View Full Version : Forced Induction
- question about cam gears on a boost set up?
- resistor box with precision 780cc LI injectors?
- Ran my Gsr turbo on the dyno today.
- This is weird...see if it makes any sense to you...
- Opinions on Twin flute exhaust housings
- How do I rebuild my 14b?
- SHOW ME YOUR LS TURBO'D SET UP
- greddy turbo kit install,eng light,codes,stalls at red lights
- what are your EGT's
- will a boost controller help my turbo spool quicker?
- Looking for Greddy GSR turbo install guide
- which turbo is better.. T3 super 60 vs. T3/T4b
- question on wideband setup??
- Pro-rwd Class vids
- Greddy CEL after WOT...please help
- Installation of the turbo FINALLY!!!!! (56k dont think u should maybe dono)
- Hondata tuning in VA
- Charge Piping
- Oil return fitting ?'s...
- Anyone tried this?
- LS/VTEC turbo guys/ oil line question
- How long until you were bored?
- which ecu for gsr turbo?
- solid cel after getting codes...
- beerbongs first time at the track! ::video and timeslip inside::
- Buying a JRSC
- Draft: The green monster is alive!!!! DYNO, Mod list, and highway run.
- Coolant evaporating after turbo install. Any suggestions? :(
- Crank for Turbo GSR??
- Who rebuilds turbos in SoCal?
- D16a6 with D16y8 head...head studs?
- will t04B h-3 compressor take me to 350whp??
- Picked up a manifold. Cheap. Help identify.
- Lower compression headgasket for D16Y8?
- Hondata Tuner in the area of Springfield, MA???
- Tuning fuel w/ Hondata
- B16A in a DA...what size turbo????
- bluish white smoke
- i need advice
- Good idea to put a boost controller for stock wastegate setting?
- what you think the best setup on a b16a with stock sleeves?RODs/pistons/crank??
- Intercooler Piping 2.5"
- 255 and 255 high pressure pumps? difference?
- Hondata S100 or S200
- Part number for a 3bolt 3" exhaust gasket?
- Fuel pump question
- Will this missing link work on my car? 94 Civic Si.
- Second hand Turbos
- Is this turbo worth getting a cartridge for or should I toss it?
- planning to boost. need help!!!
- GE Vacuum manifold
- Can someone confirm these are the pipes for GReddy kit??
- preparing for 3bar install
- What turbo is this?
- Need help!
- ** Greddy Gauges Help **
- APEX-i AVC-R
- Just ordered my Turbo Kit!!!
- Just got my Turbo LS somewhat tunned tonight...well, kinda...
- Any where else to "t" the fuel line?
- Which bov?
- b16b ctr turbo?
- 60-1 hi-fi question.
- Best turbo kit for a stock itr
- which oil pump?
- stupid car...
- *~*Calling all EFI and Turbo nerds, HELP!! running too rich on 450cc and 390cc w/ VAFC
- injector clips ... ???
- car skips at idle... HONDATA or injectors??
- Carbon fiber part...come one come all.
- ZEX dry nitrous...is 100 shot ok!
- AEM's new Cam Gear
- Turbo install in 93 si need opinion
- block notcthing question
- d16z6 cp piston ring gap..NEED HELP!!!
- DIY Stainless Steel Turbo Manifold
- GM TPS sensor issues...
- Diagnostic help please, headgasket and rings?
- driving with untune hondata
- B16 laying around, what do you think is the best?
- TO4E 50 trim vs. TO4B 60-1
- HAS ANYONE EVER SEEN A TURBO DOHC PULL 243 LBS TQ AT 4.5K? MY FRIEND DID AND I WAS LIKE WTF!
- Boost
- ARP or AEBS headstuds??
- rsx turbo problems, help
- If you had the choice...
- 38mm VS 40mm WG Spring
- Changing Wastegate Spring....
- what do you guys think of this mani
- spot the difference??
- Aftermarket Intake, PCV Question/Problem...
- T3 and T4 comp housing fitment?
- will i be safe using a vafc or safc
- t3 turbine flange dimensions
- No oxygen sensor, hurt performance?
- I need a chip with basemap ASAP.
- BOV question
- who boosts AND sprays?
- Whats the highest you're boosing in your JRSC kit ??
- which turbo timer??
- Tubular vs. Semi tubular dyno
- Need instructions on Blitz dual sbc****pics inside****
- got the turbo d16 up and running. pics inside
- Dyno day with with the boosted-hybrid squad
- turbo ar question...
- special sleeves for b20
- Correct Injector Sizing ... searched already, 2pt. question (LONG)
- turbo manifold
- detonation question?????
- Intercooler question - something different.
- Hondata Tuner in Nor Cal? Recommend anyone?
- dyno session at inline pro
- Shoul di buy a used BOV or new?
- max boost on gsr stock fueling?
- Greddy GSR and SI differences ?
- HKS Type-0 Turbo Timer Porblems (searched)
- DOUBLE POST: Turbo guys=Good Tech support (link inside)(Just my motor build process!
- Mopar T3 turbo inlet side? What is needed?
- numerous problems with freshly turbo'd car
- stock headgasket 24psi???
- Exedy Twin Disc question//Paging GOLDMEMBER&XXXRACING
- Help, i just installed an fmic on my sohc vtec, but it did'nt run so good.
- Manifold
- Hondata basemap no workie, driving far with stock ecu......
- d and b series kit
- absolute vs gauge pressure
- how many wires to ignition is TOOOO much???
- Eagle rods
- best turbo manifold for h22....
- No room for a filter, what do you guys do?
- help with my tuning please
- Give me your thoughts about these turbos.
- IC piping in MN
- 2002 honda civic ex 1.7 SOHC turbo kit???
- Jackson Racing S/C Problem: Civic Si
- this might b kinda stupid but would be helpful if somebody out there answeeered this
- PGMFI inling pump wire.. QUICK question!
- FI questions
- Is my motor Blown ?
- DEL SOL TURBO KIT
- how long has everyone had there turbo
- turbo bogging
- anyone use turbocalculator.com
- intercooler question
- boost gauge install Question
- My dealings with Jordon Kohler
- IC Piping ?
- Exhaust leaks after the turbo.. do they effect performance?
- Buying GReddy 18g kit for 00 Si, issues....
- low Compression (~8:1) on a honda motor?
- Turbos
- installed greddy turbo kit(eng light)
- custom intake manifold???
- Aem fpr question
- Does JE distribute total seal rings
- post pics of you turbo to FMIC piping
- IDEAL precision turbo for stock head/built bottom end h22??
- just got done reading my turbos compressor map...NEED A 2ND OPINION!
- Best boost controller?
- 99-00 EK Turbo owners.....
- FMU/FPR question with Hondata
- Nitrous question ( Direct Port for b16a1 )
- 2nd wont rev past 6200rpm?
- turbonetics vs. garrets turbo
- Air Fuel management with Turbo ZC.
- NEED inline fuel pump relay diagram!!
- Help!!! Is the first gen APEXi S-AFC the same wiring diagram as the second gen???
- Is it OK to have 2.5" downpipe then 3" exhaust all the way back to muffler?
- just installed fpr now car wont start
- Anyone rebuilt their own turbo?
- Safe boost on a soch teg
- Critique my setup....
- NGK 9 series spark plug part #?
- I HAVE A PROBLEM WITH MY TURBO.....
- Defi gauges (pictures)
- del sol intercooler piping?
- afc hack problems
- car wont boost anymore
- overheating. bogging, stalling problems w/ SOHC-T
- Reliability (and power)
- ACL bearings question
- Hondata Help for JRSC GSR
- Mini-me meet HT, HT, meet Mini-me.
- what rod bearings do use for my eagle rods in my b18b?
- Anyone use the walmart marine pump on thier daily driver?
- radiator fan replacement
- what is a safe PSI for b18b
- smallest filter w/4" inlet
- stay with greddy blue box or not?
- greddy 18g fit d series greddy manifold?
- greddy emanage questuions
- any tuners or builders cheap in Md/Va?
- retune w/ test pipe?
- EGT Wire
- best way for catch can install
- important: head gasket blowen, is it possible that the engine could handle that?
- Best Closed deck H22 sleeves??
- is it ok to run oil feed line under/next to oil pan
- oil return line fitting ????
- Question on: sc61 & gt35 & pt67
- 754cc injectors for the street
- Can I make 400hp with 550cc injectors?
- Hondata w/ AFC
- intercooler piping
- kinda OT: pics and setup on my awd dsm (56k..i doubt it)
- used JRSC with uberdata
- what does a gm 3 bar map sensor come out of
- Z-10 oil catch can...Where to mount it?
- Help, i need some suggestions on how to run ic piping. I got some pics.
- Going to the Dyno on Monday 28th with leaky HG
- Did everyone have to cut out there front grills on there bumpers?
- B16a2 JDM Hatch Turbo Questions...
- are there any headgaskets that actually help seal better then stock??
- t3/t4 B good for 350whp??
- best turbo for 300whp application
- Project Big Block Update....
- best way to tell what injectors you have?
- bad seal or oil return line??
- replacing toasted valves
- oil feed nipple fitment
- Uberdata problem or maybe not?
- boost leak?? HELP
- MSD coils? which one to get?
- Can anyone give a logical explanation to this setup???
- Turbo Oil Problems
- ls vtec turbo no vtec engagemant
- question
- Type1 turbo manifold: Any reviews?
- High mileage b18c1 head...what kind of maintenance?
- Where Can I Get ARC Intercoolers ??
- Cars with Big Turbos With A/C Im trying to get Ideas
- Upper Radiator Hose Diameter--2000 Civic EX
- Fuel Injector Resistor Box - Which cars have them stock?
- Need some advice on turbo setup
- what kind of gas mileage do you get on a turbo b16
- transmission pick
- Max HP with 440cc injectors?
- greddy turbo
- ok i want to turbo help me out
- DSM T25->what size plug will fit the O2 hole in the Housing?
- jdogg's tuning road trip through the north east
- turbo install problem HELP OIL LEAK
- Turbo rebuild?
- Bad distributor?
- BEST FLYWHEEL AND CLUTCH SETUP?
- Weisco or CP?
- Oil line off firewall.
- New Build! Will not start, Compression test cylinder #1-4: 0, 120, 0, and 0
- Gsr turbo w/ or w/out cams?
- Got my car re-tuned..
