View Full Version : Forced Induction
- FMU with Vtec AFC
- car over heated today
- interchangeable supercharger
- trying to identify trim of t3 turbo
- injectors???
- How do you tell if you have a real type-s bov?
- water lines
- How fast are you!?!?! :thumbup:
- Jacksonracing supercharger d16 vtec
- Anyone used the DynoTune Nitrous Air/Fuel ratio shutdown switch with boost?
- B16B forged rods...?
- Fixed problem with hood getting too hot (thx Full Race)
- question ? about the power band of a log manifold
- LS VTEC TURBO OR LS TURBO
- lhtperformance email
- so much for racing at the Honda vs Acura shootout... pics
- D16z6 D16yb turbo question
- Manifold for EVO8 turbo on to a B~
- Stock gsr valvetrain on boost
- Looking for a few pics of remote mounted FPR setups
- Solution for keeping AC with any turbo setup
- Down pipe
- Tune Needed
- Just some venting on SLOWBOYRACING.com
- Are there any K20 JRSC guys??
- 92 Hatch B18 boost
- Fuel delivery for f.i. ??'s
- Using Nitrous...Any recomendations?
- Boost Spikes???
- are either of these turbo's any good
- valve spring sticking!
- wideband tuning - how to start?
- oil return help. where does the oil level sit??
- d series turbo ?s
- Safe pressure for GSR motor
- small idle surge
- Rebuilding block for boost.
- Turbo build how much power will i be making aprox. guess
- Custom Map Bypass Valve or missing link or map defensor and FMU questions
- What size core on Precision 350 or knock off ebay intercooler? And which one to go with Precision vs
- Where is the BEST placement for MY 3inch flex pipe help
- fmu question?????????????????????
- soon to be sohc turbo
- blown turbo seal = bad o2 sensor?
- Help, how to setup GM 3bar map sensor in Hondatas300
- 500R Turbo? Anyone heard of it? Tony1, Boostfed, The Shodan????
- too big?
- Intercooler kits on ebay, What you guys think?
- Intercooler Question
- Turbo worries
- do i need a boost controller?
- starting my turbo build finally
- Goodridge SS brake line -an size? please help!
- u feelings on the new turbo of honda
- Fresh motor Compression test results
- Summit battery box help!!
- what are the pros and cons between a ramhorn and topmount manifold?
- 95 teg' GSR b18c turbo problem....please helP!
- Max Current Pull of Stock ECU Injector Drivers?
- Picking up my turbo on friday..... questions....
- crower stroker kit vs. micropolish and balance crank?
- turbo b18 Troubles
- ECU questions
- wich turbo is best for me??
- biggest intercooler for civic w/out cutting frame??
- turbo plus ac?
- white/blue smoke--smells like fuel??? New turbo setup
- anyone have pics of top mount with a/c for b series?
- newb here...point me in the right direction
- Got The Parts Got Confused !! HELP !!
- Dead Miss on cyl #1 : Lots of things checked, HELP!
- o=ring for greddy sandwich plate
- Searched. Water Pump Help
- E85: Some real-world data
- downpipe ????????????
- Greddy Rebuild Kit?
- ***SC61 TURBO HORSEPOWER***
- Mistubishi turbo manifold??
- 4" HKS filter - Looking for a real or knockoff 4" mushroom filter
- AEM tuners in South FL
- ebay Turbo
- I need advice with my turbo d16 setup
- can you re-use arp headstuds?
- Anyone here running 300whp+ with 450cc injectors??
- Is it possible to replace the exhaust wheel on a GT35R ?
- difference between these turbos t3/t61 sc61
- Turbo DA Integra pics... With or without swaps....
- Injector size?
- copper spray
- quick turbo ?'s i need answered
- Greddy BOV flange the same as Eclipse 1G BOV?
- downpipe question with pics
- Multiple choice time, Question: "Staying out of boost"?
- Why am I Maxing my injectors?
- Question about uberdata
- another tuning question
- what size injectors for a b16 at 400hp?
- turbonetics 60-1 question???
- safe to boost this?
- is there something wrong......
- Quik video on 6psi
- i want to order my fuel injectors 4 turbo prelude look at my setup help
- [quote="redzcstandardhatch"]my new 60-1 to4b houseing turbo! (cold side used to be on cody from love
- Here's whats left of the gt4294r after the car accident...PICS inside! Getting rebuilt!!!
- IM ABOUT TO SHOOT THIS CAR!!!! HELP, if you can
- which manifold will directly replace a revhard?
- Someone with a Autometer Sport Comp boost gauge!!!!
- How are these turbos (Master Power)?
- sohc turbo gurus helppp
- Turbo Coolant Question
- Best turbo manifold for H22?
- d-series port and polish job, worth it for 300whp goal???
- Feels like my Rev Limiter is coming on at 5k.....Helpppppppppppppppppp
- Z6 75.5mm SRP's work in a 75.5mm A6/Z6 Mini-Me?
- Turbo manifold, Cast iron vs tubular stainless steel!
- does dry nitrous equal backfire??
- noob question, sorry
- b16 turbo won't idle! plz look at my maps OBD-O
- 509whp/387tq stock h23 bottom end, stock h22 top end
- oil pressure issue!!!
- HKS Turbo Kit + A'PEXi Power FC
- exhaust piping size for b18c turbo setup?
- fuel lines
- Swapping out ABS for non ABS
- 450 DSM injector question an timming
- big turbo vids
- EGT
- Balancing my motor?
- Boosted B20 pics and such (56k....you know the drill)
- Effects of running boosted car without charge pipe???? (noob)
- noise when VTEC crosses over?
- Precision injector question
- Individual cyl egt ???
- Boost with bigger injectors..but stock ecu?
- Well after all this turbo reading.. i really think i just hurt my eyes.. - some basic info help
- what am i missing?
- Help!!!! maybe boosted problem????????
- That triangle cutout thing in the bumper/hood, functional?
- total timing on h22 turbo
- F.A.S.T. standalone not showing 12volts and won't start the car??? HELP!!!
- Anyone with experience with anything similar to this?
- Help, breaking WG bolts.
- Checking Oil Level
- ac doesn't work with Hondata s200
- compressor surge?
- dumptube routing.
- got a gm map sensor.... how can i know if its 3 bar?
- 02 civic
- what battery offset to use with Precision 1600cc injectors for aem
- 38mm Tial waategate allen bolt size.
- egt guage not working all the time (long)
- Tial BOV sound Clip?
- I Found A Turbo Kit but I still have questions. HELP!!!
- Ignition... Maybe stuck valve?
- Ls/Vtec Setup....How Much Hp?
- Which turbo for 300whp d16z6?
- jrc 8 inch intercooler
- Another fix another problem (Prelude Boost)
- Gauges for the true baller....
- who is running ls w/greddy turbo 18 g dyno numbers please
- My Egt Guage Is Not Working, Where to look?
- i have a question about zex dry nitrous kit
- turbo question for b-series
- cam question
- is3" intercooler piping size 2 big on my setup?
- GSR crank in LS block
- who makes 4in exhaust
- wanting to turbo the z6, the RIGHT way
- turbo setup.....what do you think????
- Blow off valve not workin??new turbo install
- Gimmick or Valid?
- Are these dynos realistic>????
- what can you guys tell me about high compression with boost?
- AEM GAUGE TYPE 6 IN 1 WIDEBAND UEGO
- ZEX dry nitrous kit HELP
- Greddy Type S BOV Owners is there an Attachment!?!?!?!?
- HKS GT2540R
- need help with troubleshooting please
- is 150 compression across all 4 ok for b18a?
- Interesting info, HKS SSQV, Vac Source, Compressor Surge.....
- turbo and nitrous setups
- B20Vtec Turbo
- whats the most CC's you could get out of a SOHC?
- first boosted car finally done!
- hesitation in mid RPM range
- Mounting the Precision 350hp intercooler on an eg
- what is everyones opinion on this manifold?
- Skunk2 stage 2 cams on a turboi set up
- comp ratio with 404's and turbo?
- Turbo flange questions
- 1000cc saturated injectors
- need some feedback.. soon to be turbo b16a2
- honda vti 98 b16a2 peru fuel managemet
- need help mounting my intercooler pics inside
- Full-Race Top Mount in a DC2
- Is there a difference between Greddy Blue Boxes???
- BOV ?
- Difference between the GT3582 and the GT3571?
- turbo d16 turbo!!!
- High Compression D + supercharger
- Gsr with JRSC?!..
- keeping the power to the floor??
- Divided Manifold/Housing Setups
- Centrifugal Supercharger For h22?
- Turbo GSR just dynoed... power seems too low. 339 / 250 @ 20 psi
- Going turbo with a type-r motor, need new fly wheel, what should I get?????
- Start-up problem
- Boost question
- picking a turbo for my d16z6
- Car died suddenly last night.... again... details inside
- h2b kit
- Ebay Catch can
- Ignition Cut or Wheelhop?!?!
- gt42r ?'s...can it be rebuilt if needed? i need a compressor housing, PLZ HELP!!! Pics inside
- i need help......
- power/weight
- h22 turbo
- Action 2KS clutch owners!(or anyone) Do you have this problem?
- plug
- What compression i should be getting with 9:1 pistons ??
- Hope i don't get banned for this....
- Next Project: Ls/b16Vtec on boost
- 2000 CFM fan update
- Not making full boost?
- uberdata software needed
- Boost bug bit me hard....need more power!!
- safe setup?
- For all you oil burning wizards!!!
- Help with turbocharging my h23.
- Piston $2$ Head question
- Realistic hp goals with a gt25 on a b18c1
- anyone tried a VNT turbo
- Best oil-cooled only turbo for 400-500whp?
- Turbo filter alternative, for those of you with no space...
- GT3076R -- should I plug the water lines?
- ls/vtec
- look at at my AFR sheet, tell me if it looks OK
- who makes hi hp on cast manis???
- Recommended Guages
- Would like solid info...
- ultimate sandrail pictures.
- Anyone know who has RC 1000p/h injectors in stock?
- Vegas tuner or anyone close to.
- painting a FMIC?
- Thermal 3" Integra Turbo Exhaust
- Better Spool threw timing in maps
- fmu...
- LHT intercooler and ITR, throttle cable too long!!
- Has anyone seen a Greddy Turbo Kit on an H22 Civic?
- ever heard of this company
