View Full Version : Forced Induction
- headgasket or what?
- No boost until 6krpm?
- need help with injectors
- Highest HP #'s for B16 tuned w/ vafc
- Installed new dizzy- which timing mark should i aim for?
- should i just disregard a/f readings from a stock 02?
- APEXi WS World Sport Exhaust Catback for nitrous use?
- B18c1 Block B16a Head.....
- quick identification: what turbo is PTB 150-3070 a/r .60?
- New dyno ###
- just took of the head after my motor started to blow alot of smoke
- b16 project
- GM SYCLONE TYPHOON INTERCOOLER ON A CIVIC?
- Jackson Racing
- wastegate vac line langht ?
- How much does a drop in static compression affect a tune?
- help turbo b18 idle jumps up and down after 2k
- Built Gsr
- When did your T3 - 42/48 STOP making power.
- Turbo?
- oil return line....turbo sits a little bit too low
- what exhaust a/r to run with LS turbo?
- HKS turbo timer hook up
- Will an exhaust leak make your motor run rich?
- Picked up a Turbo and Intercooler from a junkyard. Got some questions?
- would this spool fast
- Damn what did i do
- distributor problem?
- Problem with hi-throttle VTEC engage
- oil restrictor
- fpr
- Direct Correlation between Ignition timing and spool up?
- turning T04E into an SC61 by swapping compressor parts?
- possibly clutch/pp failure...?
- ctr crank pulley
- when will somebody step up and make this manifold..
- HKS SSQV Vaccuum Nipple broken Off-Help
- something went wrong and i dont know what it is help is needed
- how can you tell if you have the real hks ssqv bov or not?
- Where to find aluminium case like the Hondata S200 has???
- Anyone run a stock Greddy Kit and an Oil Restrictor?
- Skunk2 or Ferrea valvestrain for turbo H22?
- Testing 3 bar map sensor..
- Boosted B18C Help!!!
- Turbonetics Raptor BOV - quick question
- Fuel system
- How would this turbo fair on a b16(pulsar T28)
- turbo type r
- how can you check injectors to see if they went bad?
- k20 boost or B16 boost???!
- TURBO TIMER NEEDED
- V-band confusion
- Anyone have a screen shot of an LM-1 data log? AFR/ RPM/ BOOST/ TPS etc..
- Apexi power FC
- f22 turbo ....need some info....
- boost creep...to a high point
- TURBO KIT INFO PLEASE
- Compression test results on 8.5:1 CR engine...
- retuning after installing new pistons
- running a wastegate without a boost controller?
- FI first annual survivor contest
- Easiest way to install UNIVERSAL oil catch can?
- Are these vacuum lines hooked up right (diagram)
- turbo rebuild!
- Turbo B16 part 2
- Valvetrain for B16 revving to 9K.
- need help on built turbo teg
- gt28rs = Full Boost at 6000 rpm
- TDO5
- TOPMOUNT IN CRX!!!11 ... and my problems
- EGT Gauge Components
- Prices.....
- Which Turbo To Use?
- Mahle pistons
- semi OT sorry 2.2 litre ECOTEC engine?
- Need Help Removing Turbo
- head work or equal length manifold?
- Is is ok to run a oil restrictor on -3an line?
- T3 exhaust flange quesion
- Cheapturbo/Phoenix Turbo/Peakboost's Ken Peak Happy Birthday
- 3 inch ic pipping
- intercooler question
- car smoking bad
- fuel issues
- how to get to 11sec 1/4?
- Where to get metal gasket for Tial 38mm??
- Which turbo for remote mounted turbo d16?
- Equal length manifold for H22
- NEED a 4" filter.....any ideas?
- Benefit of polished Intake Manifold??
- What turbonetics turbo am i?
- Valves ticking. Remedy=Boost?
- timing for vortech supercharger
- Car seems to have blown headgasket, but all signs are not there.
- JRSC issue
- boosting ... need some advice on a throttle body
- anyone use a "pump" to evacuate crankcase pressures?
- Chugging in closed loop
- anyone turbo a CTR motor
- civic radiator
- Garrett T28 Silvia turbo and Edelbrock manifold?
- tuning turbo h22 with vafc
- Tuning issues on JRSC GSR
- SOHC people running zex stage 2 cam on stock valvetrain post up
- Toyota CT26 on my d16?
- GT42R the turbo with its own zip code
- GSR cams in a b16 head: Good for Turbo?
- Installed my LCON traction bars today
- What's the rev limit on my hybrid? (Z6/Y5)
- should polish the head intake ports ??
- ATTN: fake Apexi turbo timers on the market, be careful
- Which to boost for street H or B
- vacuum gage reads 20 inches at idle, is this normal?
- no boost until 6k
- FYI - Fake APEXi Turbo Timers on the market - watch out!
- Stock ls turbo setups
- profec-b solenoid replacement ? found something that might work ?
- for all boost heads
- RC 550 injectors, harness and resistor
- peakboost kit on crx?
- Just for fun.....
- When is neptune tuner coming out?
- TURBO EG: INJECTOR question
- Planning to do a b20/vtec turbo motor need a couple ?'s answered first tho.
- Received the wrong clutch...can I still use it?
- Help! What kind of turbo is this?
- So how much power have you seen out of B series GT28R setups?
- Any of you using the BBK intake manifold??
- going turbo and want to hit 500whp
- has anyone done 86mm sleeved for turbo
- Sound/Video clip request: apexi Dual Chamber BOV
- Anybody with built high compression motor and turbo?
- need ideas for a winter project.
- Raising Boost w/ internal wastegate
- electric h20 pump vs. stock water pump?
- b16 or ls
- Misfires under vacuum?
- on colder days when the car is cold , do you get low vacuum?
- Full-Race B-series non-AC Stage II (low boost plots)
- Not flowing enough air!!
- Stock b16 head vs ITR head (b18c6)
- DIY CATCH CAN *PICS* Now How Do I **LEGALLY** Run Everything?
- Decisions Decisions...Which Route to go? Budget VS Baller..
- hks evc IV problems
- inputs on the GT2876r turbo
- Can i piece together a turbo with $1500
- what r u guys running?
- started my car for the 1st time, engine noises?
- Le Thermal Exhaust (3")
- boosting a Type-R
- HELP Resistor box question
- Help me with estimating cost to build GSR motor
- Anyone in Columbus, Ohio?
- Dyno session not so good. Help w/ suggestions on the power band
- Need an inline fuel pump to run a slightly modified d16z6
- Built Turboed GSR
- hell yea
- Anyone tried a GT35R ona 81mm B16?
- Mase Tuning in NY, NJ, CT area..
- Turbo steup
- oil return line question
- 9.5:1 itr motor. what turbo?
- Very random miss
- ????????twin walboro pumps????
- boring a gsr block
- f22 question / dsm manifold etc etc etc...
- Neptune was the cause of my 4 weeks without my car!
- oil cooler maybe?
- What happened to the AIR CF intake manifold?
- borg warner gm-8 useable for a high hp solid deck b16a?
- Ls/Turbo Question
- took some time but i finally got my turbo installed (pics & dyno graph)
- engine managment E-MAN
- Size Injectors??? Help
- Rebuilt my turbo and it still smokes!!!
- just dynoed my car and is very disappointing
- Skirt Coating and Piston Wall Clearance
- Crome question..
- IHI RHB5 TURBO
- OMG new turbo =) and look at my spark plugs
- Garrett Ball Bearing T3/T4 NOW AVAILABLE!!
- Streetimports distributors??? experiences?
- painting header/exhaust wrap?
- tubular or cast
- Questions: Half size aftermarket radiator/o.e.m on F.I. prelude
- type r turbo
- Could someone please explain why everyone thinks the 57 flows more than the 60 trim?
- Stock Sleeves
- Looking for 2.5" catback system with resonator built-in, suggestions?
- need some help
- 60-1 compressor map...
- GSR Head or work my b18 head??
- head gasket and ARP studs question
- Turbo ITB??
- Ok, S1 to A1 tranny question...
- Turbo RSX Type S - RevHard doesnt feel right?
- CO2 Powered supercharger
- Carbon Fiber Intercooler Piping.
- Turbonetics Evolution wastegate ????
- type r head gaskets
- hondata stolen
- how in the hell do u measure spool time...
- LS Final Drive??
- ac removal??
- IHI AX-1 ball bearing turbo Q?
- GT2871r vs. GT28rs which is the better turbo
- Best non-vtec LS turbo HP #'s?
- water cooled turbos....not running the coolant lines bad?
- d16 ZEX/COMP cam question?
- Opinion on Turboxs Dual Boost controller
- help looking for the right turbo. looking at 600 whp
- help..turbo for a b20 non vtec.
- hello new to boost
- oil leaking from turbo agian
- HKS Turbine Housings .
- tial wastgate
- You think these numbers seem way low for my setup?
- catch can off intake man in fi setups = bad?
- honing cylinders and aftermarker pistons and rods?
- no boost
- Need some feedback re: GSR vs. Ls/vtec (both turbo)
- Which turbo to run on LS?
- HELP!..ran my car at the track.. now missing in high rpms...
- Oil temperatures?
- Best bang for the buck - Cams, IM or TB? 84mm B18B-T
- VAFC - Vacuum/boost
- blow off valves
- Turbo problem
- need help sohc turbo
- injector dutie
- 250hp/240wtq on t25!?!?!
- injectors
- Whats the a/r's on a wrx td04l turbo?
- hondata+obd1 conversion questions.
- ???can u adjust the boost from the wastegate???
- Is building a custom kit on this site a good idea for my noob self?
- GT in B16A - Best Choice!
- t3/60-1 guys what kind of power are you making....
- EK i/c piping on EG? can it be done?
- turboXS mbc=bad idle?...plus some more questions that came up today
- SETTING VAFC
- need some help with engine trouble
- My Motor build idea....
- Building my engine
- GT42R A/R Housing
- hydrocarbon leak = overheating?
- Question about friends turbo rsx
- What to use to moUnt FMIC???
- Anyone buddy's with South Florida Performance?
