- Ok... help me out with logical power goals for a car I'm about to buy...
- SC34??
- Question
- Tial bov is fluttering like crazy!
- GM 3 bar map?
- What manifolds keep/don't keep A/C?
- Bov question
- HELP!!!vavletrain and intake manifold
- Intercooler question
- HELP WITH TURBO SELECTION
- Need help figuring out the correct compression ratio. was i sent the wrong ones???
- Smoke coming from the breather filter bad?
- gsr cams/b16 cams
- how much power will this turbo support??
- which aem ems for 96 civic with b16b and obd2a ecu?
- Z6 intake manifold and Precision 780ccs WHY ARE THEY NOT FITTING? its not seal related
- **JUST WENT TURBO some little problems**
- question about s200
- Uberdata users......
- quick question on my gsr
- tuning question
- slim fan question
- Which wastegate (greddy kit)
- help me identify this turbo.
- Built H22 GT30R not boosting before 6k rpm
- wastegate valve seat
- any experience with this t3?
- Viton valve seals?
- is this turbo kit off ebay legit or not?
- TD06H vs. T3 turbine wheel
- Piston Comp.
- Where can I get a heat shield for my log turbo manifold?
- emanage questions.
- 2.5" or 3" intake for turbo?
- Have you guys seen the new www.jacksonracing.com?
- Anyone boostin 85mm pistons
- rc inectors
- evo to civic??
- stock internals...what hp/psi to stop at for tune?
- SPOON MUFFLER?
- External Wastegate? Where does the excess exhaust go?
- Turbo selection for 450hp-550hp H22 GT3040R, GT3076R, or GT35R??
- another intercooler piping????
- complete stock boosted b16 numbers
- GSR all motor/nitrous build
- crank?
- Displacement issue
- i need a hondata s200b chip burned for jdm h22a turbo.....
- Ls-t idling VERY rich, cuts off
- what size downpipe?
- What is the quitest muffler for EK must be 3"? i got turbo
- RODS OR NOT for 350whp
- my setup!!!
- strange part throttle/cruisin sputter at random .
- boost cut on a T25. quick fix?
- Competition Clutch Stage 5 or Ironman - input needed
- Dual Stage turboXS mbc
- question about pcv and catch can (searched)
- what are some good aftermarket sleeves to run turbo??
- line bore?
- turbo experts help please
- TURBO MANIFOLD CUSTOM TURBO HELP !?!?!??!!?
- OFFICIAL BOOSTED K SERIES SET-UPS
- K Series Manifolds
- GSR not getting oil pressure
- Firering?
- Check out this manifold..??
- which turbo is better for an f20c?
- pistons?????
- slimfan push or pull?
- B16 turbo > B18 turbo > B20 turbo... fact or fiction?
- Tuning Question?
- Best Clutch Flywheel set up for 500hp
- Ignition questions?
- oil pump shimmg????
- Relative spool times for H22 on GT35R?
- 3 inch exhaust.
- retard and advance
- Clutch question
- Differences in Garret T3/T04E 60 trim vs. Precision SC-5027E ????
- Looking for guestimates as to how much whp my setup could get b16/stg3gt fr kit and more
- ebay kit(searched got nothing)
- Turbo setup on B16+B20B engine, need advise please!
- Need help with turbo edit map
- how do i know if i have a t04b or a t04e
- 5 bar map sensor how do you its bad?
- need help with my setup....
- Help Needed Wiring Up DSM Injectors
- Fu*k!!! Keep Blowing My Oil Pan Gasket!?!?!?!
- 250whp on stock block D?
- Part # for block plug....
- Main Bore Diameter + Align Bore Question - D16Z6
- Is freeway driving okay on boosted cars??
- contact info for DRAG...
- safe to boost on basmap?
- D16 FI setup
- boost control
- d15b7 at 9000rpm
- garret t3?
- built b16 what turbo?
- help please
- internal--->external wastegate???help
- black trax intake manifold for h23?
- GT3567r, 25psi
- can running too rich foul o2 sensor and make it read lean .
- Which 2 step is better??
- T3/TO4E 60 Trim question
- Dyno vs. Track boost
- Please let me know what you guys/gal think of this LS/VTEC-T build...
- valve springs and retainers for boosted ls
- is OBX manifold any good?
- exhaust leak...no boost? need help fast
- Time for a rebuild... Crower 402-t's or 404's?!?
- Rim offset
- reuse spirolocks on JE's?
- New parts came in today! PICS
- dual charged sohc??
- Issues trying to contact Tial...?
- P75 or PR4 headgasket?????
- low oil pressure question
- Who runs a stock fuel pump?
- .48 a/r vs .63 a/r T3
- t3/t4 spool up?
- quick injector question
- HELP!!!!!!!!! 3" downpipe
- Eristic gaskets
- std manifold with t3/t4?
- any vw owners here?????
- What do you think of this peak boost kit?
- Catch can necessary?
- fmu
- Just wondering if anyone has seen this before (wastegate placement idea)
- Anyone running an LS/VTEC turbos unbuilt?
- To turbo or not??
- wastegate question and whats this part called! t25 question
- Will leaded gas mess up aem wideband o2 sensor
- ngk BKR6E-11 turbo gap?
- dsm 450 install? (already did search and it hasnt been awnsered)
- fjo injector driver
- where to tee
- Motor mounts
- ive got a dumb question
- GT3567R dyno
- Holset Turbo Sizing information for larger displacement application
- Few questions about turbo
- I got all this for 600!!!!
- t25 on a stock b18c1.
- ECU Chipping; Iron Tempature
- Difference between these two adapters?
- Can this destroy the turbo?
- Turbine housing + daily driver advice
- Part number request: B series NGK spark plug 500+whp
- throttle body coolant feed . pics please...
- full boost setting
- GT3251E vs GT28RS
- Turbo kit price difference....?
- When do you think I will hit full boost/ how much whp do you think I will get?
- Where can i find a..?
- i need 2 hook my aem wideband o2 the probelm is i lost the paper work help
- High Compression & Turbo & Goals ?
- Block guards......are they necessary?
- intercooler flow?!
- Turbo Filter? Knock protection?
- vafc 2
- oil line problem
- when it comes to bearings what does DAIDO and TAIHO mean
- Anybody know any specs on Wideband o2 sensors? i.e. what voltage is what air fuel ratio.?
- JRSC with 11:1 compression...
- hks
- Nitrous : Safety ?
- h23 turbo manifold
- Tech Talk: Ignition Tuning...Not your average question...
- Motor Build. which cams???
- which is better hondata or greddy emanage system
- M&H dot street vs. M/T drag radial
- Best Turbo Block?
- nitrous is it a yes or no???
- Those familiar with the Exedy Twin-Disc clutch.... HELP!!!
- Need Ideas For picking a set-up. Please throw ideas!!
- I searched and searched...
- i need 2 break in turbo h22 the problem i have a new aem ems what should i do
- Question about material for IC Piping
- largest/highest output t3 frame turbo???
- problem with gears blowing up and disenegrating
- any 1 got obd1 injector clips f/s
- compression ratio???????????????????
- stock ignition how much boost?
- When does stock b16 head become a restriction??
- Need new manifold for IHI .50
- coolant from blow off????????
- Knocking On Idle
- IB Spec quality?
- whats the best obdo free ware rom editor?
- catch can (I know I know)
- Anyone ever use the Zex Traction Control: zex vs. msd
- J1 Transmission?
- Anyone have experience with the T3/60-1 on a B16?
- gt35r survey
- b20 turbo
- new dyno... disapointed...
- fmu or emanage
- STUFFED TURBO?
- innovative or aem wideband
- Has anyone supercharged a new SI (k20)
- what is this wastegate fitting for?
- my manifold cracked and would like an opinion on my next one (SSautochrome monster)
- A ball park price for my turbo setup
- Rods B16
- Block Girdle? (i know, i know-- I've searched a ton)
- turbo help
- turbo leaking oil, what do you think?
- Stock map sensor...
- What manifolds will HKS wastegates fit on?
- d series manifold
- HPC 777HP SPFWD car
- My boosted SOHC vtec hit the dyno last night!
- H22A/F22A Main bearings the same?
- Nitous Question!!!!
- My new JGS Precision 44mm wastegate
- crappy fuel regulators and boost
- bored block ok?
- AFI turbokits
- SAFE TO TURBO MY ALL MOTOR SETUP??
- this is my turbo set up on stock block, anything missing.
- GT2871R .63 ar b16 slower than average spool up?
- how reliable will this turbo setup be ????????????????????????????
- turning boost down for the dd
- honda ram turbo manifolds
- New TunerToys Product (Opinions Wanted)...
- Treadstone Turbo Kit?
- Turbo Feed/ Return line gasket for t3/t60-1
- Ported Shroud on a SC61??
- What should I do with these???
- Is this really a garrett turbo?
- mmmm turbo parts!
- Check Valves?
- Need some information on siemens injectors
- THIRD ANNUAL FULL-RACE OPEN HOUSE
- I tried searching... How much power on tsunami?
- Which spools faster?
- What Turbo ?
- I need engine management (motorcycle)
- Yonaka intercoolers????
- Is a high proformance fuel pressure regulator needed to work with a walbro pump
- holeset turbos any info
- golden eagle oil plate adapter thread sizes?
- scat rods? what are the rods numbers? ie...eagle is number 3
- Walbro pumps and external mounting
- intercooler options.
