valve?
- Any one ever heard af a stroker kit from a company called ARI
- which engine
- what turbo for b18c
- Vortech CAN be fast...
- Let Go @ 10psi!!!
- Wheres the TPS on a d16y7?
- bosch wideband part number
- stock LS cams and turbo?
- Fuel Pump not kickin on when i turn the key forward????
- This isn't something I need...
- Custom Accord Turbo, help! Read!!
- pics of Another Car with a junkyard turbo kit! lol
- Oil return line angle....
- Is this gonna be a problem?
- will greddy kit fit on delsol VTEC w/ b16?
- Electronic Load Detector Help!!!!!!!!!
- MSD 6 BTM wiring diagram
- my motor is idling at 2000 rpm. why?
- thinking of ditching my thermal...
- coupling and elbow ?
- question about how much power from this setup
- are any of your friends looking to go FI? check it out
- Apexi Avc-r Question... need help
- Greddy Blue Box or AFC hack
- need help with check valves
- Is this gasket recommended?
- greddy profec B/ apex avc-r?? wich one??
- Anyone running a stock b20b w/ turbo??
- Rev Hard fuel pump
- Oil Return Line
- Oil return location on 4 bolt t3/t4
- Is this a good price for a custom Turbo setup???
- reccomend me bolts n stuff
- best regulator for boost???
- can I run 7psi safely?
- how can you tell if your clutch is slippin?
- Sleeper done...again...ya
- Silencer for the Thermal 3" Exhaust?
- Here is a place to get BSPT fittings at a good price
- Will JE'S resist/stand up to detonation?
- Welding stainless to mild steel?
- Custom JE Pistons...
- how do you mount your air sensor into drag piping???
- Turbo Weather
- EF-1 valve springs...are they any good????
- Tial wastegate touching hood.. need help
- Turbo rebuild at cheap turbo .com???
- critique my setup and tell me what you think, please
- I need a custom head gasket, please help.
- Help, my Tial WG gasket cracked in half!
- apexi gauges??
- AEM Wideband!!!!!!!!
- quick question about flywheel..
- hydro lock vs. blown headgasket
- ECU programing
- what inside diameter should i use for my oil return line?
- After 3 weeks turbo rec from Hell is running......
- Need some help with my turbo gs, please read :) Boost problems
- Type R Heads
