View Full Version : Forced Induction
- what to do with my turbo
- what kind of turbo is this
- 380hp @ 14psi Pump Gas -- SC61 GSR -- Mase Tuned
- bov o-ring size question for ebay FMIC kit...I know some of you have them...
- Greddy TD05H-18G turbo wastegate actuator size question
- HELP Me Choose a Turbo Please...
- superchargerd jdm b16?
- Freon air to water intercooler??
- its good idea to use crv 5spd trans on b20vtec 600+hp
- 400whp b16 stock block E85 build??
- Questions on Superchargers..
- D15 turbo?
- best a/c p/s manifold??
- Peakboost kit oil return question on GT30
- Build on my Fully Built b16a EJ1
- HOLSET HE351 powerd lsvtec pics 15lbs street tuned
- Injector Driver vs Resistor Box
- Twin Turbo
- Ostrich version of Uberdata?
- ls/vtec t
- greddy 18g and 15g internal wastegates interchangable?
- Vitara Piston / Connecting Rod Question.....
- Anyone use Water/alky/meth Injection?
- HX35 on a D16?
- Post Pics of your RLD-fab products!
- POST UR BOOSTED DA INTEGRA PICS N MOVIES
- EK civic Front Mount Intercooler PICTURES
- LS crank
- GT2860RS oil orfice
- Holes tapped through tubo OK???
- Anyone w/ GREDDY turbo kit on their integra GSR 94-01
- Piston and Rod Weight/Strength Question...
- new to me jrsc, tuning advise?
- synapse engineering design philosophy
- Can i use Skunk2 pro1 boost?
- GT32 For 350-400whp?
- White Smoke from time to time
- turbonetics turbo?
- My wastegate sounds like an airhorn
- ***HI, PLEASE HELP***
- Got the S2000 back from the shop...
- Headgasket sizing
- Need Help with injector setup and resistor box
- How far should I space downpipe from oil pan?
- where do all the vacum lines go?
- Searched: Need engine builders help!!!!
- Racepak's sohc build log. 400hp goal
- is anyone here running a T3/T04E with A/C compatible log manifold?
- should i use my stock gsr valves or aftermarket?
- direct port on the bottom of your intake???
- cometic head gaskets
- Name that BORG
- Tial 44mm wgate stuck open???? whats causing this??
- Boost Cut
- problems after turbo timer install
- Best Way to Oil your TURBO
- gsr boost
- turboxs manual boost controller question
- transmission
- How many of you drive a B-series GT42/GT42R turbo on the street?
- problems with o2 sensor on ls-turbo
- EF guys Stock crossmember? possible downpipe? Which way to run the turbo
- Turbo honda setup, where do I start?
- NEED TURBO HELP!!!!
- Wastegate problem!
- still overheating....
- what clutch for this setup??
- question on Ebay Intercooler kits
- is 87mm to big for turbo
- b20vtec turbo leaking???
- sound decent for 1st Tsetup?
- Turbo set up for a civic Wagon need some help
- Loooooong story, please read. Need lots of experience on this one.
- Buddy Club Secu Timer
- question?
- Best turbo for fast spool and low end torque?
- Anyone w/H-Brace Clear a 3" DP??
- turbo manifold was glowing red???
- Good Deal from ebay?
- a/f ratio's on e85
- built & supercharged b20z camshafts???
- catch can?
- What car should i buy for sohc fi turbo
- ACT hc5-hdg6 anyone rockin it?
- are these 450cc dsm injectors or not??
- Fully Building a LS for Turbo.......ANY HELP???
- dei cryo2...
- New Blowoff Valve Design from Tial!
- EK with B20b and t3/t4 and dsm's
- JRSC MSD/BTM question.
- AllState insurance Claim gone Wrong- on turbocharged integra will extra insurance
- What size intercooler piping!?
- need a clutch for h22 with gt40r help
- 400hp safe on stock sleeves no BG?
- wastegate to small??
- whats this out of?
- ????$332.65 for forged piston????
- 95A Grade Urethane bushings on a daily driven car?
- Omnipower 4 bar MAP
- b18c build or b20b build?
- dry nitrous question
- noob question
- what's involved in turbo for 92 civic
- Best FAST/Speedpro tuner in OH, WV, KY, MY, TN, VA ?
- CRX Turbo: Things to look for
- are two relays needed for dual inline fuel pumps?
- Noob question. Turbos and sizes?
- whats the word on JE piston coatings?
- I Need Room For A Turbo...
- Turbo recommendations
- DSS axle problem/question
- 02 turbo rsx type s trouble
- Spa Turbo
- stock sleeves
- 437whp SC61 GSR stock sleeves/stock head T1 tuned
- does 9.5* total timing at 14.5 psi on my stock sohc seem low? 57 trim ...
- turbo 07 si
- northern phoenix - where is there some 110 at the pump?
- More Power, More problems
- Question for 400 hp sc61 owners..
- BW T3 s366 vs gt37
- which head gasket for stock turbo gsr
- Best Intercooler for EF ???
- Need a top mount for and Ef hatch.
- 2.5" or 3" Downpipe
- my b16 setup
- Strait T3 setups on a B20?
- do i need the windage tray?
- Turbo fitment issue
- Reading 100 psi on fuel gauge.. (b&M) fuel gauge
- Head gasket question on thickness/brand for my set up.
- Anyone still rockin the oldschool SC61?
- Bad Blowoff?
- Utterly confused on spark plug selection. I have given up.
- Help me pick the best head set-up
- sc pullies
- results?
- LS-T w/ greddy kit having problems..... help please~~~~
- complete turbo
- Why did my OBX TURBO thread get locked?
- blow off valve and waist gate???
- Blow off valve???
- noob looking to turbo ls
- what to check on a USED Jackson Racing Supercharger BEFORE BUYING???
- OBX Turbocharger
- smoke from catch can??
- compressor surge? help
- P/W clearences?
- 92 turbo si stalls after 20 mins
- just wanted some epinions on this turbo
- D16a1 turbo 1st gen CRX!!!! wats its limits???
- t 38mm WG w/ GT35R?
- List your 450+ hp setup's
- ZEX plugs for 75hp wetshot? Can't figure this out.h
- Carbon deposits in pistons and valves!
- d15b7 turbo
- sohc zc turbo set-up options!
- Looking for recommendations for tuners in the midwest....
- Boost opinions
- helpppppppppppp!!!!!!
- help. check engine light, feels like boost cut.
- newbie ? about boost and break in
- Wastegate Spring Question
- Edelbrock IM questions...please help out if you can
- hondata boost option
- H22 Cams
- best valvetrain combo?
- motor choice?
- what valve train for blox b cams???
- y8/z6
- gsr oil pan on a b16 searched
- Best supercharger for an H22 DOHC JDM?!!
- Triple HKS BOV
- SRP pistons ????
- help with 400 hp setup
- HELP! Looking to start my first BOOSTED project! 2000 si
- does wrapping the manifold really help under hood temps?
- FUEL PRESSURE
- All OBD0 BRE Tuners
- WHATS THE LARGEST FMIC ON A EK WITHOUT CUTTING BUMPER
- Boost by Gear install***HELP***
- My hatch, vs 1000 and 1300cc bikes...
- does a bigger intake mani mean better or not really?
- Turbo intake manifold ( JG Engine Dynamics ) on N/A motor - power loss normal?
- ecu/tuning ??
- Wiseco part # question
- tune without ems on stock pcm?
- Turbo set up, gsr please help
- Product Test: Bullseye Power S368 (67mm) vs Garrett GT4294R (70mm)
- FJO 341B engine management
- Which Spark Plugs and Wires to use for a Turbo Ls/Vtec......
- greddy turbo kit help PLZ
- disabling a internal wastegate
- Need help deciding on which turbo for built H22
- Injector Brands
- I can't get my boost up
- Wastegate? I DONT HAVE ONE?
- Crower turbo cams
- 407HP stock block LS Turbo (finally edited the video)
- What is this
- Hondata s100 w/ boost option
- Turbo shootout results: BW S256 vs GT3076R
- Help with turbo size question....
- KMS valvetrain... anyone running it?
- need turbo advice
- Turbo QUESTION!!! Turbo in Rainy season???
- blox turbo cams experience???
- HELP TURBO GSR FUEL/TUNING ISSUES
- OEM Rebuild Q's?
- Piston choices for 84mm sleeved gsr block
- Towing car across the border.
- Yes another Compression Ratio Thread, searched.
- just want to make sure about this turbo
- what turbo should i use?
- what compressions to expect ?? help
- My turbo D16z6 thread...
- short sweep fuel pres gauge ? ?
- Wastegate question.
- best cams for turbo
- turbo ls wont start.... sometimes.. confused???
- Crower Strokered H22 w/ boost?
- Needed good ignition & EMS Setup for 600-700whp
- engine builder.....
- THE best Supercharger or Turbocharger is...
- Running with no wastgate spring???
- cam setup question
- Where to buy a filter for a GT35r?
- 400 hp on stock rods in a B series?
- turbo ls b18b sotck internals
- JRSC question??
- Integra LS-T WON't BOOST !!?!?
- Wastegate used as a bov
- check this out!
- Coolant options?
- thinking bout running e85 need advice
- LS crank?
- Axle back Idea.
- Bolt on Turbo kits.
- srp pistons
- LS-T Turbo Setup .. whatcha think?
- topmount or ramhorn
- e85
- Question about psi and velocity
- fuel ?
- AEM TRU boost controller
- compression ratio
- car starts for second then shuts off
- GSR turbo ChokIng
- is this a good turbo for 400-450 whp
- Boosting a D need some help
