View Full Version : Forced Induction
- turbo or supercharger?
- feedback on running both apexi vfac & avc-r..on drag III turbo.. good or have better solution..(besi
- wastegates: delta or tial?
- my car is running like CRAP....possible fuel problem????(anyone)
- DRAG turbo kit plumbing - how well does it fit?
- how much to gap stock spark plugs? (did search)
- Turbonetics manual boost controller...which way is to up the boost, and vice versa.?
- low idle...
- How do i hook up my turbonetics MBC to my tial.....?
- need help wireing an old avcr.
- H23 Turbo Manifold
- big problems- need help and info
- Question about Wiring up a Resistor Box
- Compressor Surge
- ATTENTION st00pid
- Any built ZC's with dyno #'s???
- looking for info on nitrous (preferably the zex kit)
- does anyone use the NITROUS mastermind?
- quick question, vacuum source for manual boost gauge?
- whats a burnt clutch feel like?
- 12:1 Vortech FMU???????
- 60mm Pillar guage pod. Is there Such a thing?!?!
- What Cams are you using if you have Nitrous in you car?
- Is this true?????....H22 and pistons?????
- Good online store to buy gauges?
- Project DSM 450cc w/o a resistor box.
- Greddy SOHC kit piping layout
- Motor Installed!
- What injectors for 15 psi?
- PCV/catchcan: help me clarify something
- Need to sell my RC 320...
- Need a pic of TD05-14g, somebody got one?
- Need help asap
- SON OF A......IM PISSED!!!!!
- Is it okay to mix gauges like...
- Do Defi gauges fit in Autometer Gauge pods and BEZELS?
- Downpipe size?
- UNHAPPY with turbo
- Best buy for DRAG 3 kit ? Where have you seen it?
- Fuel sufficient or not?
- Fuel pump?what kinda.....
- high fuel pressure question
- stock Fuel Pressure on a 2000 Civic EX SOHC motor?
- Guys HELP I need the hondata fuel maps for a B16 with boost and PW0 ECu
- WTT: RC 550cs for RC 440s
- Finally have my dyno numbers....
- Safe to hold boost??
- any thoughts on this turbo ?
- Wrapping Manifold
- headgasket thickness questions...did search
- ITR TB for boosted Si
- bosch inline fuel pump
- whats a better turbo motor B16A or B18A/B?
- Limits of pump gas
- damn my car is running like shit...
- gm map sensor???
- Any tricks to holding the silicone hoses from POPPing off?
- turbo?
- Can i use thicker oil for a blown turbo
- damn, turbo is blown
- Need Custom Kit Help
- fuel pressure guage broken.....anyone have this problem?
- vortech or jrsc?
- Semi-tuned 10 psi!!
- Has anyone done the AFC Hack on 370cc Injectors (did Search)
- Where to buy spring, and ball bearing for homemade MBC?
- turbo feed line restrictors
- Who can get me a block?
- FS or Trade: RC 310cc injectors, i blew my engine so i need bigger
- WHAT NEXT?
- head gasket with turbo
- CA Residents : Have you passed SMOG W/ Greddy Turbo?
- Pics of my junkyard IC piping, for those of you who wanted to see (!!LARGE PICS!!)
- Vacuum line size.
- hondata users
- fuel pump and filter help.
- Good place to buy a Qaife LSD Differential cheap?
- You want to talk about forced induction?
- IS there some extra thingy I need to buy when buying a EGT GAUGE?
- Which FMU for 550s?
- Valve Alignment questions
- engine shelf life?
- Bar to PSI conversion
- stock elcise tubo size??
- track meet/competition.. see link
- Upgraded Rear control arm in blue and Gold color
- I'm in need of BROWN MAIN BEARINGS
- when building your bottom end to be stronger, does anything need to be done to head...
- My experiences with Golden Eagle
- Garrett 4 bolt downpipe flange?
- Critique my setup
- Where to find a good priced Greddy Type S bov
- t3/t4 Problems
- T4 AND THE T3/T4
- OT: Video of rally AWD celica........
- DFI Tuning
- Need JG Intake Manifold ASAP
- JRSC parts???
- exhaust
- Stage1 cams ok with turbo?
- Where to buy engine rebuild kit for b18c1?
- Recall on Autometer electric full sweep fuel pressure guages
- boost controller
- b16a internals on a b18c1?
- hate to post off topic
- DSM Injectors...
- exhaust for turbo ludes
- How much does the moroso oil pan hang down Vs. stock oil pan?
- CM stage 3 question
- 370cc injectors good enough for this setup??
- Anyone interested in a GT Ball Bearing turbo kit?
- LS/VTEC. Which turbo kit?
- ok so iam going turbo hel me choose a turbo
- griffin fmic
- Looking for ignition, have been hearing a lot of bad stores abou MSD?
- Greddy blue box question
- So, why do I even NEED a Fuel and Oil Pressure gauges then?
- is it possible to have ....
- Which turbo should I go with?
- Assembling AN fittings?
- I HAVE JOINED THE DARK SIDE... (3 semi big pics inside)
- 300 WHP on stock b16 axles
- What else am I going to need to make 400whp? I am trying to decide if I need more..
- Fuel Supply and Etc...
- vaccum/boost sources
- I heart boost
- Place to buy a Type R FLywheel.
- Detonating already?????????
- just got funded for gsr turbo..need a few quick questions answered..
- Drag 3 intercooler mounting question...
- 97 turbo EX...2.5" exhaust or 3"
- which teg/turbo kit would you get? (Lets get technical guys)
- D16 turbo guys? what kind of clutch/flywheel combination are you using
- Looking for a source for 3Bar GM map sensors
- new manifold,wastegate and downpipe on.WOW!-no more boost creep
- AEM short ram with JRSC
- Resurfacing a STock Flywheel.
- Am I really asking too much for my chassis?
- Radiator Fan is not on?
- sohc turbo swap questions
- Anyone have 1/4mi results with a JRSC Prelude?
- Coolant leak?
- Pictures of equal length manifold.
- where is the cheapest place to buy hondata?
- are "bandaids" overall reliable for low boost apps?
- (Hybrid901) Dynorun #'s
- 3 gauges?? Or 4 guages?
- What brand of head gasket do you recommend?
- IF you had to choose, EGT gauge, or water guage.
- POST pics of your oil return lines..
- another sleeving question
- Turbo timer + Alarm
- oil return fittings
- Supra Injector fitment. What will work (INJECTORS)
- heat wrap stinks
- turbo newbie questions...
- To everyone I pissed off by saying "Single Cams sucks"
- Anyone made 400 whp or more on pump gas yet with non vtec?
- My turbo setup (pics!)
- cold air setup with turbo?
- whats is better supercharger or turbocharger?
- Dataloggers q's?
- Life with the JRSC
- LS or GSR tranny for LS/VTEC turbo?
- The history of turbo 101
- JRSC 17LBS
- what kind of turbo?
- Turbo Terminology...
- Well, my MSD is in and working, but I noticed something really odd...
- reusing head bolts
- Lowering Compression?????
- Turbo or supercharger? help!
- UEGO (wideband O2) Group-buy!!!
- Ordering hondata, base map question?
- T-25
- - PICS - My new custom SOHC T3 manifold!
- wtb: have money - need fmic blow off boost controller and guages
- 60ft times? how to bring them down .
- what thickness head gasket to lower compression ratio
- has anyone had ENDYN modify their supercharger?
- slightly OT: want the FI opinion
- Wiring
- mainfold question?
- Dual ball bearing turbos --> Are they worth it?
- Blitz 660ccs?
- 01 Prelude Sh what Turbo should I get?
- Used JRSC
- Dimple drilled vs Drilled thru rotors
- Nitrous bottle, when do you refill...help
- Greddy Kit with intercooler on CRX made easy!
- Need your experience with the state ref pleaseeeeeee help
- blue smokin when shifted down ....
- Where can I buy a 3" flexpipe?? (I searched)
- Resistors
- tdo4 14g tdo5 16g
- Turnbed up the boost--now theres a hesitation in boost going from 2nd to 3rd
- anyone use RPT specs Turbo chip for pr3 ecu.
- PICS of my new turbo setup =D
- Opinions on piston coatings
- BOV. . . ?
- Boost Controlers. . . . . ?
- max boost from greddy kit on built motor
- 2.0 liter block with STOCK B18C head?
- what ignition timing do you guys run at like 20 psi and up
- Radiator help for 97 DRAGIII turboed Integra...
- My fuel press crazy?
- Dyno #'s
- Steel or Aluminum?
- WOULD I PASS SMOG IF I RUN 9:1 OR 9:8:1 COMPRESSION
- 1st Intercooled JRSC Si that I know of.
- Which turbo
- Drag3/stock GSR which tranny GSR or LS?
- boosting less than 10psi is useless
- greddy fuel setup
- screw it... im putting my turbo in tomorrow morning...
- need help with new turbo setup
- which plugs to use, Denso Iridium or NGK BCPR7ES-11
- making my own turbo manifold.. have questions
- b18b eagle rods on a b17a crank
- To Boost, or not to Boost, that is the question.
- How stinky will a Turbo be with a Test pipe????!!!!!
- car cuts out at 5psi
- CTR Cams in LS/VTEC Turbo???
- Who needs fuel rails
- Will b18c turbo manifold fit b18b1?
- Lower boost problem in 1st and 2nd gear.. what do you guys do.
- Getting ready to start it up
- ARP head stud specs?
- Hey guys i am ready to sell more of the prodrive oil pump gears
- Boost dropping off with AVC-R?
- Rollcage wanted for eg hatch
- 1.8 turbo question
- FMAX Kit Limitations? / A few Q's on the boosted H22A1
- how do i measure the voltage for a TPS sensor?
- smiling but curious(urgent)
- First steps to upgrade a stock 91 Eagle Talon Tsi AWD?
- nitrous law in ca?
- How do I get more fuel??
- ok guys here goes something
- zex spark plugs...BAD?
- and after 138 trouble free miles we have a problem
- what size pistons?
- Which type of injector is better for turbo apps?
- Dart/Payn B-series Honda Block
- last chance before i start my car
- tubo???
- DB8GSR doing auto-x. Video inside.
- Good Place to buy Greddy Profec B Boost controller??
