View Full Version : Forced Induction
- Wiring Resistors on 450CC DSM Bluetops
- Ok I think I am coming to the dark side
- Help! My turbo is not spooling
- downpipe wraping thing
- Boost controller choice
- CHECK VALVE ???????????
- need help with head gasket ?
- QUESTION WHAT KIND OF LSD?
- Ford 5-Bolt question, please help....
- how much boost could this hold
- ATTN: Full-RAce,LoveFAB, and similar Turbo manifold manufactures
- LooK HeRe!!!Turbo Center cartridge opinions
- HOW CAN I MAKE 400WHP!??!
- 427 @ 10psi & 515 @ 15psi...
- New engine... won't start now. Will pay if someone tells me whats wrong. NO JOKE!
- Forced Air Induction By Other Means
- SAFC sensor select rule of thumb?
- Boost drop @ WOT?
- Need some help with the size of an oil line....
- innovative boost controller
- horrible vaccum leak......
- Question? Specific Items to Obtain 400 whp for H22
- How to tune timing with no knock sensor or EGT gauge
- Pre-install checklist
- how mutch boost 400 whp
- V-afc hach ??????
- who's running a oil cooler setup?
- It's all over before it started
- who makes a 2.5" that opens to 3.0" downpipe for sc-61.....
- question bout rev hard
- Garret Vs. Precision
- where have you guys got your head gasket from?
- What is the best size intercooler for b18c turbo?
- buying DSM T25 junkyard turbo, which manifold for B series?
- DSeries Ninjas - Question for you
- b18b p/p intake
- how many of you guys have this kit and how do you like it?
- Turbo on Auto
- what clutch for b16a1 @ 12psi
- whew.... that was close...
- need some input: CAI filter or Heat sheild for Boosted Z6T
- What do you guys think of this TURBO???? Good for B SERIES?
- JDM EK9 Civic Type-R Turbo "ADVICE NEEDED - PLEASE HELP"
- throttle acts weird..help please
- Anyone ever run a Ta3107 Garrett turbo
- fuel pressure guage, electrical or mechanical?
- Headgaskets for boosting
- 05 accord coupe 4 cyl
- Stock injectors with Uberdata?
- what straight t4 for a b16? t4/t67 too much?
- TURBO GSR PROBLEMS?
- how many of you build your own engine?
- rc injector sat. non sat.
- Emanage tuning need help asap
- CRX HF with Nitrous.... stupid idea yes, but it's the beater
- Where is my weakness in my setup?
- building b18a1 block,do i need sleeves?
- oil leaking on downpipe! oil pan gasket help needed
- F22b1 rebuild?
- Filter or no Filter on your turbo inlet?
- D16z6 w/JRSC & Comp. ratio
- Ripped wastegate diaphragm (part 2)
- anyone have any suggestions on where the smoke is coming from?
- turbo question
- Did I go too small of a turbo ?
- FMIC question for 5th gen prelude
- parts
- 99 EX ECU goes past 7500 rpm's on a boosted d16y8???
- IS the SOHC and DOHC DP the same ...
- turbo shopping, help me decide (turbine wheel question, number of blades)
- Question about dumptube on External WG
- low voltage to o2 sensor=bad sensor?
- radiator leak, tiny hole on tube... is it fixable with jb weld?
- Help. Burning oil near the back of the block.
- Car hesitation at 4500+ rpm and now it wont start!!!!!!
- JRSC for daily driver - B18B or B16A setup?
- Profec B (not the normal questions)
- completed the greddy install
- Universal IC piping kit. Where to buy and what bends?
- H22 Skunk2 manifold problem
- Precision 780cc injector , what style clip OBDI or OBDII ?
- dry, wet, or direct port?
- Boring 82mm Benson sleeves to 84mm
- Anyone Think i Should keep my d16z6 Turbo Or get a h23a For my 93 civic?
- DSM 450cc injectors. do your click???
- SoCal..wideband.
- Blown Head gasket and stripped block?
- Boosting with iron sleeves
- To those who own JRSC'ed Integras...
- how my motor is running with new turbo kit
- skunk2 manifold and hondata gasket = lower egt?
- turbo
- zex nitrous wiring *pics*
- comptech header with JRSC????
- Turbonetics 0.63 housing fit where a Garett 0.82 housing used to be?
- which turbo is this?
- D16z6 Turbo
- #%^&* Overboosting
- CRVTEC / LSVTEC Turbo Oil Tap questions answered *searched*
- Which RC Injectors have a green top?
- PLs post pics for b18c intake manifold b16 type r intake..
- b18 turbo CRX VS. H22 turbo CRX
- What is the best intake manifold for b18c turbo charged
- one says...dont do it...the other says do it?
- 2" chargepipes
- what are the specs of this turbo
- nos build
- hows the vaccum work?
- Need some help making a decision... info, advice, opinions...
- the LS needs Boost! *pix*
- Video of Reilly's hatchback. Track run and fun run. Enjoy
- turbine housing compatibility question -- .63a/r and .48a/r
- Nitrous vs. turbo
- FAST system...where did you mount the ecu ?
- AFC setting's tuned for turbo. wanna convert back 2 na but how??
- DYNOED TONITE......NOT TOO SHABBY!!!!!
- For those who have a 3"
- te04h rebuild can't find????
- HKS ZC and t25 turbo......fitment??
- What kills the rods on D motors? well any motor...
- Spun Bearing
- I've seen some videos of crazy turbo'd cars...
- earl?
- What should I do???
- Finished up the charge piping today...(Second time welding!)
- Installing walbro 255 need help??
- Dart users!
- 5-bolt to 4-bolt turbine housing... is it as easy as it seams???
- wtb:MSD Digital SCI Ignition
- aem wideband o2
- EMS Gripe! LOL
- B16a turbo del sol build!!!!
- Turbo B16 w/T3....what tranny?
- which intake is the one
- Conversion Harness OBD2A/OBD2B
- So think i blew a ringland ...
- Tuning question - will running lean or rich cause misfiring?
- WHo was the guy who makes the greddy 2.5" or 3" DP??? I forgot his username
- I know its a noob question, sorry
- Help, running lean!!!!
- HONDA-TECH forum 101 question
- hks hiper falling apart???
- d-16 w/11 psi hold stock brand new head bolts with no lift?
- BUILT GSR 95
- help with 95 gsr turbo
- BUILT GSR 95
- Someone in ohio help with turbo teg!!!!
- Radiator questions for TURBO OWNERS.
- Inline Pro Turbo Cams, anyone got these?
- Help w/ unknown garrett turbo! searched!!!
- afc hack..CEL
- 6th gen h22 biulding question
- Info needed, Garrett Turbo
- Socketing a ECU???
- what to do without turbo timer questions...
- Can someone help me out to why I am getting boost creep?
- PYR or PORTFLOW?
- GT35R.. specs/help??
- ODBII B16 1996 Del Sol with Drag Gen 3
- im happy . . .
- Almost ready.some clearance issues(Tinker come and see =) ) PICS PICS PICS
- 1993 Honda Civic dx w LS/Vtec/Turbo Must Sell
- Boosted crank vent and catch can problems. Diagram inside
- hks bov
- Tial 44mm Wastegate Question
- Question about Vacuum Ports at Intake Manifold
- HOW LONG HAS YOUR BUILT MOTOR LASTED?
- which is a better engine and how much power will i get
- Oil Lines
- Well my EM2 (2002 Civic) is now Boosted
- MAP check engine code.
- best turbo for 1 cam
- Good Turbo?????
- 700whp Civic Coupe - B20VTEC
- best turbo for my CRvtec project
- GReddy Intercoolers
- One quick question!!!!
- Engine choking at 6,500 RPM
- Small crack on turbo housing still usable???
- Motor Went BOOM, CRAPPY TUNERS SUCK!
- WRX turbo WG spring?
- need help injector sizing
- 01 up civic injectors
- d16 FI compression - HOW LOW CAN I GO?????????????
- Wastegate vacuum ?
- where to get uberdata
- DA.... Will Turbo Plumbing fit?????
- Is my turbo cooked?
- Wanna see a bad setup?
- What are my chances on hitting 350hp with this setup???
- is a precission pte gt 52 a big turbo?
- part one of project boost.
- vac leak sound comming from turbo xs mbc.
- someone help me solve my overheating problems..
- how much boost can b18b handle stock?
- D16z6, greddy turbo, Emanage
- EG/EJ OEM fogs with FMIC??? does it fit?
- Post Pics of your 3" KTeller Exhaust
- My interesting experience with OIL WEIGHTS, for newbies and those wondering...
- whats the fastest a newer evo with stock turbo goes ... with no NOS ?
- need help car wont boost pass 3lbs and wont go over 4k rpms
- Machine shop f!@ked up, would like some advice from the experienced...
- What should definately be new on a turbo setup?
- Boost Problems
- SR20 question, but you guys should be able to answer it.
- My car cuts out in upper RPMs when boosting hard...ignition?
- Do the New Eagle Rods have the Upgraded bolts?
- Back in Action. My MR GSR is boosted, now better than ever! (Seriously, no 56k)
- OT: Dynoflash Evo Goes 10.594 @ 137.30
- And Then There Was K.....R.I.P. B-series
- Fuel Pump.... is it strong enough??
- ALUMINIUM intake manifold good or bad?
- I just joined the darkside
- Do I need To Overbore or Not?
- RESISTOR BOX WIRING
- WHAT to do with hot manifold
- what pistons?
- NYC NEW YORK - Need hondata cable today!!! Please help me out - I'll buy or borrow.
- leaking charge pipes
- Car Misfires after being pushed hard
- where to get piping?
- Vortech bov flange same as greddy type S?
- SOHC-T dyno plot need help from the turbo gurus
- I found several uberdata nokia datlogging cables!!
- Feed line problems
- Uberdata Help!
- Dead Oil Pump?
- cracked block wtf?
- Best Adjustable Fuel Pressure Regulator
- 550 injectors
- GT2540R on B16A?
- ebay air/fuel gauge
- how much will a highflow cat hurt?
- watercooled turbo
- t3/t4e on b16s-what power?
- where can i get silicone turbo hoses/reducer from in red?
- Went to the track with the 4DR Finished 11.993
- need a chip for my ecu ASAP PLEASE HELP
- Internal wastegate?
- !!Need help on injector question!!
- i'm begging please help!!!!!!!!!!!!!!!
- Has anyone heard of...?
- Anyone use Factory Mopar turbo's??
- B16a dyno results
- What Rod Bearings fit my car?
- Will a avc-r work for engine management for my turbo Del Sol?
- Greddy e-Manage Support Tool
- on a supercharger should the fan inside it turn while your car is off?
- My first set of sleeves and they sank!!!!!!!!!!
- Help!!! Oil coming out of my exhaust housing!?? anyone??
