View Full Version : Forced Induction
- Oil restrictor for -4an to T3/t04e turbo what size??????
- POST PICTURES OF YOUR CAR/MOTOR PLEASE
- chicago, turbo rebuild????
- Peak boost kit in integra WITH ABS....?
- 393.3whp - 282.5wtq @ 13psi
- PLX WIDEBAND QUESTION
- ~~~~****HKS SSQ BOV inserts********
- Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim?
- cel 3 H22 boosted
- Suspension setup on High whp hondas...
- Evaluate my catch can setup
- any know if CRFAB04 is still selling his turbo manifold? fullrace style?
- Edelbrock Vs. ITR Cams for turbo use
- oil leaking
- advise about broken oil feed t
- Oil pump problem, need help ASAP!!
- eagle rods arp bolts + LS crank, rev limitations?
- smoke from the motor, but good compression
- Turboedit tuning in colorado?
- K-series: Oside Jimc's CTSC RSX-S: Optimized
- oil in charge pipe
- 96-00 civic hatch 3" exhaust.... anyone make it ???
- Apexi turbo timer install?
- Any company make a Adaper can bult EVo8 16G turbo to HKS manifold ?
- Turbo S2000. Stock block with GT35R and new Full-Race turbo kit. 448hp 272tq
- GSR turbo block guard question, please help!
- 99 civic supercharger problems......
- I need a uberdata tuner in North West FL.
- Misfire Codes
- Which one will be more dangerous for stock internals? small turbo high psi / big turbo low psi? or h
- Do I really need the missing link with this amount of boost?
- Car overheats with a/c running
- where can i get cheap CAT???
- B18B Oil Feed
- pointless or helpful?
- quick question about gm 3 bar map sensor
- ATTN: AEM Gauge type Wideband UEGO users
- LS/Vtec ? The back metal cooling hose
- finall fixed! but another problem!!
- Balancing the rotating assembly - how does it get done?
- Still stuck on which FPR and why.
- APEXI SAFC
- ? about H22 turbo
- Greddy Turbo Kit(15g) on JDM D15B
- best prices on reducer couplings
- AAM Hiring Techs!
- Suggestions please B18C1 turbo build
- low idle
- GT32 VS. GT28RS
- car smoking in the morning
- Oil line placement
- turbo causing wear on built engine?
- Blox Turbo cams?
- Oil Pressure sender
- Exhaust housing warp easily? (SC61)
- Charge piping-most effective coupler locations
- who sold WEQ a turbo?
- CRV-Tec+Boost
- uberdata basemaps in v 1.6 and then different in 1.7? huh?
- oil cause overheating?
- Inline fuel filter??
- block guard vs. sleeves
- ge dowel pin ? on lsvtec need help FAST!
- Greddy Profec B Spec 2 owners check in
- pre-boost 2 days left till i boost
- Does ne1 need an Eo1
- Hesitation / Slow acceleration
- which combo woudl you recommend
- Boost HUD?
- LOOKING FOR CATALYTIC CONVERTER FOR SUPERCHARGED CIVIC
- gt55?? GT55 !! 2jzgte DRRRRAAAAAGGGGGGG setup
- SETUP UPDATE: Precision GT35e, AEM Datalogs, Rocket Motorsports M21 CAMS. 56k beware!
- anyone know where i can buy a 5 psi spring for a tial sytle wastegate?
- My New Turbo setup. On a budget
- TURBO REBUILD WHERE???
- Which Injectors Should I Choose?
- I'm going to buy another set of injectors - 550cc... should I get saturated or peak and hold?
- Hondata check engine light after 3 bar install
- Dsm Prelude Boost problem
- MBC question?
- Oil in exhaust port number 2 piston rings or valve guides/seals?
- Intercooler Question
- Greddy Kit to t3/t04e... Will Greddy Oil Lines work?
- need help with afc hack on d16a6
- Is a 3" cutout or a full 4" exhaust better?
- Fastest spool turbo for GSR?
- 4G63 help needed...well turbo at least
- Full Race S2000 Turbo kit Pics
- question about tapping for my EGT
- HIGH PERFORMANCE Insurance M3...oh no (near Seattle)
- code 21 today!
- 90 CRX OBD 1 D15b injector question!!!Help!!!
- .63 Exhaust Housing
- Attention Portland area residents!! FREE DYNO TIME! Sign up NOW!!
- another injector question
- I think I finally get it now
- compression test
- b16g turbo on a d16
- latest in Action clutch troubles. 2KS
- cleaning the injectors
- How To: Making the Greddy Turbo Timer coexist with your alarm
- Oil pressure guage Question
- OBD0 + 450cc
- For those with RFL BOVs
- gear correction fuel tuning
- Action 1ms clutch and in a boosted b16...will it hold?
- Difference Between RC Injector SL4 and SL9???
- is it possible to use a d16z6 oilpan on a jdm d15b?
- Wideband users: A/F @ idle?
- Next Step for a b18B Turbo?
- Building Motor to 450whp....
- Plugging the pcv hole in a b16a2 I/M?
- NEw turbo gsr, funny sound at 5k to redline
- Timing Belt Slipped. How many have you been lucky?
- who should i buy a new clutch and lsd from?
- 2000 Procharged ITR dyno results
- help with csr with greddy turbo??SMOG??
- T3/T4E Turbo!!! Stage 3 Compressor wheel w/ a 57 Trim, Exhaust .63a/r
- GE sandwhich adapter
- jrsc on 00 si (b16a2) what pistons shud i use????
- Turbo GSR need advice on build...
- Budling a new turbo setup
- Blowoff valve
- thicker headgasket =bad or good
- McMaster Vacuum manifold . what size inlet and outlet?
- do u have to run water lines for gt30r turbo??
- Dilema, JRSC intercooler , remove it or not ?
- pics of bmc log mani for d series falnged for t25 or 14b
- best turbo for the best price
- how much will jdm gsr 10.6:1 cr drop after putting in .043" thick cometic head gasket??
- wierd sound when fuel is low...is it normal?
- PTE 600 or PTE 750?
- H22 turbo setup
- Turbo Question
- JRSC with 40 shot, wanting to add more nitrous
- 400whp guys... what tires do you guys drive on the street with?
- 10" slim fan... overheats when a/c is on.
- Fan not coming on
- do i need to run a missing link or different map sensor with crome chipped p28????
- h22 accord turbo... finally got my car back after 6 months... new turbo setup
- Turbo Size Dilemna
- NEW Carbon H22 Intake Manifold RELEASED
- Boost w/o having to loose AC
- apexi power fc
- before/after pics of turbo install last night (lots of pics)
- Missing link question
- What cars will these injectors fit?
- .8 bar tial spring
- how to tell what AN fitting you have?
- Compressor fitting
- which plugs to use with jrsc??
- Turbosmart wastegate and the vacuum source?????
- axle issues
- intake manifold for low end
- loctite on arp headstuds???
- B18c4 limits
- Intercooler in eg bumper (searched)
- can i still run my old cams...?
- Anybody running Edelbrock's d16z6 turbo kit?
- i build my motor for turbo i want higher rpms clutch questions
- how much power can you make with a t3/t4 turbo a/r 53 on a h22
- another problem
- bottomend build for 350-450 hp ?
- What do you all think
- Can i keep A/C and power steering with this turbo?
- d17 turbo manifold.
- I need help going boost
- mild turbo setup and cam gears
- where to find black braided steel lines????
- is this ok for ls/vtec turbo
- clutch lasted a week on a boost
- oil consumption, fresh motor?!!?
- Stolen Parts...longshot but any help is appreciated!!!
- brief stutter after let off gas on highway?
- idle vacuum different under boost?
- Sleeved Engine + Si Greddy Kit = 257whp?
- t3/t4 54 trim uberdata chip close to t3 60 trim chip????
- 3 cats dead... What am I doing wrong?
- dyno graph of h22 with sc63 turbo
- problem with profec b spec 1...
- Garrett GT35R Warranty?
- wastegate problem....
- hondata p75 help
- can i ditch the Emanage????
- Cracking dumptube due to heat expansion???
- please help looking for part any info would be great.
- Looking to build 400whp to 450whp B18c motor......
- What Garrett turbo is this? HELP
- bad stutter/backfire
- Venom Intake manifold / Need help finding the correct fitting.
- need urgent help code 16 injector dsm
- Greddy Blue box
- cracked sleeve, b18 turbo
- Right exhaust?!
- fuel cell: what kind level sending unit to get?
- TURBO KIT for DA's?
- downpipe question
- has anyone ever wired a up a button to activate windshild washer fluid for IC?
- greddy profec B Spec II
- where can i buy heat wrap for my downpipe?
- H22A Turbo
- AEBS T-Sleevess OR Darton Mid Sleeves ?
- question about dsm injectors... (asaplease)
- Spec for arp studs in a ls/vtec
- have a few q`s!
- Best Cams for your car.
- back door intercooler question
- need help with CEL codes!!!
- Trouble starting car w/ new injectors
- d17 return fuel setup...this will work i hope. Any thoughts/experiances
- Will my blitz bov swap out for hks ssq in my drag gen3 ??
- Name this old school HKS BOV
- Comments on Spark Plugs with JRSC
- gt35r or gt40 on b18c1?...
- which axles?
- Velocity stacks inside intake manifold????
- bigger intake mani less low end?
- good turbo for b16
- radiator?
- water cooled turbo
- San Jose Grand Prix..
- Tuning Safc/Vafc
- Some hesitation at part throttle/normal driving.. help
- vac line questions...turbo almost done...
- what are your opinions of a clutchmasters stage 3 on a turbo car
- what is this
- Putting a 3" DP flange and pipe on 2.5" turbine outlet good or bad idea?
- spun rod bearing
- obx lsd install problems...
- Integra intercooler piping on 93 civic?
- B20B Turbo Set-up
- A whole lotta nitrous....
- How much hp needed to run 150 in a 1/4
- Got car dyno'ed, but power drops off too soon in powerband?
- car bogging....need help
- wilding bucking on p72 s200b hondata from 2k - 4.5k rpms?
- quick noob wastegate question???
- Greddy Type-S Flange dimensions
- d16y7 w/50shot compression results
- BAR to PSI Calculator with Altitude Adjustment
- what piece is this PCV valve maybe????
- rebuilt motor and wont rev past 2krpms..(hondata)
- Put exhaust wrap on and I am very impressed.
- Pics of my 93 Del Sol Turbo
- blitz super sound bov
- massive smoke when i rev quickly in neutral
- Question about B18C1 GSR with B20 CRV crank pulley
- CM flywheel replacable friction surface?
- I'm stumped... need some help has to do w/ turbo to intercooler piping
- ODB2 turbo cars, CAT help
