View Full Version : Forced Induction
- car tuned and now after time weird A/F ratio
- Direct Port Nitrous kit Used as single fogger?
- ge hesitation after 4500 rpms
- boosted gsr... possible headgasket leak?
- Ebay Turbo Kits???
- What do you guys think of this turbo kit???
- surprisingly went up to 10 lbs on the boost gauge!!
- Good Turbo Kit for b16
- b16a2 turbo setup
- How much power do you guys think this will make....
- T25 tubular manifold for B series
- WG/blowoff vacuum line questions
- SOHC Greddy turbo manifold. need a B18 manifold that works
- going from 9:1 to 10:1 C/R.. timing adjustments?
- NEED HELP... water lines for my gt35r.
- LEAN!! Car Goes Lean @ 4000+ RPM, TE Fuel Adj Not Working!!
- Help me with a turbo selection
- gt30r tubine housing?
- 450 setup?
- ebay turbo....real or fake garrett?
- Honda Integra ZX-AWD
- HELP! Need turbo replaced!
- dont hear spool noise as loud...
- Max amount of psi
- Funky Oil Pressure Problems
- modified to fit?
- Feedback needed: Turbo XS dual stage boost controller
- RC 440 Injector-intake manifold seal?
- 3SGTE
- anyone used an EBAY MBC? share your experience
- what motor mounts?
- weird question
- Another Greddy Manifold Question ...
- HP question
- Junkyard D series turbo setup...just a quick question
- So, I'm going to build a turbo S2000. Have a few questions for the F20 guys.
- flywheel question,blew up another motor
- quick turbo cool down question.
- B16B Shell
- Blox b series mani problems...help asap
- nice number
- Autometer Gauge with Innovate Wideband... possible?
- Which tranny for a turbo B18A??
- 2 strange hondata/tach/romulator problems
- cometic headgasket thickness .72'' too thick for b16a
- Any Info on the GT40/42R???
- overheating...intercooler blocking radiator
- Precision 1000cc, did i get screwed????
- Post up Dreamer Setups
- Edelbrock turbo kit......Compressor surge !!
- 2 quick turbo questions
- BOV for an auto
- Max boost on GSR
- LHT INTERCOOLER WATER PUMP
- Noob Question, Please Answer
- could these injectors work.
- 6th Gen. 1999 Accord F23 OBD II - Questions on Cat. o2 sensor and 450cc Injectors
- BREAKING IN MOTOR TIPS PLEASE HELP!
- JRSC help needed...weird problem
- compressor surge
- 20G BMW M3
- painting intercooler
- Would this sequential twin turbo setup work (theoretically)?
- Who makes this? do they have one for B16
- Turbo XS Dtec FCBC HELP!
- WEST COAST ssAUTOchrome?
- anyone got a dyno sheet of a 1.8ls or gsr with a .63AR 50 trim?
- Tach breaking up issues...
- air filter for my turbo
- E10 issues?
- need some input
- downsides to having a short downpipe?
- ME EM DEAROBRUT NTAV TTEERRAG **BACKWARDS**
- New and have lots of questions about my turbo B18C
- what would be best
- Megan Racing Tripple Gauge A pillar Pod. how to install.
- Tranny issue
- Cracked Sleeve, now what?
- need quick help!
- advice on new setup (from the experts)
- BOV Install Bay Area (Welder Needed)
- Import faceoff July 2nd
- so when is a 3" exhaust really needed???
- What's the pump gas limit on a d16?
- Starter Problem
- Turbo Timer Harness For EG???
- Dynoed my Car Again... 775whp 570wtq
- intercooler question
- sad day on the dyno
- Drove WRX, Lag Maybe?...help
- uge directly to the Trouble with my O2 sensor signal in turbo application
- i dont know what to do
- vatn turbocharger anyone here???
- Integra GSR Turbo advice
- Precision Turbos mismatch policies?
- Need a cLutch for H22...Insight needed
- Weird clicking at idle... goes away under load, p/s pump?
- P2Tcomputer dilemma
- ghetto head stud changeover
- b20... supercharge or turbo ?
- hybirding a turbo???
- head gasket
- ls vtec build?
- best intake manifold for a high powered boosted d16z6?
- greddy h22 manifold
- Full-Race Stage I SOHC (D16Y7) plots/pics
- SKUNK2 parts for turbo set up
- Street legal Jet Powered Beetle!!!
- FJT can I buy some vitara pistons
- JRSC Install Help - Coolant Pipe Leaking - Hose Routing - B18C
- How much will my tune change with 2 different map sensors.
- Washer bottle relocation
- picture of actual hondata kpro needed!!
- i need to know the oil and coolant inlet thread sizes for gt3076r
- The baddest street turbo on the planet...
- SKUNK2 cams on turbo Bseries????
- Stand Alone Fuel Management System HKS PFC f-CON
- Does anyone have the Greddy Type S boost controller instructions?
- WG line to compressor or IM
- greddy turbo 15g ?
- what headgasket for lsvtec??? searched ut just wanna make sure
- crx supercharger is squeaking jacksonracing
- synchronic fuel pressure regulator
- Acura | Honda 6 Speed Turbo Transmission
- Having some problems and cannot figure out why! Its begining to piss me off
- Intercooler Piping Homemade¿¿
- Can you blow a headgasket and not leak coolant into the oil?
- Does a thrown rod bearing affect compression #'s?
- My GSRT dyno sheet
- Down pipe flange ? Will this fit and work w/ the gt35r
- DIY Intercooler piping for integra
- how many psi can my wastegate take
- wideband question...
- Resistor question with pic
- CP Pistons Part Number Help
- Quick Q : Greddy 15g Manifold compatible with ihi rhb5
- water/methanol injection!
- Ebay radiator?
- k and N filter for 3" turbo inlet
- plug up oil fitting?
- turbo ? help
- Hondata + larger injectors vs. FMU (searched)
- Where To Get Tial 40MM Wastegate Bolts ?
- need help asap running boost hondata with all motor running like shit
- built ls eg project the makin of a monster in the dfw
- s2k head? max boost on comptec kit?
- Air filter - Element Versus Full induction
- Tuner Toy Rod Fitment Question *ASAP*
- idle problem cel light on!!!
- Turbo makes loud whirring sound, Brand new?
- is it true??? that b20 crank pulley raises boost on a b18c1 engine ?
- Leaded Fuel
- how should i clean my oil lines?
- Keeping Elec Boost Gauge Calibrated.
- Muscle Car BOOST question?
- HKS SSQV or Tail 50mm BOV???
- Stock GSR with thicker head gasket?
- TunerToy rods, a review...
- Surging Idle....why??
- Need help with building block for some boost
- oil drain ...... to much? (video)
- SOHC turbo or GSR MOTOR
- turbo sound
- Anyone with a EATON M62 super charger laying around for sale or measurements
- Question about aftermarket chips + boost.
- basic EMS questions....
- what to do? h22 turbo
- My piping
- BOV's and wastegates?
- need info on supertech
- JAZ products Breather ??
- jg intake (range)
- What Pistons and Rods
- Igniton Timing Under Boost...Ho
- aftermarket gas gauge
- how strong LS stock sleeves are?
- wideband o2 question....
- Help with getting my turboed car starting
- tuning in CT NY RI MA
- Turbo Manifold for Sale
- it alive!!
- Turbo hitting hood...Where to get a good hood hump/cowl?
- fuel cut too early problem
- best turbo manifold
- stock sleeve built b16 how much boost??
- oil pan
- clutch
- Radiator
- Brand New turbo on Dohc Zc..white smoke?
- What could be wrong with my H22 Turbo set-up? Please help!!!
- Digi Key map sensor - Two nipples :O
- type RS
- Is it possible.......????
- S housing inlet machining - short radius 4" bend...
- Greddy SOHC manifold tubular replacement?
- anyone out there running a gt3071?
- gapping help on turbochagrged h22, already searched!
- Another "Official" Catch Can Thread. A Compilation of All Catch Can Info With Install on B series.
- Smoking Wastegate??????????
- what injector clips for precision injectors???
- aebs headstuds better quality than arp??
- Whose catch can do you use?
- building block.
- need basemap to get my car running
- New Series of DEFI Gauges
- 680cc Delphi Injectors
- CAR BACKFIRES MISSES BUCKING LIKE CRAZY! Car Barely Runs When In Throttle, Out of Knowwhere!!!!
- What oil line kit for a gt28r?
- Mitsubishi turbo questions..?
- VTEC engages, LOUD, but no power! CTR cams...HELP PLS!
- Internal wastegate fluttering and oscillating boost.
- Is the TurboXS RFL bov too much?
- turbo setup question
- surging idle.....need help QUICK!!!
- Teaser pics, gt35 2.0L lsvtec... (I'm obviously bored)...
- manifold question
- oil pressure
- B16 TURBO SETUP------------HAVING PROBLEMS PLEASE HELP
- B&M FPR walbro 255hp with boost?? did search did not find def answer..
- Opinions on STR sheet metal manifolds, str vs. edelbrock, GE ect?
- how do you put AN fittings onto ss line? I dont get it
- Well the FAST EMS is hooked up, just kinda of acting up, details inside, need advice from FAST owner
- What turbo is this?????
- My dyno adventure didnt go so well tonight.... (no, not that bad)
- wanted to make sure b4 i tried it...PSI question
- bosch injectors
- turbo problem i am reall a moran
- any one use a DSM SMIC with a SOHC Greddy kit?
- Wastegate Question
- Will ef turbo kit and intercooler piping work on an eg
- Help.. Where to buy copper spray?
- Anyone in Winchester/Northern Virginia tune with CROME?
- Westcoast-turbo **searched**
- b18b1 or b16a2
- Anyone dealt with Turbochargers.com?
- Amber Gauges
- what plugs & wires?
- Reputable turbo sellers
- vibrations??
- F'd up my motor, looking at options.
- prelude turbo manifold?
- ~~Starting a built motor after it has SAT FOR A YEAR~~
- I have a brand new LS that my shop is getting fully built is the turbo set up im buying worht it
- downpipe hits my oil pan need help and ideas..
- while installing turbo..
- Back in the Day...Looking for Digital readout to wire into AEM Wideband
- Russell AN fittings
- Best way to clean up a dirty ramhorn manifold?
- CpU Fried??
- Anyone run the d16z6 crower stage 3 cam.....
