View Full Version : Forced Induction
- comment's on my DP
- Super 60 T3 on a stock internal b16....anyone with exeprience???
- internal or external wastegate?
- torquing blower on the jr intake manifold
- Compression results, good for JRSC?
- Does a nitrous bottle go bad ??
- WTF!!! talk about boost creep!
- oem integra fog light and fmic fitment ???? searched..
- quick question regarding straight thru exhaust please look
- TURBOSMART PRODUCTS
- what valves, valvesprings, and retainers are you running with turbo and where did you get them?
- Which Engine Management Suits Do You Think Suits Me?
- what happened to CR-FAB
- need help on installing the JRSC on my 96 obd2 gsr.....please give me images ....
- jun 3 with direct port nitrous
- cooling issues in this heat!!
- building my jspec d15b motor
- sc61 is not for everybody. :)
- Need gasket
- block gaurd
- No Fuel Pressure....what the hell is wrong?
- 14B Fittings Question
- Ls/vtec question
- Can you combine uberdata, and VAFC?
- need to build my motor...need advice
- VAFC Hack throttle points setting?
- cermaic coatings ????????
- Possible to adjust fuel pressure with a stock fuel pressure regulator?
- T3/T04e 57 trim 4-bolt turbine discharge size??
- tci axles??
- Want to get honest opinion...b16 head on b18c
- JRSC GSR Question... Dyno'd my car and numbers are kind of low... many questions inside!
- TURBO KIT HELP?
- Whose got a 70mm throttle body with......
- JRSC........?
- REALL NEED to get rid of a turbo kit
- Sc61 Oil return flange
- Pics of my Full-Race Turbo kit.
- Oil Pressure Reducer
- Questions about cheap turbo set up for '96 Civic EX
- Well It Had to Happen Sooner Or Later (PiXXx) =(
- post 1/4 mile times in 92-95 hatch
- going to the dyno in a week.
- my new full-race setup
- Just installed Tial BOV--delay in opening
- ok to timesert and boost?
- o ringed ls vtec leakin oil from the headgasket
- How can you tell if your ECU has Uberdata ?
- post some pics of your pre turbo intake pipes and filters (compressor on pass side)
- what is the highest a/f ratio you would be comfortable with in boost?
- GReddy Pro-fec e0-1 install help...
- My new turbo what do you think
- Broke bolt on turbo, leaking oil......now what???
- Cant figure out misfire
- boost help please
- Wired Ricky - no more - contact info
- went to the dyno made 326 hp & 233 ft tq...what do you guys think
- where can i get a pipe for the turbo?
- B20-Gsr Boosted...Fuel Management...=-(
- B20-Gsr BOOSTED Fuel Management
- VAFC wiring with engine management
- Question about my tial bov...which spring to use
- when do you need a main girdle?
- should i wait for turbo to install lsd + new clutch
- Oil coming from the breether on valve cover (turbo)
- rpms goes crazy...
- Where to mount Zeitronix wideband display??
- Exhaust housing swap question (searched)
- OBX intercooler results!
- TURBO KIT ?
- need a builder
- ssautocrome sucks! why dont people understand!
- 1997 Honda Prelude Turbo??? Need Help!
- Has any one seen this manifold! (pics inside)
- Breaking in
- car sometimes doesnt start after turbo
- this "?" is about fuel systems, i`m listing my setup. what do you think is best ??
- Summit Turbo kit any good?
- DIFFERENCES Between Greddy Type S BOV and Greddy Type R BOV
- builder, sleeve or head gasket
- Differences between bottom end's: b18c5, b18c, b18c1
- My destruction pics :)
- bad idea to run long IC couplers?
- Help with Boost gauge question...
- Oil on compressor housing inlet between wheel and housing?
- Thinking of starting a turbo project...
- how are my compression numbers?
- Tranny slip out of gear during boost?
- MSD digital window switch
- VIDEO: 7.5@96mph 1/8mile 1.66 60' Turbo 2.4L Neon
- garret GT2871 question
- Power FC Users with Datalogit
- New Results
- Fitment issues with 3" AC downpipe
- Quick question re: turbo oil supply and oil return lines
- Vacuum leak from boost controller? Is this normal?
- Is my block really sleeved
- Hondata S300
- civic 1.5 turbo at 12psi. lag/hesitate on 5k rpm
- good or bad clutch
- filter on vacuum line for Greddy profec B
- will she BLOW>>>>IF YOU DONT KNOW YOUR SHIT DONT BOTHER LOOKING
- my type RSX-S has got a greddy turbo kit ,greddy e management system, 440cc injectors, and a bbk fu
- high vacuum at idle, weird boost behaviors
- allen wrench bolt problem on wastegate
- Is it possible to replace my jdm 4-1 without having to change my existing cat and catback (jrsc)
- what PSI should i take my boosted rsx Type-s up to check my parts and give me a #
- AMS EVO 775whp @ 39 PSI GT42R Dyno Video
- turbo newbie q's
- what is this for
- Wiredspeedlab, What happen to them? I need help.
- Power Potential for RSX Type S
- radiator question...
- bov hose popped off for a couple days
- B17 Dyno 224 WHP @ 12 PSI
- all stock LS turbo question
- Turbo Rebuild Question
- Slim Fan with AC Condenser
- looking for a link to a theard (i searched)
- Oil weight question
- Turbo a D15z1
- Looking for a GT35R
- Thought I'd share my 15g greddy kit on z6 dyno numbers
- HOW TO: Turbo a Civic HX (d16y5 turbo for searching purposes)
- how much tq. will a 40 shot add @ 24psi on a single cam?
- Am i gettin a good deal? somone help me out here
- How do my compression numbers look
- d series turbo?
- Full Race K series Kit for DC5 RSX and EP Civic
- onefab type1 ac in a full radiator car?
- Need help guys ...Just started smoking out of no where ...
- filter resticts boost/?
- turbo b16 starting question
- Full Race D Series
- Overheating, PLEASE LOOK! Ideas needed....
- Saab turbo?
- my sohc 15G greddy kit question....
- noob to turbo please help
- Anybody ever dealt with F1Dyno in Maine?
- Anyone boosting a ZC?
- Oil circuit help please
- What WHP is 3" Exhaust good to? Should I go 3.5...or 4"??
- Cold engine idle problem. 3bar?
- stupid question, what does CHRA stand for?
- is it safe to rebuild your own turbo?
- T3/T4 on a WRX? (Not honda related)
- Coolant leak, view blocked by JR supercharger. Tips to find leak w/o removing JRS (again)?
- My First Logs for my JRSC Install
- master power turbo I brought
- oem map?did a search
- too big for boost??
- dsm injectos install on hondata.net?
- Problems with JR Vpac
- cooling question
- Setup Critique
- Will i pass emissions? ( turbo )
- Where to purchase a climax fuel rail?
- I searched :( Who has eliminted traction probs on street with 500+whp ?
- 550 injectors going to be big enough?
- anyone run jrsc on hpde events for 30 minutes ??
- LS Turbo Rebuild, Motorola 2.5 MAP Sensor, MAP CEL 5
- ANYONE MAKE 18G Turbo Maifolds??? ~~~~
- RSX Throttel Body HERE NOW
- wastegate settings?
- 96-00 Civic Ex Greddy Turbo Kit Picture Request
- fluidyne
- Tial 46mm Wastegate
- fuel pump install
- Suggestions LS Block 82mm Bore, 10psi boost: Pistons and Rods?
- zex nitrous kit question?
- GReddy TDO4H-15G
- Anyone use the D16Z6 Greddy Turbo kit on D15B7?
- Multi-disc cluthes (TILTON vs RPS vs EXEDY)
- Greddy turbo dyno......is this right????
- fmic piping nova?
- Built bottom end B18A, Low end low end acceleration/rev problem
- obd2->obd1 what about my immobilizer?
- 1mm oversized valves on turbo b18b?
- can a b16a= 500whp?????
- extending iac wires, what is the best method?
- Crankshaft is binding.Any machine shops in Ca Inland empire do align honing?
- Is it SAFE to drive my car?? Please look....
- rubber intercooler piping???
- Spark Plugs
- Take a look at my 100% FAKE real GARRETT t3/t04e!!!!
- burning hondata prom problems
- Is GT35R worth it? or SC61 better deal?
- ONE-FAB NON A/C pics?!
- Never doubt precision's quality!
- how to tell if its a t3t4 50trim comp. or 60trim comp.?
- Oil feed source????
- please help me
- B16 rods to lower compresion in a b18??????
- Recommendations for tuning in the UK???
- WS2 catback good for JRSC?
- can i still use this turbo
- What size injectors?
- Hondata+ Emissions in CT
- Need Some Info : B20 Turbo
- wastegate spring question
- garrett 42/.48a/r on a stock ls
- Good Price for a TEC-2?? Anyone have one for sale
- Sleeve questions......
- Help with Ignition Timing during tuning
- noob boosted timing question....(quick question)
- Another Idle Issue thread. I have some different questions than most. Please HELP!!
- GM 3Bar Wiring Diagram
- Greddy Turbo setup
- need some advise
- B&M FPR
- Street tunner by IN
- What do I Need???
- how do i determine the specs of a turbo?
- Wastegate dumptube?
- where can i find a d16y8 gasket????
- good a/f ratio on street tune?
- Running a mustang throttle body on a b-series intake manifold
- can someone identify these pistons?
- tilton clutch install gone bad?
- PLX Devices M-500 Install Tip...signal spikes
- 18G replacement ?
- Turbo kit
- Having MSD problems on a car that i'm tuning.
- does anyone know when the 94-95 turbo greddy kit for integra will be smog legal
- d16y8 turbo pistions
- Only two cylinders work properly after rebuild (kinda long)
- 01` Civic turbo install, 56k NO WAY!
- I need someone to chip my pr3
- Issues with a bit of compressor surge (greddy type s)
- Good fuel pressure to start with to idle 550s?
- Oil fittings dont tread correctly! Need help desperately......
- Accord Turbocharger
- Turbo for J series engines? (J32A2)
- Help with Bearings choice...
- Good turbo for stock d16y8...
- do u guys have the air temp sensor hooked up?
- boosting issues
- Oil blow by turbine side...... out of ideas
- How high will Crower 403's Make Power To?
- S-300
- Garrett T3/60-1 .48 a/r on a B16...just curious to see who's running it.
- JRSC Install - Intake, Header, and Map Sensor Modificatons
- code#9 #1 cylinder sensor
- Honda-Tech fi guys, help me find this!
- SLOWBOY RACING?? indiana pa, anyone heard of em?
- H22 thicker head gaskets
- H22 Supercharger Exhaust Manifold
- TurboSmart vs Tial wastegates
