Pusher fan help, pic inside - blade and motor direction
I've installed this fan on my condenser, and I can make it a pusher by reversing the wires (making the motor turn clockwise), but I want to be sure I have the blades setup correctly.
Can someone please advise if I have this setup correctly?
1. Should the motor turn clockwise as a pusher?
2. Is the blade assembly installed correctly to be as efficient as possible in a pusher config? Or should I pull it and flip it.
Thanks!
Chris
Thanks!
Chris
Re: Pusher fan help, pic inside - blade and motor direction
It certainly appears that the blades are properly faced for a pusher application... which means that the rotation direction would be clockwise.
stinkbox
10
09-15-2011 02:02 PM
Trizzy123
12-02-2007 01:58 PM
