View Full Version : Forced Induction
- Turbo leaking/consuming oil
- Need Assistance: How to determine turbine Hsg exhaust A/R on this unit?
- Recommendations Welcomed: 1st timer..Custom-create or entry level turbo kit?
- Question:Is it possible to migrate B18B1 Internals to B18C1? what should I expect?
- Need Assistance: Optimal B16A2 Turbo Build Parts List?
- Discussion Topic: Electric Turbo Assist Module (ETAM) - The Great Experiment
- Em1 turbo selection help
- Turbocharging Questions for 1st time D16 user.
- Is it possible to use Brian Crower Stage 2 NA cams in a turbo B18B?
- Need Assistance: 94 B18B1 turbo w/ TPS problem
- Need Assistance: B20 Swap using LS OBD1 Automatic ECU possibilities
- Umair's Turbo s2000 build showcase
- BeaterBoost's Built D16Y8 Novice thread
- Suggestions: How can one effectively build a Turbo CRX for a Street/Strip purpose?
- D17A2 turbo build questions
- Turbo Type R Piston/Compression advice on pump gas
- Discussion: Let's talk about optimal oil pressure and oil temps for the turbocharged
- Assistance needed: BW S362 creates (Blue) oil smoke during idle conditions
- Assistance needed: Engine Misfire occurs at "low" boost pressure levels
- EG6 Civic VTi - Darton Mid Sleeves Temperature Problem
- Suggestions & Opinions: Comp-R HX32 T28 7cm Hybrid Turbocharger
- Assistance needed: Rod bearing measurement/clearance methodology
- Opinions/Assistance needed: First attempt for B18C 600whp project build
- RC injector question
- What can we use when OEM distributors are hard to find?
- Assistance needed: Boost creep condition during tuning
- Stock Muffler Major Restriction?
- Need Assistance: Engine is Cutting out after warmed up.
- Can't Retard Timing?
- Confirming my smoking issues
- Header wrap question
- Weird problem leaking oil
- mrdpep's FI crankcase ventilation catch can theoretical diagram
- Assistance needed: H23A1VTEC Engine management options
- Assistance needed: B18B Turbo with fuel pressure / mileage issue
- B18C1 JRSC General Maintenance
- Is my wastegate broken?
- fic 2150 install skunk2 composite rail/victor x man
- Ring Gap recommendations for nippon cast pistons for turbo B18c1
- Rise of the turd (EG turbo)
- Suggestions needed: B20/VTEC turbo project -Will sleeving create a power advantage?
- kevinweinmann's JDM D15b vtec turbo project build progress
- f23a1 turbo questions and help
- The Blackbird rises from the ashes - SUPERCHARGED - Build Thread
- Slipknotko's Build thread: looking to build a 500hp "G"23
- BWR Turbo "Hot Parts": Feedback on Quality and Utility
- Need Assistance: F23 Accord Coupe Turbo - White smoke issue
- H22A Turbo Complete rebuild 1st start suggestions
- Is my wideband sensor set too far away to get an accurate reading?
- Should I install an aftermarket camshaft on a B18A/B using a T3 sized turbo?
- Garrett T31 2.5" 4bolt turbine housing vs. GT 3.0" 4 bolt conical turbine housing
- Is it possible to use a turbo engine then convert to All Motor for Winter?
- Opinions on motor build direction G"LS"R or B20A4?
- Need assistance: What it takes to get 200hp on a stock D16Z6
- D15b vtec pistons that don't require boring the block?
- What are some tips on removing a turbocharger's turbine exhaust housing?
- Intercooler pipe knocking - recommendations of protection from erosion from rubbing
- Help me fix my TS Wastegate!
- D16Z6 Turbocharged CEL, Idle, Vacuum solutions?
- Radiator drain plug replacement possibilities?
- Berto 24 Turbo Build Progress :)
- B20 VTEC turbocharger setup question
- Oil Feed / Return line configuration feedback
- Alvarez.Esteban's 1995 honda civic dx b18C1 turbo build thread
- Any vacuum leak solutions to regulate car's ability to idle properly?
- Pictures/Advice Needed on AC Compatible Ramhorn & RR Manifolds
- D16Z6: Stock injectors max fuel pressure
- I have $1,200 to spend on a D-series turbo kit for 200hp. Opinions welcomed
- B16/B20 400hp dreams!
- Turbonetics turbo as part of an eBay kit: Real or Ruse?
- Just dynoed my s2000 gtx3076r setup. Down sized from a gtx35r
- Assistance needed: Ignition related(?)stutter b18C Turbo
- Ebay catch can's vs everything else
- 1000awhp CRX AWD Turbo 4G63T
- 92_civic_eg's D16y8 Turbocharged build thread
- Walbro 400 fueling issue
- d16z6 head with d15z1 bottom end combo. ptw clearance??
- d16 Best Junkyard Turbo
- B18b turbo check engine while drive
- Need Assistance: Cylinders 1 & 4 are not firing
- Juancito's boosted 1730cc EG6 build thread from Argentina
- Ssqv4 and FLUTTER??!!?!?!
- Poor ground connections, ecu wont respond.
- Boost problem!
- D16Y8 turbo build
- GSC turbo cams installed advice needed
- Turbine Inlet question
- Garrett T3 60-1 standard or Turbonetics GT-K 325?
- Bigger injectors on mini me swap until turbo....
- Obd2 emissions
- Post-turbo issues
- Assitance Needed: Engine Overheating (Hondata Code 11)
- How can I tell if a turbo kit is quality or Chinese ebay junk.
- not sure how this makes sense, but...
- Need some help with my lsv turbo build
- Need help with my Mac boost solenoid
- B16a1 head. -turbo
- B16 head. What block? - Turbo
- B16a head on a b18c block with boost
- s366sxe extend tip
- Any expiernce with these injectors?
- Anyone set valve lash looser with high boost?
- Bad Boost Creep
- No Intercooler
- Best SOHC Vtec for boost?
- Going turbo - d16 ebay cam help
- D16 turbo build, but will the transmission hold up
- F22b2 Turbo help
- eBay turbo kit on d16y8?
- How high coolant temps before damaged engine?
- compression Test question LS/VTEC Turbo
- Best way to start stock b18b1 recomendations!!
- Name this turbo
- Goldiewang's K20A Swapped TR3030R "VelociRaptor" Project Build
- Help with boosting 1991 Prelude si?
- Holset HX35 compressor vband flange
- 1997 Ek Coupe D15b1 Boosted
- b16a turbo size
- full boost and engine cut under high rpm issue
- Boosted B18b not starting????
- 94 civic ex - No throttle response, rough idle, dies without foot on gas
- Oil Pressure
- Turbo build thread for a F20B in a BB6 Prelude Chassis
- GSR Turbo
- Boosting my D16z6, a little help with some questions? :)
- CFM and PR calcs - something I'm not getting
- Advise for my b16 turbo
- H22A4 Turbo Project: 16 and trying to boost
- Engine misfiring
- GM IAT is compatible with Hondata S300 now?
- Turbine selection for different manifold designs?
- b18c turbo suggestions
- Turbo or N/A?
- Turbo CRV suggestions
- bought a civic turbo. having problems. please help!
- Ebay Turbo Build Low Budget
- f23 02 ACCORD LX TURBO BUILD
- My Turbo/Engine Build List-'01BB6
- Back from the dyno - 84mm Type R - 500whp goal
- CRX b16... inline pro OR drag gen 3 - keep A/C?
- Is this how you install this catch can?
- What turbo is this?!?!?
- LS-T falling on its face.
- Turbo GSR w/Skunk2 IM???
- first time k20 turbo build STOCK MOTOR
- B18c4 turbo annoying problem
- thinking about going boost
- 98EGY8's Stock D16Y8 Budget Turbo Build Thread
- ready to be flamed
- Has anyone here ever used the Z10 oil pump fitting?
- BordWarner S256, stock LS set up.
- Loose boost on the top end
- Turbo Feedback & Wastegate Question
- What turbo kit to get?
- BW S366 on stock LS?
- D16 turbo runs really rough
- eBay but custom build kit CRX b16
- k20 turbo manifolds obx, speedfactory, full race comparison
- New turbo or fix old?
- Any of you guys using a Vibrant catch can?
- Turbo GSR w/ forged internals max hp?
- D16 turbo won't hit boost
- open build
- ArgonB18's B18b1 Turbo Progress build
- Question on on3 turbos
- for those that want to get a GE sleeved block, got a video for you
- Performer-X kit.
- Tire Size & Wheel Width for Turbo EG Hatch With 16in Wheels?
- Gt2871 power
- After 15 years, I want turbo!!!
- Brando's F22B Prelude "Hunter" Progress Build
- 91 C-Rex Si B16a turbo coming together
- sheepey ff smoking issue
- Sheepy Manifold / Downpipe Question/Help
- Battery light + fuel/ignition cut around 5000rpm???
- h22a7 block question
- Turbo B18A1
- main cap differences from different year gsr?
- Having an issue with my heatwrap..
- Street Turbocharged GSR?
- Super Cheap Ebay Turbo Build
- D16 turbo fitment
- I have question
- Any help would be appreciated!
- OFFICIAL HOW TO: Hardwire a Fuel Pump
- New Walbro sound?
- D16 Smoke After Sitting
- Boost By Gear Question
- HELP!! Ignition Table D16 FJ Vitara Build 8PSI--IS IT SAFE??
- STC dbb hunter turbo + db8 gsr = grocery gettin street car build
- new to forced induction. Need some guidance. h22a delsol
- 10ga fuel pump hot wire question
- Help! What turbo will i get.
- Would this put me at 600hp?
- ignition timing a civic for turbo
- Boost drop question
- crank case pressure problem
- How much power can i get with this stuff 0n b18 motor
- Please help me! Civic d16y8 turbo project!
- 800hp Turbo Dart Block on AWD EG6
- JRSC B20 fuel advice.
- My Toyota ae91corolla has a problem with it Honda ecu software
- Fuel Pumps - Latest and Greatest?
- Turbo Installed - White Smoke at Idle
- b18b1 supercharge build?
- Gt2781 size
- Tial 38mm Wastegate Not Closing Properly
- Bumper fitment with Intercooler
- Tank to Rail braided line, Fuel pressure drop
- T25 on stock y8 motor
- D16 turbo help
- Blowing out oil?
- DUAL WALBRO 450
- Fast spooling turbo that's doesn't break the bank?
- D16 turbo size
- How have people plumbed in their water cooled turbos?
- D16z6 turbo or not to turbo.. DD - gas milage is important
- Piston install
- Best a/c compatible turbo setup for B series?
- D16 turbo exhaust question
- 98EGY8's LS-T 300whp Stock build thread
- Lsvtec boosted help camshaft selection
- Anyone running Type R cams...Vtec engagement point??
- fuel feed question
- Voltage drop under WOT
- Turbo Selection Options: B16/Spoon Cross-mission Trans for Flat Torqueband
- d16 turbo help
- Oil restictor & oil feed to PTE and similar turbochargers
- Need advice for my d16y8
- over heats than boost cuts
- Why isnt AWD more popular?
- T46266 JB .8x A/R Precision Turbo 17 miles Failure? Thoughts? Feed size?
- 6466?
- what flange is this?
- 350hp B18A turbo and fuel question
- b18c cracked sleeve
- Overboost issues
- Hey everyone Project accord has begun!
- Feedback needed for d16 build for my power goal
- SOHC turbo build for 200 HP
- S300 special wiring for VX
- Turbo d16, High egt, power loss
- Full-Race B-series Ramshorn Manifold
- Help me ID some sleeves, por favor - H22 shortblock
- engine gurus i need your wisdom
- You guys wanna help me design my exhaust?
- Afr reading correct??
- 2001 Accord EX 2 be boostd proejct!
- Opinions EFR7163 or GTX7160 @350whp/400hp
