View Full Version : Forced Induction
- Royal purple or Mobil 1
- Update... white smoke coming out of radiator
- b18b + turbo
- Poll of turbos by State!
- turbo sizing ?
- $5000 Question
- Hey, is it cool to wrap the down pipe with heat wrap?
- How To Rebuild 99' Si Altenator....Anyone!
- to the guys with the crazy idle prob. i think i have the fix!
- JRSC/LS Dyno Plot Links?
- chance of warpage on block and head?
- Post Pics of tubular manifolds
- should i??????
- ECM Boost limit on PWC
- MAP sensor identification???
- h23 turbo?
- Should I go F/I on my 94 GSR?
- May buy JRSC! Pros & Cons?
- Fuel Cut Strategy of the ECU - Any thoughts?
- Anyone know the bottom line Dealer price/wholesale price on a Drag III kit??
- Diagram on how to hookup a MBC?
- My new toys :)
- getting a/c to work without stock ECU?
- HELP!!! Replaced headgasket, still doing the same thing!
- hondata...do i need all this stuff or not?
- how are darton sleeves?
- Anyone running Crower Cams
- will a drag gen3 manifold and 35mm tial wg fit my car?
- **BOV vacuum line blew off**
- DRAG Kits....
- A/F Ratio gauge Insallation ?
- Is a Field VTEC compatible with boost????
- Hondata need help!
- Got my B16a, want to turbo, how will stock ECM react?
- Got screwed by shop. Now what?
- Hondata installation on obd1 LS computer
- Oil return fitting placement
- fenders with flares molded on?
- non believing friends of mine.
- Mix Matching ECUs Help
- How many of you guys w/turbos actually use adjustable cam gears?
- boost spike....need help
- how to identify intake vs. exhaust rocker shafts
- Solve this vibration riddle and become a good friend of mine !!!! =) (please)
- Turbo with 2.5" piping, but stock muffler?
- What size charge pipes should I use?
- puddle under my car
- Confused on adjusting BOV
- Will Non-mandrel bent pipes hurt performance?
- f-max turbo kit...how bad is their mf2? sorry, search came up w/ not a lot of info
- Ok my hood is messed up and i think its cause of the turbo. any ideas?
- How do you remove the turbine housing from a turbo?
- WTF does "ttt" mean?
- greddy t.v.v.c amnual boost controller??(anyone problems W/ this ?)
- which spark plugs for jrsc
- Headgaskets
- turbo professionals ONLY!!!!
- apexi turbo impressions
- High 14's with a SOHC turbo?
- dsm's get low 1/4 mile times but low mph???
- who has crower turbo cams??
- QT movie: Defi BF series guages
- Golden Eagle Mfg. Sleeves
- Which turbo kit do you prefer?
- Blew a spark plug at the track
- How does a Intercooler, actually cool air?
- Where can I buy a piolet and throw out bearings????
- lower temp thermoswitch (fan switch) is it worth it?
- Help Please! I can't figure my problem out
- What FMU disc to get with holley 255 fp and 310cc injectors with fully built block (and a crank?)
- SoCal: Dyno Day Cometh
- I am such a Tool
- honda tech members on espn this weekend................
- Pornstar Race Car raped
- DSM injector question
- TO the guy who got his 550cc's for 270 shipped <sorry forgot your name>, how long did it take
- engine mods to run 9 to 12 psi
- ATTN Incognito
- Dyno Horror Stories
- prelude injectors fitment on turbo civic
- How much HP can a stock Prelude pump support?
- How much boost on an unsleeved block?
- CRVTEC, Boosted or All Motor?
- Clutch masters
- JRSC with Vortech Aftercooler???
- Fuel management on a badget ?
- tyte supercharged s2k
- Quaife or Kaaz?
- Best cams
- steps in polishing turbo?????
- OT, how do you replace one of the studs on the head for the exhaust manifold ?
- ARP head studs...LS/vtec...let's get this straight for good...
- blow by?
- homemade electronic map limiter.... anyone else using one?
- Fuel Pressure, Timing, and Spark Plug Gap With NX EFI NOS Kit (35 and 50 Shots)
- what size and where to buy my magnaflow muffler
- bosch in-line??what fuel pump recommended and where to buy
- whats the cost of building turbo motor?
- Dawes Devices mbc
- Turbo Compare- Lotus Esprit Turbo Gsr Turbo
- should i get this 3" downpipe for my car?
- Info! (DRAG DEALER) Can someone give me info on becoming a drag dealer?
- t-25 true psi?
- how hot does it need to get to warp the cylinder head when overheating?
- A few pics of our revised Custom Turbo Project on our D16z6
- what exhaust is good for turbo?
- turbo on gsr
- is anyone using the crower 63401t turbo gs-r cams?
- what cam for JRSC
- any JRSC B20/Vtec
- Anyone fooled with the hondata autotune functionality?
- teg ls boost question
- HKS SSBOV help....
- Help with SpeedPro installation
- DRAG questions: FMU, fitment, and tuning...
- Does Skunk2 manifold have any type of stamping on it?
- What gauges do you have. . . . .?
- What did you use to file down block?
- Anyone in Saint Louis area or Missouri with Hondata???
- Ball and spring or check valve?
- Z10 with turbo
- strange vibration in engine
- Omori gauges
- "Turbo" ecu chip?
- Wastegate dump question
- CRX full race drag car
- drag on a B18c
- anyone selling a used turbo kit for an civic si?
- NEED a RevHard or equal length H22A Turbo Manifold!!
- AEM EMS possible on non-obd vehicle?
- B18c Supercharger setup
- who is running a turbo timer...any suggestions
- another break-in question
- I need a hookup in SoCal....
- N1 3inch turbo(not a cat-back Q)
- Turbo Integra final Dyno results and 1/4 mile times post here..................
- turbo clearance
- Slicks are in, what to do to prevent axles breaking
- O2 simulator....
- HKS/tial wastegate
- polishing iron?
- well my motor went again.....
- Tial Wastegate need now.
- NDRA in texas
- stage 5 cm clutch looks like...?
- Most Important 3rd guage?
- No OBDI ecu yet, run the LS or GSR OBDII ?
- GSR Tranny rebuild
- need help with a turbo set up!!!
- Hondata 4b users in Atlanta area (help)
- Running good on AEM EMS PNP with 3 bar map and 550cc
- Estimated Power/times...
- need help with turbo
- Need pics of blockguard installed
- DOH!! DRAG manifold bolt on turbo is brocken!
- 1/4 times on my setup, what do you think
- noob question: do you need headwork for 15+ psi?
- Prelude Eagle Rods?
- ringing bell sound, think it is the clutch
- Wanna get a headcount on turbo'd hondas here vote once..
- Anyone looking for a 3 BAR GM Map sensor for boost ?
- Fmax Turbo Need Help!!!
- something weird! check this out!!!!!!!
- quick b20 question...
- Found out how a blockguard works...
- Pics of my turbo setup!!
- Drag Gen III...
- is it ok?
- Is this safe??
- drag 3 turbo and hondata?
- blowing fpr diaphram all the time why?
- My dyno run.........
- they call it...
- what do i need to make DSM 450 INJECTORS to work in a 99 TURBO LUDE?
- How important is fuel pump at 7-8psi?
- valve clearence on turbo d16y8
- Just Got external Wastegate(PICS)!!!
- Selling something else if anyone is interested
- Running rich w/turbo setup?
- Paxton FMU disk
- t-25 what psi?
- good luck
- b.o.v sound??
- Need detailed answers on cooling system please!
- Hosing on Boost gauge?
- I'm BOOSTED!!!!!
- wutup guyz...new to honda-tech just wanted tah say supp
- turbine seal blown
- BOV question
- 00 Civic EX w/Turbo vs. B16a CRX, need opinions/stats...
- I need emissions done in VA. Help!
- Question about 2nd O2 sensor.
- Turbo d15? what do I need?
- SMALLEST turbo for b18c?
- Base fuel map wanted for D15
- DIY-WB installed
- greddy exhaust question
- What the best boost to run for street w/street tyres
- Broken axles
- Melting SPAL fans
- A boosted ITR joins among the ranks...
- Swain or Jet Hot
- Idle Problem...HELP ME PLEASE!!!!!
- Intercooler End tanks design...
- custom downpipe
- JRSC Question
- OT:rant about Battle of imports at Route 66...
- pistons and rods
- Ghetto ignition timing help.
- t25-fuel questions!
- Places to get a good cheap inline fuel pump......
- Now hard core tuning, but how to get EGTs down?
- I need a simple knock detector..... j&s is overkill for me
- trust this?
- Has anyone rebuilt their T3?
- how much boost does stock si sleeves can take...did a search but no luck...
- stock sleeves w/ lots of boost!!!
- i cant get the starter to fit flush in..
- whats needed to runs DSM 450's?
- why are lightweight flywheels bad for turbo
- Turbo cams?
- d16a6 z6 head greaddy kit 8psi...........
- mini me swap + turbo
- Will a 00 si turbo kit fit a 94 hatch?
- Help with install on Profec B for 99 Civic SI... Need Help quickly Please....
- ot:timing belt tension
- 99+ Civic owners with FOG LIGHTS.....
- LS/V-tech turbo or LS turbo???
- Is my turbo weak?
- pictures of my car....................(jinxproof99)
- New Turbo--Few questions--almost crapped my pants
- Torque spec for b18c oil pan?
- head gastkit and other ??
- whats a good clutch for forced induct...
- What intake Manifold should i get??
- How hot does everyone's chargepipe get ?
- HOLY SHEOT !! 11 psi intercooled JRSC.
- Car not starting..
- cooling system + fan
- FS: DRAG manifold, B series, brand new
- how can my EG get into the 14's with a SOHC??
- OT: where to get keepers for valves
- who can host photos??????????????
- 98 gsr tranny
- Blitz turbo timer insatllation
- No Gaskets come with Tial 40mm kit?
- Anyone know what plugs i need to convert to- to make Rc 370cc injectors fit?
- White smoke and oil in the charge pipes?
- Has anyone ever seen this...?
- Excited japanese guys
