View Full Version : Forced Induction
- First time at the track
- freshley built b18c, can i brake it in with turbo installed????
- GT42R hybrid?
- needeing the 411 on boost controllers
- turbo xs dual boost cont. VS turbo smart dual stage boost cont.????
- oil restrictor
- Check out this really sweet downpipe and this car I picked up...
- WIll this work?
- charge pipes?
- headgasket?
- resistor box question
- autometer boost gauge not reading boost????
- PT3ecu
- exhaust piping
- hondata question?
- crome or hondata?
- blow off valve problems
- 440cc saturated injectors on a turbo si
- best cam for a turbo d16z6???
- Quick fuel pump question...
- Really confused about "help with GT4088R , GT4082R and GT4067R" . ?????
- Reputable tuner in my area.....
- CRV Supercharger kit anyone?? (searched)
- To turbocharge or not to turbocharge? (D16Y7)
- AEM EMS 1050 Question.... MAP Sensor Issues
- boost increase
- Any one got pics of a sumped tank in a crx
- Turbo Manifold question
- ECU EPROM rewrite question
- Friend's Built GSR-turbo won't start
- RC or Precision 1600cc injectors?
- .nate
- manifold
- witch ram horn should i use
- how long time did you 15G last ?
- Wastegate opening at idle
- 75.5mm Headgasket with a 75mm bore? Does it matter? (cometic MLS)
- turbo for my sohc build... (need some input)
- apex afc
- Would this turbo work?
- my b18b setup
- Turbo Kit for R18? (2006 civic dx/lx/ex)
- xenocron tunning reputation??
- Where can I get these adapters??
- Rods?
- Why do most turbo imports come with side feed?
- Kteller 3inch catback with Magnaflow muffler
- What are the stock valve lash settings?
- thermal 3" catback... anybody sell a baffle?
- Is a t3/t4 60 trim .48a/r compressor .60 a/r turbine good for a built d16?
- Evolution Wastegate...........
- surging!!!!!!! DISTRESS
- o2 sensor location
- Injector and clips
- FJO VS AEM injector driver
- How much would you pay for a used Greddy turbo?
- tune yesterday....breaking up after 4,500rpm
- oil pressure gauge reading wrong
- Tuning boosted s2000 today
- A few questions and my setup :D
- Update: ls/vtec-t with newly installed cage! 56k no way!
- Going for a 75 Shot! What do i need to DO
- GReddy PRofec B-Spec II air filter
- 750cc RC Engineering Saturated Fuel Injectors HELP!
- WG flange
- ge sandwich adapter...which to order??
- Gitwidit civic Movie
- MY Turbo just installed and info about me 56k nonoo
- Walbro pump question....
- Where can I find a 22" resonator for 3" KTeller exhaust?
- Shop in Miami for EJ8 D16y8 T25 Downpipe?
- high compression boost,why?
- QTP e cutout?...
- the truth about the ZEX 59300 cam?
- Best turbo or setup for D15B7?
- Pistons...
- I ordered a Fuel pump and.....
- spark plugs
- Nology with Nitrous
- JG intake manifold for d16z6
- GReddy TD04H 15g Downpipe flange?
- Question: Ever done Before? Carbon Fiber Charge Pipe
- WestCoast-Turbo.com any good?
- AEM pully kit.....harmonic balance?
- a little something for you guys.....
- HELP!!! please, looking for a map for temp use
- rc Injector question
- my initial review of the Rev Hard b-series intake manifold
- turbo cost?
- what size exhaust on turbo ls
- clevite main bearing no good??
- ** Hot Tanking vs. Sand Blasting + Hot Tanking
- What fuel pump would u recommend on this setup...gsr
- HkS BLow off valve ssqv not making any noise at all
- B18c5 Internals???????????????
- How to wire up individual MSD coils on K series
- what else can break in stock 300 hp daily driver
- Ebay Intercooler
- Full-Race Turbo Cams
- Thermal 3in
- speedometer not working...why?
- Oil pressure Gauge Install...
- Turbo Recomendation
- Building 300-400whp D series. Question about overboring/sleeving & which turbo to use.
- LS/VTEC BUILD>>!!!!!!
- Anyone have a Chome or Uberdata tune for GSR with JRSC @ 9-10 psi?
- Header stud kit
- whats this elbow and flange that comes off the wastegate?
- Block wasn't cracked! How do these machining prices sound?
- Anybody use Eldelbrocks Oil fsupply kit adapter?
- SPECIAL THANKS from FULL RACE
- fmu good or bad
- SAFC 2 hack.. is anyone running this on turbo set up??
- Is this a good Deal - for a Fjo Wideband Unit + Ntk o2
- Flowmaster on Turbo D16y8
- Which Blox cams are best for my setup??
- spark plugs brand/gap
- 4 inch downpipe for ramhorn manifold
- Haltech Flat Shift??
- Engine management options???
- spoolin log manifold dyno or 1/4 times anyone?
- Turbo b16
- New exhaust
- What could be causing this? (ACT Clutch Problem)
- Bigger Exhaust?
- No. I didn't search.
- where is the thread for how to make a boost controller?
- can i used a aem 3.5 bar map sensor with hondata???
- Whos using the TurboXS Quad Stage BC
- where to get 3" muffler that sounds/looks good?
- what gm 3 bar do i have?
- Kteller 3" Exhaust LOUD!!!
- Help with b18c1 turbo choice!
- noob question
- wat kind of turbo???
- searched : pic request (distributor side) intake-exhaust cams ITR,GSR,CTR,B16,B17,
- Need some assistance and advice, please.
- zex dry kit
- GT40R vs GT35R T4 vs GT4082 and GT4088
- Primary lobe size affect Turbo spool?
- How to tell what size AN hose or fittings you have?
- how much boost/HP can stock injectors support?
- Nitrous Gauge Problem
- gauges
- Problems with my new turbo setup!
- Helper spring on 18g wastegate actuator
- JRSC BELT question!!! will this fit??????? HELP
- turbo ballancing (searched)
- walbro 255 lph
- Engine code running rich
- SOMEONE ANSWER ME THIS ONCE AND FOR ALL!!!!!!!?????
- D16 turbo setup
- 486hp in a 1,6L toyota !
- hondata and crome pro
- crome or uberdata
- How you raise your oil pressure after a rebuilt ?????
- Wastegate issue
- WTB: Motorola 2.5 bar map sensor
- My turbo B18C Buildup, what hp do I expect out of this?
- Replacement JRSC belt question also... Napa, Autozone or Pep boys Part number.
- what companies offer backdoor style intercoolers?
- I know it's a t25 but i nodn't think it's to small?
- Catch can filling up with water??
- How to remove top part on a Turbonetics Evolution wastegate to change the spring?
- Fraudluent material?... or authentic?
- AVCR VS AEM with GM boost solenoid
- Piston to Sleeve Clearance
- Need help identifying a turbo flange
- seen this on alot of boosted car lately
- swollen top radiator hose, help
- Quick wideband Q
- importing p75 vs p06 maps into uberdata.
- Weird Problem On Fresh Install. Please help.
- removing cat after tune?
- How does this manifold look? do not know the Brand/quality.
- Bay Area Honda Data TunneR?
- removing and installing pistons
- anyone have MBC problems over 25psi
- oil lines???????
- what kind of turbo is this? t04e t04b? what is it cant figure it out?
- Tired of killing sparkplug wires!
- anyone ever deal with himni-racing???
- any difference hks ssqv/sqv BOV
- Race fuel additives
- What size AN hose to use to B Series radiator?
- what do you guys think
- spot welded ported shroud????
- few finished pics of my turbo setup, built this winter
- Oil feed and return - Hardlines?
- bone stock b18c1 oil recommendations
- Is it possible to run a 100 shot on a D15B safely?
- I need oil lines
- eagle rods hp handle?
- will Tial wastegate springs work with Turbonetics Evolution wastegates ?
- where can i get 2.5" exhaust flange??
- Need H22 log turbo manifold
- Motorola 2.5 bar anyone have in stock?
- anyone got a oil line kit for sale? besides Flamenco-T
- Help on install... where do these go?
- Electric Turbo
- Hi, how you doing?
- Rev Hard kits
- Where can i get an oil return line? what size or what not?
- Help Wanted performance Shop in Delaware.
- where can i get a lsd install
- Did a leak compression test....are these god numbers?
- Turbosmart Supersonic and Megasonic BOV Opnions, PLZ.
- Where to buy turbo.
- Lovefab Manifolds.......
- T4 flange to a t25 flange manifold?
- Is it a good clutch ?
- Choosing Wastegate
- Precision 50 Trim or Prescision SC61 for B16
- DUHR Q: Shaft Play on Drag t3/to4e and how to ID?
- help me with my problem please
- sohc boost question
- ELECTRONICS question for boost, ls/vtec
- h22 engine build
- Turbo install tomorrow - any last minute preps?
- Solid CEL on key with stock? Problem with wiring?ecu?rom?
- need help with msd btm insallation...
- Pinks episode that just aired
- breaking up in boost
- ECU hondata 0r crome?
- Is a Catch Can necessary.................
- 90* fitting coming straight off the oil return, too harsh?
- Greddy Type s Question
- Precision GT40R with H22
- Is the Blox IM a good choice for my application?
- Switching over to boost!
- uberdata...what the diff between opening and importing?
- twin or biturbos
- Can I use this piston now???
- 250 whp D16 - What internals? Need forged pistons?
- HELP!! boosted msd ignition problems - sputtering.. misfiring.. cutting out~
- Can you explain why the 14b sucks for built d16 or b16?
- Got my turbo today
- Will no o2 sensor send the car into safe mode?(cant rev past 3800)
- Rod Bearing Notch?
- motor mount incerts
- 333whp Stock B16
- Competition Clutch break in?
- problem with new boost guage. help please.
- intercooler Q's
- Spark Plug Gap?
- Post pics of your full-race fuel sump installed
- need help locating a turbo
- Some pics of My D Series Top Mount Manifold
- info on this turbo 1.00 ar and .70 compresser with pics
