View Full Version : Forced Induction
- o2 Question
- my quest for 320+ whp
- OBD II B18B Turbo options
- Boosted head set up
- junkyard turbos
- bkr7e-11 sparkplugs in a turbo charged b16
- Can a turbo be blown/toast without leaking oil from the seals?
- Boost Controllers
- Want to turbo my gs-r, wtb hondata s200b with ecu anybody have???
- plx DM-5 AFR + SM-AFR COMBO
- For those considering Vortech superchargers...
- O ringed recommended for high boost setup?
- What kind of Gas Mileage are you getting?
- Vibration, think it might be axles
- 85mmGSR Turbo>>MAP PRoblems!!
- Do forged pistons/rods have to be machined together?
- oem fpr....fuel pressure of all oem honda fpr
- leaking from FMIC?? can it be?
- got back from dyno today... new numbers, but something still wrong help
- Turbo elements top mount manifold!
- b20 turbo
- t3 or t4?
- BKR8E Need stock number
- 550cc + Crome + Turbo LS = No need FPR and Gauge??
- turbo oil seals...
- 38mm tial wastegate ? HELP!!!
- LS boosted with these pistons?
- How bad is it to boost on a basemap
- Turbo Manifolds
- how much does a 5th gen (96-00) civic weigh???
- dsms
- B16A head
- WTF how are Vband clamps and flanges measured???
- DSS stage 5 users... I need your help
- boosted b16 running 6-10psi do i need a 3 bar MAP sensor???
- What should the resistance (ohms) be on precision 1000cc inj.
- Anyone using the PHX42-GT-Q from Phoenix Turbo?
- BKR7E or BKR7E-11?
- 2.0L ls vtec turbo
- 5 psi on a ls with stock fuel
- Ignition Coil crapped out on my on the HWY..
- Anybody tried Jacobs nitrous Mastermind on their zex kit
- wheres the MAP sensor on a 2000 civic?
- stupid Question about the Garret GT28rs (searched)
- upgraded fuel return line is it needed?
- Arp head studs...Quick Question
- What You Think About My GSR-T Setup?
- piston/rod combo
- Where can I get a .48 backhousing for an sc61?
- Evans Tuned 400whp GSR Dyno Graph
- Skunk2 Intake Manifold and charge pipes
- At what hp/psi should a block be sleeved?
- *Searched* motorola 2.5 bar map, AFC settings?
- Boost but no power!? Engine feel asleep above 6000 rpm - please help
- cel misfire codes/cel flashes while driving........obd2 greedy turbo
- Knock Sensor Readout/Display?!?!
- RLD Fab or Full race Mani?
- what will it take to beat evo8
- another catchcan story .. will this work
- bov strength
- why does the oil return have to be tapped as high as possible?
- Just got my turbo today!
- so after she got to my head things wen down hill
- coolant hose
- cam not spindont spin, so how bad of a problem is this. ning
- Cam gears+30 lbs question
- ecu code help (searched)
- *IF* I Had A Blown HG - How Fast Does Coolant Get Burned?
- Necessary upgrades prior to turboing...
- BOV PLACEMENT???
- help with hondata s300 launch control
- tuning idle For VAFC II
- logging with lc-1
- Newb question abolut custom turbo.....
- PLX M-300 and CROME Datalogging. Help Needed!!!
- Hondata S300 question LS vs B16
- Anyone in South Florida want to make $500 tonight?
- HELP! Turbo install No Spark
- wtf tiny supercharger
- anybody using LMA-3 (AuxBox) or DL-32 with your innovate wideband?
- People making 400-450+whp
- Can you blow the oil seals on a ball bearing turbo?
- Installed Greddy Turbo Kit 92-95 EG Wont START!?!?!
- I dont know if its me or not
- help! can't remove drag manifold, need an 12mm offset wrench???? damn....
- my $175 single cam turbo kit
- would these work together?
- aftermarket tb's
- Top-Mount.... Oil Return set ups
- Need information please
- Where to buy a...
- Need everyone's help
- Gt30 shaft play
- TURBO ls throwin trouble code 43, HELP!!
- 8:1 pistons???
- Turbo B18C1 or Turbo B16B?
- whats the hights compression?
- Tuning options for a Turbo Carburated V8? I don't have the slightest clue.
- LsVtec Turbo Oil Feed Question
- Turbo question for junkyard turbo...searched...
- Turbo Filter Impossible - What are you guys using besides?
- Bought a Darton mid sleeved block but there is an issue
- gt35r upgrade what a/r with gsr 84mm???
- Vitara Oversized bore
- Aem or Hondata
- Endyn catchcan install, whats this bracket in the way?
- B18C
- New Wastegate Technology, Different Concepts
- How long should it idle down for?
- S300 w/ GM 3 bar settings anyone?
- Removing Charcoal Canister/ Evap Emissions
- Problem with wastegate/radiator
- good idle AFR for turbo'd d15\d14 with 450's and safc.
- ls or gsr for boost on budget?!?!?!?!?
- looking fo a shop
- Crower Stroker kit for b20 need opinions.
- Tuner in baltimore area for crome!!!
- Alcohol/methanol injection kits to bolt into a 99-00 civic? Anyone?
- how to make ls rods fit.
- PLX M300 PART NUMBER!!!
- SC'ed K20's
- OVERBORED CYLINDER!!!
- What is your TURBO IQ?
- How much boost or horsepower on pumpgas before detontation?
- Who makes RELIABLE cams for the LS?
- Piston selection Q's
- Does this turbo cam exist?
- PCD of bolt holes in T3 turbine housing.
- How Much Boost ??????
- First time at the track and I'm really dissapointed
- Cranks for Z6
- where do my coolant hoses go?
- my oil line keeps kinking
- Found a cheap 3" inlet muffler if anyone is interested.
- BOV question
- GT4088 on LS/VTEC - Power to expect?
- fuel pump?
- WANTING TO TURBOT NEed Advice...
- quick question about supercharger pullys
- AVC-R Problem
- Are these CP pistons in "great" shape? *PICS*
- Harm in driving with a cracked manifold?
- Went to the dyno last night (video)
- RSX Turbo Idle to High..??
- Greddy T517z, ANYONE With a member ship to clubrsx??????
- 95 civic sohc turbo
- supercharger?
- downpipe help?
- T3 .60/.63 VS SSAC T04E .50/.63 - Why is the SSAC Compressor So HUGE?
- FMIC with oil inside. How to clean it out?
- Full-Race Bushing GT-40 Dyno (Servion Tuned!!)
- The boost confuser
- New Turbo Install - How To Stop From Spinning *alone* ???
- S2000 422whp
- i am looking for jdavis
- HELP! Turbo started and idled fine! Then it wont start again!!
- Is this good?
- Opinions on using the IACV and FITV...
- d16y8 block w/ z6 head Nitrous build
- After turbo install, I hear ticking arounf IntakeManifold. What is it??
- help with check engine light
- What is the diameter of Drad IC piping (cold side)
- Stroking a GSR............
- Crankshaft Micropolishing
- what can I do to a 92 hatch cx
- spinning on the dyno troubles?
- Tuning
- golden eagle head stud
- arp bolts
- kms ultimate valvetrain package?
- OBX LSD: How to get the axle out?
- Turbo Downpipe
- Exhaust cam advance
- checking for wiring resistor box
- *PICS REQUEST* JohnnyRace 6" Intercooler + 92-95 Sedan w/ foglights?
- water and Oil cooled turbo cooling time.
- Smoke from under the hood after a hard ride?
- 4" downpipe/exhaust under rear cross member pics
- Target A/F I know asked this but whats the optimal A/F ?
- Please review my first CROME basemap
- What trannies for the B series are good with 300-400 WHP
- boost controller wont set lower psi
- turboing b18b1 stock internals
- Vtec with Forced induction
- 706 whp St00pified Turbo B18C
- Something different. Turbo LT1 swapped S10
- Post your turbo DC2 sedan! Boosted, all motor, please share!
- Ek and EJ, where did you mount you AVRC (or AFC unit)?
- dc5 and ep3 greddy turbo kit owners
- woohoo
- got my dyno sheets up
- Oil feed line/ missing link
- dip stick
- oil lines
- looked at tuner directory and saw Performance EFI in san diego. anyone heard of it?
- RSR S2000
- does anyone have a pic of fast-turbo fuel kit installed on eg
- E-Cut out Question
- do i need to put my intake temp sensor in my intercooler pipe?
- Ignition breakup when hot
- waste gate not opening?
- How to keep your car COOL under FI?
- exhaust fumes smelling really strong lately??
- Turbod (singleslam) 12s Civic Video (new)
- What should My next EMS be?
- I need help ASAP... stupid cam oil seal
- got tuned yesturday had problems need some advice
- Help needed please
- Car suddenly wont start, please give advice....
- Boost Gauge
- Rate my build! How much HP?
- Tuning questions.. what else do i need??
- Injectors Size
- Fuel System Question??
- Dyno for Steady State Loading??
- How to hook up a PLX-M300 wideband?
- boosted b16b questions
- looking for someone that can make a topmount/dp that fits well in a da integra...
- what is a good tune?
- Relocating the IAT and filter after a tune
- Some pics of a fully built 01 ITR-T..
- will a 99 SiR JRSC fit a 98 B18C5?
- coating flexpipe sections?
- nos
- PRofec B-spec2 question
- Overheating......help!!!!!!!!!
- need some info on Zdyne pm6 si ecu for turbo application
- AEM dryflow filters vs K&N oiled filters?
- Oil Feed line question
- Searched but couldn't find it...Td04 or smaller turbo on a DOHC? Will it be ok?
- Tuning with Aem compared to Hondata s300
- Topmount Oil Return Pics...
- BLOX turbo cams idle???
- wastegate ..."situation"
- How heavy should a dumptube BE? i got mines done at muffler shop too heavy??
- Whitfield racing? anyone heard of them? should i get my car tuned there?
- Routing the dumptube to the exhaust
- Oil Return Line on Moroso Steel Pan Fitment Issues
- Best beginner Manifold
- GT42R, AC, 4" downpipe, need I say anymore?
- RE-SLEEVING A D16Y8 AND I'M ALSO LOOKING FOR PISTONS & RODS
- just trying to be like tony1 .. spoolin personal street car
- no turbo timer
- got ati super damper now i have a question for you all * look here*
- greddy kit
- Easy question
- i need some one in charlottesville , virginia
- cometic head gasket thickness???
- h22 stoker turbo ?
- Overheating with top mount manafold?
